Visitor Agreement.
-juice
The battery is $80, so no big deal.
The '94s are a good model year. They have the bigger, 1.8l engine for extra torque, but they were before the on board diagnostic baby-sitter came into play. I think it was also the last year with a working oil pressure gauge. To a lot of folks, it's the most sought after year.
Try to bargain him down $500 or so. Check for rust, accident damage, peeling paint, and then see if it operates smoothly. If so, go for it.
-juice
bring the vehicle to a GOOD mechanic. have them do a full inspection. shouldn't be more than 1.0 or 1.5 hours of shop labor. a good investment. take the thing out and drive it. make sure that you will be comfortable in it!!!! drive it for a couple of hours, it's a small car with vey little trunk.
as to value. the hardtop is worth $700 to $800. so consider that. the miles are pretty high, as compared to the average '94 miata, not the average '94 automobile. you don't mention the equipment on it. is it a base, a package, b package??? what's it got for options? i would guess the fair value, given that we are getting the Spring time, is probably in the $6,500 range, if the mechanicals check out and it at least has a radio and a/c.
the tires are going to set you back $300 to $400 so count on that, and the battery from westco is $79. be sure to check the condition of the softop. it is being covered over by the hardtop. remove the hardtop and raise and lower the convertible. this is important, b/c the softop is a big expense if it needs replacement!!!!
biggest thing in my opinion is checking for accident repair. miata's are VERY sensitive to alignment/chassis problems. if the frame isn't perfect, the ride will suffer big time!
oh yea, go to miata.net for everything you could want or need.
good luck, it is a great little car.
ace
We bought a used red '94 (back in '99). It had 100k on it - very high mileage - but it was in superb condition. And, we got it for $5k, which made the high mileage seem less significant. We did have a mechanic check it out, & it passed with flying colors. So far, we haven't had problems with it, and it is still going strong. We expect it to last a long time.
If your red Miata is in good condition and the mechanic checks it out "OK", then I wouldn't be afraid of the mileage. I would try to get it for less, though, as the price is a little high.
Check out our Miata here to learn all about it:
http://convertiblencats.homestead.com
www.miata.net
http://www.miata.net/faq/faq3.html#Z
The 93s and earlier have only one airbag, but the above link shows how to disable them anyway.
-juice
Have my eye on 1996 with 5900 miles, repeat 5900 miles. The guy uses it for 4 months when visiting Florida. Detect some vibration in third and i am also worried about the car being in storage for long periods. Can buy for $10,000, any input appreciated.
Give is a close look-see. I'd run a compression test on the cylinders, looking for no more than 10% variation.
I wonder if the long term storage could harm the piston rings' seal.
-juice
The big concern about longer-term storage is "was it done correctly each time?" Check out www.miata.net for a complete list of what should have been done.
5900 is extremely low miles. You need to be more specific about the vibration. Was it speed dependent or rpm? Are you sure that it was only in third gear? Miatas are very prone to vibration, but generally not originating from the drivetrain. Are the tires original? If so, they could have been damaged from the storage. The sidewalls can harden-up. It is best to store the vehicle on jackstands. Most of the vibration in miatas is attributed to the tires/wheels.
ace
as to a base '96 for $10K... that might be a little high. my opinion, is that there are tons of low and very low mileage miatas out there. i think that the used car calculators add too much value for low miles for a car like these. yea, it's nice to have a pristine auto, but the lack of use can have it's drawbacks. the tires must be bad by now. either dryrotted or hardened sidewalls. possible corrosion inside the engine. battery has to be questionable. if it has been replaced be sure that it is not a "wet-cel" type. a '96 with 6K miles isn't going to be any less likely to have problems that a '96 with 25K miles. they are both out of warranty and the one with 25K has a least some time to get the "bugs" shaken out of it.
i don't know, sounds like low $9's is more like it, if the mechanicals check out.
ace
Chuck
My wife and I drove it and we both were surprised at how clean it was. It will be our third car( fun car), we both have trucks, wife a SUV and myself a truck. So we're both thrilled!!
