Timing belt replacement
When belts are changed, idler and tension pullies should always be checked or replaced. This is probably more important than changing water pumps. Water pumps last a very long time if the cooling system is well maintained.
Been there.
On the Water pump. On my Mazda as it reached the 120,000 mile checkup I not only spoke with my mechanic, but called the parts department of my local dealer. Both verified that most pumps didn't last long after 120,000 miles. My Subaru mechanic recommended waiting until 150-160 since they are generally more stable.
No free lunch if you don't do the maintenance, belt or chain or gears.
Now, if they ask, I'll be happy to tell them.
With the new CRVS and S-2000's I don't say..." Now, this model uses a timing chain...at some point it may wear and need to be replaced"
A buddy had a timing chain ship on his Pontiac once. I remember it bent some pushrods and something else had to be replaced. The teeth on the plastic timing gear had worn out causing the chain to slip. We had to pull the oil pan to clean out the broken plastic so it wouldn't plug the oil pump screen.
Another time I remember changing timing gears on an old 6 cyl Chevrolet. No chain, just a fiber timing gear that stripped out.
Any system can and will fail at some point.
Not a big deal!
1: purchase an Alldata DIY subscription at http://www.alldata.com/products/diy/index.html
2: buy a Haynes manual
3: check if your local library has the manual available
