Stop here! Let's talk about brakes
1343536373840»
  • imidazol97imidazol97 Member Posts: 27,767
    >so I don't see how a slightly cooler /slightly heavier rotor will stop a car quicker.
    I do not know that the tenet is that a thicker rotor will stop the car quicker. What it will do is stay slightly cooler as the predetermined quantity of heat is transferred into it. Staying slightly cooler may mean better braking, but in my thinking it means the rotor is slightly less likely to suffer distortion at the end of the stop due to the extreme heating during a hard stop or a long braking period such as a long downhill run.
    But I have another observation. That is that the inside fins of most rotors are covered with a rust material. That has to insulate an old rotor from the air going through the fins and somewhat lower the transfer of heat to the air through those openings. That's why if I drive a car hard or I have had brakes that warped slighty I feel it's time for a quality new rotor that has a cleaner surface on the fins with which to transfer heat to the air that's interior to the rotor as well as the external surface air. If it's my 180,000 mile Buick that's driven mostly gently around the suburban and rural region, I think less about new rotors.
    So, if I machine the rotors on one of our CRV's leaving it well within specs and someone with an identical CRV REPLACES his rotors and we both make a panic stop from 60 MPH, are you telling me that there would be a measurable distance in stopping?
    Of course, this assumes identical tires, same road conditions etc?
    I'm not buying that. Sorry.
    I was thinking that there's a certain amount of glazing on pads and burning on old rotors, and some roughness, so all together yeah, you might get a few extra feet out of brand new rotors and pads vs. a set that's been working hard for 25,000 miles. Perhaps it's the overall combination of all the things about a "new brake job" that gives me that confidence.
    Well, I was assuming both cars had new pads. One had NEW rotors and the other had freshly resurfaced in tolerance rotors.
    Speaking of which, our 2003 CRV has 53,000 miles on the original brakes. 10,000 miles ago, they still had lots of pad left.
    Time to take another look!
    I drive pretty darn hard, so I'm not comfortable with shaving any appreciable metal off a rotor. I'm okay with cleaning them up but I wouldn't run mine if they are close to minimum tolerance. I'm just too hard on brakes to take a chance.
    Lets say the stop is from 70 to zero; yes, there will be a measurable difference if said stop is at impending lock-up. Now lets say the rotors are already hot from heat yet to be dissipated from previous stops, then the difference stopping distance will be even more pronounced.
  • jipsterjipster Member Posts: 6,302
    edited December 2010
    Is this fact or theory? Measurable difference? How much is total weight of an average rotor face? How much is machined off? How much heat would need to be dissipated before it would affect performance?
    Sounds like something the auto parts industry would fund if putting on new rotors were noticeably more beneficial than machining. I mean why not put on a new set of tires after every 10,000 miles... same thing.
    Probably the only real advantage of not turning rotors is that, if you are a hard driver, a thinner rotor would probably warp more easily---let's say if you were coming down a long hill and then hit a puddle of water at the bottom.
    It seems that many modern cars, especially entry-level types, are plagued with rotors that warp as easily as the tinfoil in an Italian TV dinner tray.
    Sorry guys, the fact is, the thinner the rotor, the lower the thermal mass of said rotor; the lower the thermal mass, the higher the rotor will heat up with the application of any given amount of heat; the higher the heat the lesser the effective braking power. Is it significant? I believe it is and have read plenty of studies published in the SAE archives that back that up with hard numbers.
    That said, you shouldn't believe some dumb [non-permissible content removed] on the internet; if you're interested in this kind of stuff you should do your own research. I've done mine and I change rotors at every brake job. That's my story and I'm sticking to it.
  • srs_49srs_49 Member Posts: 1,394
    Yes, the temperature rise is directly related to the mass of the rotor. The lighter the rotor, the more the temperature rise for the same amount of energy (heat) input.
    That said, what kind of difference in temperature rise are we talking about for a machined vs a non-machined rotor? Well, we need an estimate of the before and after machining weight of the rotor.
    Assume a stock rotor weighs 15 lbs. Further assume that after using up one set of brake pads (which wear the rotor) and then machining said rotor, it's weight it 14.5 lbs (0.5 lb metal loss seems high to me, but this will give us a worst case estimate or temperature rise).
