Volkswagen Beetle Body Work Problems
1234568
  • rope1rope1 Member Posts: 1
    Anyone know how to bleed the New Beetle Convertible Motor/Pump? Is there a place/valve to bleed the air? Is it in the trunk?
    Any help is appreciated!
  • bobm16bobm16 Member Posts: 1
    My warranty ended in September 08. The car has 28.8k miles on it. I just found out the side cables inside the roof need to be repaired. Ouch! Also, the rear window is SEPARATING from the interior. The total repair is $650 with dealer "discount". There is also a small defect in the fabric on the exterior, which I have a bad feeling about. Although this was discussed while under warranty, it never was resolved. Any similar experience or advice?
  • 04beetletaf04beetletaf Member Posts: 1
    I have an 04 Beetle convertible with 19K miles and the right rear flap assembly also broke off. Who or where did you call to convince VW to pay for the repair?
  • dfraherdfraher Member Posts: 1
    I hope someone can help me. I purchased my convertible bug online and had it shipped to the house. I was out of the country when I bought it. I figured out how to put the top down but the indicator light and buzzer sounds like the top isnt all the way down. The warning ping is the same as when you dont have your seat belt fastened. And it pings when you put the car in gear. Did I miss a step in putting the top down?
    I didnt get an owners manual so I have no idea if I am missing a step, is there a lock for the top or something? :confuse:
  • imbatgirlimbatgirl Member Posts: 6
    Hey. I am in Jackson, MS and need help with my beetle top. Do you still have the name of the repair person you used? Thanks.
  • belaircarguybelaircarguy Member Posts: 107
    If you have a power top, when you lower the top it reaches a point where it sounds like it is making a slight "grinding" noise. Continue to hold the button and in a second or two that noise will stop. This is the top being locked into the down position. If you don't lock the top down, you get that buzzer sound as soon as you begin to drive or put the car into gear.
    If you have a manual top, I would believe you have to push the top down into the locked position, but I don't know for sure, as my car has the automatic top.
    Hope this helps.
  • cookie6161cookie6161 Member Posts: 1
    The top flap on my beetle just came flying off in the parking lot a few days ago. I took the beetle to a dealership and they want $700.00 to repair. It seems to me that these cars have many common faults about them. The check engine light stays on, the window regulators are defective, and the air bag system has defects. That was another $250.00 dollar expense for replacement of the seat belt sensor. I am very disappointed in the mechanics of this vehicle. VW needs to acknowledge these recurring problems and recall the defective parts. If you hear about a suit, let me know. I believe that these complaints warrants attention.
  • donalds71donalds71 Member Posts: 3
    I have a 2001 New Beetle. It has been performing just fine...except, the air-bag light on the dash won't go out and...the trunk will not open.
    As far as the air-bag light is concerned, I'm just not going to worry about it right now, it's the trunks failure to open that has to be fixed. When I use the trunk open switch on driver side door, it "clicks" okay, and the trunk opens about 1/2 inch, but I cannot raise it up. Something is holding it in place. Using the key remote does nothing at all.
    Very frustrating.
    Don Schaaf
  • seaamigoseaamigo Member Posts: 1
    Don,
    I have a low-mileage 2001 1.8 gas Turbo Beetle and I can offer this on the airbag light:
    My airbag light came on and after researching it found that there is a wiring harness under the seat that controls the side airbags, which are in the sides of the seats. The wires plug in under the seats, and also plug in to the base of the seat belt connectors. The harnesses are micro-thin and also too short, so when you move the seats to gain access to the rear, the wires get pulled loose or break. You'll notice that the bucket seats also pop up when accessing the rear seat, which may be the source of the stress. These wires have very specific electrical resistance, so can't be spliced - or so I am told. I didn't risk it, because I didn't want a deployed airbag. The dealer charged me almost $400 to repair one side. After 8 months of no airbag light, I moved the seats for the first time to gain access to the rear seat, and immediately got an airbag light again. Look under the seat, and if you're lucky, the plug may just be pulled out. If it's on the seatbelt clip, there is a rubber boot on the harness where it plugs into the base of the seatbelt female end. Gently pull that back, and you may see the broken wires. Again, if you're lucky, check the wiring harness under the seats to see if the connectors on either end have slipped out of the sockets. I believe these wires are green and yellow. If you're a rational person, you will probably now start sputtering the following: "This is a safety issue and the government should force a recall!" They didn't.
    If nothing else, if you have to take it to the dealer, mention that you're aware of this defect and they may be too embarrased to tell you you need an $800 airbag module or some similar nonsense.
