Just comparing in my area, though, I can see there are more Dakotas than anything else and they are by far nicer for the money. Here are just a few examples.
This one even has 4 doors
Extended cab and 4x4
Standard cab '03
For comparison, an '01 Chevy 4-cyl.
The best two for work are the Chevy/GMC 1500 and the F150 (who would have guessed - heh )
Other than that, though, it comes down to one choice. Get a Toyota with the 3RZ engine in it. Get it with manual. The automatic is terrible but the older Toyota manuals are bulletproof. Mine lasted 280K miles before I had to get it replaced. And not a minute of that was anyone giving it any love, either. The truck is still running around somewhere in N. Cal I think with about 350K on it (sold it at almost 325K on it two years ago).
http://en.wikipedia.org/wiki/Toyota_RZ_engine
Nothing else works like it does in terms of low cost to maintain and the durability overall. There are several vehicles that used it, so you have a good range of years and models to look at. The newer TR and ZR 2.7L engines are also good, but they lack the tractor simplicity of the RZ.
And, yes, manual with short gearing and 160HP will out-accelerate most yuppic-mobiles unless they floor it. I found it to be extremely enjoyable to drive, even in So Cal traffic as I'd just leave it in 2nd or 3rd gear and trundle along in heavy traffic. And then when I had to dodge into a gap in traffic, I was already in the right gear.
The problem is finding one as most people who have one simply aren't interested in selling theirs.
The only real downside is the fuel economy. It gets about 25mpg highway. But other than the issue of MPG, it's probably the best solution that I can work out since you won't want a European car. It does use normal 87 octane fuel, though, so that's worth about 2mpg right there vs a higher mpg car that requires premium.
Hell, I still think the 22RE engine with manual trans was the most bulletproof setup ... but good luck finding that with low miles and no rust.
EDIT: I just looked it up. Even an '02 Tacoma 2wd reg cab with 100k miles is going to be well over the OP's budget.
How much were you looking to spend?
Peronally, I love the looks of the XF.
pricerange would definitely be helpful in this situation.
$40,000 is the maximum he can spend, but he'd prefer something less expensive.
Does anyone have any suggestions?
The choices are very few, unfortunately.
As mentioned, the 2013 Impala LS and LT are available with a 40/20/40 bench seat as an option for $195. It isn't available with the Sunroof or LT Luxury Package, so that means no Leather and no power adjustments for the driver's seat. Also, the 2014 Impala is a new design, so the 2013 will soon be gone!
That is really the only sedan without a center console. I know you said an SUV no longer met his needs, but what about a minivan? The Honda Odyssey and Toyota Sienna both have high dash-mounted shifters that allows a break between the center console and the dash. It would allow a lot of extra right leg room!
One other oddball that I'll include for the sake of being thorough is the Nissan Cube. I certainly don't like it and I doubt a former Tahoe owner would be interested, but it has a very low center console (near the floor) so it's well below the lever the front seats. I believe it originally came with a column shifter, but I could be wrong.
Personally, I'd buy an Odyssey EX or EX-L...but I hope you find something that will work for him!
DTS is a nicer car if you can live with the performance to economy ratio being far less than many others. It's a shame the only options are antiques!!
I would be curious why a "sedan" is the only option. There are a couple cross-over type vehicles that might work...as mentioned the Soul. I'm thinking the CRV also has a lot more room up front.
Most of all, though, is that the Lucerne CXS and DTS with the performance trim has the same electronic suspension as a Corvette, the Audi R8, and the Ferrari 599. The electromagnetic suspension on it is a drastic step up and makes it handle better than a typical GM car half it's size. It frankly drives as nicely as a S Class. The new Range Rover Evoke uses it as well. And of course, most of the Cadillac line.
And that's a world better than any Impala. Shockingly so in actual driving. It's a shame that GM isn't marketing it more aggressively or including it in all of their vehicles. These cars may be "antiques" in your mind, but the reality is that it's the Impala that's still using 1980s technology underneath that shiny exterior.
Lastly, a typical CPO DTS or Lucerne will have hardly any miles on it. It's not hard to find CPO models with 20K or less on them. That's really not even worth worrying about when there's 10K or more in savings on the table.
And the bench seat isn't available in the CXS or Platinum DTS...so you're stuck with lower end models.....a very mediocre V6/4-speed combo on the Buick or plain jane lousy handling with the Caddy.
If you're stuck buying a mediocre car, you might as well buy the cheaper of them!
I'd say the DTS has a better interior by far, though, even in the base trim. As a bonus, the DTS has a terrible depreciation. It's closer to $30K for a 2011 model and that's great news for the original poster. $50K new and close to half that in three years. Problem solved and it's actually less than a new Impala. ($30K starting price, plus options?)
Add in lower initial registration and insurance as it's not "new", and you're looking at getting a Cadillac for Chevy prices. I'd call that an acceptable solution. But it's literally about the only one.
