Visitor Agreement.
John
Anyone here experienced this problem? If so, what was your fix? I'm guessing for me right now, the best thing to do is go to Advance Auto or Autozone here in town to see if they can code scan it??? I don't even know where the service port is on this vehicle. Thoughts. Thanks and God Bless You (and The United States of America).
1) Gas cap
2) Evacuation Canister
3) & 4) some solenoid things (forgot)
ANY ONE RUN INTO THIS BEFORE? I've searched previous posts and it seams everyone that has run into this problem hasn't found a viable solution. HELP!!!!
i believe the emissions system is covered under a longer warranty than the 3yr/36000mi. look into it.
1) I called Honda of America; the only recall is for a transmission problem. No emissions system extensions...
2) I was told by a Honda Master Tech (schooling from Honda + >8 yrs of experience)
that the P1456 code thrown by my Odyssey is a TANK SIDE emission problem. If it were a solenoid purge valve/vapor canister, etc., it would have thrown a P1457.
3) Knowing that, I thought it foolish not to try buying a new gas cap. Went to autozone, bought a nonvented cap ($6.99)...OBD II scanned again...code P1456. Had the A'Zone guy reset/clear the code. Put on the new gas cap, making sure it clicked atleast 3 times after tightening...then had him run the scan...NO TROUBLE CODES.
4) Drove a couple of miles yesterday after the fact and the light hasn't returned *looks up to heaven, and prays to Jesus*
5) Will update in 2 weeks or so...
It's got 72k miles
Has leather, rear dvd, mats, all the typical stuff.
Extended Hondacare warranty to cover 6 years / 100,000 miles.
No mechanical problems at all
Two small dings/scratches (one on left slider, one on back door)
Dark Blue Paint that is still very shiny!
Tires still have plenty of wear
I was thinking of asking $18,000. Does that sound ok?
seems like you're asking a dealer retail type price to me. perhaps a tad high. i think the miles are on the very high side (maybe not for CA), although you got what, another year or so for warranty coverage? that probably adds something to the mix.
it's the kind of price that leaves room to take less. :shades:
Let us know how you do. Could be of future interest for many of us...
Yes. It's most likely a faulty tire if everything was good before.
Should be 225R16 98T
sbpceap, "Honda Odyssey: Care & Maintenance" #429, 30 Jul 2007 8:41 pm
If any of you can share your experience with lock cylinder problems in your ODY, can you post please? I have an LX obviously.
thanks.
We are thinking of this because we don't want to spend $500 per month on payments.
WOuld any of these be good deals, or should we not worry and just suck it up and go brand new?
Also, the transmissions in the '03 are suspect. The '04 may be slightly more reliable, however, the 2007+ has a rugged 4-shaft design borrowed from the Pilot & Ridgeline.
Here is a link regarding the class action lawsuit for Honda V6 transmission failures from '00-'03. link title
My 2 cents.
Two weeks ago, on July 4th, 2007, my wife noticed the rust on the outside-channel where the weather-strip is in the rear view mirror area. I took it to my dealer’s bodyshop area for them to look at and the bodyshop manager lifted the weather-strip showing most of this channel had rust area six inches long. He sprayed it with rustproofing and said that his brother’s Odyssey has the same thing happening. When I bought the van the dealer suggested that I buy a rust protection plan that covers all the vehicle’s panels. Unfortunately this plan does not cover this area. If it keeps rusting the weather strip will not fit into the channel designed to keep it into place. The driver’s side door has a lot less rust in this area. I was told that it’s unfortunate that I have over the ‘5 year warranty’ as I could have gotten new doors replaced ‘no charge’.
This certainly looks like a ‘design flaw’ and there should be a recall.
The body shop at the dealership worked up a price for Honda Canada and it came to about $4,800; with me to pay $2,800.
