Honda Pilot 2003 through 2005
1117118120122123134
  • wmquanwmquan Member Posts: 1,817
    From what I've seen, it's pretty typical of Toyota dealerships. The various regions end up selling very specifically packaged vehicles. One can get a decent idea of what they're facing by using the build-your-Toyota function on the Toyota web site. It takes your zip code and seems to only offer packages targetted for your area.
    Often they'll bundle in some accessories one may or may not want. Lexus dealers do this too.
    One nice thing about Honda/Acura is how they don't offer as many option packages.
  • jonb1jonb1 Member Posts: 4
    Hi. I am considering a Pilot vs Odyssey. What do you mean by the Ody has too many problems right now? Please Advise
  • dklaneckydklanecky Member Posts: 559
    Have you checked CarMax.com? They have (in my area) about a dozen V8 4 Runners ranging from $27,4xx to $33,7xx. The range of reduction from MSRP is from $5600 to $6500 right now!
    http://www.carmax.com/dyn/compare/comparevehicles.aspx
    I have no idea where you live, but you could probably pick up a cheap airline ticket, throw away the return trip and save quite a bit of money if you've got the time for a road trip over the holidays!
    Good Luck!
  • sportymonksportymonk Member Posts: 258
    No need for the plane ticket, car max will bring the car to you. I believe (please verify) free if in the local area, for $150 if far away. I think the $150 is written off if you buy it.
  • jeff1natjeff1nat Member Posts: 1
    Two questions for the Honda Pilot Forum:
    1. Is there any way to program the seat belt reminder beeper to stop beeping??
    2. Is there any information on the largest tire that will fit on a stock pilot? I am looking to put on a more aggresive tread, maybe a 265 or 31 inch.
    1. Wear your seatbelt.
    2. I would check with the Tire Rack guys. Be careful not to go overboard.
  • lumber2lumber2 Member Posts: 184
    Jeff: Tires: Honda has always filled the wheelarch with the stock tire, so I don't think you can grow in size -by much, 245/70-16 is fine, 255/70-16 is just ok too.
    If you are thinking all terrain or mud terrain, there are plenty in the 235/70-16 size. That size was first used on the 94 Land Rover Discovery and now can be found on Jeep Liberty to Pilots.
  • firetyfirety Member Posts: 5
    My wife and I purchase a '05 Pilot EX-L this past Saturday. Very pleased with the car, but on the way home the TPMS light came on and has come on the two other times that we have driven the Pilot. Any ideas what causes it to come on and stay on? It has been exceptionally cold here, so maybe that has something to do with it. Anyway, we are planning on taking it in in 2 weeks to see if they can fix the problem.
    TPMS monitors the air pressure in your tires. If it's going off, you have a tire (probably all four) that need additional air added to them soon.
    When the outside air temp drops, so does the air pressure in your tires. Mine tires will drop about 2 lbs per every 15-20 degrees F drop.
    We're predicted to drop below zero over the next couple of days, from 40 degrees when I last checked the pressure. I know I'm going to be between 4-6lbs light in each tire by Christmas morning.
    The worst (short term) thing you can do to a tire is drive it when it's under inflated.
    This will eventually destroy the sidewalls on the tires (remember the Ford Exploder with the Firestone under inflated tire disaster)?
  • ukkoukko Member Posts: 23
    The Pilot should have had a good test in this recent snow event. Some areas received about a foot of snow. Are there any of you out there that had your Pilot tested in the storm? How did the vehicle, with its 4 wheel drive system, do?
  • sleepdeprivedsleepdeprived Member Posts: 1
    Does anyone know if you add the Honda Pilot Side Steps (08L33-S9V-100A)as an option, whether you can bump the GVW from 5950 to 6000 lbs to qualify for what is left of the 179 deduction?
  • 01r101r1 Member Posts: 280
    Nope. The only deduction will be in your load carrying capacity, they won't increase your GVWR. I have not heard of any easy solution to get the Pilot into that section 179 option. I'm sticking to the standard mileage deduction for mine.