The comment about a crossover or small SUV (why only a sedan) does seem appropriate, though. A few small SUVs and crossovers have an open floorplan. Trucks do as well, as a rule, but most get terrible MPG (15 even on a good day as a rule). The Chevy Colorado gets car like mpg and has an open center console area, though. The Tacoma also does. Both drive a lot like cars now that they have gone to unibody construction.
Long time site visitor, first time poster. I'm currently trying to decide between a couple of cars I've had my eye on to replace a 95' Acura that's not going to pass inspection due to rust. I would appreciate any feedback I could get on these three options. Below are the cars and the carfaxs.
The first is a 2005 Honda Civic EX - 87k miles - $7900
Carfax
This seems like my most practical choice and the one I'm leaning towards most.
The second is a 2009 Honda Civic Hybrid - 147k miles - $10,517
Carfax
I don't know too much about the hybrids, but I'd like something with great gas mileage since I'll be using it for my daily commute. I'm just not sure about the high number of miles on this car.
The third is a brand new 2013 ford focus SE with winter package - $14715
The ford focus would be great, and I really enjoyed driving the 2012 as a rental over the summer, but it's definitely the priciest of the three options, and would be pretty tight in my budget since it would come to ~$17,500 after titles and fees etc.. plus it's the most expensive as far as insurance goes. My other reservation is I don't know how good it will be after I have it paid off, I don't want to end up servicing a lot later in it's life (after it gets past 100k miles).
Any help with deciding between these and any insight would be greatly appreciated.
There is a Civic for you that does all of that and averages about 60-70mpg. The trick is that it runs on CNG, which sells for half the price of gasoline, or sometimes a bit less. So the equivalent MPG our of your pocket at the end of the day is about 60-70mpg. When you can get CNG for under $2 a gallon equivalent, and it fills just as fast as a gas pump, it's really an awesome deal for someone who commutes every day.
You will have to search around to see if there's a filling option in your area (usually at municipal yards, which by law have to allow the public to also fill there, though it's not always the cheapest place). As a bonus, the cars also get carpool access pretty much forever as they are true alternate fuel vehicles.
The cars also pollute so little that it's hard to actually measure it with a smog test. In some cases, the air is actually cleaner than the local pollution. Also, the cars last forever due to there being virtually no grime when it burns (oil looks like new when changed, almost)
You can also get a device for about $3000 or so that fills it overnight in your garage. So you become your own gas station and pay about 1/3 of the price of gasoline.
The downsides are two. One, it has a 200 mile range between fills. And the trunk is 1/3 the normal size as the tank's back there. Used, they run about 10-15K and are right in your price range.
It drives exactly like a normal Civic, other than having half the range between fills and a much smaller trunk.(about the size of the trunk in a Mini - not useless, just smaller)
If the Focus is going to stretch your budget right now, it's probably not worth it. I'd buy used, then sock away as much money as you can to help with a downpayment on a new vehicle in a few years.
I'd avoid the Civic Hybrid, personally. We've seen lots of reports about issues with the IMA battery on that model, and some owners have experienced a rather drastic reduction in MPG - if that happens, you won't reap the savings on fuel that you would hope to with a hybrid.
Just on person's opinion!
MODERATOR /ADMINISTRATOR
Review your vehicle
2009 Honda Civic LX with 76663 miles
Here's the Carfax
I do like the idea of getting something relatively newer so that it won't have as many issues, do you think this might fit the bill?
Thank you all for your responses so far!
The 2009 is obviously going to have some more modern features, like MP3 input and keyless entry. If the manual vs. automatic and coupe vs. sedan difference isn't important to you, then the LX looks like a better deal for you. High miles for its age, but the Carfax shows that it at least had regular maintenance performed.
Review your vehicle
Also the 2009 is safer (standard curtain airbags, better crash worthiness) than the 2005, which was an older generation).
no convertibles, trucks, SUVs, coupes
Leaning to mid/full size sedan, crossover, hatchback.
I was a "lay down" last time I bought, but I'm here to learn.
I really like cars with convenient tech.
The Fusion Titanium is a front runner, there's also Accord EX-L w/Navi
Altima was, but I read about major issues with them. I've considered an Optima as well.
I believe that I would fit into the "well qualified lessee" category finally, so that option is on the table and it could put me into more car than I've considered.
Thursday I am going to drive a Fusion and Accord again. Any others I should add to Thursday plan? Plan is to try and negotiate a good price Friday due to EOM.
I doubt if one person in a hundred even knows that Honda makes the Civic with a CNG option. For long distance highway commuters, it's a very frugal choice provided there is a filling station in your area. As gas prices climb to $5 a gallon this summer, it might be a bit more appealing to people, though.
The original poster did mention a Civic. If the Civic came with CDI engine as an option (like it does in the U.K.) , I'd have also recommended it.
Oh good grief. Do we need to help spread this rumor every year? :sick:
Welcome to California. Now open your wallet.