    Now, assume a braking scenario that raises the temperature of the stock 15.0 lb rotor 100 deg C. Then that same braking scenario, applied to the used, machined 14.5 lb rotor would raise its temperature 103.45 deg C, a 3.45 deg C increase.
    So yes, the used, machined rotor does run hotter, but does the 3.45 deg C increase make that much difference?
    If the rotor was half as heavy as the one I postulated (7.5 lbs from the factory), and the braking scenario twice as hard, the temperature difference between the two rotors would still only be 24.29 deg C.
    I do not know if a 24.29 deg C difference in rotor temperature is significant or not. For the average driver who maybe needs to do 1 full blown panic stop from highway speeds a year, probably not. For those who like to push the envelope coming down a mountain, :shades: .
  • bpeeblesbpeebles Member Posts: 4,085
    The main reason for NOT turning modern rotors is because many are HARD SURFACED.... not because of loss of braking charictoristics. There is a min. number embossed on the casting to tell you what is safe. Turning them removes the all-important hardend surface whence the pads create friction.
    Todays modern brake-rotor may be made up of several different materials.
    - The hard-surfacing for the pads to bite into.
    - softer material which conducts heat away.
    - tougher material which resists warping near the bolt-holes
    You may not be able to visually *see* these differences. Modern meterallgy tecniques like flame-hardening can make one cast peice have very different charactoristics.
    Of course, you can always buy cheep rotors that will warp the 1st time you do a panic-stop.
    Heck - the brake rotors on my motorcycle are aluminium inner section with fully-floating StainlessSteel outer area for the pads to bite into. (Just like race-cars use.)
  • tedbarttedbart Member Posts: 1
    edited January 2011
    The brakes on my 2006 Toyota Avalon (46K miles) started to make a grinding noise. Pads were worn to the center groove but still has ~3/16" of friction material. Changed them any way, but the noise is still there. Rotors are smooth and brakes are steady.
    1. Is the grinding noise present all the time, or only when you are applying the brakes?
    2. Can you isolate the noise to the front or rear?
    3. Does the noise change if the wheels are being turned?
    4. Maybe the water splash shield is bent and rubbing on the rotor.
    Are you using Toyota pads or aftermarket pads? I had my mechanic change the brakes on my 2006 Camry. Used napa Gold pads like he always uses on any brake job. Brakes started grinding. Replaced pads again and turned the rotors. Still grinding. Finally he just used Toyota pads and rotors. problem solved.
    A cheaper solution would have been to replace the rotors with Napa brand but we both were so frustrated that he just used Toyota parts.
    Lets be realistic here. Noisy brakes may be an annoyance... but it is is not a "problem".
  • ski23bumski23bum Member Posts: 1
    Check these out... Phoenix Systems brake fluid test strips
    measures the level of copper present in the brake fluid. Just tried these out as I had dealers for both my cars push brake fluid changes at 36K miles which seemed very early. Seem to work well and easy to use.
    http://www.brakebleeder.com/index.php?main_page=index&cPath=3
    Thanks. I'll keep those in mind. Had the brake fluid changed out a few months ago as it was noticeably dirty.
  • salilsurendransalilsurendran Member Posts: 4
    Hello Friends,
    Recently my brakes started squealing and I took it to a mechanic. He initially said the brake pads would have to be replaced and quoted me around $260 each axle. Then he called me up and said that the front rotors would have to be replaced since they were metal to metal. I was wondering as to why the rotors need to be replaced since they can be resurfaced and I had brake problems for only a couple of days and surely the brake pads would have given some indication that they were wearing out before going metal to metal. He even showed me the place where the metal on the rotor had filed away because of the brake pads being metal to metal. He quoted me $718 + tax. Of which about $315 is labor and $310 is parts and $50 is something like sublet which I think is rotor turning. Is the job too expensive. My car is at 60k miles and this is my first brake job.
    What year make model of car are we talking about?
    It's a 2008 Mitsubishi Eclipse Spyder 2-door convertible.
    edited September 2012
    Okay....
    rotors are $90 each
    pads for the front are $99 for a set
    Labor should be about 2 hours give or take
    So if the labor rate is $100 an hour (don't know in your area), that's $200 labor and roughly $300 parts I listed---so $500 is about right.
    any additional work or materials would be added on, of course.
