Dodge Ram: Problems & Solutions
When I am sitting at idle I hear a ticking noise similar to a lifter tapping. I have taken it to the dealer to be checked out and the explanation given to me is Dodge uses an oil filter with a valve that keeps the oil from draining out of the top end when shut off. Has anyone else heard of this? Also has anyone else had this problem. Any help would be appreciated.
as for the tick...it might not necessarily be a valve. many things under the hood or even in the cab can make a ticking noise. i've noticed that some fuel injectors make a slight tapping noise...especially when cold. even heard an interior fan make that kinda noise. anyway you've got lots of warranty left if indeed a valve is the culprit...
Design flaw I suppose.
______________________________________
2002 Ram QC 4x4 Sport
20inch wheels
Black Exterior
Dark Slate Gray Interior
This is the first I've heard of any engine noise on a 4.7, especially valve train. Lifter clatter on start up can be caused by a drainback valve in the oil filter sticking or leaking, low oil pressure, wrong viscosity oil for the ambient temperature, or some engine defect that allows oil to drain down or a defective valve lifter, among other things. But I think you are indicating that this noise is present most of the time, so oil filter drainback valve isn't the problem in that scenario.
Make a pest of yourself until its resolved!
Good luck,
Dusty
Also I asked them to check the tire hop and they gave the old standby line " checks OK at this time".
One last thing - radio clock was running fast. They replaced the radio but this seems to be a known problem also.
Should I just put a gear clamp on it and be done with it?
Any other ideas, other than the cap?
Good luck,
Dusty
it just broke down with what seems to be a clogged converter, I had the same problem in Jan 02, had a new thermostat, O2 sensor, and temp sensor installed along with a new converter, sinse then the truck has run about 3000 miles. It dispays a sudden loss of power under load then stalls, will not restart until allowed to sit for 15-20 min, it will then run for 15min. If allowed to sit for several days the problem will not occur until being driven over 90 min. Anybody got any ideas?
Well, it sounds like you know what the problem is, but not the cause. The most common cause for premature catalytic converter failure is an engine that is running too rich. There could be a number of reasons for this, including a faulty computer or problems with your injectors.
Good luck,
Dusty
Kelly
Otherwise, I've enjoyed the truck and it rides very nice and performs well. Good value for the money of all the trucks I looked at. I was surprised however, to see that I have a Mexican truck! I've been taking some Spanish lessons to better communicate with her!
Also, I was wondering if anyone had a problem with the power door locks? When I push the power door lock button it only unlocks the front doors. You then have to reach in and pull the back door locks up so you can open it from the outside.
In spite of my troubles, and there are a couple others which I will put in another posting, I really do like my truck. It is a very comfortable ride. I have had it since Feb. 2002 and already have 17000+ miles on it. Anyway, I would appreciate any replies to this posting.
Steve
Let me know what part they had to order to fix the rack.
tom
Ramforceone, thanks for the link. I went right to the part that is needed for fixing the door lock. That is a great website. I made sure to bookmark it for future reference. When I called the dealer, I gave him the part#. He put me on hold a when he came back to the phone he said that was the correct part.
I also told the dealer that the first thing in the morning, after I have let it warm up, I pull away and get up to about 40-45 mph. As I come to a stop sign to take a right turn, I feel a very hard downshift at about 10-15 mph. Sounds like "THUNK". After that I don't hear it any more. I read about this problem on another posting, but I can't remember who wrote it. Sorry.
One more thing, does anybody think the power windows are too slow? Mine seem to take forever. You know how you touch the drivers window switch and it goes down by itself? Most of the time mine will only go 3/4 of the way down and I have to hold the switch to put it all the way down. At that point I hear a grinding noise. Hopefully the dealer can take care of all of this in my next visit.
Once again, thanks peppe1 and ramforceone for your input. If you or anybody else reading this knows about the other problems I mentioned, I would appreciate some more help.
Steve
The engine in my 98 Dodge Ram needs to be replaced at 60,000 miles (about $3000) - the repair shop said these engines had problems with a small oil intake (or something similar) causing the engine to not get enough oil, but if you check the oil, it shows in the safe zone. - anyone else had that happen.
The oil comment drew a blank. Not enough information. The only thing I could think of was a problem with intake gaskets while ago. That would cause oil loss or burning. But nothing related to inadequate oiling, at least in stock form.
Dusty
While headgasket failure on the 360 isn't that common, anything is possible.
Most of the engine failures I have seen involved valvetrain failures from an exhaust leak or cracked manifold.
I've owned several brands of new cars before, including many Toyotas, but have yet to have a vehicle that I would proclaim perfect, except for my 03 Ram 1500!
I have only one minor problem with the truck - the heater fan now makes a low drone sound when it's on speed 3 or 4. On speed 2, it makes a rapid clicking sound. The sound isn't loud, but it is a bit annoying. Any thoughts about what's happening with the fan.
Exhaust leaks can pull cool air into the valve area on deceleration.
Add cold air to hot metal and it can snap the valve head.
Fairly common on motor homes. Not sure why, but have seen seven 360/318 engines in motor homes with cracked exhaust manifolds and the exhaust valve had snapped off and been driven clean thru the piston.
Also, being from Chicago, the truck is in the midst of it's first salty winter. I have noticed small (pin head) sized spots of what appear to be surface rust develop. There aren't a lot of them and I can easily remove them with my finger nail after a good washing and waxing/polish, but I find it odd that these develop since I have never found this on any of the other vehicles I have owned. Has anyone experience this? Maybe they are just more easily discovered on the bright silver, most of my other vehicles have been black or graphite.
Does everyone else have this problem, and if so what type of shocks have you replaced the original with?
Thanks for the info,
Jim
February 27th I took it back in because I thought I would beat the heat. After a day in the service dept. they told me they could not diagnose the problem and it was working when I left. My skepticism rose. "Bring it back in if it happens again" they said. I tried it today, it was 55 degrees out. NOTHIN'! I called and they said bring it back in. I'm sorry but four trips to the dealer for one problem is ridiculous for a truck with more computers than the Apollo spacecraft. Does anybody have any suggestions before May when the heat really hits? I can only be patient for so long!
Bernie
You might try slowing or speeding up a bit to reduce the oscillation reinforcing effect of the regularly spaced and high joints in the concrete. The only other solutions I can think of are lower tire pressure, softer springs or different tires, all of which have significant drawbacks. Fortunately, newer concrete highway construction methods eliminate most of the joints and are much smoother.
Incidentally, you have good taste! The ‘03s look great and from all that I’ve heard, uphold Dodge’s growing reputation of building reliable trucks. If I weren’t so totally satisfied with my ‘01 2500 Cummins RAM, I’d be driving an ‘03 too.
Good luck