In any case, some folks have been chanting the sky is falling every year around this time for many years now, and it has yet to happen. I guess as long as it keeps getting repeated, it has to be right EVENTUALLY, and those folks can finally say "I told you so!"
We've been much closer before, though. It fluctuates, of course. Unless some crisis happens, I think we'll still be cheaper this summer than last.
Review your vehicle
And, GE is working on making a $500 device that fills in your garage. Which means you avoid the gas taxes and other idiocy as well as never run out of gas or have to look for it. Most people don't drive more than 200 miles a day, so it's perfect once at-home fueling becomes the norm. They say it will be ready in a year or less. Then the game completely changes. $500 to not have to deal with a gas station, ever? That's worth it right there.
My relative has a CNG Civic. It's OK (not a Mustang or similar - heh), but it costs him $16 to fill his tank. No joke. Not a typo. $16. And he gets carpool access as well. He has to fill up every other day, but it's utterly painless since it's really pocket change and he'd be filling up for $50 every four days with a normal Civic. Plus, he gets some of that "bling" factor for being a techno-weenie :P It's a whole other level above a hybrid in terms of being eco-friendly and cutting edge.
Repairs? It's a Civic. Enough said
I drive a 2002 bmw 330 and I am looking to buy a small / midsize sedan. I am looking for suggestions on what car (make/model) will come closest to my bmw's performance specifically low end torque. My budget is in the 22K-24K range and if the car is used, not older than 2010 and not more than 30K miles. And it must be a STICK!
So far I test drove the Dart (great car but a little underpowered) and the Focus SXT (out of my budget but I loved it). Any other suggestions?
Thank you,
Vik
I'm wondering now if I should sell this car for $1,500 or so, and get a newer Toyota Echo at around 100,000 miles (they are going for $4-5,000 right now). I'm wondering if I'm about to enter a period when I'll be needing to put in lots of money to keep this Civic going. When I bought the Civic, I junked the Corolla I had because I would have had to pay some $2,000 to install a rebuilt engine, and I had already put in $2,400 in repairs in the last 24 months for that Corolla. I was thinking that if I had known that I was going to put that much money in repairs alone into the Corolla, I would have sold it 2 years before, and bought the Civic then.
What I'm thinking is that I want to sell my Civic before I enter this period of costly maintenance on it. Is it reasonable to expect a Civic to go 200 or even 250 thousand, before everything goes out on it? The Corolla I was talking about had the engine seize up at 250,000, which prompted me to junk it for 100 bucks, rather than fix it.
Just get a newer 3-Series.. The prettier front-end started in '09, I think, so I'd start there..
I'm about to buy my first new car (had an used one for years til it died.) A few questions:
1) is it worth it to get rubberized floor mats?
2) I'm getting the base model 2.0i with fog lights. What's the difference between black bezels and beige bezels on the fog lights--anyone have links to photos so I can see the difference?
3) I have a few dealers. One gave me a guarantee of the out-the-door price (my neighbor has bought from them and was satisfied.) Another gave me a lower price ($25 less but he's throwing in floor mats & a cargo tray.) Haven't spoke with him yet about a guaranteed out-the-door price (I did a search on car woo, he gave me a price, I called a few weeks later--he's also a zag dealer and contacted him through that--he initially gave me a higher price, when I told him he had submitted to through car woo for a bit cheaper, he said he'd honor the price--a $250 savings.) I've heard horror stories about dealers lying. I don't want to travel a long distance to have the rug pulled out from under me with the price. Any advice? Suggestions?
Many Thanks.
I think CNG has a fighting chance with municipalities and companies large enough to fuel them up themselves.
If it wasn't maintained well you might end up with a few unexpected repairs all of a sudden.
Since you owned the Civic for a while you should have a basic idea and schedule on what items will need replacing soon.
If it's routine maintenance and nothing major keep your Civic.
The first car is a 2009 Mazda 3 - 45,000 miles, $12,000 Private Party
fully loaded with leather heated seats, bose stereo, moon roof. Owner insists it has a clean car fax which he'll show me when I look at it. It's also automatic which would be nice since I do a lot of stop and go traffic in my daily commute, and that way my girlfriend could drive it if we take it on a road trip or something.
The second car is a 2011 Mazda 3 - 17,000 miles - $12,900 Dealer Carfax
This is just the basic model, but it got better reviews from consumer's reports than the 09, and it's really low miles which is great! I feel like it'd almost be like buying new. It is a manual, which would be fun, but again driving it in stop and go is killer on manuals and my foot, and forget about my gf being able to drive it. Still I feel like it would last longer and might make the most financial sense. I think it might also still be under warranty (not sure). I'm torn though, the 09 seems really nice and it'd be great for those cold winters we get here.
This is why I need advice. Am I being dumb drolling over the 09 while I secretly know that the 11 makes more sense, or would the 09 actually be a good purchase?
I'm going to see the 2011 today and have yet to see the 09. Should I see them both before deciding? Any help to sway me one way or another would be appreciated.