    On the trunk issue: Mine did that too. I found that if I clicked it and raced to the rear, it would open. If I walked back at a leisurely pace, it would stick when I pulled the handle. When I reprogrammed the remote after changing the battery, it stopped.
    I don't exactly recall the details on how I did that, but it involved putting one key in the door while a second key was in the ignition. It may be in the manual or you can search the procedure on-line.
    Good luck,
    Mike
  • redvw2006redvw2006 Member Posts: 1
    Came home last night we shut our driver door as normal and the the driver window shattered
  • I've heard of other folks that this has happened to on other vehicles. But since it doesn't seem to happen on anything like a regular basis (i.e. no sudden rash of VW Beetle windows breaking on normal door closures) I would think the explanation has to be that there was a crack in the window that you were unaware of and the normal impact of the door closing was finally too much for it.
  • vwforbwvwforbw Member Posts: 1
    I have a '03 convertible turbo Beetle that is falling apart. My headlights do not work on a consistant basis, my right brake light is always out. I recently had to replace the mechanism for the rear window for the sweet price $1100 (and that wasn't even at the dealership!). The frosting on the cake is now the top is starting to pull away from the window. Granted my car is 6 years old but it only has 75k miles. My advice for anyone looking to own a VW Beetle convt, she may be a great car to drive but make sure you have a large savings for repairs costs!!
  • fandbeansfandbeans Member Posts: 3
    I see a lot of problems on this post and really, c'mon, your cars are five and six years old. Unfortunately, owners are going to encounter issues. Does it stink that after 5 years there are repairs that need to be made? Yes. Is it 100% impossible to design for every situation/climate/owner? Another yes.
    Another part that comes into play here is that quite a few of these vehicles are purchased used and no one can actually tell how the prior owner used the car. People get rid of cars for a reason, mostly because of issues that arise with it. It is definitely no fun to be the recipient of these problems.
    :D
    I have the same year model and some of the same problems. I tied my back windows up so I wouldn't have to pay 1000's to get that repaired only to break again. The window pulling away can be fixed. I used Rhino glue, bought it online, let the top partially down and glued it sections at a time. I stuffed several blankets under the glass to hold it up. I let it dry a good while, I think it was 2 days. Then I sealed it with black caulk type stuff from Lowes. So far so good. I think I did it in June. In my opinion, an 03 car should not be having problems. I have always had Toyotas and Lexus' and now have an 04 BMW and never had problems. VW should have to pay for all of these problems but they won't. A car taken care of should last a long time.
  • hatemyluvbughatemyluvbug Member Posts: 1
    I would really be interested in a class action law suit!! My Beetle has 25,000 miles on it and the convertible top has pulled away from the back window. Rain gets in, I can't wash it, and now I'm afraid the window will fall out. VW says "it's no longer under warranty and they won't cover it". I say it's defective and their adhesive is bad. Everything plastic and/or rubber on my car has broken. The gaskets around the headlights and brake lights is melting!!! VW needs to take responsibility for their product.
    After reading these forums I see a trend that I believe warrants a class action law suit. If anyone is interested or knows of one that is started please, please let me know.
    These cars are not cheap, and VW should be held accountable for selling such a bad product at such a high price.
  • The CarSpace forums may NOT be used to organize any legal actions. Please do not use them for that purpose. Posts along those lines will be removed.
    What you do outside of the forums is your own business and if you want someone to be able to contact you outside of the forums you can always click on the Forum Preferences link and change your email setting to public. That way, other registered forums users, and ONLY registered forums users, can click on your username and find your email address.
  • ragtop5ragtop5 Member Posts: 1
    How did you tie up the backseat windows? My drivers side regulator just broke on my '05 NB Cabriolet and am not sure I want to spend $$ right now and want to keep nature out of my back seat for now, Thanks. I have the seat, trim and speaker removed right now.
    We used these small bungee cords. If you can send me your email, I can email you a photo.
    I can't get a picture tonight, its too dark out there. I'll get one in the morning.
  • damnbugdamnbug Member Posts: 1
    :mad: I just wanted to comment that I also have a 2004 VW Beetle convertible and am fixing the window... again... for the 5th time! After fixing each of the 4 windows individually, I am now beginning my second round and have am about to have the rear side window fixed AGAIN! The first few times this happened the car was under warranty, so although it was annoying to constantly be servicing the car, at least it didn't cost me anything. The last time was just over a month ago in August 09 and the dealer tried to charge me for the repair stating that this time the problem was "different" than before. After some serious huffing and puffing, they said they would provide the service "complimentary" as a "courtesy" to me for being a regular customer. I'm only a regular customer b/c the damn car keeps breaking!!!! I now have an appt for tomorrow morning to have the latest window repaired and I'm dreading the ordeal that will occur in the morning. I absolutely REFUSE to pay one penny for a reoccuring problem that they have previously "fixed", and a problem that also appears to be a factory issue!
