Dodge Ram: Problems & Solutions
Any suggestions on the cause.
Have read a few posts about the mirrors snapping off and had the dealer tell me of a few also. And guess what? My passenger side mirror broke today! Just sitting in the vehicle, windows down, engine off and POP! The mirror is still on the vehicle, but it no longer has detents to hold it out straight. It just flops around! Can pull it up about 2 inches and the only thing holding it on is the wires to the defroster/mirror adjustment motor. Should have a new one in about a week. (national backorderd, 1,620 of them is what a dealer told me).
I have NEVER folded my mirrors since I got it and have not hit anything either.
Jack
Don't help any of us now, but hopefully this won't take too long! By the way to keep it from stalling in the interim they stand by using the A/C or defrost.
1. Check to see if the tires are inflated to specs. Bounce the front end.
2. Measure the distance from the ground to the center line of the lower control arm bolt front tip.
3. Measure the distance from the ground to the center line of the front spindle.
4. Subtract the first from the second and the difference should be 58mm(2.3in)
5. If the difference is greater than 61mm(2.4in) then tighten the torsion bar bolt until the spec is reached.
6. If the difference is less than 55mm(2.1in) then loosen the torsion bar bolt.
7. Always get to the right height by raising the bar if it is to high then lower it more than enough so you can raise it to the proper height. (Clockwise to raise)
So there is not really a measurement that is the ride height but it is the difference between two heights.
Hoe this helps!!
Tom
Yes, Chrysler has announced that the new hemi engine will replace the 360 motor in 2003, although the hemi introduction date will be just after the 2003 intro date.
Dusty
to the best of my knowledge dodge has said that the hemi will replace the 360 in the heavy duty trucks, but, has never said the hemi will replace the 360 in the 1500. however, with annual hemi production expected to exceed 440,000...and only a small portion of those expected to go into the heavies...there will be plenty for the 1500s...what is odd is that dodge has never publicly announced that the hemi will be available in the 1/2 ton when of course it will...very odd!!
Again, thanks a million!!
I know for a fact that Dodge has announced to fleet buyers that the hemi will be available in the 2003 RAM 1500 series, although it will be introduced "sometime" after the model introduction. One automotive news source says that it will be March of '03 when this occurs.
From a production perspective, it just doesn't make sense for Chrysler to continue the 360 motor while building the hemi. Industry reports indicate that they will be expanding the hemi series into as many as 5 variations of both horsepower and cubic inch displacements. The new hemi design is considerably more efficient and can develop more torque.
Dusty
This new generation of motors will have a number of versions as they will show up in the next generation of LH models codenamed LX (ie: 300M, Intrepid, Concorde - renamed the New Yorker). These cars will be available with the 3.5L V6, 4.7L V8 and in some instances the 5.7L HEMI (ie: the new 300M). These cars will be rear drive and will have some Mercedes parts incl. transmissions, stability aids, electronics...
As an aside: the old generation of Magnum engines (3.9L/5.2L/5.9L) will still be offered on the Dodge Ram Vans and Wagons until the vehicles are eliminated sometime next year; the old 3.9L V6 and 5.9L V8 will still be offered on the Dakota until it's redesign in a year or so.
Dealer's advice-watch the fluid for anything unusual and do the 30k mile service.
Dave Huber
WhereareyaHowareyaWhatchadoinNow?
See profile for email address...
Although a trip to Hawaii sounds nice...:-)
Dave Huber-Pendleton, Oregon
Thanks for the response.
Umm, oh yeah.. Got to watch those new Trucks for longevity. Must have a preference for those WaterCooler Meeting conversations... ;-)
Paul
is your truck the 5.9l gas engine? if so, all i can say is that every 360 cube equipped ram (including one i leased in 97-98) i've been in or ridden in idles roughly. seems to be the nature of the beast...
Here is all I have noticed since March:
-Condensation inside the left taillight assembly
-Exterior mirrors vibrate
-A weird buzz when I put her in reverse. It always goes backward so I assume the buzz is just a cool sound affect.
This is still the best vehicle I have ever owned. Solid and dependable for me. I'll bet there are many more of you out there with many more good things to say than bad.
Good luck to all of you who are having problems. Keep us posted in case it happens to those of us who have none.
Any help would really be appreciated.
My mechanic did that to my 87 Caravan. He said that that light didn't really let you know when there was a problem but they seemed to come on after 60K miles.
Don't Know if those lights are indicators or not but the codes will still be set for problems.
Dave
Chris
Good luck,
Dusty
adjusting the torsion bars won't hurt anything. there is nothing wrong with your truck. i almost always have mine adjusted on the driver's side because that is where i sit and also the side where the gas tank is...and therefore after short time that side tends to sag a bit compared to the passenger side.
Good luck,
Dusty
I have an 02 reg cab LWB 4x4, 4.7 auto. I first noticed the problem with less than 200 miles on the truck. I now have approx 1100. When going around curves and hitting a bump the back end wants to pass the front end! Took it to 2 dealers and the solutions are 1. It's normal, but if you put a camper shell on it goes away! That came from the STAR(?) guy in Detroit who has the same truck and problem. 2. Tire pressure too low, bump up to 50 psi (Tires are 275/17s)3. Tire pressure is too high, drop to 35 psi.
Higher pressure is better but not by much, haven't bought a camper shell yet!
The service manager at Metro Chrystler has been very good about this. He agrees the ride stinks but the big boys in Detroit say this is normal, is it? He thinks there might be a shock mis-match, has anyone put on after market shocks to solve this?
Any input would be welcome. I haven't made a payment yet and I don't know if I should keep the truck or not.
the truck has the 5.9, towing package, extended cab and 6ft box. It also seems to have a dealer installed lift. 98000 km on it.
I'm not saying that it is right or wrong, but merely what my experience with it has been.
Steve
It really only happens to me on a sharp turn, where there also happens to be a bump in the road, on a particular off ramp I take frequently. I learned, don't try to correct, just keep the steering wheel as if nothing happened, and you ll head straight down the road, no problem at all.
The rack & pinion steering along with the 20inch wheels makes for a VERY NICE handling truck, especially for a 4x4 that sits up higher than any other stock pickup
Last week my truck developed an upper engine thump and after a little troubleshooting I found a 1" section of the belt had peeled, I looked in my maintenance records in the back of the owners manual and it did not say to inspect and replace the belt until 60,000 miles so out of curiosity I called the service department today and they said that under the 3year 36,000 mile warranty they will replace it tomorrow for free. If nothing else it saves me 50 bucks and the hassle of wrestling a new belt on.
By the way, I am also feeling the same scary wheel hop and the terrible MPG that everyone else seems to be discussing!
Anyway, just a suggestion. I've had no problems with my 02 QC 1500 brakes warping and am at 13,000 miles (but only have 17 inch wheels)
Steve
Anyone out there had any of these problems. for those thinking of buying a new Ram I don't suggest getting the new RAM, My ram dousent even have 6000 miles and it's already falling apart.
so, i don't think you can blame wheel hop on dodge having the stiffest rear springs!!
(V6 models)
Dodge RAM 1500 LWB - Payload 1,850; GVW 6550=4550
Chevy Silverado LWB - Payload 2,189; GVW 6400=4211
Dusty
