Unfortunately, I consider this a DRIVER defect, not a car defect. My wife never has a problem, and I have scaped the bottom of our Acord in a similar fashion.
Service Cost (SC) defined as the estimated 5 year cost of maintenance and unscheduled repairs, based on past costs from "IntelliChoice"
The higest SC is for the Dodge Grand Caravan at $4347. Toyota Sienna CE 5dr is the next to lowest at $2302.
I don't see how it is driver error. The reason for parking stops is so you stop your car on them with a front tire. That way you know you have pulled forward as far as you can go. That is the safest place to be. They are not to prevent you from running into the car in front of you or as a final emergency stop. Some parking lots don't have them. If you will look at a parking lot with parking stops, you will see that is how most drivers use them. Some just touch the parking stop with a front tire and then back off slightly.
So yes, the fact that the Odyssey stops the car with some other part of the car on the parking stop, other then a front tire, is a design error in the car, not the driver. It is a design error that causes damage to the car and it can get serious. So lets call a design error a design error and a driver error a driver error.
I would bet that if the Odyssey is used in a fleet of cars at companies, or for rental, they would be putting out quite a bit of money because of this problem.
That said, using the fool me once but not twice principal, after it happens to you once or even 2 or 3 times you can adjust for it. So I am guessing it will probably not happen again to me. I may end up further back however, sometimes, then is the safest position.
The top feature safety, was assigned as VI. The folding down back seat was also very important to me as I often don't need the back seat and don't want to have to store it and have two people take it in and out. Cost of ownership was another. It was those three things that mostly did it over the others.
There were some minivans that were quiter but not by much and it was not significant at all. The Windstar was rated a better ride but I liked the Odyssey ride better.
So it turned out no contest. I did not care at all which looked the best, as minivans are not expected to look sporty. I was certainly willing to wait for the long time to get one, because a car is a long term investment.
Of all the things I can think of, where another minivan might have an edge that is significant, is some other minivans had seats that were a bit more comfortable and had a fancier interior. I don't see how those things can outweigh all the other positives of the Odyssey. But then the 2002 Odyssey design has overcome even those minimal disadvantages.
I don't think a person can come up with a rational reason for owning any other minivan then an Odyssey. I remember one person I meet, who was in his twenties in 1945 and served in WWII, who would never buy a Japanese car because of what they did to us at Pearl Harbor, but that is a very personal reason and he is certainly entitle to it. Perhaps I will never buy a car made in Afganistan. I have also heard that their quality control is not very good.
Steve
SUVs, Vans and Accessories Message Boards
First of all it is obvious that you are just trying to win the argument against dmathews and are not really interested if the Odyssey is the best minivan or not. Most of us have been around long enough and have seen that so often that we can easily spot it. So your post contains no useful information.
Most of us could care less if you win or lose and I don't see why you should care about such a silly thing either. Your life will not change one bit one way or the other. For all I know dmathews may not even be a person. It may be the A.I. computer that IBM used to beat the worlds human chess champion or one of their much improved models.
The fact is that most Odysseys are not experancing transmission problems. When one does it receives an upgraded designed transmission under the warranty, which then does not have the problem. Consumers Reports follows these issues very closely and has not found that problem. Also note you are talking about a 1999 Odyssey and the 2002 Odysseys are what is now being sold
If you have found a real design problem with the Odyssey lets hear it. Don't make one up. I think I found one with my parking stop problem, but I also came up with a solution. Don't park your Odyssey up against the parking stop and you will not have the problem.
Looks like you guys in the southest will get Alabama built ones very soon. Only 50 built to date but not for sale. Watch for that learning curve. ie Canadian Odyssey better assembly at first.
INKY
I posted this info in the interest of full disclosure. Buyers should know that while Honda is typically reliable, they are not infallable, and clearly they really screwed up with the '99 Odyssey transmission (the wait list for a new one was 300+ deep). In addition to the Odyssey, I have a 12-year-old Accord that's never had a problem, and a 2-month-old Acura TL that's been in for service twice to replace a shim and a hose. So perhaps the best advice I've seen on this board is to inspect upon delivery!
For what it's worth, I would buy an Odyssey again. The 2002 has been improved over what was already the best van in the business. However, based on my experience buying the first production run from Canada, I would try to wait a year for the Alabama bugs to be worked out.