    Happy Holidays.
    -Pete
  • billybbillyb Member Posts: 4
    I am sure this has been covered previously but could not find the exact answer I am looking for.
    I have VTM4 and to use it you set it while stopped and put gear on 2 or 1 - this locks the wheels and makes it 4 wheel drive. Does the light on VTM need be on for all wheel drive to work or does all wheel drive work as soon as you start your car automatically sending power to wheels that lose traction?
    Press the button in 1 ot 2 and you lock the rear differential under 18 MPH. Over 18 MPH the light goes out. The button/light is a rear differential lock, I believe it locks both the rear differential (locking left/right together) and the center differential (applying same power to front/rear) under 18 MPH.
    All wheel drive is all the time. When you start out the rears get more power than when moving at 40 MPH where they little or none. The light doesn't need to be on and if the fronts slip the rears get traction. However if 1 rear is on ice, you have an open differential in the rear and you will just spin 1 of those tires.
    If you press the button and get the light, both rears are locked and you get the same power applied to both wheels so even if both fronts and one rear is spinning, you will move forward.
    So when driving in snow, you don't need to do anything, the system will route power as required and I think you will be happy with the performance. If you get stuck on an ice patch or need a little extra to get through a snow bank, you can lock the rears by hitting the button.
  • snowman5snowman5 Member Posts: 6
    I just looked at a new Pilot yesterday. The salesman told me that the AWD only works up to 18mph. Any faster and it is basically front wheel drive. Is this not correct? Is the Pilot's AWD different than other vehicles' AWD systems that are AWD all of the time? Thanks.
    It's amazing how little some salespeople know about the vehicles they sell, or not take the time to explain the vehicle correctly.
    The 18mph restriction only applies when you manually engage the "VTM-4 Lock" mode by pressing a button on the console. This works in 1st, 2nd, and reverse gears and forces power to the rear axle. The Lock mode progressively reduces the amount of torque allocated to the rear, to the point where it disappears at 18mph. This mode is used primarily for extricating oneself from a sticky situation.
    Under normal cruising (at speeds below and above 18mph), the VTM-4 system drives the front wheels only. However, when slippage is detected, the system can and will route torque to the rear to drive the rear wheels. In that sense, the Pilot is like other "full-time AWD" vehicles that do not drive all the wheels all the time, but don't automatically engage all the wheels as needed.
    It just has the extra "Lock" mode which is useful for extrication, as well as an anticipatory mode where it will engage the rears when accelerating (to prevent slippage on launches).
    The Pilot/MDX are essentially a front wheel drive at higher speeds, this cuts down on gas mileage. However the system is designed to sense slippage and apply torque to the rears all the time.
    There is probably little torque applied to the rears at 40 MPH, how often do you spin your wheels getting traction at that speed? Even in offroad conditions, over 20 MPH 2wd will get you through, there is enough car momentum to keep you moving.
    I agree with the above comments regarding salespeople. I often test drive new cars/trucks for fun. I read all about them on the web and then have to drive them. I know about all the problems, true costs, accessories, wind noise, etc. I have friends that take me car shopping...it is fun to undermine the salesperson during the process to hopefully get as much of an upperhand as possible. Usually I can do circles around them regarding the information...and they do it for a living. I have even practiced going all the way to the sale before backing out, this was prior to my last purchase (I don't do this all the time, because that is just unfair to the salespeople). The only upperhand they really have is knowing how much the car really costs them if you do your homework. While I am on my high horse...I think something should be done about car salespeople outright lying to you. As far as I know there is no advisory board, no one gets a license or has to take a test to sell cars...the day someone actually regulates that industry would really change things. If other industries tricked consumers, lied, didn't honor deals, etc the way some dealerships and salespeople do, there would be legal action. Ok off my horse.
    There was a web article, I cannot find it anymore, about how the MDX VTM system was specifically designed for snow and tested in the himalayas. I think you will be pleased with the Pilot AWD system. I have an Isuzu with a "real" 4x4 system and a MDX...both are about the same in snow...which is very good, if not great.
