Visitor Agreement.
Steve
Many have reported similar bribes/inducements from Honda dealers....
This is the classic situation of the manufacturer insisting on "perfection"--or else--and as a result getting utterly meaningless survey results. Sort of like making the punishment for a petty midemeanor so severe that no one is ever punished for committing it.
Erik V.
2400 miles, no problems of any kind.
Can some others on this board verify whether or not the 2001 manual says 5W-20? I would appreciate a double check on that.
I used to be willing to answer product/service satisfaction surveys, especially those done over the phone because they didn't take long. After a while I began to refuse, for the simple reason that they did not appear to be designed to *really* determine *anything*. Why ? The questions inevitably were absolute, something like (exaggerating a bit): "The salesman was 1-very helpful, 2-rude, condescending, and unhelpful." Inevitably I found myself answering in the positive because the negative was usually so negative and unyielding that it seemed unfair to whomever/whatever I was evaluating. I suspect that the true purpose of many of these surveys was to get a nice satisfaction rating for ads & commercials.
I would guess that the wear is slightly more with the 5W-30.
ps: even Honda's website specs 5w-30 which according to conversation with engineers at Honda is wrong!These are the specs for the '01- 5w-20
For example, lets say that you love your salesman, and have no complaints what-so ever. Yet the F&I mgr, or the used car manager or 'whomever' at the dealership you have some problem with...it is the salesman and his/her pay that is directly affected.
Think about that the next time you have a survey in your hands.
If anyone else is interested his name is Greg Allen at Union Park Honda (wilmington, De)
ph- 302.573.5222 or e-mail- gjv1152@aol.com
also since I'm out of state I pay no sales tax.
Purchased Jan 31- driven less than 1,000 miles and 6 year HondaCare warranty. Car is in perfect condition. E-mail me if interested.
madonna826@aol.com
Dan Madonna
Ford and Honda apparently switched to recommending 5W-20 for many model 2001 (and some earlier) vehicles for fuel economy reasons. I'm guessing that since both are rated "5W", your climate probably doesn't matter so much (i.e 0W is for cold extremes, 10W or 15W for warmer temperatures). From limited reading, 5W-20 may not offer as much protection since it is thinner at operating temps. On the other hand, 5W-20 also shouldn't have the viscosity improvers and additives that conventional 5W-30 oils have, which supposedly lead to varnish/sludge/deposits. I don't trust dealers to put in what I tell them, so I doubt it makes much difference. I suppose they'll use whatever they have or whatever is cheaper.
I also don't trust dealers to inflate tires to spec, as they always seem to under inflate them. I have my Odyssey at 33-34 psi. 35 is recommended, and is also the max listed on the tire.
Some quick specs from penzoil/Mobil1 (also see http://www.atis.net/oil_faq.html ):
Penzoil 5W-20 Flash Point=445F, Pour Point=-49F, Viscosity Index=158, Pump Limit=-35F, Viscosity@100C=8.6cST
Penzoil 5W-30 Flash Point=420F, Pour Point=-44F, Viscosity Index=160, Pump Limit=-35F, Viscosity@100C=10.5cSt
Mobil1 5W-30 Flash Point=455F, Pour Point=-65F, Viscosity Index=162, Pump Limit=-54F, Viscosity@100C=9.9cSt
I am going to discuss this with my service department before my next oil change. At the most there is probably a slight more amount of wear with one over the other.
According to post #1326 it is not a misprint. I wonder if Honda took into account the large differences in average temperatures in the US. You have some places that get to 120F or more and some that get to -30F or less.
Siva.
I would think there would be enough demand to make it worth while for someone to provide a kit or perhaps the dealer can do it. In the worst case you might have to replace the entire seat, but hopefully not how it is fastened to the floor.
Bob Widmer @ Bob Lindsay Honda, Peoria, IL (309)692-3200. Don't know if he sells out of state, but I paid $755, since my friend and I bought at the same time. Inital quote was $805.
