Visitor Agreement.
he gets a larger chunk of the change than by selling turtle wax.
out of this world benefits: none. superior performance: doubtful. worth the difference? -- not to me.
Again, if you wish to be anal about the car (you haven't clarified that important issue), I would recommend having the car "clayed." This will remove any and all residue/pollution/sap/etc. I don't think any clay is especially better than another and all it amounts to is using a detailing wax as a lubricant and a wad of clay to rub over the surface of the car. Following that, a wash, then wax.
But if you're not going to be anal, the cleaner wax is still not needed (unless you see -- literally -- that the damage from the environment has had an effect).
You seem to be attracted to the high tech panaceas that are offered. Lots of passionate opinions out there. No convincing proof that I've seen. Sorry.
IMO. JW
Yup, I admit it-- I'm being anal (first new car. Not sure I'll do this again!) And since I'm fairly ignorant as well, I'm easy prey for hawkers of high-tech solutions, so all the opinions I'm getting here are much appreciated. I'll forget the expensive wax stuff, as recommended.
One other high-tech solution I'm drawn to: the 3-M front-end paint protection film. I've heard good things about it and it seems to be a better choice in some ways than a front-end "bra." Any comments on the film? Worth the $300?
Thanks again-- really appreciate the help.
recommended, and not just because they're a local outfit. my 90 ranger had similar film on the lower body, and it really turned the stones away.
Two words of caution -- it does yellow a little bit. So, especially on light colors, you might be thinking of perhaps replacing it every 4-5 years. The only real option to it is to have the same areas -- mirrors, bumper, lights, hood, etc? -- 'touched up' at a good body shop when it's needed. The clear bra is a more economical option.
Also: Make sure you get it done by an installer who has quite a bit of experience with your car. Some cars have lots of strange curves and the job will come out better if you're not the first one that the installer has done. Shop around a bit, ask for references, that sort of thing ....
Take care. JW
Use lots of water and rinse the mitt frequently. When the mitt starts looking and feeling grubby, replace it. I replace my chenille mitts every 7-10 washes.
Bug guts are quite acidic and can easily eat into your clearcoat. Some bug residue is very similar to shellac so sometimes a petroleum distillate like mineral spirits is needed. Most of the "bug and tar remover" products are nothing more than repackaged mineral spirits or naptha, which you can buy at the hardware store.
Here's how I remove them during a detail job:
1. Use a dedicated bug juice remover to dissolve the bond between the guts and the paint. This works great on fresh bug residue. I use a remover from Hi Temp Products that's designed for this very task.
2. Try some mineral spirits on the more stubborn guts.
3. Clay the area to remove the micro-sized residue that you can feel but can barely see.
4. If all else fails, bust out the compounds and polish off the residue.
None of the above is a guarantee of removing 100% of the residue. If the guts have been on the paint for months at a time, the damage can be permanent.
Don't forget to follow up with a coat of your favorite wax or sealant for added protection.
If buffing doesn't work, next stop is the body shop.
The scratches are not too bad - in fact, I missed them first time around - and there's not too much foreign paint on the bumper (which is plastic, by the way). I think they can be buffed out. My first inclination is to find a real good detailer.
1. Does anyone know of a good detailer in the PG County - Washington DC area?
2. If I can't find one, what are your recommendations for a buffing compound? This is a two-year old car, always garaged, no scratches or swirls, in pristine condition. I keep it clayed and sealed with Zaino (now Diamond Plus) and don't even put it away wet if I can help it. It's never been buffed and I don't own a Porter-Cable, but I'm willing to laboriously polish by hand if necessary.
Thanks for your help, all! gene
So I'm just curious, being completely ignorant (I've put wax on, but never removed it): how do you do remove wax without hurting the clearcoat? Thanks.
basically, they wash the car with stuff you are not supposed to wash it with to strip the wax.
now, when it comes to stripping paint off a car, you're into a whole 'nother kettle of crud....
That's why I keep a commuter car. Scrapes and door dings don't faze me on that one.
Interesting article...
Many factors that the article does not go in-depth with could be the answer to the surprizing findings that came from it, but it still makes you think. I personally think it is a bunch of BS, but of course I am not exactly a guru of washing cars, I just do what I can to make my car look its best....
What do yall think??
Every form of "professional" car wash -- automatic or manual -- that I've seen features recycled rags, water, dirt, and grit. I may take the car there to get sanded, but not for a wash ... now the high-pressure hose bays that are attached to some and in which you can do it yourself by feeding a coin machine quarters seems to work pretty well .... so long as you just use their hose and water and skip the brush and detergent. The brush is obvious, I guess, and the detergent is the high-test stuff I think that eats wax. I take my own washing equipment, and a bucket of water to boot, and use their high pressure wand to clean off the surface dirt, then I wash it with my stuff, and use their wand again to rinse -- works in the winter when my driveway is frozen over.
JW
My next step would be to clay the front end.
If you don't know about clay, ask and someone will surely explain. But don't go to an abrasive (cleaner wax) until you try that.
My guess is white paint from someone in front of you going across a fresh highway paint job and you caught their spray. So if my guess is right, you should do this asap as it won't get any easier to remove with time.
Keep us posted. JW
1998 Pontiac Grand Am
Mirror Replacement, Power
Removal Procedure
Remove the door rear view mirror bezel screw.
Remove the door rear view mirror bezel.
Remove power mirror wire harness.
Remove the insulator.
Remove the rear view mirror nuts.
Remove the rear view mirror.
Installation Procedure
Install the rear view mirror.
Install the rear view mirror nuts.
Tighten the nut to 5.6 N·m (50 lb in).
Install the insulator.
Install the power mirror wire harness.
Install the door rear view mirror bezel.
Install the door rear view mirror bezel screw.
Tighten the screw to 1 N·m (9 lb in).
What kind of adhesive works? Two part epoxy? Any application directions?
The body shop I talked to said that this is a huge problem with GM vehicles due to very thin paint that allows premature oxidation of the primer and then peeling. The body shop said the only way to fix this is to completely strip the car with acid to the bare metal and reprimer and repaint, very expensive. I feel GM is liable for defects in workmanship and should reimbursh owners for this repair. You could sell the vehicle, but who is going want to buy it? Talk about built in obsolesence!
if they repaint over the old primer, it's likely to happen again. sounds more to me like incompatible chemistry than a laughable top coat.
the effect would be like you get when you squeeze a corner of a heinz ketchup bottle really hard. there are several layers of plastic in those bottles, and they get a shattered look.
you don't want that. so if you decide to go whole-hog, get it done professionally.