    Puffing has a long, if not honorable, history, and one not just limited to car sales.
    Gotta do your homework (as you obviously do).
    Thanks for your response...very helpful. Also, thanks sbcooke for your feedback as well.
    Edmunds articles on being a car salesperson and how to manage the buying process are good reasources as well. I point anyone who asks me about a new car to those. Just a few hints in the right direction can really help consumers get the best deal for them. Practicing helps too...anyone buying a car should practice. A lot of car salespeople are pushy, have tricks, flim-flam, etc. Practicing managing the situation...not waiting 1/2 hour while they "wait for their manager", walking out in the middle because the guy didn't give you the deal you like, even just going to the sales manager and saying you don't like the salesperson who picked you up when you came on the lot and that you would prefer to work with someone else require practice.
    " I often test drive cars/trucks for fun"
    Yeah, we do run into time wasters like yourself.
    I won't even comment on the rest of your post except to say you are correct. There are, indeed salespeople who know little about their product.
    I just hope I don't get you as a "customer".
    Seriously, I think you need a hobby.
    Here's the link for anyone interested: Confessions of a Car Salesman
    Haha. There is the chance I will buy something new. Test driving the Nissan Titan almost pushed me in that direction. I get 10-12 MPH in my Isuzu, I can get that in a full size truck. So it someday it may not be a waste of time.
    Hobbies, I have a few. I test drive 3/4 cars a year. Reading about cars on the internet is one my hobbies and it is great to get a chance to test drive something you read about. Next up is the new Nissan Pathfinder...which too has a chance to replace my Isuzu. Typically I bring my 5 year old with me so it can almost qualify as babysitting :-).
  • schulhofschulhof Member Posts: 71
    So what is everyone replacing the OE Goodyear Integrity's with?
    I think the Integrity's are poor on wet and snow. I am looking to replace them with a better light all terrain.
    My previous SUV, an Isuzu Trooper came with Bridgestone Duelers, then I put on BFG AT's ($$$) and then Kumho Road Venture AT's.
    I may put the Kumho's on the Pilot next. They were a great compromise between price and performance, a good value.
    What are you folks replacing the Integrity's with?
    -Eric
    How about Goodyear Fortera's? Consumer Reports rated them very highly, beyond the vaunted Michelin Cross Terrain SUV's that some MDX models get. Input on Tirerack.com is very positive, and some MDX owners who have switched from the Cross Terrains to the Fortera's are very praiseworthy.
  • crawfishcrawfish Member Posts: 39
    "For now, we are not thinking about it" for the three-year plan starting in April, says Honda President Takeo Fukui.
    SUV owners care little about fuel economy, Fukui says. "If they look for fuel efficiency," he says, "they could shift to a car."
    http://www.autoweek.com/news.cms?newsId=101529
  • kennynmdkennynmd Member Posts: 424
    My wife and I are expecting our second child soon (the first is still in a car seat). My wife sits in the back with him but will sit in the back as well when the next one is born. She has an ES300 which is too tight to have 2 car seats as well as her back there. My question is, what average size SUV's out there is wide enough for 2 car seats as well as an adult in the second row? We are looking at the MDX but 2 people in my family has it already(my sister just bought one 2 days ago and my brother already has one), as well as the Pilot which is attractive because of the price however and most importantly, no curtain air bags. Any input would be helpful..Thanks
  • jay_24jay_24 Member Posts: 536
    The Pilot will be a tight back seat with two cars seats and an adult. Most infant/child seats are right about 18 to 19 inches wide. The pilots back seat is like 56 inches wide. I have 3 kids that were in booster/child seats at the same time. It was just too tight all 3 in one row and to easily get seat belts fastened.
    Instead we went for a Tahoe with 61 inches of rear seat. Its not that much larger. The Tahoe is definitely more of a truck than the Pilot but it tows our camper probably better. Gas milage isn't that much different. we get 18-19mpg highway. The Pilots fold flat 3rd row is better.