    On a side note, I also had to repair the sensor that indicates a faulty (or disengaged) airbag two times (luckily under warranty) before finally receiving a letter indicating the recall! When will VW issue a recall on these windows!?!?!?!!
    Has anyone had any success in this issue?
  • mihaicmihaic Member Posts: 1
    Hi Don,
    My name is Mihai and I have exactly the same problem with the openning the trunk.
    How did you solve it eventualy?
    Thank you very much!
    Mihai Coman
  • sadcarownersadcarowner Member Posts: 3
    I have a turbo new beetle convertable 05 and during my warranty had many prblems fixed- rear window falling out, broken parts on covertable, bad electrical issues, trunk latch, window motors ( 2 covered under warranty). Right out of warranty had transmission problems, additional window motors, and headlights/turnsignals going out. Good luck with VWOA-they too told me when I called to complain about their poor product-"no promises" I was called back and told- your issues are isolated, no other owners have come forward with the same concerns-and when I told them to go on the internet I was told that you can't believe everything you read on the internet!!! I will never buy another VW product-ever! I'm going back to Honda and Toyota-at least they stand by their product.
  • universemanuniverseman Member Posts: 2
    I have a 2001 new beetle and during this (Florida) summer, the roofliner has detached from the roof and now hangs down about 4 inches. The grey plastic liner on the doors also is detaching.
    Is there a fix for this?
    I have a 2001 new Beetle and, over the last year, a large bubble (almost 2 inches in diameter) has formed in the paint on the driver side door. It is getting bigger! Is there a fix for this?
  • trixhildatrixhilda Member Posts: 1
    You can contact me about the class actions we have had 11 window problems most requiring a new regulator we have also had the airbag light come on because of bad sensor in the seat belt clip we also had the check engine light come on and it was the temp sensor and a turbo valve cover that were bad that time we have also had other multiple problems with the top and others that I can provide information on. Now the real big bomb on all of this is we have a 2004 beetle like the rest here but ours only has 34700.00 miles this many problems and it has less than 35000 miles on it. Now we have a new problem that is not covered in any way by VW we replace the tires on the car about 6wks ago 4 brand new ones and with in 6 weeks they showed wear like needing rotation so I took the car back to the shop that did the tires at the time on the new tires being put on they asked if the car was pulling to one side or the other or if we thought alignment was required and we said no and they said that when the new tires were put on they test drove it and didn't think alignment was necessary at the time now about 6 weeks later the car is at dealership for window work again and other stuff and they notate the wear on the tires so I went to tire guy and he checks the car and finds the camber is -2.14 degrees off he feels that with it that much off and it can't be adjusted into proper alignment that it came from the factory that way. Of course they are not going to do anything about it I am not done talking to them yet we will see what happens. So contact me if you need info about about window problems and count us in. Thanks trixhilda
  • dcm5150dcm5150 Member Posts: 7
    "You can contact me about the class actions we have had 11 window problems most requiring a new regulator we have also had the airbag light come on because of bad sensor in the seat belt clip we also had the check engine light come on and it was the temp sensor..."
    We have had the exact same problems. In addition, we had to get a new catalytic converter. Luckily this item was still under warranty, but really, I have never even heard of anyone needing a new CC on a car with only 45,000 mi on it.
    BUT ITS GONE NOW!!!! We got rid of it, which is very exciting. (airbag light was still on when we traded it)
  • The CarSpace forums cannot be used to organize any legal actions. What you do via email or outside the forums is your own business, but please don't post anything about organizing legal actions on the forums, thanks!
  • sundevil77sundevil77 Member Posts: 8
    I purchased my vw beetle convertible brand new and the top has been inoperable so many times and repaired so many times that I stopped using it a long time ago. Don't buy this car!! This is minor compared to the other issues, I have a lengthy list. My car has been in the shop for 145 days since I bought it! I finally got the time to submit a claim to BBB and lemon law.
  • wellsie7wellsie7 Member Posts: 2
    Is a class action suit going foward on the window regulator issue. I have had this happen twice already, costing a ton of money w/less than 35,000 miles. I am scared to put the windows down now. I have also had the air bag sensor problem, headlight/signal problems, and check engine light issues. The passenger seat will not push all the way forward so people cannot get in the back from that side, etc. Very disappointed. Will gladly help w/lawsuit.
