Visitor Agreement.
Steve
If you are having a pinging issue, then using higher octane will help but it is in no way a requirement for normal operation. The pinging may be a symptom of a mechanical issue.
I doubt very much that anybody could feel the difference of five more horsepower!
A lot of well meaning people waste a lot of money buying premium gas that isn't needed.
230 HP not on premium...
Horsepower@ rpm (SAE net)240 @5500 RPM.
Torque(lb-ft @rpm) 242 Torque @4500 RPM.
Required Fuel: Regular Unleaded
Assuming that no premium was paid, that is a depreciation of only $7,800 in 3 years.
Can any other minivan match that low depreciation?
"Your Honda is designed to operate on unleaded gasoline with a pump octane number or 86 or higher. Use of a lower octane gasoline can cause a persistent, heavy metallic rapping noise in the engine that can lead to mechanical damage.
We recommend gasolines containing detergent additives that help prevent fuel system and engine deposits.
Using gasoline containing lead will damage your vehicle's emissions controls. This contributes to air pollution.
In cananad, some gasolines contain an octane-enhancing additive called MMT. If you use such gasolines, your emissions conrol system performance may deteiorate and the Malfunction Indicator Lamp on your instrument panel may turn on. If this happens, contact your authorized Honda dealer for service."
And under the back cover for Service Information Summary: "Gasoline - Unleaded gasoline, pump number of 86 or higher"
I looked all over the owner's manual for a recommendation for premium gasoline, even if it were for the extra 5 hps, and I can't find it. If you have, please give the page reference to me.
Does anyone know how long the '04's will continue to be generally available before 05's hit the street? I continue to notice lots of Ody's on dealer lots. Plus saw a few trailer loads of new Ody's on I-95 heading to dealers no doubt!
I plan to buy in March, and hope that the good deals on the ody continue!
"With premium fuel (205hp/217 lb-ft with regular unleaded fuel)"
I was pretty sure that my (US version) owners manual recommended premium fuel but did allow that regular was also acceptable. Wish I could quote that to you, but I can't.
Here's some more info.
The Feb 2000 Consumer Guide book that tests and rates each vehicle and lists their invoice and suggested prices also states "Honda recommends premium fuel, but says the V6 will tolerate regular with a slight loss of power."
The June 1999 issue of Consumers Reports also mentions that the van will develop 210 HP on premium and 205 on regular gasoline.
I never ran premium in my 2000 Ody, and I certainly don't in my 2004 one either, but Honda did recommend premium fuel (for maximum performance) for the U.S. version of the vehicle during model year 2000 and I believe for other years as well, until they upgraded the engine in 2003.
Anyway, hardly an urban legend, its right there in black in white in the official company brochure of the US version of the vehicle.
octane levels by bobresnikoff Jan 24, 1999
Consumer's Reports is often wrong and this is one of those times.
My 99 V-6 Accord Coupe has the same engine as a 99 Odyssey and the fuel requirements are the same.
I've run a couple of tanks of premium in it and I couldn't tell the slightest difference.
Yes, it is, indeed there in black and white!
TIA
Your Accord has an engine closely related to the 99 Odyssey, but it's not the same.
And he SELLS hondas for a living!. LOL, sorry couldn't resist!.
Plus, I don't recommend or use premium, I just thought that a couple of folks on the board (Dave and Isell) where trying to come off like anyone who had at least heard of the possibility of using it (from their "United States" version of the brochure and owner's manual) must be a kook and succumbing to an urban legend. The engine was rated with a notation for premium fuel. It was in writing from the company, not an urban legend.
It also was Consumer Guide I quoted with the Honda recommendation, not Consumer Reports. In all fairness, the July 1999 Consumer Reports list the fuel that they used as regular, with a notation that the vehicle would make 5 more HP on premium.
Thankfully now the engine is rated at full power with regular gas, even if Isellhondas isn't sure of which engine goes in which model.
The fan in the way back wall picks up speed, but no air blows out of the ducts under seats. I have to take in the van for a recall on belt tensioner, and was going to inquire about that.
The way the manual reads, I should expect air to flow out of the ducts under the two front seats.
Anybody????
Thanks in advance!!
Thanks for the wake up!
Vehicle stats:
GCWR = 8,265 lbs.
GVWR = 5,665 lbs.
Dry weight = 4,365 lbs.
20 gallon gas tank = 120 lbs.
Occupants = 210 lbs over and above Honda’s 300 lb allowance.
Cargo = an estimated 150 lbs.
Hitch = an estimated 50 lbs???
Camper stats:
We are looking at 2 different pop-ups:
One is a Fleetwood Tacoma. Unloaded vehicle weight = 2,030. Tongue weight = 150.
The other is the Fleetwood Sedona. Unloaded vehicle weight = 1,545. Tongue weight = 170.
In either case, add the following:
Options = 90 lbs (roof AC = 70 lbs, furnace = 10 lbs, misc = 10 lbs).
Propane tank = 38 lbs.
10 gallons of water = 84 lbs.
Cargo = another estimated 150 lbs.
When I do the math:
I’m under the Ody’s supposed 3,500 tow weight limit.
However, I’m around 90% of the GCWR.
And, I’m even closer on the GVWR calculation.
I need some advice:
1) Is the weight of the Ody in the brochure the “dry weight”?
2) Am I really that close on GCWR & GVWR – did I do the math right?
3) Does anyone else tow a 1,500 lb or 2,000 lb pop-up with an Ody & how much do you feel it?
4) I have heard that Ody’s tend to sag when hitched up. As a result, I would definitely want a WDH for the Tacoma but probably not for the Sedona. Agree or disagree?
Thanks for any & all help!
We brought it to the dealer, who told us it was because the cross bars were installed backwards.
They fixed it, but we still have a wind noise, although much less annoying. It seems like it is due to the cross bars? Anybody else have that problem?
billg7 Jan 21, 2003 12:57am
You may want to browse around the Honda Odyssey Owners: Problems & Solutions board too.
Thoughts?
In theory, your engine would last longer and put less stress on the corresponding components if the oil is warmed. What it corresponds to in real life miles, etc probably cannot be determined.
I had one on a Ford Windstar and never used it. Was on the vehicle because it was relocated from a much colder climate (near Duluth, MN).
Same manufacturer for the headphones?
I know this might stir some discussion but for the price I paid, I could not handle the door rattles, wind noise, road noise, and intermittent tranmission slippage anymore. I love the way the new Sienna drives and hated where Ody stood in comparision.
I was surprised with CarMax's offer, which was about $200 above KBB "excellent" trade-in value ($700 above trade in & $600 below private party on Edmunds) and sold it as soon as it was appraised.
Now, I gotta figure out what I'm gonna do with $500 in savings every month (payment+insurance)!!!!!!!!!
Good luck with your Odys friends.
