Mazda6 Sedan
16061636566342
  • dinu01dinu01 Member Posts: 2,586
    Dinu
  • groovypippingroovypippin Member Posts: 264
    It always amazes me how subjective seating comfort is. A car can be reviewed be a dozen different sources who all generally agree on things like braking, handling - even on whether a car is attractive or not - but you always seem to get 12 different opinions on whether the damn thing is comfortable to sit in.
    I'm beginning to think the human rump is the most sensitive organ on the body!
  • dsm6dsm6 Member Posts: 813
    That's the second or third time I've heard someone say that Edmunds got the 0-60 down .7 seconds from 8.0 to 7.3 with a brake stand. ...
    I went back and re-read the review, and I think you are misinterpreting the results. I do believe that the test driver is explaining how he or she achieved the 8.0 result - with a brake-stand. I think he or she is saying that without a brake stand, the 0-60 is around 8.7. It is customary in test drives to report either the best result or an average of results using the best technique - which in autos means doing a brake stand. 0-60 without the brake stand is akin to 5-60 street start times, and that is why published 5-60 times are often paradoxically longer than 0-60 times.
    So I do believe that the 1.0 second diff. between Accord and 6 V6 auto "stands", so to speak. Sorry if that bursts anybody's bubble. Then again, maybe your interpretation is correct, and mine is wrong.
  • newcar31newcar31 Member Posts: 3,711
    I don't see how it could be 8.7 seconds to 60 with the automatic V6. C&D got 6.8 with the manual. How could the automatic be almost 2 seconds slower?
    Why on earth would they report a non-brake stand 8.0 if they got a perfectly legit brake-stand 7.3 using the same technique ever other serious tester uses?
    Further, I am almost 100% positive I've read acceleration test comments in other Edmund's reviews where the tester has explained directly that the time printed was achieved with a brake-stand. Why should the 6 be different?
    And the 6.8 0-60 for the manual is, no doubt, with revs built up and a clutch dump. So, it should be compared to the brake-torque time of 8.0. So the difference is not 2 seconds, but 1.2 seconds - a fairly large difference, yes, but not totally unbelievable.
    This goes back to the different strokes for different folks stuff. Some people measure sporty by how hard the car pushes you into the back of the seat, some by how hard it can throw you from side to side, some by both, etc. etc.
    Obviously I'm over simplifying to be cute, but you get the idea. Americans have "traditionally" valued that forward thrust, push back into the seat, low-end torque kind of performance. Your mileage may vary.
    Ideally, I'd like spine-crushing acceleration, nimble, "oh-crap" handle necessitating cornering, and eye-popping braking, but that costs too much money - so I personally will sacrifice some power and acceleration for the other two. That's just me, though - meaning that others have their own priorities that may differ. That's fine. In fact, it is a good thing, because it gives buyers more options and it pushes manufacturers to make better cars in every way. Witness the way the Altima attacks the marketer vs. the approach the 6 takes.
    Better that way, Pat?
  • vocusvocus Member Posts: 7,777
    Well, if I am personally accelerating from a stop, I am not going to do a brake stand. I am not going to abuse my car to do that. I wouldn't think they would publish a time using that method.
    Look back at the automatic WRX wagon they tested. They published both times, normal acceleration and brake stand acceleration.
    I think the 8.0 is normal time.
    Do you think Car and Driver does their tests with, or without, a brake-stand?
    Oh, and a random look at Edmund's road tests uncovered the comments for the Mercury Sable Wagon test, where the published 0-60 time was accomplished with a "2,350 rpm brake torque."
  • windowphobe6windowphobe6 Member Posts: 765
    Testing an automatic, C/D routinely stands on the brake and then lets it go; they've stated this in the magazine at least three times I can remember (which doesn't mean you've necessarily seen it, since I've subscribed for 24 years). In the unlikely event that they get a better result without doing it, they'll post the better result and explain in the text.
    While C/D hasn't published official 0-60 times for the auto-equipped V6 6, they have published an estimate. And that estimate is ...
    drum roll please ...
    Exactly 8.0 seconds!
    I'm sorry, but thanks for playing "The 0-60 Time is Right."
    All kidding aside, go compare 0-60 times for cars of similar drivetrains, weights, power, torque, etc. 8.0 seems about right, with the brake stand, for a car weighing over 3300 lbs and 220 hp, 192 ft-lbs torque at a relatively high 5000 rpm. At least to me it does.
    But don't let that get you down. The car is about handling, road feel, balance, not drag racing. Besides, the manual version is decent at 6.8 seconds.
  • capitanocapitano Member Posts: 509
    I keep thinking to myself that I would need the 6s (or the 3.5SE if I went Altima). But then I think back to one of the funnest cars I have driven: a beat up 84 scirocco with 90hp. It had some glorious understeer, was loud, had no radio, no AC, no powersteering (oh the pain in the parking lot!) but on the curvy roads on the way home it was just a blast.