*When* you get your van (timothyadavis) it does make sense to wait a year to check your useage and then buy the coverage that suits your driving habits. Just buy it before 18K miles.
Anyone else with solutions to this problem?
I test drove one Monday and I'm feeling it's a deal breaker at this point. (Which is bumming me out as the Ody seems to clearly be the best)!
My experience with the doors was this - I could not get the door on the one I drove to switch direction by pushing it or banging it - not even during the last 18'' of travel.
The only time it switched direction was when the door wedged my arm up against the door jam and squeezed - HARD. It hurt a bit and I'm a grown man - I fear for a child that got in the way.
Is this the way it's supposed to be or was the one I was test driving not functioning properly? Can you choose to shut the doors manually if you want (switching off the auto), perhaps using it that way when you're transporting small children and using the convenience when you're not? I know I could buy the LX instead but the auto doors are a nice option, if only you didn't need the strength of a bull to reverse them.
Any thoughts or comments greatly appreciated--
Tuesdays: 4-5pmPT/7-8pmET
-or-
Thursdays: 5-6pmPT/8-9pmET, 6-7pmPT/9-10ET, 7-8pmPT/10-11pmET
(The latter may be rather late for East Coasters, but is available if you want.)
Let me know if you are interested in a chat and the day/time convenient for you.
KarenS
Owner's Clubs
My impression is that the reverse sensor works in the last 12 inches of travel but I have never tried to test mine with anything other than my arm. I don't think the pressure on my arm was that bad, but that's a personal observation.
As for young children, we have yet to have an incident with our now 4 year old in almost 1 year of ownership. We have stressed to him over and over about cars and car doors (both sliding and swinging) and that he stay out of the way and not touch them. Luckily, he listens.
As an aside, I tried my arm in the Windstar door and the pressure before reverse was about the same.
Good Luck in your decision.
It would interesting if someone had injury data of manual versus power car doors. I do know that the manual doors do not have a reverse feature when you put your arm in them.
That person I know who lost part of a finger, was a kid at the time, and his brother, also a kid, slamed the door on him. Maybe this shows that if you have car manual doors then you shouln't have any brothers or sisters.
The NHTSA complaints area does list a number of reports of power door injuries for Odyssey. See:
http://www.nhtsa.dot.gov/cars/problems/complain/compmmy1.cfm
Note many minivans, like Odyssey are in the "Truck" category for each manufacturer. In a quick scan, I found 8 complaints that recorded injuries from the power doors, 5 for 2000, 3 for 1999. Unfortunately, the whole text of the complaint is not available to see the whole story... There were other complaints that did not record the incident as an injury.
The difference in safety wasn't the deciding factor for us buying an LX. I didn't care for the speed and logic of the system, though apparently many people are very satisfied. I've read the system on the 2001 Chrysler vans is a big improvement for auto/manual operation, but have yet to try one.
In the end, the real difference is whether you want to blame the door injury on the van (power) or on a person (manual):-)
gently, or allow the weight of the hatch to lower it, then the latch doesn't fully
engage, the interior lights stay on, and the door open indicator lights up on the dash.
Last week after a couple of failed attempts to gently latch it with my 8'2" kayak inside,
I slammed the hatch and cracked the rear plastic panel like an egg. BTW that panel is
surprisingly thin and fragile compared to my old explorer's, which only bears scuff marks
from 5 years of doing the same thing.
My question: Has anybody had and fixed this problem? Perhaps by adjusting the latch
or striker?
nate
(#1352) My new EX has the same problem. I prefer not to slam the thing shut every time so if anyone has had this problem fixed, let me know. I didn't want the dealer to look at me like I was nuts when I asked about it.
Thanks for any time you spend on this
If I had to do it again, I would still get the Power doors, They are such a convenience and like some here have already said, I don't remember reading of any serious injuries caused by the door.
Also, once you have those power doors, you'll never want a van without them.
So get the EX, and remember . . . Mr. Honda would not allow his Minivan's sliding doors to injure the people that buy them, it just wouldn't make sense especially for a company known for playing it safe.
nate
Hope this helps.