I send a letter of Honda Customer Relations in Toronto about their offer and my non-ability to pay more then $800 and this thing should not have happen. The early part of the week of August 6th Toronto Relations phoned to state what a great deal I had. I said I could not take it. Honda Relations left a message on Aug 14th for me to call. I spoke to Honda Relations on Aug 17th and they had lowered my price to $1,800. I showed a local Honda dealer and they suggest that CarStar look at it. CarStar said they could fix both doors for $534. My dealer says you cannot repair this properly without replacing the door(s) and Honda Relations says they have nothing to do with CarStar, although the local dealer uses CarStar for their body work.
If you own a 1998-2004 Odyssey, inspect this area... Take a close look because it is concealed and is not noticeable without lifting the weather-strip.
Also check http://www.odyclub.com/forums/showthread.php?s=&threadid=27939&highlight=door+ru- st
I would like to hear from any 1998-2004 owners with the same problem and what solutions were taken and what they might recommend.
I recently found a local shop who is very competent (45-60 yr. old senior mechanics and certified).
The private shop had quoted me labor and material,
A. $580 Timing belt/Water Pump NAPA. Water Pump life time warranty
B. $630 - Honda Parts, 12 month warranty on labor. Honda Warranty on Parts. Even I can buy the parts for them (I asked them).
I know that these guys know what they do and are honest mechanics. However, in the past I always took Odyssey to the dealer since I had extended coverage.
What is your opinion? Dealer or Private Shop.
another option... call another dealer. not all dealers will have the same pricing. may have web discounts as well. if no dealer is more competitive, the Private shop.
that price seems stratospheric.
We've had ours for the past 3 1/2 years, and it's been a great car. We haven't had any mechanical problems with it whatsoever (transmission included), and have only had to pay for maintenance items.
One thing I will say is that the brake pads did wear out faster than I thought they would (replaced them at 31K miles); however, we do live in a hilly area, and it is a rather heavy vehicle.
A 2000 Odyssey with 67000 miles. The timing belt was replaced during the 65k maintainance (all done at Honda dealers). The transmission is original.
Price is ~ $10,500
A 2003 Odyssey with 103000 miles. Don't know about transmission or timing belt.
Price is ~ $9,000
Both seem to drive fine, and are in comparable condition. Autocheck gives both clean reports.
Does lower mileage or fewer years matter more? Also, do these prices seem reasonable overall?
Thanks everyone for your help!
I just had a similar experience. My rear sliding door to the Honda Ody spontaneously exploded. Fortunately, none of my kids were in. I wasnt sure what happened and would not even have bothered to look this online since I had already called GEICO and they sent their guy to change the window for a $50 co pay. But when he opened it up, he said that the regulator had broken and that I would need to have it replaced by the dealer. I guess people may not be reporting it because the burden of proof is sort of on you that you didnt have something break it besides it being easily replaced by theinsurance companies. Fortunately no one has been hurt but I cant fathom the implications if a little kid is sitting in the back when this happens.
Thought of adding the list for others to find something should anyone else report this.
you mean the rear vent windows aft of the sliding doors?
I have a 2004 odyssey and have a strange problem which I have been unable to duplicate when I take the car in to the dealership. If I slowly accelerate upto either 30 or 40 mph and try to maintain it at that speed, the car shudders for a couple of seconds and then smoothens out. It happens more frequently at 40 but is intermittent. If I speed thru these speeds (say speeding from 0 to 60), the upshifting works fine with no such problem. Any ideas?
MP
All Odyssey models from 99, 2000,2001,2003,2004,2005,2006, 20007 have faulty transmissions.
Dont make the same mistake....
We have tried the wheel balancing and tire rotation thing several times over the past 4 years to no avail. My wife drives the van and for the most part in the suburbs so she does not notice this problem. It's only when we drive on highways that I notice this and it is VERY annoying. The problem actually gets worse everytime we take it to the dealer for a service that includes tire rotation!!
My questions:
- Is this something that others are seeing?
- Any thoughts on a solution?
- If this is unique to my van is it even fixable?
- Should I buy extended warranty given that we are out of the 3 year warranty period (We get calls and e-mails from companies offering warranties)?
The van probably has less than 30,000 miles on it.
Thanks for your responses!
Vger
