Visitor Agreement.
If you don't need the 3rd row seat, what about the new Honda Ridgeline? It appears to have as wide a back seat as the Pilot, plus it still has a trunk (although smaller) and it can haul and tow way more than a Pilot. It is suppose to be available this spring and it will have side curtain airbags. If I didn't have three kids and a desire for the extra utility the 3rd row offered, I would be thinking Ridgeline right now (even though it is slightly ugly).
Is this really the case or did the salesman not know how to work the seats
thx
mick
In any case, yes, I have had issues with being able to fit things in the back of the pilot's cargo area, then finding I can't slide them all the way forward because the cargo area height gets shorter towards the front. thankfully we have the roof rack.
I do wish the Pilot had a opening rear window so long objects could be carried.
Gas milage isn't much different expect to save maybe $150-200 a year if you drive about 12k a year. SUV milage stinks. Don't buy based on that. If you really want to save gas money buy a car or van.
Size wise, you will loose about 6 inches in width on the second row. 56 vs 62 if memory is correct.
With three kids you want all the room you can get. I have three also with the oldest almost 8.
I'd say go Sienna with the 3 seats in the second row. That way the third row can be optional and gives more storage space for trips. But if the seats aren't comforatable....Pilot is an option, but I don't think you will save much $$.
--jay
I was wondering if anyone has a feel for how prevalent this problem is. Does it effect all Pilots or is it random?
We are considering the Pilot EXL and I know I could not live with such a problem.
test drive the one you buy, that's all.
Honda really should develop bigger engine to compete instead of increasing nominal HP year after year by tweaking the engine timing here and there.
Ever rev your Pilot to 5600rpm?
Hook a 2000lb trailer to that WRX and lets see how it does. Being fast is one thing hauling and towing is another. (And yes a WRX is rated to tow 200lbs)
It would be nice to have a choice of engines if the bigger(v8?) would also increase tow/haul ratings.
--jay
Thanks in advance.
yes, torque is important for acceleration, too, and I thought about that as I was typing my last post, and what I should have said was "all else being equal," but I assumed that would have been apparent. Displacement and cylinders just don't matter if the engine is not putting out its full potential. A well designed V6 can and does outperform a poorly designed V8.
The Pilot's low towing has much more to do with its suspension, frame, and tranny. That's why something like a Dodge Dakota with a V6 (210hp/235ft.lbs.) is able to tow more than the Pilot (255hp/250ft.lbs.).
And, yes, I've revved my Pilot up to and past 5600, why do you ask?
Dodge Durango: v6 215/235 = max towing 3700
v8 235/300 = max towing 7400
v8 hemi 335/370 = max towing 8900
(from Dodge web page)
Toyota 4runner: v6 245/282 = max towing 5000
v8 270/320 = max towing 7000
A good v8 with less or similar HP but more torque can out perform that v6 in towing and hauling because the max HP and toque will be at a broarder and more usable RPM range.
If you have hit 5600+ RPM on your Pilot you actually used its peak HP and Torque. However when you start from a stop sign at 1500RPM how much torque and HP do you have? how quick will you have 80% of max? Most people don't drive at normal speeds turning 5600rpm.
Bottom line it would be nice if Honda gave Pilot buyers a choice.
The improvements I expect on the next generation are better economy, better power, hybrid power, beter interior ammenities/use of space, minor size variance.
Of course I'm not saying torque has nothing to do with it, BUT, in the case of the Pilot, more than just the engine would have to be changed to up the towing. And I think the current V6 is capable of towing more, but only in the correct vehicle.
If you look at the power curves of a Honda V6, you'll see that the torque curve is actually quite impressive.
I'm trying to find exact numbers, but having trouble. Best I've got so far is this quote from TruckTrend:
It may sound like you'd need to mash the throttle to get smartly off the line, but the reality is that a large amount of torque is available at lower rpms.
I can't argue with you about choices. I'm all for more choices.
With the new Honda Ridgeline they are makeing that truck/crossover line pretty grey.
A small v8 woiuld be nice.
I agree with all you have said except for the choice of V6 over V8.
Considering only the performance, I will happily choose a V8 (for example, last generation 4.7L V8 in Toyota Sequoia, 240HP@4800RPM, 315LB@3400RPM) over the newest V6 in Acura RL (300HP@6200RPM, 260LB@5000RPM).
We all know the peak HP number is sales pitch. No average commuter like me drives at 6200RPM. In fact, most probably will stay between 2000-3000RPM. That is where the strength of a bigger engine shows.
If you look at the performance technical details of the Acura RL (at www.vtec.net), at 3000RPM, the engine is pretty weak.
Honda's major competitors all have bigger engines. Mitsubishi has 3.8LV6, Nissan has 4.0LV6, Toyota has 4.0LV6, even Hyundai is going to put 3.8LV6 in their next Santa Fe.
As I understand your description, it doesn't really sound as though it would be from the transmission though I would be hard pressed to guess the cause.
Now, I'll start out simply by pointing out that the new RL holds its own quite well in the luxo-sport-sedan category. 0-60 in the low 6-sec range is nothing to sneeze at. BUT, as has been pointed out, the competitors do at least offer a v8 option while no such option is available in the RL. Is that a disadvantage? Maybe a slight one. But let's not forget that the competitors sell MORE of their 6-cylinder models. Honda has always been about catering to the majority, hence their limited options.
YOu mention the sizes of competitors engines. This brings us back to my original point: displacement means nothing. Hyundai's 3.8? Considering their current 3.5 is nowhere near the Honda's power, maybe the bigger engine will get them a bit closer.
