Dodge Ram: Problems & Solutions
is anyone here able to compare the new heavies to the half ton on ride...wheel hop, etc?
I saw on another site someone has changed shocks and gone softer and harder with no change in ride quality. I'm beginning to think there is no cure outside of a design change from Dodge and I think slick1ru2 is right, someone is going to have to die first, any volunteers!?!?
Richieb may be on to something with the stiff springs but I wonder if a shock could cure that by having less resistence on rebound, i.e. extending. Wouldn't that allow the spring to return to it's relaxed position faster and keep the wheel on the road?
Lets keep chewing on this and maybe we'll come up with a cure.
Made a world of difference.
Did you install yourself
What model do you have
http://www.dodgetrucksteeringproblems.com/mb/topic.asp?TOPIC_ID=78
Ride related link.
based on what you said, i'd really be guessing, but what the hey! have they checked your torque converter? if it generally happens around 40-45 mph, that is when the torque converter clutch tries to lock up. sounds like it is having problems locking up...just a guesss.
On your vintage RAM can you defeature (switch off) the overdrive? In some systems when the OD is switched off the torque converter solenoid is not energized and the converter will not go into lock mode. This might be a way of determining whether its related to the torque converter lock-up or not.
Good luck,
Dusty
mike, you might have em fully drain and flush your tranny (including the torque converter). alot of times this will "fix" tranny issues that might not be major.
Have you ever had your transmission serviced (filter change or fluid flush) since you've owned the vehicle? Was it recently?
I've been told that one of the problems that using something other than ATF+4 is torque converter shudder. Now, I think your problem sounds a little more serious, but it might be worth looking into. I know of one person who successfully sued a local 'quick lube' establishment for using Mercon in their Chrysler vehicle.
Draining and flushing might be a worthy suggestion. Your vintage RAM should have what is called a "drainback" valve installed in the return line from the transmission cooler. This prevents fluid from siphoning out of the torque converter after engine shutdown. These are notorious for either failing partially or fully closed. They also cause fluid to freeze under certain conditions, shutting off the flow of fluid to the transmission. Contaminated fluid will easily clog these valves.
The recommendation is to replace or (unofficially) completely remove this valve. If you remove it, you must allow the transmission to warm up a bit in very cold weather before attempting drive away.
Best regards,
Dusty
atf+4 didn't come out until around '00. is chrysler now "back" recommending that folks use atf+4 instead of 7176 type 2 and atf+3??
I had downloaded the Dodge truck TSB but I can't find the darn thing at the moment.
Dusty
i did some looking around...and it appears the only chrysler vehicles that are not supposed to use the atf+4 are '99 and older minivans. it appears then that atf+4 can be used in place of atf+2 and atf+3 which were the standards prior to model year '00...
Dusty
http://dodgeram.info/tsb/2002/18-030-02.htm
Lets hope that this fixes the idle problem with no loss of power like the death flash of the past!!
Dusty
I think we have a couple of problems here, vibration at speed and wheel hop after hitting a bump. I'm not out of control like Sailboat but I have a lot of hop after hitting bumps. I've seen this on other sites and no one has an answer. I've seen suggestions to raise the front end by cranking up the torsion bars, change shocks to a firmer ride, to a softer ride and tough it out! Feels to me like there's too much flex in the suspension somewhere, maybe the shocks are not right but maybe the frame is twisting. I don't know what it is I just don't think it's right.
I've ridden in older Dodges and not felt the same hop. On the other hand I rode in a '03 Chevy and flat did not like the way that handled and the ride wasn't that great either but there was no wheel hop.
I think the only way this will be solved is at the HQ level. I know Dodge is aware of the problem because I registered a complaint with STAR and the operator had the same truck and problem! I urge all of you to register with STAR so our numbers will get them off their butts. Don't let this die! Start threatening lemon law settlements, keep after the dealers. (Anyone have Ralph Nader's phone number?) Sooner or later someone will catch on and solve the problem.
In the mean time if you try something let us know, whether it works or not.
Just a recommendation. I don't think Dodge dealers are a whole lot better, but with any problem or any dealer I'd give them an honest chance before I brought the hammer down. One you start the threats you begin an alienation process that could be counterproductive for you.
The RAM is an all new platform this year and this problem might be a surprise to everyone, especially the dealers service personnel. I spoke with my service manager today and he said they've sold over 200 RAMs (2002 & 2003s) and so far he hasn't had one complaint of this nature. And I haven't talked to anyone that's complained about it either. In fact, the now more than a dozen RAM owners I've talked to have nothing but praise for the handling and the ride combination.