    Rear pads would be $75 the set, plus maybe 1.3 hours to replace them in the back.
    So another $200 for rear pads.
    So you are basically saying that $718 seems right for front rotors and all brake pads.
    Look/call around and you can find it a lot cheaper than that. Brakeway will do a 4 wheel brake job with "quality" ceramic pads and turn your rotors for $139. Most shops though you'd be looking at between $400-$700 for that work. A dealership will be at the high end of the price scale.
    I had the front brakes done on my Dodge Dakota truck a couple of months ago. Bill came to $750. This included:
    1. Front pads and rotors
    2. One front caliper assembly
    3. New hardware (caliper bolts, spring clips, etc)
    4. Brake fluid flush/changeout
    5. Rear brake inspection and adjustment(?).
  • pedrodagr8pedrodagr8 Member Posts: 1
    I'm sure this has been covered but I am patting myself on the back for changing my own pads this weekend. :D If you don't need things like the rotors turned changing your own brakepads is surprisingly easy (and pretty inexpensive). On my car (2004 Honda CR-V) literally, jack the car up and use a second jack to support the wheel (not sure if necessary but I had it so I did it). Remove the tire. Find the two bolts on the back side of the caliper (they have rubber boots connected to them). Undo one and rotate the caliper out of the way. Replace pads and other needed parts. Check the rubber boots for cracking and make sure the pins move properly. Depress the caliper, this is the hard part as it takes strength (I'm not the strongest person in the world) and some patience to do it by hand but I did it. They likely make tools for this but it can be done by hand, just remember that you are forcing liquid back out through a tiny hose so it will move VERY slowly and you just can't speed it up.
    All in all, to replace the front pads it took me 20-30min tops for both sides combined and $50 for some Wagner Thermoquiet ceramic pads. No clue if there are better deals on pads but I've been very happy with them on the rear and I decided to put them on the front as well.
    Woo Hoo - Congratulations for replacing your own brake pads. I have been doing this since I was about 15 years old and have learned a "trick or two" along the way.
    *) An inexpensive clamp or even a large pair of waterpump-pliers can be used to compress the caliper. (plus you get to own a cool new tool!)
    *) Have the cap off of the master-cylinder and WATCH THE FLUID LEVEL as you compress a caliper.... the level WILL go up and you may need to remove some fluid before it overflows and makes the paint come off your car.
    *) REAR calipers which have integrated parking-brake *MUST* be compressed and rotated at the same time. (An opportunity to own a real caliper-compressor)
    *) File smooth all the pad-slider surfaces before applying the hi-temp grease.
    *) Apply a thin layer of antisease grease to inside of wheel so it does not get stuck to the rotor.
    *) Use torque-wrench on lugnuts and RETORQUE a few days later if you have aluminum wheels. (another opportunity to own a new tool)
  • vballplayer30vballplayer30 Member Posts: 27
    I own a 2008 Lexus IS 250. I've owned it since late 2009. Just brought my car in for an oil change and they said I need new front brakes. They showed me the pads and I guess they looked low compared to a model they had of new pads. I had my front pads replaced 6/12/11 and it's now Oct 2012. It looks like they wrote my mileage on the receipt, but I'm not positive (it's listed under license No, but it's obv not my license #)...40,815...my mileage now is a little over 50k...I thought brake pads should last closer to 30,000 miles?? I found it interesting when I first was told I needed new brakes that I got, not only different price quotes for the repairs, but that each shop (local mechanics, midas, etc) told me that I needed different things. Some said just front brakes, some said front and back. Some said new rotors or rotor resurfacing, some just pads...Called the dealer who put the pads on in 2011 and said it seems kinda soon to need new pads and he said to bring it in and he'd take a look at it. Any advice?
    Also, after reading the tips on brakes on this website, one article said you can wait until you hear a squeeking noise from the metal in the pads, which is there to tell you it's time to replace. Another article said you should try to time it before that happens...any suggestions?
    edited October 2012
    Is this the first time you have ever taken a car in for service? Unfortunately, this happens ALL THE TIME. Some places are worse than others. (For example Midas mechanics get a 'kickback' when they sell more stuff to a customer)
    As for waiting for a "squeeking sound" This is only true if the pads have "wear sensors" attached to them. Some better-designed cars actually have an electrical sensor which lite up an indicator on the dash (Volkswagen, Audi and other German makes.)