Mitsu is a decent example. Would you give up 30 HP in exchange for 5 ft/lbs? Like I said, i think torque is more important, but I don't think its 6 times more important.
toyota's 4 liter has good torque, yes, but its not available in the Highlander, which is the Pilot competitor.
Nissan seems to have a little powerhouse of an engine on their hands. And that's great, if that's your thing. Personally, I don't know if Honda's image of efficiency could deal with 15 mpg. I've seen plenty of complaints about 17 in the Pilot. And I, for one, would hate getting 15 mpg with a V6. That's what I used to get with my Dodge Dakota V8, and that's exactly the reason I got rid of it after just 2 years.
So, out of those competitors you listed, only the Nissan currently definitively overpowers the Pilot, and that is at a significant gas penalty.
Mitsu Endeavour has 255LB@3750RPM, compared with Pilot's 250LB@4500RPM. That seems more than just 5LB. More than that, Endeavous LS AWD is about 400 LBs lighter (roughly 4000 vs 4400). So I expect Mitsu has more punches during acceleration and passing.
Hyundai already has variable timing in their upcoming 3.3LV6 sonata and promises better acceleration than both Accord and Camry. It won't take long for them to enhance their 3.8LV6. At least they have something bigger to work on.
Pretty soon larger engine trickles down, I won't be surprised to learn the 4.0LV6 is tucked into HighLander.
When the next generation comes, Toyota has 4.3LV8, 4.7LV8. Nissan has 4.5LV8, 5.6LV8. As a loyal HONDA customer (87Accord LXi/92 Acura/03 Accord), I wonder what is in line for HONDA?
Finally, a knock on the Acura RL, which probably should be in the other forum. With MSRP around $49K, 6.7 seconds in 0-60, compared with Audi S4, with MSRP around $47K, 5.4 seconds in 0-60. Why is that? 3.5L V6 vs 4.2L V8.
Honda may already be quietly developing bigger ones and let's hope so. But please, Honda, I am with kennynmd, please put curtain airbags in Pilot first!
Enjoy the ride!
Also, with the highlander I've had AWD with traction and stability control. How do people find the pilot handles in snow, wet etc. without the trac and stability features?
Thanks for your input.
With 6 people you will need to use the third row. With just 1/2 of that up the rest can be for the dogs, but it would be tight if they are in kennels. Leaving little to no space for the rest. If it was 5 people I think it would work well since you wouldn't have to use the third row.
--jay
S4 vs. RL? There is an incredible size difference there, that's for sure. If I were to pay nearly $50k for a compact car, it sure as heck better be fast.
I just got a Pilot, one early question - Im pretty up to date and capable with electronic equipment (my vcr rarely had the flashing clock for months on end) an am suprised with the complexity of the RES. I can follow it adequately but had to read the manual, but it sure seems as if what I consider the average person in this regard will find the system very user unfriendly. I am counting the days till the first call from my wife, frantic with the kids screaming and she cant get the thing to work. For one thing, a menu and enter button at the front unit would have been nice. I think the play will act like the enter though, and why the heck is the dvd play button got "prog" on it as the primary description.
How much is the real difference between a Ody and Pilot? Have seen the numbers but numbers don't say it all. Is there a practical significant difference?
as far as no traction and stability control, we're now into our 2nd winter with the Pilot sans these devices. Its been great. I thought we'd at least have to replace the stock tires, but that has not been the case. Even with our recent 12+ inches of snow, the Pilot could not be stopped.
By the way guys(qbrozen & lxv603), towing capacity is weighted more on the vehicle frame construction and torque output of the engine, not horsepower. Remember, torque is the grunt to move the vehicle from a stopped position, horsepower is what gets you from 65mph to 80mph when passing someone. Look at a diesel truck if you want to see torque numbers vs. horsepower numbers.You can have a 255hp motor that packs 200 lb-ft of torque with a unibody undercarriage and you're not going to load the trailer too heavy.
A similar note, the Ridgeline is only going to have a 5,000lb towing capacity. That's the ol' Pilot/MDX/Odessey undercarriage with beefier control arms and axles (retaining AWD) and a little more torque from the V6. My Honda salesman thought my towing querries were a good time to bring up the Ridgeline, hence the info. The key here is capacity-that's the maximum the manufacturer wants you to pull with their vehicle. I'm not looking to tow a Bobcat tractor but if someone out there actually tows, I would appreciate any info.
Actually, according to Honda, the Ridgeline platform is heavily modified from the Pilot. IIRC, the exact number was somewhere around 90% new. so its much more than just control arms. The structure has been reinforced in many ways.
I saw the Honda page with the Pilot towing a ski boat and all that looks great but I know we're all suckers for advertising and I do use a trailer frequently. I liked the Pilot alot but I don't want to get into tearing up something. Just wanted to know how this thing handles with around 2500-3000lbs behind it. Obviously, I don't want to load up 60 bags of woodchips and limp my $35K beauty home only to find I stressed out or broke drivetrain components. Plus the wife would yell at me.
How much does a ski boat weigh anyway? I really have no clue about these things.
Honestly, I think I'd avoid the Pilot if I intended to do any kind towing at or anywhere near its limit on a regular basis. I mean, with the transmission issues, no matter how few and far between the problems are, I wouldn't take the risk. Heck, I'm looking at Accords and the only way I'd get one at this point is with the stick, and my reasoning is that I push my cars very hard.
I haul all kinds of garbage in the Pilot. I just tell my wife "hey, then let me go buy a pickup strictly for hauling duties." That usually stops the complaining.
Heh, are you softening the DW up for the Honda Ridgeline SUT - 2006?