    Sorry - I read your post right after I sent mine. Will not post on this subject again.
  • lrock1lrock1 Member Posts: 1
    I'm feeling vindicated after reading some of these posts. I have an '04 Beetle Convertible Turbo. Had the airbag light problem. Took it in to be fixed while under warranty. Came back on. Took it in after the recall. Came back on. Called to have it dealt with again and was told they'd ALREADY FIXED IT. MUST BE ANOTHER PROBLEM! The flap thingy on the driver's side broke off and shortly thereafter, the top got stuck - open, with rain coming and no garage. Took it in, out of warranty. Cost $900 to fix. But the airbag light was off! Can't open the trunk with the key. Have to use the switch on the door. But now I fear that'll stop working soon. How is is possible that one can't open the trunk with a normal key??? Get the feeling that this car is WAY over-designed and WAY under engineered. Did I mention that all this has happened and I don't even have 20K miles? I can't wait to get rid of it.
  • winklebugwinklebug Member Posts: 3
    I currently have 70,000 miles on my beetle. (One of the many mentioned in the stream of blogging beetle banter here) My warranty has finally expired...and that is upsetting enough...because I had to put so many miles on it to drive it back and forth to the shop--ugh.
    I ,too, had the trunk not opening--First by key--then by switch and key. And NO it was not in Valet mode...which is the option to take your key and lock the gas lock and trunk lock so that those things are inaccessible when the top is down or valet takes your amazing sweet Beetle ride to park!!
    So in 2 years I have warranty work done:
    Top flappy thing broke TWICE (47,000 miles and 58, 000 miles)
    Had an entire NEW CONVERTIBLE top put on (47,000 miles)
    Airbag sensor replaced (42,000 miles)
    Check engine sensor...
    Power Steering Rack replacement ...after having an oil change...and tires rotated...the problem started---started car the next day--grinding power steering pump. (67,000 miles)
    Window switch replacement (67,000 miles) becasue the windows weren't rolling all the way up after dropping the 1" or so when opening and closing door...
    Trunk release switch Replaced
    PROBLEM STILL OCCURING NOW AND AGAIN...they said it's something with the timing of the locks, blah blah blah...
    Center console lock needed replacing--THEY HAD TO BREAK IT TO GET IN UNLATCHED!
    Seat adjuster at the shoulder (the ones that drop the seat forward) Broke...was apparently glued back on...
    The driver side window squeaks terribly--it's embarassing and if anyone has a solution--I would appreciate it...They never fixed that problem.
    The second huge (and embarassing) issue is the entire interior console is coated with a rubberish black material--probably looked pretty cool when it was new--but it has degraded so much--it is just scraping off....If you were to take your fingernail and even lightinly scratch it--it removes the surface and looks terrible.
    I borrowed a loaner--a 2009 Beetle NON convertible...it was soo roomy. I could really pack things in and my 11 mos old daughter loved the big window.
    Sooooo/...if anyone want's to buy my Beetle--please disregard the forementioned problems and contact me! LOL :)
    It is still fun in the sun....but not a Mom car! :cry:
    We got rid of ours! (2003 NBC)
    Besides the usual problems (airbag light, windows, headlights, front door falling off), we also had to replace the catalytic converter (at 40,000). Of course the garage first wanted to charge us a few hundred for the temperature sensor so they could be sure it was the catalytic converter. Then on top of it all, the shop didn't put the hoses back so one rubbed on the belt and leaked all the coolant out so it had to be towed back to the garage. Never so happy to be rid of something (the conv. top was about ready to completely break too!)
  • bpaigebpaige Member Posts: 1
    Have a 04 beetle convertible and already had to replace top due to back window falling out several times after dealer glued it back. Also, once the top goes down I have to wait several hours for it to go back up again. Additionally, after the top goes down, the cover plates stay up. Can't ever get those to go down until I put the top back up and then they retract OK. I have told the dealer this several times and they seem to have no trouble with any of it till this last time I had it in for the same problem and I was told they would have to replace both motors. Also my driver airbag light stays on. Dealer says the problem is in the seatbelt. All this will cost about $2000 to correct. The new top cost over $4000. I am wondering if a stronger battery might be what's needed. Any ideas?? After Road Mart put in their strongest battery for this car last year, the top and cover plates worked pretty good for a few times. I have had several VW's but am really disappointed with this one.
