My commute is similar to yours, I work in Exeter and live in MA. I'll have to check them out when I buy my new GT. I like the idea of a free loaner.
Suggestion: If your oil filter screws on straight up-and-down (vertically), try filling it with fresh oil before installing it. Might get oil circulating that much quicker.
Cheers!
Paul
JonL
Craig
I had Subaru install the alarm system and that was $272 to fix it. Well, less than 24 hours later, I can unlock..but not LOCK the doors with the indoor auto locking switch.
Looking at their rates..it was almost 10 hours to repair the car. The sales guy on Saturday hinted that they are short-staffed at this point. Happy that I am paying extra for that.
Craig
The 2005 models will offer a 2.5i (base) model with no moonroof. I think it will have alloys, but why not reduce unsprung weight? It's less mass for the suspension to fight with.
fitzy2: next time, see if you can find an incline and then aim the car down, then drive up the ramps. That leaves it about level while you're going the work. That may or may not help the oil circulate faster, but it's worth a shot.
Also, try pre-filling the new oil filter before you install it. Folks here gave me that hint.
-juice
I'm afraid I had "prime the filter" so thoroughly drummed into me when I was a kid, I'll always believe its the best way to go.
Here's an observation that makes no sense - Purolator OEM's the Subaru filters, -but- at least for the filter's I'm using now the Purolators thread on easier. Strange.
Larry
I contacted Subaru about plain Legacy L models last June.
I was told that Subaru did manufacture some plain L models for fleet sales and that the dealer could special order them. At that time they had several 2003 Legacy L models in the factory lot. Early in the 2004 model year, I saw punlished prices for non SE Legacy models, so I think some were produced.
The dealers were not ordering them because the SE package was priced very low for the amount of equipment included, so I could not find any on the dealer lots.
The factory should start retooling for the 2005 models very soon, so I think they old models are no longer being produced.
Even if your dealer will special order a plain 2004 Legacy, I would agree with juice and
wait for the 2005 models that should hit the streets in June. They look more stylish and offer many refinements
-gearhead4
They'd sell you a base Outback if you didn't want a moonroof. That gets you heated seats.
Subaru doesn't really sell "stripped" models, the Brighton is long gone.
-juice
-mike
Will do this from now on.
I have another question. I need to replace one tire (because of a temp replacement...previous owner). I like to buy 60 - 70K rated tires but the Bridgestone Potenza's are rated only for 45k. I cant' afford four new tires and was wondering have any of you put on other than the Bridgestones and what do you think about two different tires on same end (225-60R-16's of course)as from the other end/???? just narrowing the options........thanks again.....since I discovered this platform I have been reassured by the help out there.
Irish.
-mike
Other Potenza RE92s have lower TW ratings and will only last 25-40K.
Another great tire is the Potenza RE750. That is more of a performance tire (still all season) and has a TW rating of 400.
Take a look at the TireRack website and browse the selection. You should be able to find a tire that meets your needs, whether it's handling, quiet ride, etc....
Definitely make sure all the tires are within the 0.25" circumference difference recommended by Subaru. That generally means 4 new tires or getting new tires shaved to match the tread depth of the others.
Craig
I am taking it back in, and have also contact SOA.
Does Subaru really have a specification for how much tapping is normal? I would think that any tapping would be abnormal. I know the boxer is not the quietest engine but my last car was a diesel and was quiter in the cabin when really cold than my Subaru.
Mind you really cold is not very cold, I live in WA.
Let's see if I can get them to fix this.
Any feedback from people who have had their pistons replaced and if this really fixes it would be appreciated. The dealer I go to has not yet offered to do that. I currently have just under 20,000 miles.
I hope we can help!! Sorry for the agg.
Patti
Patti
Thank you for your response. They tracked down the source of my wacky security system. It is the actual switch on the driver's side for my auto door locks. My doors don't lock at this point from the driver's side. The part is on order and they will be calling me when it is due in.
Also, even though I purchased the extended plan from my dealer, they had no record of it. They credited about $200 back to me. So all that is good. I hope the switch issue is fixed when the part comes in.
FWIW- I have actually started taking a look at the CR-V and RAV4 for a mid-summer purchase. I had an oil leak fixed but the car STILL smells like it is burning all the time. Others have said it is a normal Subie smell. Sorry, but not a smell I want to live with having customers driving in my car with me. Also, the heater switch does not go all the way to hot anymore..I put it to hot and then it goes back toward the cold. Also, I have two new air leaks in my driver window. Sounds like a wind-tunnel occassionally.
