Visitor Agreement.
Anyway, you failed to answer my question, is this common with the Odyssey when cold weather hits or is our case isolated?
I was also told to prime the fuel injection system by turning the key until all dashboard lights are on, wait for some to go off, then start the engine. It has worked for me since.
The owners manual does state that you should not crank the engine for more than 15 seconds. If the engine does not start to press the accelerator halfway and crank the engine at the same time. Then to release the accelerator if the engine starts. If the engine still fails to start to hold down the accelerator all the way down and try to start the engine at the same time to clear any flooding.
Hope this helps.
I'm hoping to have better luck with the Ody.
Anyway, I have noticed the starting problems with the new van too. Thanks for the information on how to handle it.
Re: cold starts. Our 2003 ody just hit 3k, and it alway starts the first crank. Have not had an opportunity for super cold weather, as we live in Tucson. Its supposed to get down to 20 degrees here tonight though (about as cold as it gets in Tucson), so I will see if it starts right up tommorow AM.
I ordered from Tire Rack:
* Bridgestone Blizzak WS-50, 225/60QR16 (Part#: 26R6BZWS50)
* New steel wheels, black, 16X6.5 (Part#: X45441)
* Mount and balanced (no charge)
I installed in my garage in about 1 hour:
* Read owners manual.
* Lifted rear of van using hydraulic floor jack.
* Placed jack stands at jack points identified in the owners manual.
* Removed regular tires/wheels and installed winter tires/wheels.
* Lowered van, torqued lugs to factory spec (80ft/lbs).
* Lifted front of van using hydraulic floor jack.
* Lowered car, torqued lugs to factory spec (80ft/lbs).
How to jack both rear wheels of the ground:
* There is a heavy steel "flange" welded perpendicular to a thick tubular support about 2.5' in from the rear of the van.
* Center the jack on this flange and lift.
* Both wheels come off the ground, slide jack stands under jack points specified in the manual.
How to jack both front wheels of the ground:
* There is a heavy rod steel "V" welded to a thick tubular support about 1.5' in from the front of the van.
* Center the jack on this "V" and lift.
Important points to remember:
* Read the owners manual.
* Know how to use your tools.
* Place chocks behind tires opposite the location of the floor jack when lifting.
* Mark each tire/wheel for position so you know where each one goes next spring.
* Store your tires/wheels in a cool, dry place not exposed to sunlight.
* Tires should not be stored in a vertical position (i.e. on the wear patch).
* The van is 5600+ lbs. empty. Make sure your lifting equipment and stands can support this weight.
* The "rails" under the sill of van did NOT crumple when the weight of the van was supported by the jack points sitting on jack stands.
* Next time I will get the whole van on stands and do the tire swap at one time as I will be rotating the regular tires/wheels.
* "Break the torque" (i.e. loosen the lugs) BEFORE you get the van on the lift or stands.
* Use common sense, seek professional help if you have any doubts that you can do the job.
Hope this helps. Good luck and happy holidays!
Phil
My 2001 Chevy Blazer seems nicer all the time as I read of problems people are having with both the Odyssey and Sienna minivans.
Hope none of you have as many problems with your Odyssey that I did with my 1970 Dodge van.
Just past 500 miles. At first I thought the seats were uncomfortable, but they seem to be growing on me. This is our first mini van, can't understand why we didn't make the change sooner.
Is the above sufficient for torquing lug nuts? Or must I get the wrench that is specifically made for this purpose. Sears makes this version also.
But, now I'm trying to find out the lug nut size on my Odyssey. Someone told me they were 13/16, but I know Honda is metric so that can't be right. I took out a 17mm (too small) and 19mm socket (rocks a hair when on nut). I'm thinking its 18mm.
Any thoughts on this? Don't want to strip those nuts.
Currently I drive a Saab 9-5 wagon that we love, but it does not have the room.
My driving impressions:
1) Car like ride - have heard this before, but did not believe until I actually drove it.
2) Can't see why one would opt for the EX, since LX has same motor, TCS, ABS, etc. Maybe a few creature comforts, but this is a minivan...i'd pocket the savings and get the LX
3) Spartan interior - compared to my Saab with burled walnut dash, etc, the Ody is like a ryder van.
4) Driving position seemed strange - I am 5'8 - but didn't feel confident that i could sit comfortably - maybe i didn't play around with seat position,etc. Maybe i can never feel comfortable - might be because the Saab driving position is more ergonomic, or jsut that all vans are like this.
5) titl wheel doesn't really tilt. poor design.
6) Spacious interior - but not as wide as other vans - i like the magic seat - but having to remove the headrests seem unecessary.
7) Clever center console
I was pleased with EX, it is a nice, but spartan, design. Basic transport, with good engine and nice features like TCS, EBD, 4wheel disc ABS.
Dealer i visited has 12 Odysseys. Clearly willing to deal. I would opt for LX - pocket the 2-3K extra for boat upgrades...;>
Plan is to test drive the Quest next and compare notes.
i'm curious also to know if VSC causes pads to be used up more rapidly. maybe if you're always driving aggressively.
of course, if were a racer and i needed to get around pylons or through Ss quickly or if i like to push it in the corners, then i'd value the technology.
but in a mini-van?
i'm sure there are numerous scenarios where the system will help, but the premise is that we aren't driving properly and we should let some engineers in a lab decide how the vehicle should drive and respond to our control inputs for us.
yikes.
http://www.magnetbra.com/models.html
and
http://www.weathertech.com/store/vehsearch.asp?make_id=21&yea- r_no=2004&veh_id=281&item_group_id=5&veh_opt_choice_i- d=0
I'm worried however about what the paint would look like after a few years of use in regards to fading, etc. I'd have a two-toned hood.
Do you know if this 3M material has any fading issues?
http://www.3m.com/US/auto_marine_aero/auto/pdf/holdingfast_no16.p- df
Anyone?
Will TCS get me in and out of a snow covered driveway or parking lot? Will it suffice in the snow if driving under 35 mph?
can't say I've ever pushed this button on except to see if it lights up.
yes the tires are the originals Michelen Synergy tires - they only have 17k miles and are in good shape.
So does the TCS buy me anything in the snow?
thanks for pointing that out.
Do you have any experience driving with the Odyssey in the snow? or have you had to put chains on?
BTW; I heard there is 2 feet of fresh powder up at Tahoe (lake level).