    If your last "barke job" was done on the cheap... then you may not have any wear-sensors at all.
    On to your underlying question.... "is this "too soon" to be needing new pads" ABSOLUTELY!! (I get 60-80 thousand miles on brakepads)
    However, your driving-habits may wear the brakes faster. (Do you completely release the brake pedal when not using brakes?)
    Pads which are sticking in the guides may wear faster... but a properly executed "brake job" should have filed the rust off of the guides and lubed them.
    A problem with the hydrolic-system could also cause premature brake-wear. (very VERY unlikely)
    "Do you need rotors" Usually NO... If they are still servicable, they can be used for a very long time.
    Your *real* problem?.... you seem to be having troubles finding a reputable service mechanic that you can trust with your car.
    Thanks for the info! I am trying to find a trustworthy mechanic, but it seems like you can't trust any of them! And yes, I know all about the mechanics and tire guys trying to get you to buy extra things you don;t need! Thanks again!
    This happens occasionally. A medium to harder stop resulting in a popping sound, then what feels like a split second loss of braking force before reengaging. New pads, rotors turned. Dealership says can't find or duplicate.
    Any ideas on what problem may be?
    Don't you think you might get an answer if you posted this under cardoc's topic?
    Is the popping felt in the pedal?
    edited April 2013
    Well, my impression is that doc doesn't care to answer diagnostic related questions.
    The bolt like popping sound comes from underneath the car. You feel a split second loss of pressure in the pedal at the sound of the pop.
    edited April 2013
    My best guess is that it sounds like the pad is hanging up causing the sound or a loose caliper.
    ABS kicking in, for some reason?
  • stephroshstephrosh Member Posts: 2
    1
    Get the correct brake pads - Pads are available at any auto parts store or your local car dealership. Just let them know the year, make and model of your car. They will typically offer you a choice of different quality pads with a wide range in price. In general, the more expensive they are, the longer they last. Be aware that some very expensive pads with a higher than desirable metal content may be aimed at the 'Rally' market for use with performance Rotors. You will probably not want those because they are likely to cause premature wear of standard Rotors. Preferably try to obtain brake pads that have a visibly similar metal content to the existing pads. Also, some people find that less expensive pads are noisier than "brand name" pads.
    2
    Make sure the vehicle is cooled down - If you have recently driven, you may be working with extremely hot pads, calipers and rotors. Be sure that these parts are safe to touch before moving on.
    3
    Loosen the lug nuts - Using a lug wrench (one is usually provided along with the car's jack), loosen each of the lug nuts that hold the wheels onto the car about two thirds of the way.
    4
    Jack the car up - Locate a safe place to position the car jack under your car. Check the user's manual or check for markings that indicate where to place the jack. Put some chocks behind the wheels that are on the ground to stop the car from rolling forward or back. Carefully jack the car up until the wheel can be removed easily. Place a jack stand or blocks under the frame of the vehicle. Do NOT trust the jack alone. Repeat for the other side of the car so that both sides are securely supported.
    5
    Remove the wheels - Finish loosening and removing the lug nuts. Pull the wheel straight out towards you to remove it.
    6
    If the wheel rims are Alloy and are either seized or partially seized on the studs, try kicking the tyre at the bottom with your foot a few times and hopefully it will move. when this occurs, you should clean the studs, stud holes, Rotor mounting surface, and the rear mounting surface of the alloy wheel - with a wire brush and apply anti seize compound before refitting the wheel.
    7
    You should now be looking at the rotor (a large, flat metal disc) and the caliper (a large clamp-like device wrapped around the top of the rotor).
    8
    Remove the caliper bolts - There are many different ways that the caliper is secured and different Caliper designs necessitating different removal procedures. The mounting position also depends on the Caliper design and whether it is an all one piece, a two piece, or a more complex design Caliper. All One piece Calipers are generally secured with between 2 to four bolts at the inside of the stub axle housing. Spray these bolts with WD-40 or PB Penetrating Catalyst to aid in removing them. Using a correct size Socket or Ring spanner, loosen and remove the bolts MAKING ABSOLUTELY SURE THAT THERE ARE NO SHIMS FITTED BETWEEN THE CALIPER MOUNTING BOLTS AND MOUNTING SURFACE. If there are they must be refitted as they were or the Caliper will not sit correctly.