The Odyssey transmissions receive the best reliability rating (full red circle) for '95, '96, '97, '00 and '01. Odyssey gets the second best rating (half red) for '99, and an average rating for '98. Meanwhile, the Daimler vans (twin vehicles are grouped for reliability) received the best transmission reliability rating for '01 also. For '97, '98, '99 and '00 they received the third-best or average rating, and for '94, '95 and '96 they received the worst rating (full black circle).
Overall, The Odyssey gets a "Red Check" for well above average reliability for '95, '96, '97, '98 and '01. It received a "Black Check" for average or better in '99 and '00. Meanwhile, the DC vans received the "Black Check" for '98, '99, '00, and '01. All previous years were below average overall.
Keep in mind that the average problem rate in Consumer Reports is only 0.2 problems per vehicle in the first 12 months. At that rate, a vehicle well below average would take years to have even ONE more problem than one well above average.
I think that both the Odyssey and the current DC vans are excellent vans that have a lot to offer. I personally am planning on purchasing a used 2001 DC van in the near future. I like the Oddysey but I plan on taking advantage of the lower resale on the DC vans which will save me $8000 or more over purchasing a used Oddysey. I will use part of that difference to buy an extended warranty. My current vehicle is a Chrysler product and has served me very well for 7 years and I hope that the van will serve me as well.
Also, if you aren't already aware of it, 2001 MY DC vans made after July 6, 2001 have the revised fuel pump mounting flange. The IIHS claims earlier vans have an issue with potential fuel leaks from this part in a crash.
Enjoy the new van. With a 2001, you may not even need consider the extended warranty:-)
I emailed my wife (who's been begging for an Ody for months--but I have finally talked her into waiting) to tell her that supply is about to meet demand.
Is the Alabama plant up and running.
The trucking company is most likely out of Brimingham and was carting vehicles from the rail depot to the dealer or storage lots.
Steve
http://www.caa.ca/CAAInternet/automotive&consumerservices/frames1.htm
Steve
it is not fair to compare a Honda van with a Hyundai sedan.
Ody's reliability ranks #4 only behind Sienna, MPV, and
Quest/Village among vans. Furthermore, most Ody owners
purchased extended warranty. 2003 Sienna will be a killer.
It will combine Ody's room and features with Toyota reliability.
built at this new plant.
2): At Canada, the maximum capacity of that plant
is 140,000 vehicles. Now it builds 110,000 Van
and 30,000 Acura MDX. The new plant will finally
build 180,000 Odyssey. And the Canada plant
will build 60,000 Acura MDX and 80,000 Honda MDX.
3): Personally, from long term reliability point,
Nissan (and Toyato too) is better than Honda.
A lot of 90-92 year Honda cars have more problems than Nissan (and Toyato too). CR only have 8 year
records, and Honda has better marketing too.
So most guys thought that Honda has better than Nissan.
thanks for suggestions.
I use an ear-nub headset pretty much all the time while driving. Although not as comfortable as a true hand free with speaker and microphone, it works great as a reasonable cost (appx $30) hands free solution.
I got the setup from canyonriver.com - a distributor in Texas.
I just made my decision between the Chrysler Town and Country (any model) and the Odyssey LX; the Odyssey won. I own a '91 Plymouth Grand Voyager, and have had a fair amount of trouble with it over the years. But this is an Odyssey board, so I won't detail the problems. Rather, I would like to emphasize my reasons for picking the Honda. It's just more van for the money, even with the huge discounts DC is offering. Bigger engine, equal gas mileage, 5 speed automatic from a company with a better reputation for product reliablilty and customer service when something does go wrong, excellent dealer service department near my office. I also have a '98 Accord, and had a '94 (wrecked) and a '96 (stolen), and when I did have trouble with the '94, Honda made it right without any hassle at all. The '96 Accord LX was stolen when it had 36,000 miles on it, so I had to take what the insurance company gave me for it; their payoff plus $500 bought me a brand new Accord LX! So resale value is another big plus in the Ody's favor. Don't say it doesn't matter to you. If your car is totalled or stolen, you will care a lot about resale value!
http://www.caa.ca/CAAInternet/automotive&consumerservices/frd_2000/frd007.htm
Nither van looks particularly good to me. Odyssey did weigh in with lower repiar costs, better vehicle, sales and service satisfaction, and a higher repeat purchase percentage, for what its worth.