Sorry to sound down..I just drive 30,000 miles / yr and I can't afford to keep taking the car back to the dealership for these annoyances.
SOA replaced 2 pistons mine, but it took 15 minutes or so for the piston slap to quiet down and that was well after the coolant reached normal temp. If yours quiets down in 5 or fewer minutes then I doubt its much of an issue. Does it still nock when the coolant temp is up to normal?
-jay
I had bad fuel efficiency in my 2000 legacy L for over a year (15-16 MPG). The local dealership could not diagnose a problem.
Recently, check engine and AT temp light went off and TPS sensor failure was diagnosed. $330 and new TPS later, the MPG went back to 20 (normal in my car in city). However, one month later, the same problem comes back: solid engine light, blinking AT temp light, erratic power, delayed and hard shifts. BTW, the AT temp is normal: 160-180 F, I have an AT temp gauge installed.
Does one know if there is a reason for repeated TPS failures?
Or maybe other failures in Subaru can mascarade as TPS?
Jacek
As for that squeek, I would lube the sway bar bushings. Use lithium grease, not anything petroleum based.
-juice
Juice, Bob, can you confirm that too, about the L 35th being the base-line Leg?
-juice
The tapping is detectable even after the engine has warmed up. I have driven the car for 20 mins and still been able to detect the tapping. The tapping does get quieter as the engine gets warmer but does not fully go away. I would understand if this was something that lasted a couple of mins. but it is still detectable when warm.
My case number is 586715.
It is really frustrating when you buy a car and it does not make the tapping sound and once it develops you are told that it is within spec. I really like the car and had planned on keeping it for a long time when I bought it. Having this tapping and being told it is within spec. has me concerned about the longetivity of the engine (my particular engine as I have known many people to drive Subaru's for a longer period of time and bought one due to the reliability).
I did see on here someone said that a SOA Rep gave him a free Subaru Gold Warranty. While I would prefer that my car be repaired, this would alleviate my concerns for the long term as the damage that is most likely occuring would then be covered for as long as I will own my Subaru. I don't anticipate owning the car beyond 100,000 miles.
Any assistance you can give of having it fixed when I take it in would be appreciated.
Rick
Thanks for your patience!
Patti
Thank you for following up. I am just a little frustrated with the situation. When I read where people have had this problem corrected and they are in much colder climates, I would think that someone in a warmer climate would get the same treatment from Subaru.
Hopefully they can get the "piston slap" fixed. The few other problems I have had with the car, the dealer has done a great job getting them corrected. I had a mirror that rattled, they replaced that, and I like many owners had the wind noise through the front window. With an adjustment to the front gusset they were able to get it eliminated.
If/when they get the problem with the piston slap corrected my car will be just the way I want it.
I am taking it in on the 29th of this month and they are supoosed to look at it again on the 30th although they reiterated to me when scheduling the appointment that it is "normal" and that the tech found it "within spec." Lets see what happens.
I do know that these boards are filled with people who have had problems, but my Subaru for the most part has been a great car and you can't beat it when it snows.
Anyway - thank you for giving us another shot. We'll do our best for you.
Thanks, unfortunately TPS affects AT a lot. I my case, when trouble codes show up for TPS (intermittently), the transmission shifts very late, very hard. I guess the wrong information it gets from TPS is that I floor the pedal, which I do not.
Some follow up: local dealership saw the car yesterday, confirmed the TPS error codes in memory but determined that TPS was not defective (it was replaced a month ago: $240 part cost for a simple potentiometer; cost to produce: under a buck) and the connections were OK. They do not know how to diagnose the problem further.
This is why I need help or any good ideas.
I suspect that the TPS error codes (p0122 and TCM31) are misleading in my case and there is something else wrong escaping diagnosis at the moment.
Please, anyone?
BTW, in my line of work (I am a professional), if I do not know the answer to a challenging question, I hit books and other resources. If a mechanic at dealership does not know the answer, the buzz-phrase is: "problem could not be duplicated".
-juice
-mike
PS: those epa figures don't have wind effects.
-juice
The old 96 Outback got 24. The new 03 Outback gets 20 - 22.
I drive at 80, and rarely use CC.
Maybe try running about 55mph???? No way!
MNSteve
Craig
Thanks Folks. irish
Craig
Craig
Jim
I hope everyone is okay@
Patti