    It was even OK on the autobahn because it had a real transmission in it and I could keep the revs up.
    So I keep thinking of this car when I am playing with the build my own sites and reading the test reports. Accordingly I am definitely going to give the 6i and the 2.5s a spin before I commit to the 6s or the 3.5SE.
    in this forum prefer handling over brute power.
    I'm one of those too. Hence the reason I'm not impressed w/0-60 times (10 secs is good for me - seriously) and not shopping for one monstruos displacement GM product. Fun to drive, LOTS of road feel (some refer to it as a harsh, unrefined ride) are at the top of my list, next to value and reliability. HP ratings don't mean much.
    Dinu
  • the_big_hthe_big_h Member Posts: 1,583
    who wants to guess how long it'll be before we'll have an actual OWNER of the 6 posting their REAL LIFE driving experiences on this board??????
    come on, someone's gotta take charge and be the first one!!!!!
  • glideslopesglideslopes Member Posts: 431
    Who manufactures the 5-Speed automatic in the 6?
    Mark.
  • diploiddiploid Member Posts: 2,286
    "Edmunds was able to improve the 0-60 times by 0.7 seconds (ie. to 7.3 seconds) by holding in the brake before launching. Not recommended on an auto transmission car, but its how the Accord's 7.0 was likely measured."
    No, it was not:
    "In typical Honda fashion, the Accord's 3.0-liter V6 is quicker than it feels. The combination of refined and broad power makes this car feel much slower than an Altima, yet we tested our long-term V6 Altima the same day and found it only two-tenths faster than the Accord in the quarter-mile (though the loud and raucous engine made the Nissan seem much faster). The Honda will brake its front tires loose off the line with the traction control disengaged, and it keeps pulling all the way to 6,500 rpm. There is no manual mode for the automatic, but by turning off traction control and simply stomping on the throttle (with no brake torquing and with the automatic in "D") the tires spin at just the right level to return the best times. 'Honda -- we make it simple.'"
    http://www.edmunds.com/reviews/roadtests/roadtest/76668/page001.html
  • stretchsjestretchsje Member Posts: 700
    "who wants to guess how long it'll be before we'll have an actual OWNER of the 6 posting their REAL LIFE driving experiences on this board??????"
    Three days. Lots of dealers should have them prior to Saturday.
  • mazda6smazda6s Member Posts: 1,901
    Edmunds has full Mazda 6 pricing info:
    http://www.edmunds.com/new/2003/mazda/6/index.html
    Aren't they the first?
    Stopped at my local dealer after work today - no cars yet. I mentioned the goofy options combos, and the ordering guy said he could order any options I wanted. I said "I don't think so". So, he calls Mazda while I'm there, and sure enough, they told him the web site is correct.
  • joemcc2joemcc2 Member Posts: 1
    Would it be normal for a 97 626lx with the four cylinder to peg the tach at 6000 rpm on hard acceleration? On normal acceleration, most shifting occurs at 3000 rpm. Is this how the "electronic" transmission works normally?
  • brucec35brucec35 Member Posts: 246
    Here in Georgia, you don't have to pay sales tax on private sales. So, for example, on a $25,000 '99 BMW 528i bought from the owner, you pay just the $25,000. Meanwhile, buying a new $25,000 Mazda from a dealer, you'd be on the hook for 6-7 percent tax.
    Since I always have the option of buying a used car like this and saving the tax, I just lump it into my "what I paid" price for any new car, to make comparisons between choices fair. So when in an earlier post I said "I would nearly have $27K in a Mazda 6 like I want", that figure included tax and fees.
    Yes, Saabs also require sales tax be paid. My figures on the Saab also included tax, and came up to $30,800 on a model like I wanted.
    The point in my original post was that I doubted I'd be able to cherry pick the options I wanted on a Mazda OR Saab. With rollouts, they usually have a bunch of loaded up cars and a few zero or no option models. So my "theorectical" price points might not be possible. For example, I can build a nice Infiniti G35 Leather model and with expected discounts and sales tax, drive it off the lot for about $31,000. However, I can't find a single one like this in Atlanta in the color (black/black) I would like. So that means I have to take the $3300 premium pkg to find one, , or one with a sunroof and the Bose option, and heated seats (here in Georgia!) which is over a 10% increase for some 'improvements' I find only marginally helpful.
    We pay tax on new saabs too! We just don't pay tax on used cars purchased from private sellers. The Saab I want with auto and wheel pkg would "drive out" for $30,800 including tax. The Mazda 6 like I want would require an investment of about $28,000. The Saab has 0.0% 3 year financing, which would save me about $1500 in interest, and 36,000 miles free maintenance on the saab, and this makes the two cars even closer in real world price. Factor in resale guesses(I'm betting on this Saab doing well)and cost is pretty even.