It sounds to me that this is not a problem that shows up on every RAM, much less every RAM Quad. If that's the case it might take some time to find a cure.
Best regards,
Dusty
My wife's RAMQC has the same problem especially going around a bend and hitting a bump
Feels like the truck is going to fly across the lane
Even more so while going 65 around a bend on the PA TPK I had one hand on the wheel and was reaching across for a tape ( road was clear )
an the truck hit the rumble groves they have on the side to alert you that you are on the shoulder and the whole truck felt like it was going [non-permissible content removed] over front and was going to shift lanes
Scared the hell out of me and my wife
I tried to duplicate it further on down the road ( again very clear highway ) but didn't
bar(s) since I think the 1500 has a tendency to "wallow" a bit too much on bumps anyway. Hope this helps. Otherwise it's a marvelous, roomy, very useful and fairly economical vehicle. While the 4.7 may be small, it does afford decent hiway mileage (3:55's). I just drove 2,000+ freeway miles at 70-75 and averaged 19.4mpg.......not too bad for a 5,000 lb behemoth. Around town I pay the price......best I do is 15.1-15.3mpg. Towing 4,200# is another matter with 9.6-10 the best I can do.
I have had my truck about 3 months and found a problem with the paint on the end of the rear door on my QuadCab. I'm not sure if the paint came off, or what happened. Maybe it was bad from the factory, but I have tried some cleaners and it won't go back to black.
Here is a picture
http://www.investmentforum.net/images/paint.jpg
The picture is off the front of the rear door, and rear of the front door. You can see the fading of color on the rear door.
Will the dealer fix this problem for free?
My truck went dead four different times while sitting at stop signs or traffic lights and the dealership new nothing about this TSB. I did a little research on the Internet and found the cure for the problem so I hope this helps anyone else having this problem.
http://www.ford-trucks.com/dcforum/DCForumID93/2279.html
While I no longer have a vibration at 35-40 mph, on a less then smooth road I still have some vibration after one bad tire was replaced. I wonder if anyone here is having the problem with the 20" upgraded tires?
I obtained a replacement Thursday from Goodyear and guess what? I now have a jittery ride!
Dusty
3 days while washing it I noticed what looked like a long rust spot on the roof. I took the truck back to the dealer and
found out that this was where the primer coat was showing through the paint. They repainted the roof and gave me a lifetime warranty on the repair. I'm pleased to report that this was covered under warranty and to look at the roof you would never know that it was repainted. Hope this helps.
My dad has an '01 Ram 1500 SLT, regular cab, LWB, 2WD that he bought new in March 2001--ordered it, actually. It has the 318 engine with the automatic tranny. He's having a problem with transmission fluid leakage; it isn't much, just a couple of drops per day on the driveway, but that's a couple of drops too many for a nearly new vehicle.
This truck has not seen any sort of severe useage; in fact, it has way under 10,000 miles, and its heaviest task has been hauling a riding lawn mower on occasion--its primary job is around-town transportation. The dealer has attempted to repair the leak more than once without success.
I believe that the transmission pan has been removed & the gasket replaced; I'm not positive, though. (I don't live in the same town where the truck resides, so I don't have immediate access to it.) Has anyone experienced a similar problem with this model/powertrain and, if so, what was the resolution? The dealership owners are family friends, and they've really tried to get this leak fixed, but my dad is getting frustrated. I've checked TSBs and haven't found anything that appears to address such a problem for the '01 Ram.
I'd appreciate any ideas or suggestions, particularly regarding the location of other 'net sites that specialize in Dodge/Chryco problem-solving if anyone knows of such resources.
Last night my 2002 Dodge Ram SLT 4X4 Sport lost all power to the dash board - no gauges, no interior lights, no turn signals/wipers etc.....
My headlights would come on but only with the ignition switch, the headlight switch had no affect on the headlights at all. The only light that stayed on in the dash was the little red security light. Any answers for what this problem might be?
good luck!
Not sure about the loss of power to the instrument and dash, but this could be a fuse or circuit breaker, also.
Good luck,
Dusty
Recently fixed first problem with my '02 Quad cab 4X4. Rear U-joint went out at just over 45k miles. First symptom was a slight vibration that I thought was due to mud on the inside of the rims. Knew it was a u joint when it would disappear when I took my foot off of the accelerator.
Also, had a '79 LTD company car that did the same thing.
Good suggestion.
Dusty
club cab, Ext.cab, Quad cab,Laramie,sport and so on?
Also which type you would suggest for someone
that stands 6 feet 7 in. Tall.?
This has been my only problem since I bought the truck almost exactly one year ago and so far I've got 22,000 miles on it.
Tom
