Visitor Agreement.
Torque convereter grinding? Are you hearing a grinding noise?
For RSX '05
I don't know how to attached a file but I have an electronic copy of it.
It created a whirling noise when it reached above 60 mph.
It's hard to describe but it's like saying "woe woe woe woe . . " semi slowly at a pitch of Curlee in 3 Stooges but in monotone).
I drove above 60 mph then it got worse. Drove below 60 and it went away. Reached 60 and it did it again. I drove it for 3 days and it did the same thing everytime.
It wasn't the wind or the tire.
I was tempted to tell the dealer about it but I was afraid they would blame me or something.
No Honda/Acura cars I've driven make that sound. Any ideas?
I'm afraid if I buy an RSX and it will make that same sound. Thanks.
P.S. Didn't had a clicking sound but for those who do, I thought it's the CV joint and not the transmission problem???
MrShiftright
If you're interested in an RSX, then make sure you get a test drive in the one you plan to buy and have a chance to drive it at highway speeds.
The bulb pops out of the back of the housing after releasing a clamp mechanism. The hardest part is contorting your hand to fit down there. I've replaced both headlights by now and from what I remember, the passenger side is the hardest.
The whole process should only take about 10 minutes.
huh?
In the back end of the car? Can you explain this a little clearer please?
The car erupted into flames and was completely gutted and destroyed in under 5 minutes. The fire fighters said they had never seen anything like it. I contacted Honda Canada to let them know about this potential flaw and their attitude was basically like they couldn't care less.
Has anyone else heard of this happening from the front end of the vehicle on a low speed impact? I would never touch an Acura again at this pont.
JB
In the end I decieded not to have them do anything to the car at this time. I don't need the whole front end apart for a tempory fix. One service manager said that the noise would get louder if it wasn't fixed now. Another didn't agree with that. I called Acura HQ and they said they weren't aware of this type of problem.
I wonder if enough people complained and mentioned that we want another type of fix, they would take action.
When I called the guy wanted my VIN # which I didn't have in front of me at the time. I have it now and will make another call.
I'm rather shocked at Honda's response though. If this happened in Sweden or Germany they would probably have an investigative team out there from the factory.
I think anyone with the slightest pop or noise from the struts has to call Acura in addition to the dealer in order to get some action. A brand new car and they want to temporarily fix the problem with some grease. Not what I expected from Acura!!
what is the call number for Acura Corp in the US. i definitely want to call. i bought acura because it was supposedly problem free. i am NOT happy. never again!!!
1 800 382 2238
Monday-Friday
They'll ask you for your VIN #
I asked another RSX driver today, if they had the strut problem and they didn't. It was an '04 though, and the problem didn't start until '05 with the increased HP.(at least that's what I was told)
i was wondering if anyone has tried "spirited" driving as my dealership puts it...has anyone taken the rpm's to the redline and beyond? what happens at the point? does it harm the engine? if so, why would they allow it to go into the redline? how long can we stay there? any info on the mechanics of the redline would be appreciated...(i just found out that the rsx does NOT shift up automatically when it reaches the redline, so i was just curious as what the mechanics associated with it are)... :confuse:
thanks in advance...
I haven't been following your strut mount noise problem, but I've gotta believe the noise would have to be pretty loud to be a substantial defect. Good luck.
I think Acura is irresponsible concerning this issur!!
i always was wondering about this: my car usually is outside in the cold during the night...and i usually start it for about 10 minutes to warm up the engine before i take off...the thing i was wondering was if it puts an exceptional load on the engine if we turn the heater on while the car is warming up? i mean the indicator on the left side gauge is still below minimum at this point...just wanted any inputs...i would like to get into a warm car when i am ready to take off...thats all...has anyone done this without encountering any problems? thanks...
That's what I suspected also. Although they said that the noise was coming from the back end.I have not herad back from them on this so I susopect it was a troll.
The way the heater gets it's warmth is by warm water/antifreeze mixture that the engine uses. There's a valve (have you heard of a thermostat?)on the engine that pops open when the correct temperature is reached in the engine. When that happens, the water used to cool the engine is also circulated up into the dashboard and through a mini radiator similar to the one on the front of the car. Air is then blown across this mini radiator and out into the compartment.
So, no, there is nothing harmful in turning your heater on early...unless you fell that cold air is harmful. :-)
The problem is that the car is not going to get very warm by just sitting there idling. It needs to be worked to get up to some nice hot temperatures and the only way to do that is to drive it. You will still get some heat out of the heater...enough to get the chill out and to melt the ice on the windows, but nothing like if you drove it.
But warming up the car for 10 minutes is completely unnecessary, and just wastes gas. Even in the coldest weather, you can start it up, let it idle for 15-30 seconds, then take off. Drive it gently until the engine begins to warm up. You'll warm the car faster this way and use less gas. Put on a pair of gloves for the first five minutes of driving to be more comfortable.
Also, the strut problem that is floating around. Is that mainly a front strut problem or a rear strut problem? Reason for asking, wondering if a noice is coming from the rear strut or from the hatch just being loose.