    The Saab has various subtle differences that I guess got it "near lux" status. My dad's $40,000 Lexus EX300 "eggmobile" is based on the chassis of a $20,000 Camry. There's more to it than where the car's origins come from.
    As for Saabs being for the image conscious. the appeal for me was that it was a way to avoid the "attention" (by the envious, law enforcement, vandals, theives, carjackers, hostile drivers, etc) received by our '98 BMW 540i sport 6 speed and '97 540 Auto we owned. I never look twice at most Saabs, but they are handsome, so that was a plus for me. Put it this way, go ask a Hooters girl if she wants a ride home in a Bimmer or in your Saab. "Saab? Aren't they from Finland or something?"
  • venus537venus537 Member Posts: 1,443
    when are the first mazda6s scheduled to hit the dealerships? i think i read somewhere that they'll start showing up this Friday. is this true? please forgive me if this has already been discussed in here, but there were over 200 posts since i was last here and i didn't want to read through all of them.
  • johnclineiijohnclineii Member Posts: 2,287
    Venus, your luck is about like mine. The answer was about SIX posts up! :)
    Many dealers should have at least one car by Saturday. Whether or not it is prepped and ready to be driven is a whole 'nother story.
  • ickes_mobileickes_mobile Member Posts: 675
    Interesting that Edmunds is already listing a "TMV" price about 5% or $900 below MSRP. How do they figure that when none have been sold? Anyway, my Mazda6s with leather, comfort, sunroof, and 6-disc changes retails at $23,900 and "should" sell for $22,879. Any bets as to whether they'd take the offer at Morries?
  • wgrwgr Member Posts: 127
    Yes, Edmonds shows the TMV at approx 96% of MSRP and CarsDirect.com shows it at approx 93.5%. How DO they do this when hardly any have been sold; and the ones that have been probably were at full MSRP ??? $ 22,600 for a 6s with everything I want on it is not bad at all ! I also wonder how this fits with the real world right now. These prices would make more sense 3-4 months from now.
  • beanboybeanboy Member Posts: 442
    Because Mazda doesn't have the following of Honda? The 6 is just a sedan from Mazda, the majority of the public could care less about how sporty it feels, and the sales price will reflect that. Methinks Edmunds and carsdirect.com is correct, time will soon tell.
    -B
  • mdaffronmdaffron Member Posts: 4,421
    The 6's list of standard features on Edmunds includes "3 rear headrests." I thought some of you said the U.S. model will not have rear headrests ... ?
    Meade
    But it ain't as plain-Jane in appearance and public opinion as, say, a Neon ...
    Meade
    in the NA Mazda6 are the moulded into the top of the seatback type. Japan and Europe get true headrests like on the front seats and on the rear seats of NA Accords, Camry, and Passats.
    Thanks ...
    Meade
    The 6 has the same type of headrests in the back as the Protege does. Considering pretty much all the newly designed cars coming out have adjustable rear headrests (think Corolla, Matrix, Camry, Passat, etc.), I am surprised Mazda didn't include this feature.
    I am kinda excited about the 6 coming, I can't wait to drive it.
    I used to own a Saab that had adjustable rear headrests. The things used to drive me crazy for the following reason.
    I tend to use my car to the hilt, not only commuting to and from work and carting the baby around and getting groceries, but also making runs to Home Depot and similar places. I frequently fold down one or both of my rear seatbacks to haul stuff.
    And in every car I've ever encountered that has adjustable rear headrests, you either have to re-adjust them all the way down or remove them altogether (and then have to find somewhere to put them) when you want to fold down the rear seatbacks. And that's a hassle in my opinion.
    If the integrated headrests function to prevent whiplash, which they probably do, then I see no reason for adjustable ones back there. As Forrest Gump said, "You know, one less thing ..."
    Meade
    are supposably designed to fold out of the way with the automatic seatback. You are probably right that you'd have to set them to their lowest level in order for this to work. Frankly, I don't really see anyone going to the trouble to adjust the rear headrest unless there is a consistent passenger.
    What's the point of adjustable rear headrests? Same thing on my Saab -- they were just fine at their lowest setting. Any higher and they didn't catch you below the ears like they're supposed to, and would've done more harm than good in a crash. Thanks, Mazda, for keeping it simple!
    Tell me -- I could go and look this up, but I'm too lazy. Does the 6 have a folding center armrest in the back seat?
    Meade
  • mwittmermwittmer Member Posts: 2
    I work at Jim Ellis Mazda of Chamblee. We had 3 Mazda 6s come in Tue 11/12. All of them manumatic, with one being the 6i. Test drove them. What a blast. The handling is right on the money.