* Every major automotive magazine has the Honda rated as their best minivan. Honda beats out every alternative in comparison tests, road tests and value tests. (Car & Driver, MotorTrend, Road & Track, Popular Mechanics etc....)
* Every Consumer group rates the Honda the best overall minivan (Consumer Reports, Consumer Digest, and Yes EDMUNDS)
* Every user rating service rates the Honda the best (Epinions)
And lastly while Chrysler dealers have to resort to every gimmick and rebate and markdown to get rid of their vehicles and Honda get produce them fast enough to accomodate user demand is a testament to which is the better van.
Honda is the best minivan currently hands down. And it meets the needs of the majority of minivan shoppers better than any other van on the market.
BTW, I have said before that I think that both of these vans are very capable machines and if I were choosing a brand new van I would definitely consider the Oddysey. I will personally be purchasing a DC van because I can take advantage of the huge depreciation caused by the larger production volumes and perceived reliability to save a lot of money on a slightly used van.
I guess that I just don't quite uderstand why both boards seem to have so many posters who are obsessed with proving that their vehicle is the best. When it comes down to it, purchasing a vehicle is a subjective process. You pick the one that meets your particular needs and budget at the time. Should one's needs or budget change, their decision could very well change also.
Maybe you'll enjoy this article: Why Buy New?
Steve
BTW, has anyone ever had their Odyssey catch on fire?
http://www.consumeraffairs.com/automotive/honda_fire.html
Well you have given me some hope. If my Odyssey burns up it will give me a good reason to buy a 2002 model. Other wise I would not be able to justify the added cost to my self.
By the way thanks to the ETH spelling checker, I got the word liar spelled correctly. I couldn't find it even in a very big dictionary.
lie, lied, lying, liar. Now where does the a come from?
No. No fuel leaks from a cracked fuel pump mounting flange, either ( http://www.consumeraffairs.com/news/caravan.html ). So, given the possibility of fires on these or any vehicle, do you have any data to show exactly what the odds are of having such failures?
I would characterize one aspect of a troll as someone who continually throws up distractions in an effort to annoy or anger readers, rather than someone interested in an open debate on the relevant subjects. If you are indeed interested in debating an issue, how about a reasonable response to my previous questions regarding your last post?
Your courtesy in this matter is greatly appreciated. Incidentally, Carleton1 hasn't bothered to respond in the debate from his last post, either.
We have a Forester and a Miata, so I'm trying to convince the wife to get a van as our 3rd car, since she wouldn't have to drive it daily, unless she chooses to, of course.
Any how, we started by looking at a Kia Sedona. Oddly enough, this was because Kia offers a free Shrek video to anyone going in for a test drive! This was enough to lure my wife in for a look at minivans. It was actually nicer than you would expect, but the cumbersome 3rd seat and lumpy driver's seat ruled it out. The wife also found it big (uh-oh, Odyssey is big too).
So we headed for the Honda dealer, which had only a demo, none on the lot. Up front they said a 3 month wait with a $500 deposit was required, and don't even think about dealing.
Well, welcome to you, too, sir. We looked at one and like the space, the seats were comfy. No moonroof, though? Is that coming any time soon? Aftermarket or no? Also, there is traction control, but is stability control offered, or will it be?
So, my question is, are any dealers in the DC/MD/VA area discounting at all? How is availability in general, now that the 2nd plant is supposedly up and running?
I'd like to look at an EX w/leather, most likely. If I'm going to talk her into a van, it's going to be a nice one. I'm such a fan of the folding 3rd seat that the only other van I'd likely get is the MPV, and only once the 3.0l V6 arrives. I know it's smaller but she prefers small vehicles.
Advice/thoughts appreciated.
-juice
I have to admit an Odyssey at sticker is a better deal than a lot of other vans at a discount.
And get this, "lay" is the past tense of "lie" (to recline) whereas "lied" is the past tense of "lie" (to falsify). Past tense of "lay" is "laid."
Did we mention that our Editor's Most Wanted Awards may be of interest to Ody owners and potential owners? Did I lied, er lie?
Steve