    9
    If any do fall out unexpectedly, you will need to refit the Caliper without the brake pads and using a combination of feeler gauges, measure the difference between the pad mounting surface to the Caliper at the top and Bottom. Then, work out the difference/s and allocate the shims accordingly.
    10
    Alternatively, many Japanese vehicles use a 2 piece sliding Caliper that only requires the removal of 2x forward facing, upper and lower, slider bolts, and NOT the removal of the entire caliper. These bolts are often 12 or 14mm heads.
    11
    Additionally, if these caliper are completely removed, it is much more difficult to fit the brake pads into them.
    12
    Check the caliper pressure - The caliper should now move a slight amount if you shake it. If not the caliper is under pressure and it may fly off when you remove the bolts. Take extra precaution to not be in its path, whether it is loose or not.
    13
    Next, have a piece of light tie wire handy, about a foot long, before you proceed.
    14
    As the caliper will still be connected to the brake line, hang it up carefully by the wire, in the wheel well, so that it doesn't drop and have any weight on the flexible brake hose.
    15
    Remove the top of the Brake Master cylinder from under the engine hood and inspect the fluid level before the pistons are 'Squeezed' back to enable the new brake pads to be fitted. Many mechanics draw some fluid from the master cylinder before proceeding to squeeze the brake Caliper pistons.
    16
    However, a better method is bleed the old Caliper fluid off by fitting a brake bleeding hose to the Caliper nipple, place the hose in a small bottle and undo the bleeder nipple as the pistons are squeezed. They are easily squeezed with one hand using large 12 inch water pump pliers - much easier than C or G clamps. So, the pliers are held in one hand and the bleeder spanner in the other. If it was not intended to bleed the brakes they still do not need to be, but the old fluid will have been removed from the Calipers at the same time as squeezing the pistons fully inwards. Repeat this with the other pad. Note that there is normally only one piston to be compressed for the right front and likewise for the left front.
    17
    Remove the pads - Note how each brake pad is attached. They typically snap or clip in with attached metal clips. Remove both pads. They may take a little force to pop out, so take care not to damage the caliper or brake line while getting them out.
    18
    Put the new pads on - Spread the special anti seize lubricant that came with your pads, (if it's not provided you can get it at any auto store,) sparingly on the metal contact edges and on the back of the pads, the surface of any shims and the piston pad contact area. This will prevent a lot of annoying squeaking. Attach the new pads exactly the way the old ones were attached.
    19
    Check the brake fluid - Check your vehicle's brake fluid level and add some if necessary. Replace the brake fluid reservoir cap when finished.
    20
    Replace the caliper - Slide the caliper slowly back over the rotor, proceeding easily so as not to damage anything. Replace and tighten the bolts that hold the caliper in place.
    21
    Put the wheel back on - Slide the wheel back into place and hand tighten each of the lug nuts snug.
    22
    Lower the car - With one side of the car supported by the jack, remove the block or stand on that side and slowly release the jack and to lower the car. Repeat for the other side so that both wheels are back on the ground.
    23
    Tighten the lug nuts - Moving in a "star" pattern, tighten one lug nut, then one across from it until each nut is fully tightened to torque specification.
    24
    See technical info to find the torque spec for your vehicle. This will insure the lugs have been tightened enough to prevent the wheel coming off or over-tightening.
    25
    Start the vehicle - Making sure the vehicle is in neutral or park, pump
    edited May 2013
    Feels a bit like the abs now that you mention it. Got about 1,000 miles before warranty wears out. Will watch for a light next tome it happens.
  • choochoomanchoochooman Member Posts: 38
    2005 v6 camery 56,000 miles, toyota dealer saying rear brakes need relacing, showed me where there thickness was on a guage of thickness of new-worn pads at 8mm for front and 4mm for rear there guage was green 12-7 mm, yellow 6-4mm and red 3-0mm quated price of $265 for new pads, turning rotors, additional hardware for brakes is this a good price? i also have a $50. same as cash to use towards service from another toyota dealer and $20. off service coupon so i can get this done for arounf $200
    Seems fair to me. With 4mm you still have plenty of time to shop around if you wish, but it all sounds on the up and up to me.
