Visitor Agreement.
* Peanut oil. This really works. Peanut butter on trim is an old detailers trick. But if you want to skip the spread, use the oil.
* White eraser. Simply rub out the residue.
* All purpose cleaner, like Simple Green, and a small stiff brush.
* 3M Adhesive, Tar, and Wax Remover.
Any of these will take several applications and some patience on your part. I can't guarantee them but lots of people have used one or more to varying degrees of success.
My question is - if I go for a trade in when getting a new car, would it be better for me to fix this and trade it in or just let the dealer discount an amount for fixing it?
Its a 91 honda with 120,000 miles on it.
Or should I just patch up the paint?
They are a felt tipped pen filled with a polymer paint and available in nearly all colors for most cars. Read about them at:
http://www.autovisuals.com/
I've got numerous stone chips and a couple of big scratches I'd like to make go away and their pen looks easy to use.. Any experience with it?
Trying to sell the car, and two places have told me that the sloppy paint work makes the car look suspicious, when if the work was done right (so minor), it would never be noticed.
THANKS!
Does anyone have suggestions as to how to remove the tar and adhesive line that is attracting dirt from the paint without doing too much damage to the finish? Before you say Bug & Tar Remover, isn't that stuff really harsh on the paint finish.
But no way I'd do the job myself. That is sloppy prep work, imo, and you should return it to them with the evidence still visible, don't take "normal" for an answer, and have them make a record of t his in the file so if they cause damage later on you will have some recourse.
But then I'm one of those people who expect dealers to earn their money. JW
First I'd try to get it off with clay. Then I'd try swirl & scratch remover. Then I'd try mineral spirits. Then lacquer thinner. Then polishing compound.
Last resort: rubbing compound applied very gingerly, followed by polishing compound & swirl remover to restore a smooth finish, then wax.
I noticed the (red, orange, and yellow) overspray when claying my car before getting it professionally buffed out (to remove some scratches as well as some courtesy swirl marks put in the car when my dealer washed it).
However, after detailing the car last night, I still notice paint on the glass surfaces (primarily windshield and sunroof). I'm going to try claying tonight, but, if that doesn't remove it, what's my next step? I've already had my HR manager call the company, and they swear up-and-down that their new $300k paint booth won't allow this to happen (yet they frequently leave the large overhead doors open when they are painting. And gee, isn't it ironic that the paint colors on my car are the EXACT SAME colors they are painting the snowplows? Maybe the EPA'd love to hear about this problem... *sigh*)
--Robert
You can use a razor blade. Just spray the glass with a soapy water solution where you are working to keep it lubricated. You could also polish it off using a glass polish. Zaino makes a really nice glass polish (ww.zainobros.com) In place of glass polish you could use the same polish you can use to remove paint swirls. The really fine polishes are called glazes. 3M and Mequiars make a variety of paint polishing and glazing compounds that are sold in auto part stores. Or you can use toothpaste in place of polish. The whitening kind is more abrasive than the non-whitening kind, so I'd try the non-whitening kind first. I've used toothpaste for paont touch up too when I did not have any glazing or polishing coumpounds handy.
Tom
The car is only four months old, and I really want to forget the whole thing happened, so a repair shop that can make it disappear is key...
Recommendations??
Thanks in advance - Ed
I like Bigfur's idea of fine steel wool for glass, but I think it would not work well on a polyurethane finish unless you were getting ready to put another layer of polyurethane down. I think even 0000 steel wool would dull the finish.
I feel really bad about this, and I'd like to do whatever I can to repair it. What's the best way to accomplish this?
Are there services that will repair the scratch? If so, about how much could I expect that to cost?
I know there are touch-up paints, kits, and 'systems.' Are these adequate? Which "system" is the best?
How would a do-it-yourself kit compare with any service that might be available? Would either or both get it back to looking new?
Thanks a lot.
you want "eek!" make this your opportunity to learn how to do the above, then level it off with a buffer wheel and rubbing compound. the experience to make THAT work is why the body shop gets its money.
But if you want the Yukon to look like new, you will end up having a body shop sand and paint the entire panel. They would normally blend over to any adjacent panels as well. I would be very wary of any shop that would do that for $300. Depending on where the scratch is and how much prep work, I'd guess $500-$1000. IMHO, I would shop for this work by reputation, not price. If you spend $500 and the panels don't match perfectly, why did you bother?