  • iucpa1iucpa1 Member Posts: 1
    I am definitely interested in hearing how you fixed the airbag light. The same thing happened to ours (I believe). I had a hard time buckling the belt one time and had to "force" it in - later that day the airbag light came on and has been on ever since. Curious to know how to fix it.
  • groovygirlgroovygirl Member Posts: 2
    Mine is grinding and leaving a mark on the window. The Airbag light just came on. I need to get it fixed as we need to sell as we need money. Any suggestions?
  • jmr49jmr49 Member Posts: 1
    We just replaced top of our 03 Beetle Conv today. Cost of ultramax top top was $1200 and install from local auto upholstry shop was $500. Hated having to do this (top still looked new), but glass falling out. W/this top we get lifetime warranty on glass separation on 5yrs on cotton mid grade top itself. Total drive out of $1700 much less than dealer...car was garage kept. I agree VW needs to change way they do business....technology apparently exists to provide lifetime glass happiness.....can't disclose vendor but use the previous clue.....
  • harry53harry53 Member Posts: 1
    I Beetle have 46,000 miles and have exactly the same problem. We need to do thing about it. Please advise me what do do.
  • trjrtrjr Member Posts: 1
    Am having the same problems and was told that no known glue will hold glass in place for very long. Before investing in a new top (crazycrazycrazy) was wondering how your repair from '09 is holding up?
  • smcclartysmcclarty Member Posts: 4
    I replaced the entire top. That held up fine, but then the engine went out. got rid of it at that point. A previous VW, 2 years earlier, went to the shop for a month before they could figure out why it quit running and then just out of warranty, we had to replace the transmission. At this point, we had to swear off of them. We went to Toyota and never looked back. We have now purchased 3 Toyota products and are delighted with all three, one of them with 165,000 miles and no problems ever whatsoever. Sandra
    I have read many complaints on the early (2003-04) convertibles and the rear window coming loose. Apparently, this is not just a VW problem, but many others also, such as BMW convertibles. It must have been a "new and improved" manufacturing method at the companies that produce the tops. In any case, it appears many owners have success by taking these car top issues to a car upholstery shop. These shops have various glues, stitching etc., and can get these windows repaired. It seems crazy that VW would suggest just replacing the entire top, but then again VW did not make the tops to start off.
    Try an auto upholstery shop first.
    BelAirCarGuy
  • hotskins2000hotskins2000 Member Posts: 5
    edited August 2010
    What dealer did you get the clips from? What town and State
    What dealer did you get the clips from? What town and state?
    Whats the name of the dealer to get a repair kit for back window. I'm in Naples, Florida
  • mabel05mabel05 Member Posts: 1
    The cloth around the window on my '05 beetle convertible was falling off almost completely (though the glass was still in place). The dealer quoted me some insane amount of money to fix (I want to say $400) and I took it to a place called the Buggy Doctor (http://www.buggydoctor.com/) in Miami. Cost only $16.80 plus labor to replace all the clips. Try calling them if you need the clips. They were cheap. (Although I have to take it back in, this was in June and already the cloth is falling again... so not sure if that is a result of the clips themselves or the way they attached them)
  • vwdriver62vwdriver62 Member Posts: 1
    I had my top open half way several days working on regluing back window. Now that I am closing, will not close by 2 to 3 inches to be able to lock down. Has anyone had this problem. I can potentially close manually, but do not know if this will create some error code that will then call for a trip to the dealership?
    We also have a problem with our window on 2004 Bug. The top part of the window looks like it is going to fall out. I glued the bottom part and duct taped the top part. The dealer is no help they say you need a new top. We only have 40,000 miles on this car. We have not put the top down because we are afraid the window will fall out. I heard there is a place in Miami called Beetle works that has a kit to fix this problem We are located in Naples. Does anyone else have a solution to this problem. No more VW for me always some kind of problem.
    Correct my last statement on Beetle works to BuggyDoctor.com
  • jenny201316jenny201316 Member Posts: 1
    Well, not to be the barrer of bad news. I have a 2003 vw beetle convertible. The trouble started with the drivers window, then the passenger, then both back windows. The motors had to be replaced, and just found out that only last about 3 yrs., now I'm on my second round of window motors. Cable broke on my top, was able to fix but, now, the back window is coming loose(have to replace whole top 2500.00). The trunk won't open at all, no matter what I've tried. I am so unhappy with this car. Oh, transmission decided to start going out. I've been told that it will cost about 4000.00 or better to fix. I just want to scream. Its a money pit.
