-mike
And we all know that warranty times are in favor of the manufacturer.
Standard flat rate is 2.4 hours.
The dealer I deal with sells the front pads over the counter at $162 and rears at $144. So, it will depend on the dealer you go to, which is why I said around $400 or more for the pads.
As for the time, I'd be willing to bet that the dealer will charge at least the 2.4 hours, adding time for bleeding, resurfacing or rotor replacement, hazardous waste fees and incidentals. Which should average out to the 3.5 hours.
-mike
I believe you said you have an XA that requires brake fluid
flushing. I have an XB and the maintenance schedule says nothing about flushing, only inspections. How often does it say to flush? Thanks
1) The boiling point of your brake fluid goes down. You run risk of boiling the fluid during emergancy stop thus losing ALL brakes when you need them most. (air/steam in the brake fluid makes the brakes useless!)
2) The water tends to accumulate inside Brake calipers and expensive ABS components making them rust on the inside.
How do you prevent these bad things from happening? Replace your brakefluid every 2-3 years. Irreguardless of milage.
-mike
Best Regards,
Shipo
-mike
-mike
Of-course, all of our garbage-dumps have separated tubs for all recyclables. There is a book printed up so we understand how to separate things.
The good thing about it is that all recycling is FREE of charge. The actual "garbage" our household generates is about 2 garbage bags a month! (about $2.75 each to dispose of)
I checked the fluid level and it's about 1/4" to 1/2 inch down from where the stain mark is on resevior (from it's previous level) and about 3/4" an inch to an inch down from max... any thoughts? Thanks.
The "Municipality" as franchisor grants the "franchise" , but once granted, it is in effect a total monopoly and it HAS to include union labor. Cutting to the chase, you can NOT opt out of the Municipality's "solid waste" @ (currently) 26 per month. Well, technically you can!! They will technically condemn your house as unfit for human habitation, as you do not have so called "sanitation services". And we are scared of Guido with a baseball bat.
So basically your/my 2 garbage bags per mo cost 13 each or 4.73 x more!!!! Since we are on a brake thread, imagine a $300. dollar brake job costing $1,418. I am in the wrong business!!!
As your brake pads wear out the fluid level will drop proportionally. It may or may not be time for new pads, but that's why the fluid level is lower.
-mike
I thought about the brake pads wearing out causing the drop in fluid level, I'll have them checked out.
If the brake 'feel' is changing, getting harder or softer, I would guess the problem is in the vacumn booster system. Possibly the ABS, but DIY people usually don't know much about ABS stuff.
Actually on some early ABS systems you needed to bleed/flush the ABS units and it was tricky. This is what they may have been referring to.
-mike
Bleeding the brakes CAN messs up the ABS system on some vehicles. (depends on ABS design) Before bleeding the brakes on YOUR specific vehicle, read the shop manual.
Some vehicles require PRESSURE bleeding, Some specify VACUUM bleeding, others are OK to use a buddy to press the brake pedal to bleed.
Some vehicles even requre you to hook up to a computer to "activiate" the ABS motors during brake bleeding. Otherwise, the ABS motors may not get the fluid in them flushed when you bleed at the wheels.
Dont take my word for it, READ the technical manual for several vehicle makes.... but I may still be a goober - LOL
Sounds like good technique to me. It just means you do have to bleed the brakes even after a pad replacement because of the opened bleeder. Better than a $1500-2000 ABS unit.
I assume whoever I get to look at my brakes will know the proper procedure for having them bled/flushed. Really don't care to pay dealership prices on what sounds like should be a simple procedure.
I'll write back and report my findings when I get it diagnosed, hopefully sometime this week.
Any help or ideas greatly appreciated.
When I encounter a caliper which behaves like this, it is not worth trying to "fix" it... Just install a rebuilt caliper and send that bad one back to be refirbished.
-mike
Had a minor leak in rear wheel cylinders noted a couple months ago. I'm thinking this must have gotten much worse based on the amount of fluid lost.