    Give me some idea by comparing the interior volume of the Mazda6 to that of a Passat or Accord
  • kenokakenoka Member Posts: 218
    Yes, there is a folding center armrest in the back seat. It also comes with two cup holders.
    The rear headrests are a pain when I need to fold down the back seats in my Jetta. I have to remove them. But I hardly have to fold down the back seats though.
    I carry passengers in the back more than I carry materials, so it's nice to know they will have some protection in a rear-end accident. Also, my headrests back there adjust up and down and they tilt as well, so they try to be in the right place.
  • sunilbsunilb Member Posts: 407
    I found it interesting that on carsdirect, for my location (SF), 2003 Honda Accords are selling for Invoice! A few weeks ago, they were $100 over invoice and yesterday when I checked, they were right at invoice.
    While the new Accord has it's critics, I think the larger issue is the slow-down in auto sales (due to overall softness in the economy).
    ** Consequently, I can see why the 6 is not going to sell at MSRP (not to mention that this isn't a limited production vehicle)**
    To a previous point, for those looking for alternatives, why not a Maxima SE w/ 6spd? It's handling may not be as good, but the power will be better and the price will be comparable.
  • jampedrojampedro Member Posts: 38
    Rear ones are not covered. They're recessed in the center of the armrest in front of your elbow and behind your palm. Front cupholders are in the center console with a push down, spring up cover.
  • gtyler2000gtyler2000 Member Posts: 17
    My dealer had one car when I drove by last night. They had just put it out a few minutes before I arrived. They tied all these balloons to it. It was red with the beige cloth interior. Liked the red, and hated the beige. I asked to sit in it to check out it's size. It seems perfect for me. Only slightly smaller than my current car - 97 Taurus. I liked the dash a lot. I liked the environmental controls- the outside rings are pretty cool. I wish I turned the key to see the lights and how they looked. The power seat adjusts up quite a bit, but I had to put it down as far as possible to check for head room. I'm 6'1" and it was pretty close; I need to check one that has a moonroof.
    Now, about the issues that have been mentioned by others:
    1. Rear seat room
    After adjusting the drivers seat to where I would have it, I hopped in the back seat. It was fine; comfortable. The back seat is going to be for my kids anyways.
    2. Rear head rests.
    The back seats look a little weird, but it was very cool to release those seats from the trunk and have them fold down by themselves.
    3. Side view mirrors
    Yep, they'll probably snap right off if you hit them. My Taurus has the same issue. It sure hurts when you run into them.
    4. Radio display
    I like the idea of the display being higher. Even though the buttons are several inches below the display, they are pretty large and I think I'd be able to press the buttons without looking or with a quick glance.
    Bottom line for me:
    I can't justify trading in my 97 Taurus with less than 60,000 miles on it for this car. I probably won't even test drive it, just in case it's really fun to drive. However, when the hatchback comes out, I'll have a reason. I'd be trading in to get more use. It would offer a lot more flexibility in terms of what I could fit inside. Plus the hatchback is the best looking version in my opinion. Check out the pics on the Mazda site for yourself.
    Non-folding side mirrors is an issue for me. I live on a narrow side street, and have to fold my mirrors when I park the car to make sure they stay there. My mother lost 5 mirrors off 2 separate cars within about 3 years parking there. God, I need parking pad! :(
    has a transport truck with 6 Mazda6s on it right now......
    thanks for the update. I'll be leaving early to swing by Morries on my way home to Maple Grove...
    the Krispy Kremes?
    1. Side Mirrors
    Are you sure they don't fold back? Mine do in my Japanese made Latin America model. You have to look close and try them. I can't figure why in their right mind they would change this for the NA model.
    2. Back Headrests
    Mine has 3 adjustable headrests. I've lowered the rear backrests no problem without having to remove them and the driver's seat is way back. I do have them in the lowest position, though. I think the NA built in headrests look wierd, but that's a matter of taste. It's something new and certainly must improve the rear mirror view.
    3. Rear Seat Room
    I too have sat back there with the driver seat back and still comfortable. At 6 ft., my knees easily clear the front seatback.
    wanted me to bring the Krispy Kremes to eat at Morries while hanging with the attractive sales manager he's infatuated with...
  • auerbachauerbach Member Posts: 110
    This is one of my main concerns. If gtyler at 6'1" thought it was tight, how am I going to fit 6'3" of me inside?
    Guess I'll have to personally check them out - but at this point I'm beginning to get discouraged.
    I sat in a 6 at the NYIAS back in April, and I too am 6'3. I didn't seem to have a problem, but if I remember correctly my leg hit the center console. I sit pretty splayed though, because of a back problem. So you might have any problems. Head room was about 1" left between me and the roof, and I don't remember if it has a sunroof or not.