  • anotherwagonanotherwagon Member Posts: 301
    Might want to also try the Ford Freestyle. We looked at both and the back seat (3rd) has a lot more room. The seats have a lot of different configurations. Also, in some models the 2nd row slides forward for more room in the 3rd. Also, has options for air bags.
    Highlander was smaller than the Pilot.
    We looked at a lot of different models.
  • qbrozenqbrozen Member Posts: 33,849
    gas mileage isn't that different when you get 19 on the highway? I supposed that depends on your idea of different, but we get over 24 on the highway in the Pilot. 18-19 is our CITY number.
  • enascar3enascar3 Member Posts: 18
    What kind of Pilot do you have to get 24 highway?
    I've gotten 22 to 23mpg on three tanks with the tahoe, but 19mpg is the norm for highway driving. Don't most Pilot drivers get 22ish most of the time?
    Sure its a difference but its only maybe 100 to 150 bucks a year (based on 10k miles per year)
    --jay
    well, to be fair, most vehicles have owners that vary greatly in their mileage figures. I'd say you're probably pretty close with 22'ish being an average highway number (being that I've seen numbers posted from 20 to 24, with teens and higher 20s being the few anamolies.
    We are actually VERY rarely on the open highway with the Pilot and, therefore, didn't discover that highway number until a recent trip. My wife spends over 80% of her time in city driving and manages to average right around 20 mpg on a consistent basis. Pretty good for a mid-sized 7-passenger SUV, IMHO.
    Out of curiosity, do you find your Tahoe mileage to be typical of owners?
    I'm not sure of other Tahoe drivers. My dads chevy truck and uncles Avalanche both get similar highway numbers. All have the same 5.3 engine.
    14-18 is whats on the sticker for the 5.3 and I think the 4.8 is listed at 15-19mpg.
    Notice however I didn't give you my city mpg numbers. :O They are closer to 14-15 and less if my wife lets it warm up. For the past 3 weeks its been around 10F. So it spends a bunch of time just idling. I think we had a 12mpg once or twice.
    we got the 23mpg in Yellowstone last summer. I guess our Tahoe likes a nice steady cruise at 45mph. 3 tanks in a row and filled up at the same pump too. Very pleasant suprise.
    The biggest reasons we didn't get a Pilot was obnoxious sales person and location of dealer ship. 30 miles to closest dealership. just too big of pain to get regular maint. done.
    --jay
    Thanks for al the replies. Jay, are you talking about the second or 3rd row seats that are 56" wide?
     I have too many friends that have American cars/trucks that has had too many problems. The most recent being a friend with a 02 Tahoe where the fuel gauge read full twice and it ran out of gas. Brought it to the dealer and they made some crazy excuse saying that he had too much stereo equipment and TV's in his truck that he hooked up wrong to mess up the fuel gauge. I mean come on! Also, I always had a Japanese car/truck (92 Integra, 98 Montero Sport, 03 ES300, 04 Sequoia) so I'm a little biased. The Pilot and MDX seems to be the widest for average size SUV's. Dpn't know where else to look...any other suggestions?
    Our MDX fits 2 seats and an adult in the middle. We use the center console folded back with a portable DVD player on it. My wife fits easily, I fit.
    The rub with the center position in the MDX is the seatbelt is very vertical, so it doesn't fit across the shoulder as one would think it should, overall the back seat in the MDX (and I am sure the pilot) is very roomy.
    As for MPG we get 15 around town and over 23 on the highway. I don't bother checking on the highway anymore, but the increased mileage on the highway is great for road trips because it minimized stops.
    Ken, Second row is about 56" but, I'm going from memory. As for your friend it was probably the sending unit. That is the one and only item I've had fixed on ours. How about that 04 Sequoia?
    The pilot did fit three across, but it ws tight and we dislike using the third row unless absolutely necessary since it takes up a lot of cargo room. Stop by a honda dealer and try it out. Take the infant seat and child seat and see if you fit. Other thing is your wife won't sit back there too long since you oldest child will be able to help out soon with handing toys and snacks.
