Toyota Truck Owners: Problems & Solutions
When driving the truck after it has been parked more than 15 minutes there is a distinct popping noise. It happens in forward or reverse. Dealer has checked twice and said it is the "floating pads" making contact and that the noise is very normal. Sounds like a story to me. Does anyone else have this noise? Truck is an 02 Tundra Limited 4WD. Any help would be appreciated.
Thanks, Mototroy
- Paul_P
I have a 98 Prerunner V6 (first year) and have towed a 53 Ford NAA tractor on a dual axle trailer (approx. 4500lbs.) with no problems. I did add one of the very efficient stacked plate transmission coolers available either at the dealership through TRD or one of the premium parts stores. (Do not use the old style aluminum-copper tubing type) You are correct about Toyota not recommending a "load equalizing" hitch. I looked in my manual. I do not use one for my camper myself. I do not feel the need for it. The truck has the Bilstein shock option and they do an excellent job of keeping it from swaying. On a side note, Toyota does recommend a sway control device for trailers over 2000 lbs. I do not know the difference. Good luck and consider headers and a few performance upgrades if you plan to tow that heavy of a trailer often.
Chris
Mark
I will update the board after I get it in the shop. This board helped me get the brake/vibration taken care of so I owe a follow up to the rest of you.
Jeff...
Jeff
up my 2002 Tacoma SR5 4x2,and am wondering
where the best dealership to have my vehicle
serviced would be ? Happy New Year all !
and would like to recommend ? Thanks.
I am considering some "Dunlop Radial Rover A/T" tires in the last size, 225/70R14. They're also available in 205/75. However, if I can I'll go with the slightly lower profile ratio. As I'd be buying "online", I don't have the luxury to "buy & try".
If this should be on another forum, please advise. Opinions or advice are appreciated.
Tommy
Shawn
3 weeks ago & absolutely enjoy the drive -- but have a question to all those that have the stereo with the CD, AM/FM, cassette with 6 speakers.
The owner's manual (under the 3rd stereo displayed) states that when in the Control Mode the options are: bass, fader, treble, balance and MID-RANGE. My stereo is missing the MID-RANGE option & the dealer is attempting to tell me it's a "mis-print" in the manual and the stereo is "just fine." (Based upon the fact that ALL the Tacoma's in their lot operate the same way). I'm not buying that reason....
The service manager has not been much help -- so I wanted to know if this is in fact a mis-print OR they are dismissing my problem and not really wanting to resolve the issue.
Any info would be most appreciated!
Thanks.....
I have a Lexus RX300 AWD that does exactly the same thing. I too thought someone hit me from behind. Must be a Toyota trait. Doesn't much matter now though. The leased Lexus gets turned in on July 18th and the just purchased 02 Prerunner is the replacement. I know I am going to miss the plush leather seats in that Lexus.
Engine Sludge/Oil Gelling--Toyota's Customer Response
Dick
(and you may want to consider to go away from R16 tires....if you are going to put bigger tires, you will want to get wider tires and that means wider rims. Check what the stock rim is, but I think it's 16x7. You can't mount 32s on a 16x7 rim, and also, R16 tires are more expensive than R15 tires)
Stock trucks run on 31x10.5R15 tires.
To clear 32x11.5R15 tires you need 2-3" of lift.
To clear 33x12.5R15 tires you need at least 6" of lift. If you don't have that, you'll have trouble with rubbing.
I have called the customer service dept of western region toyota and they opened up a case almost 2 months ago and was just finally told I may have to go through a hassle called arbitration, My dealer has always fixed every problem and the service dept has been very accomadating but I believe I have also. Here is the kicker, I only have 26,000 miles on this new truck.
A little background on how it has been treated:
A daily commuter, has been up in the mountains 40+ times to go skiing, never seriously offroad, just a few times up forest service roads (which I don't classify as offroading anyways) thats it. Needless to say I don't trust this truck past the factory warranty, because then I will be shelling money out of my pocket just to keep this thing on the road.
I am hoping this is just some fluke on Toyotas part, this is my 4th Toyota I have owned, my last one being a 1990 4x4 truck that I sold with 198,000 miles on it and it was still going strong, My wife currently drives a 96 4runner and we have never replaced a speaker or guage or window ever, and it now has 102,000 miles and we don't intend on selling it for a long time.
Anybody have any suggestions on what else I should do? Any input would be great
My 2002 that I've had since November of last year, 19.5K miles now, has not had a single problem. No rattle, no fender flares coming off.
Fender flare problem was fixed for 2002s, you may want to point that out to the dealer.
Tire alignment: Toyota offers free alignment within 1 year/20K miles, essentially a break-in alignment. You should have used it to fix a problem with tires.
Overall, I think you got a lemon truck. Check lemon laws in your state, I think it's 3 visits to the dealer without problem being fixed, or 30 days in a garage total...something like that.
You ought to get a new truck through arbitration. If it comes to that, get a lawyer.
Thanks in advance for any and all help
Tom
Does anyone have any suggestions that may help me out? Any seat recommendations ways to actually do what I have listed or any other solutions to my problem?
There are plenty of other places on the web for this, that is just the first one that I pulled up.
we are going to make a small pillow using a grey washcloth to see if it helps. have the material, just haven't sewed it up yet. bill
I have not received them yet but I think this will solve my problem. I know, this is kind of an expensive fix,$299 per seat + $80 for each bracket, but I think it will work, I hope so anyway. If not I should at least have some comfortable seats, unlike the stock ones.
I'm 6'2", 200 lbs. and I find the buckets in my '02 Tacoma ext.cab 4X4 OK for under a 2 hour drive, but then they get pretty uncomfortable after that.
How much heat does a new engine generate? break in period? Would this be the cause? Should I put in a 180F thermostat? What is the range of the temperature gauge corresponding to temperature in degrees? (ie middle is 180, 3/4 is 220, H is 240?)
I am concerned. thanks
Yosmany
Noise 1: Appeared to be related to hood vibration; at a stoplite i could see the edge of the hood nearest the middle of the windshield vibrating. The vibration stopped when I accelerated, the rattle stopped too. I have experimented with a pice of inner-tube thickness rubber, super gluing it on the center hood stop [rubber wedge near wind shield] and that vibration has ceased so far.(couldn't find any hood adjustments that would help.)
Noise 2: Still comes from the passenger airbag area. If I press my hand on the airbag cover, the noise stops. I guess if I take out the glove box, there may be a way to tighten something. In the meantime I am going to try to work a very thin piece of foam between the airbag cover and the dashboard (closest to the windshield to see how long the fix might last. IF it does then I'll point it out to the dealer.
Hope these ideas help....
Riddler
Good news: it's not quite as bad. It's tolerable so far - I doubt I'd notice it if this was the way it originally was, but since I've been having rattling troubles, I'm sure I'm subconsciously listening more than the average guy. I'm going to give it a little time to see what happens. I haven't tried the foam strip near the windshield, maybe I'll try it next. I did see some foam at Lowe's - it was 1/2 inch round foam designed for caulking windows/doors. Is that what worked for others?
Riddler