-mike
- daughter had an episode where she lost her brakes
- took it to a shop, who didn't find anything wrong (ie. a leak somewhere), but replaced the brake fluid and properly bled the system.
- she drove for a day, and then had another episode where she lost her brakes
- took it back to the shop, and they replaced a vacuum hose
- lost the brakes for the third time.
If we assume that the first shop didn't find any leaking components at the wheels or hoses (they would have replaced some component), and also assume that there 'was' fluid in the car (they drained the old fluid and replaced/bled), then it sounds like your master cylinder needs replacing.
She should verify that she does have brake fluid up to the proper level in the master cylinder. If she doesn't, then that means there is a pretty substantial leak somewhere (loosing all of the fluid in a day), and any competent shop should be able to find the brake fluid dripping off the car. If there is brake fluid, then the master brake cylinder is suspect (since we already know that the brakes were properly bled and worked for a day).
These represent two REALLY different problems with two different solutions.
So you'll need to define exactly what happened.
You said there WAS a minor leak in the rear cylinders a couple of months ago? Were they replaced at that time?
If not, you now have a MAJOR leak! If the were replaced, it's leaking somewhere else.
Leaks don't get better when ignored and we are talking about your BRAKES and the ability to stop!
Best Regards,
Shipo
I once had a guy tell me that brake fluid *evaporates* and it was normal to lose fluid.... let me tell you I did not consider selling the car he was selling!
The problem was found when he replaced rear bearings, but he did not call and say "hey your brakes are leaking, I think you should fix those...even if it means leaving the bearings for another time".
Anyway, I've been telling my kid that he needs to fix them now...that 16 oz is a huge loss. He is finally going to do it Thursday. His big issue was he did not want to take the bus to school for one day, while his car is worked on :sick: .
Here's a photo of the typical plug-in as it goes into the brake pad (but it doesn't show the sensor itself, which is usually a small cylinder device)
http://www.pelicanparts.com/bmw/techarticles/E36-Brake_Pads/pic3.jpg
So you are saying he had the brakes open to replace the wheel bearings and the wheel cylinders were leaking and PUT IT BACK TOGENTER?????
Who does this sort of thing? I'm sorry, but some folks may thinnk I go a bit over the top about doing things the RIGHT way, but this is a clear indication of laziness.
Anyway, I've been telling my kid that he needs to fix them now...that 16 oz is a huge loss. He is finally going to do it Thursday. His big issue was he did not want to take the bus to school for one day, while his car is worked on.
Ok, I am going to say something here you may not like, but here it goes.
Leaking brakes are an UNSAFE thing. It is your responsibility as a parent to NOT allow your "child" to drive something unsafe, no matter what they think.
Take the keys away and tell them they are not driving it until it is fixed. Plain and simple. Let him scream and yell. Take a stance.
Ok, I'll go back to my corner now.
WHY wouldn't someone have replaced or at least overhauled those wheel cylinders when it was already apart??
Oh, I guess nobody rebuilds wheel cylinders anymore. I know I have honed out and rebuilt dozens of them and never a problem.
Maybe at today's labor rates it doesn't make sense?
It is best to replace with pads that have the built-in sensor. When you go to the autoparts store they will ASK you if you need the pads with the sensor or not.
It is possible to install pads WITHOUT the sensor-wire .... but you need to bypass the sensor circuit if you do this. (otherwise the light on the dashboard will stay on forever.)
you can see it here:
http://www.thepartsbin.com/sitemap/volkswagen~brake_pad_sensor~parts.html
Yes, we picked the car up and there was a note on the bill "wheel cylinder leaking".
Anyway, here is another thing that I thought was odd. My kid checked the fluid right when the brake light came on. I thought he must have lost a lot of fluid very suddenly to have the light just come and then find it 16 oz low. I had always thought that the brake light came on when only a tiny amount of fluid was needed...like a couple ounces. I really expected that he would step on the brakes once and lose most of the fluid again...but that has not happened.
Is it unusual to have the light not come on until the fluid is nearly 16 oz. low?
