Squeaky Belt
Howdy,
It seems whenever it rains or it is moist outside, the belt on my saturn squeaks. Needless to say, it's quite annoying. Any good fixes for this, or should I just replace the belt? Is it best to have the dealer do this? Can the belts on a 97 Saturn SC2 be tightened? Thanks for any input.
-Eric Harris
-Eric Harris
Anyways, how long should I expect these to last. They are still original (over 100k miles) and only squeak alittle when its wet outside. At my last oil change I asked them to check it out, they said the deflection was within spec and they didnt show any cracks or anything.
Should I be proactive and just have them replaced or just wait until it starts squealing too bad.
The Goodyear belts and hoses I have used are all top notch as far as quality and durability. I LOVE the Gator Back belts, and Hi-Miler hoses. If you find it hard to find them try http://www.summitracing.com They carry a fairly decent selection, and can get you the one for your application even if they don't stock it.
also, I have had idler pulleys on all the Fords I've had get a little dry and squeaky after car washes or in rainy weather. a couple drops light oil at the back of the idler's axle fixes the issue for months.
I can't ever remember having a Gator Back belt on, but I do swear by Dayco belts, not at 'em.
Belt squeaking (V-belts): In the good old days if the squeal was not because of being loose but just a general running noise- Don't laugh: You'd take a piece of Ivory Soap and whith the engine running, allow the side of the belt to run against the soap. I'm sure some fingers have been lost in this process. It does work, but really by masking the problem. This noise is a symptom of something not right like worn pully or misalignment, or worn belt. You should also never-never use belt dressing.
The Dayco V belts do have to be done up a little tighter and re tightened after around the first 100 miles or so or they do start to slip again.
No matter what belt you have if it comes with a lifetime warranty put the receipt somewhere that you can find it later. Sometimes stores switch brands and will not do an exchange with out it. If that does happen you should get the currently stocked lifetime warranty model, and a new receipt.
For those interested in Goodyear Belts and Hoses look here, the site was supposed to be up on Monday 10-01-01, but I guess they are working out some glitches. You can bookmark it and check it out at a later time I guess. http://www.goodyearbeltsandhose.com/