    Granted this is a mini van but how about Toyota seinna (le-8)? Some models have 3 across in the second row. Middle seat moves forward so it can be reached from the front. The new Honda Ody has a 3 across option too but I think the middle seat is a joke, but haven't seen it in person. better mpg and cost less than a SUV.
    --jay
    Thanks for the advice again. A minivan is out the question. My wife and I can't see ourselves driving a van. As for the Sequoia, it will fit any and everything. However, my wife has a hard time parking and backing out a parking space. Might have to go with the MDX, eventhough thats my last choice since my brother and sister each already owns one.
  • cccompsoncccompson Member Posts: 2,382
    I simply don't understand why folks "can't see" themselves buying a minivan. They offer better mileage and more utility than an SUV and are usually less expensive to purchase. Minivans also tend to ride and handle better than SUVs.
    I guess imagery is powerful indeed. Guilty here too - my wife drove an Odyssey for 5 years and now has a Pilot, refusing another minivan.
  • carguy1234carguy1234 Member Posts: 233
    "My wife and I can't see ourselves driving a van."
    But the MDX IS a wagon/van! It's based on the Odyssey, it just doesn't have sliding doors. We are considering one due to it's van like qualities.
    We just like the SUV look.A SUV is higher off the ground and offers AWD or 4WD depending on what model. I don't know alot about the differnece between the 2 (pilot or Odyssey), but I'm pretty sure there are more differences than just sliding doors.
    Also, does anyone know if the Pilot will have curtain airbags in 06?
    Only Honda knows for sure and they keep things close to the vest.
    That said, given all of the '05 changes, it is a good bet that they will. They have said all of their vehicles will have them by end of calendar year 2006.
    Friend calls a Pilot a MUV, Mummy utility vehicle...
    Thanks. My wife and I are probably going to wait as long as we can and hopefully there will be curtain airbags in the 06 model. Probably going to have to pay close to MSRP but still better than paying for a MDX.
  • glycinemaxglycinemax Member Posts: 74
    "VCM will be applied to the 2006 Honda Pilot sport-utility vehicle scheduled to debut this fall. VCM deactivates three of the engine's six cylinders during cruising, deceleration and other low engine load conditions to reduce fuel consumption. This technology was first introduced in the U.S. in 2004 on the all-new 2005 Odyssey minivan and 2005 Accord Hybrid." --Honda President and CEO Takeo Fukui
    http://www.hondanews.com/CatID1000?mid=2005011134476&mime=asc
    I would expect side curtain bags this time around. Still a little surprised they didn't make it to the 05MY.
    Wish I could quote the source but I remeber reading that honda would have side airbags in all vehicles by 2006 models.
  • patricemqpatricemq Member Posts: 7
    I just got my new pilot 2 weeks go and love it but...Does anyone with the 05 pilot exl find the moonroof noisy when its closed? I have driven cars with moonroofs before and never experienced this but when I'm driving a min of 35 mph with the moonroof closed I still hear the alot of wind noise. Is this normal with the pilot I read reviews and they all talk about how quiet it is. I hope there is nothing wrong with my moonroof.
    "As a part of its "Safety for Everyone" commitment, all Honda and Acura vehicles sold in the U.S., with the exception of a small number of specialty vehicles, will feature Side Curtain Airbags as standard equipment before the end of calendar year 2006." --from 04DEC03 Honda News http://www.hondanews.com/CatID1003?mid=2003120457583&mime=asc- &archives=t
    So, they could hold off till 07MY but with the 06MY being the typical mid model cycle (MMC) refresh for the Pilot and VCM being mentioned as being offered on the (some?) 06MY Pilots I would expect curtains. Wonder what else will be done? Amber directionals? Clear lenses?
  • onlysurferonlysurfer Member Posts: 96
    how about voice activated naviation system ?
  • jondjond Member Posts: 43
    Has anyone tried to have a "fix" to turn on the headlights automatically when the ignition is on, or when it is dark. Could the system that is on the Canadian version of the Pilot be installed on the American version? Is that a different switch, or just a computer setting somewhere?