Obviously, I'd prefer to have it look like new, however if that's going to cost $500 I just don't think it's feasible (or worth it, as it's not like it's a 'tricked out' collector's car). I guess I was hoping for something more in the $50-$100 range, maybe a step up from the kits.
But if no such range/option exists, then maybe I'll just try to find the best kit. Any reccomendations?
Thanks, I'll let you know if it works (or doesn't work!).
One thing I read mentioned using a "polishing compound" to smooth out the paint. Can you buy that at an auto parts store??
Thanks!!
After it's dry you can re-dab as needed until you fill the chip flush with the adjacent paint. Later (e.g., two days)if you want to you can buff the affected area a bit with "scratch remover" or "swirl remover," (on a soft fleecy cotton or microfiber cloth) which are mild polishes. I would not use polishing compound which is a bit coarser....it might add more scratches than it takes away.
Does anyone have experience with "today's paints" and can confirm that what the painter has told me is accurate? I believe he used an acrylic paint on my car and he explained that today's acrylic paints set up very, very quickly and the drying time is accelerated because of this.
Does this sound right?
The painter lives in Caldwell, TX. If you would like additional contact info., please let me know.
do hope you have checked with a magnifier for paint cracks which may still have occurred from either the injury or the dent popping. if they aren't repaired (if you get there early enough, maybe just some clearcoat and polishing compound could do it) you can still get rust and have the whole section of paint come off to show a big rust circle in a year or two. that is depending on how nasty your local weather is and whether they salt the roads.
I'm now wondering about that last one, the "paint sealant." The car looks great, and I'd like to keep it that way, and while I've waxed my previous cars (all junkers) they never looked that great. So... I'd like to inaugurate the car by hiring a detailer for $50-80 to do this.
Now to my question. One local detailer says he'd use cleaner wax, followed by butter wax. The other says, no, it needs carnauba-based wax.
Which one is right? This is all way over my head, as you can guess.
Thanks for any insight you can offer.
The undercoating, btw, has been attacked by many folk I respect as actually sealing in moisture and leading to corrosion and rust problems ... don't know but it surely is unnecessary.
The wax deal is entirely different. The answer depends on you and what you want to achieve and what kind of a guy you are for maintenance. Do you have a garage?
First, no reason you can't do your own wax. It has to be done relatively frequently and can get expensive to have it done more than once in a great while by a detailer.
Second, if you're really 'anal' about your car ... or plan to be for this, your first new car, then you should research (here at Edmund's is fine) two or three brands: Carnauba based -- Zymol, Meguier's; polymer based -- Zaino. Be careful of the Zaino guys; lots of them have taken car maintenance to the level of a religion and have gone a bit whacko with it. But the stuff is good. Both have their adherents and each is good. Both require regular upkeep and maintenance (no matter what they say) to remain in topnotch shape. You'll want to be putting on a new coat (depending on your climate) at least once every 2-3 months and stripping the whole car to start over at least once a year. With all this work, you should handwash rather than use a carwash, but you'll find that out as you read.
3) If you just want to protect the finish and keep it looking okay, any wax is okay really. Some last longer (paste wax for example) than others .... and if it's a wax that doesn't last very long (like a liquid wax, which is what many detailers use), I'd hate to pay a detailer every ten weeks or so .... or every time the water beads flatten out and the car needs a new treatment.
I have a reaction to the first detailer who wants to begin with a cleaner wax -- I don't care for that idea on a new car. A cleaner wax actually has a fine abrasive in it; the idea is to remove the pollutants and oxidation and stuff that builds up on the surface. But it also takes a tiny bit of the clear coat with it -- So on a new car I see no reason you need a cleaner.
So of the two choices you gave me, I'd go with the carnauba treatment. If you're using a detailer to save time, why not search around for a highline guy who will be willing (for extra $$$) to do a thorough job with paste wax which will last a bit longer -- of course you have to figure out if it will be worth the extra money.
Sorry if this is more info than you wanted! JW
One piece of info that may change recommendation?-- the car was sitting on the dealer's lot for six months. Not being driven, but being sunned on, polluted on, and rained on. Would that mean the paint is not really new, and that it should be waxed differently? If so, what would you recommend?
Broz
