techron
i just wanted to ask if anyone have tried using techron concentrate from chevron and fed it straight into your manifold to clean injectors, etc.? normal way fo using this product was dump whole bottle in your tank full of gas.
if i feed the whole bottle straight through the manifold, will it harm anything?
any comments? thank you.
after i finished the job, went for a drive and i definitely noticed more pick-up (power).
some people remove their injectors and hook them up with power and dip the injector in techron to clean them.
for cars with "check engine light" - when u do this type of work, there's a good chance your ilght will come on! don't panic, simply let your engine run about 5 mins when done cleaning. shut off engine and start again, sometimes this will reset your light. if not, remove the (positive) battery cable. leave it off for about 2-5mins. install cable again and fire up engine and check engine light gone!!!
i'm just sharing my thoughts and what i did. i dont have a clue???? the last time my injectors were cleaned, dealer did exact same procedure with different cleaner! i dont have a clue? backyard mechanic? i've rebuilt more engines than you can imagine pal!
if you dont like it, u dont have to be rude about it and i didnt ask u or anyone else to do it! if you dont like what i post, DONT READ IT!!!!!!!!!!!!!!!!!!
i just posted what i tried. i dont expect people to try it. i posted it here to share my experience.
Re disconnecting the battery to turn off the check engine light, won't work on most OBD II ('96 and newer) vehicles.
'use it every 10,000kms, and have had no problems related to the fuel system.
initially i used valvoline synpower fuel system cleaner, but then decided to switch to techron based on rave reviews.
my next experiment?? hmm... maybe redline si-1.
bmw recommends it.
nah! i think i'll stick to techron.
Someone told me they got that advice straight from Chevron.
I go through about 2 bottles of Redline SI-1 per year ... which I was told by a car buddy was safer for more regular use. I still use Techron ... but only maybe a couple bottles every 3 years.
--- Bror Jace
yes, i was the one who posted the email i rec'd from chevron stating that techron dilutes the crankcase oil.
and hence i use it prior to an oil change.
i use it every 5 months, irrespective of accumulated mileage - since i change my oil every 5 months.
redline told me that si-1 was safe (and actually recommended) for regular use, but being the lazy guy that i am, i prefer to put a bottle of techron and forget about it for the next 5 months.
just plain ol' convenience.
also, i tried to get my hands on si-2, but none of the dealers here seem to have it. oh well...
Thank you,
Mr Shiftright
BMW is now recommending Chevron gasoline for their new vehicles. BMW recommends Chevron fuel specifically because of the Techron fuel additive that Chevron supplies. This additive substantially reduces the formation of deposits in the injection system and valvetrain and is supplied in a preventative concentration. BMW recommends an additional fuel system cleaning additive to be used periodically in our vehicles. Three products are warranty-approved: BMW's own fuel system cleaner, Chevron Techron, and Redline SI-1.
Pretty interesting. I had been using chevron already, and i think i may try the redline to use a different cleaner in the system( they may compliment eachother ).
also interesting:
http://www.swedishbricks.net/700900faq/Fuel-LubricantData1.html
dave
dhanley I like to switch around a little and keep my bases covered as well. >;^)
sdayalani, The info I have says that SI-1 and SI-2 are the same thing ... only one is a 12oz bottle and the other a 6oz bottle. I also seem to remember that the SI-2 was a little more diluted and is designed to treat 1 tank of gas ... while SI-1 can treat up to 10 gallons with each ounce.
--- Bror Jace
yes, i am aware that si-2 is a smaller version of si-1. since my fuel tank capacity is only 13 gallons, using si-1 would be an overkill (maybe even a waste) ..unless ofcourse i use a couple of oz every tankful.
wtd:
i had posted this before - dont remember in which forum, but i'll post it again.
this is an email i rec'd from chevron re. techron diluting the crankcase. here it goes ..
>>Thanks for using our product. A small amount >>of the product can pass by the
>>rings of an engine, diluting the oil, however >>that will be of no serious
>>concern. It is little different from the fuel >>and blow-by products which
>>also can effect the oil, in the same manner.
>>Perhaps it would be possible to use Techron on >>the same cycle as your oil
>>changes. An oil change each 5,000 km and a >>bottle of Techron at the same
>>time.
> -----Original Message-----
> Sent: Sunday, August 19, 2001 8:51 PM
> To: lubetek@chevron.com
> Subject: Techron Fuel System and Motor Oil
> Importance: High
> Hi
> I regularly use Chevron Complete Fuel System Cleaner (with Techron
> Concentrate) every 5,000kms in my 1999 Mazda Protege LX.
> Since Chevron does not have a presence where I live, I
> diligently use your product to keep my fuel system clean
> I came across some discussions in a Bulletin Board which stated that Fuel
> system Cleaners should be used only prior to an oil change, since they
> have an adverse effect on the additives contained in Motor Oil. An article
> specifically stated that "Even Chevron recommends using the fuel system
> cleaner prior to an oil change, since they deplete the additives in motor
> oil".
> Is this true, since I use the Techron Fuel System Cleaner based on mileage
> accumulated, and totally independent of when I get my oil changed.
> Thanks very much for your help !