I didn't have a mechanic look at it, Saturday afternoon, I hope I won't regret this move. I have never purchased a used car this old and with this many miles! I've had a total of 6 cars all new, except for 2 and they both were 2 yr. old with less than 23K miles. But, hopefully it will run as good as it looks.
See Ya!!
See Ya...again!
Good luck,
Stuart
What services were already done? At 96k, all the routine maintenance should have been done by now - so if there are not receipts or some other proof, I'd do a full service so that you have a baseline.
Do a 60k or 90k service (oil and filter, fuel filter, 02 sensor, PCV valve, diffy oil, trans oil, air filter, alignment, rotate tires, spark plug and plug wires, etc) and you won't regret it.
Gregory: I doubt high octane could ever harm your engine, but that really seems like overkill. 87 octane is recommended, so 93 octane is more than enough, even for autocross.
-juice
Edit: PS I'd do the timing and accessory belts, and at least inspect the cooling system hoses, plus flush the coolant
If I buy the car as a toy, I'm going to look for an older one ('90 - '95) to keep the price low. Any years better than others?
I'm also thinking about buying a new one and using it as my primary car. We still have a van and a Buick Skylark at home. I drive about 20,000 miles a year, most of it commuting (about 25 miles ea. way). I'm in the Chicago area so I'll have to deal with winter cold, snow and ice.
Am I nuts to have one as my main car or should I just get one as a toy?
- Jim
1st go here and choose the year:
http://www.geocities.com/MotorCity/5361/
This is good too:
http://miata.net/faq/usedmx5.html/
And of course the all important FAQs:
As far as the winter driving is concerned, shoot, don't ask me, I think Georgia gets too cold.
I also came from motorcycles, though a while ago, and you'll still find the Miata quite fun.
'90-'93 have the 1.6l engine and one air bag, but they are light and fuel efficient. '94 got the 1.8l engine with the 2nd air bag, bigger brakes, and some extra chassis bracing. '99 got the new headlights.
I actually didn't want a 2nd air bag, so kids could ride up front, so '93 was the year for me. I think the air bag disable switch appeared in '99, though the others can be converted.
It's a good time to buy. The cold weather has brought values down, at least near me. Shop around since they are plentiful.
-juice
Which one fits your personality? Did you like the ride/handling with the bigger wheels? Could you feel the extra power? Do you want the 6 speed?
Ignore the dollar amounts and pick the one that spoke to you.
-juice
They don't have as much space as an Expedition but you can fit two standard airline carry-on bags in the trunk, plenty for a weekend trip.
IMO, you have to be in that mindset. This car is about fun, not practicality. If you can get past the relatively stiff ride, road noise, and cold, then great. It's for you. But don't overlook those, otherwise you'll be back in 6 months with a for sale sign.
If it's a 3rd car, you'll never even have to consider that fate!
-juice
What is cold about the Miata? It has a great heater, effective thermostat, and warms up quickly.
Top down motoring is the whole point of a roadster. Even with the (very) effective heater, it still gets cold below 60 or so.
I did get a nice cap, all I need now are the right driving gloves. Any suggestions? The local leather retailers are out of stock, perhaps because it's warming up.
-juice
-juice
http://www.edmunds.com/roadtests/firstdrive/2001/mazda/miata/43962/index.html
"Oh yeah, did we mention that the LS also has the option for a six-speed gearbox? Although we think that it needs more overdrive in order to keep the revs and NVH down (it still revved at 3,500 doing 70 on the highway) and adds a hefty 155 pounds to the welterweight, it will behave in a more couth manner while rolling on the highway than the standard five-speed"
more power, sure, i'll take more power any day of the week, but more gear ratios, probably not.
ace
The original Edmunds article that reported the 150# 6-speed penalty also stated that the 2001 Miata achieved near 50-50 weight distribution (improvement vs the 2000 model) by moving the battery to the trunk. (Where it has been since 1989)
If Edmunds wants their automotive reporting to be taken seriously, I think they have to become more factual in their reporting. Also, less biased toward European sedans.
