Visitor Agreement.
any help is appriciated!
A possible solution is to replace the Brake Transmission Shift Interlock (BTSI) SOLENOID. The Saturn dealership pronounced it "bitsy cell-a-noid" - It is the circuit that tells the keylock mechanism that the car is parked and allows the key to rotate to Off.
I was experiencing intermittent problem whereby ignition key would not remove from ignition switch after automatic transmission is placed in Park.
Replace the Brake-Transmission-Shift-Interlock (BTSI) SOLENOID circuit.
New BTSI solenoid fixed my 2007 Saturn Ion when the key would not rotate out of the ignition lock cylinder after car was placed in Park.
