Visitor Agreement.
Check the pressure first ! If it is OK, then I've seen posts here about a need to have the front subframe shifted.
http://www.honda-accessories.com/odyssey/drift.pdf
The problem may not be real common overall, but it is one of the more typical complaints you see on the forums (Suspension, sliding doors and transmission/Torque converter problems seem to be most typical).
FYI, for delivery there is a nice checklist:
http://www.1netweb.com/checklist.htm
Finally, you can see list of problems by going to the NHTSA complaints forum (http://www.nhtsa.dot.gov/cars/problems/complain/compmmy1.cfm). The Odyssey is listed in the "Honda Truck" category.
I too had a hard time getting use to putting the van in park so the power doors could be opened, so I modify the wiring to the EX power doors so they can be opened in drive.
After the mod the doors still will not open when the van is in motion, you must be stopped. The van has two power door safety features, (park and motion) disabling one does not effect the other.
Some time back there was much debate as to whether the modification was wise, but the doors on the LX can be opened anytime... including in motion.
(You can for your own safety put the van in park whenever stopped, but LX owners, when dropping the kids off for school, do not have to put the van in park so the doors can be opened,
is the LX van less safe?
or is the driver less safe?)
I do not wish to restart the safety debate again so if anyone is interested in how this was done, let me know.
1. Steering is making clicking sound while turning at very low speed(< 20mph)
2. There is rumbling sound in the rear every time I come to a stop for 2-3 times(Gas Sloshing???)
I'd called my salesman immed. but it was about 9pm and he asked me to bring it on Monday(12/11). I promptly did that but after wasting few hours they gave it back to me with a note "Vehicle is driving as expected at this time" eventhough salesman and mechanic both verbally agreed there is abnormal noise.
Can anyone help how to solve these peoblems?
What options do I have as I still owe some money to dealer though I've signed credit papers?
Is it worth compalining to Honda or under Lemon law?
They ran their tests and say everything looks correct. They suggested I wait until the low fuel light comes on, then fill up. It should take about 17 gallons according to them, and I should do this twice and see if it's 'accurate' both times. I'm not thrilled with filling up the van, I'd rather keep it around 1/2 a tank, but will do this to see if the gauge shapes up.
I believe the majority of the other posts I've read about the fuel gauge weren't fixed. If anyone did get their gauge fixed, please post with what was done.
this will work??)
Yes!
And pulling the fuse for 10 seconds is one heckuva a lot quicker than waiting on a service tech. At the dealers around here, it's at least 1/2 day.
This too inconvenienced me. I found directions many posts ago in this form on how to modify the power door wiring to be able to open them in any gear as long as the van is NOT moving.
It may not be for everyone, but I was able to do the modification to our 2000 van without any problems and I'm happy with the results.
I recall several responses "chastising" the original requester for even thinking about such a modification. Some may still feel the same way. Before a safety debate is started, let me say the same as the original poster, the power sliding door control unit also has an input from the vehicle speed sensor, so even with this modification, the sliding doors can NOT be opened if the vehicle is in motion.
There is input from the gear position switch on each sliding door's control unit. The doors can be opened when this input is grounded, which normally only occurs when the transmission is in Park. A snip to a wire and it's attachment to ground causes the input to be permanently grounded, and thus making the door think the van is in park, regardless of the gear position.
How to:
Rather than taking off the door panel(s) to expose the sliding door control unit, you can tap into the wire at a more convenient location. For the left side door, remove the driver's side kick panel (where the hood release is) and you'll see two gray and one light blue connector all next to each other. In the middle connector, (I don't remember it's color but it is the one in the middle of the three) look for the wire that is black with a blue stripe (also has 2 silver bands on it). Cut it at a convenient location. Use electrical tape and wrap the end that comes from the gear position indicator. (This will not be used, although you may wish to test its "continuity to ground" when in Park to make sure you're using the right end.) I attached a second wire and soldered them together to add length then grounded the other side of the wire to the large bolt nearby, which holds everything in place and the sensor will be permanently grounded.
Similarly for the right side door, remove the front passenger kick panel (it contains a little door that opens to a bunch of fuses). At the bottom of the fuse box you'll see two connectors, one gray the other light blue. In the light blue connector look for the black wire with a blue stripe (also has 2 silver bands on it) and do the same thing as above.
Prior to the surgery, the doors could only be opened in Park. If the driver shifted into gear while a door remained open, the buzzer would sound. The doors can be closed, even in Drive.
After the surgery, the doors can be opened in any gear position, provided the vehicle is NOT moving. No buzzer sounds if you shift into Drive while the door is open. However, once you start moving, the buzzer goes off. As before, the doors can be closed at any time.
Now, don't get me wrong, I avoided ABS on my personal vehicle for a long time as I was convinced that the difference in initical cost and repairs was not justifiable in my mind as a substitute for driving for the conditions and properly using the brakes when one is surprised.
(I recently had an exciting experience while pulling my 17ft sailboat. It had rained, but was not raining at that instant. As I approached a stop sign, I felt my wheels skidding (actually noticed that the deceleration from braking was not proportional to effort on the pedal). However, because of the early application of the brakes (since I was towing and it was wet) and by not panicing and shoving ever harder on the pedal, I was able to come to a stop at the normal point. My wife and the backseat passenger were not aware of what had happened. When I said "Wow, that was a little scary." they had no idea what I was talking about. It was scary because the vehicle didn't respond as I expected, but it did respond within acceptable limits to avoid a collision. (This was a T-intersection, the other side of which was a 10ft chain link fence that would have not done my boat or body work any good.)
That's not to say that one can always sufficiently anticipate these things to avoid losing traction. One should not use ABS as a substitute for cautious operation and proper training, but it is an added edge to help when the conditions cannot be anticipated, and you need to maintain control to avoid, or minimize the effects of, a collision.
I would not disable the ABS on a vehicle that has it. (I don't have a lifeboat on my 17 sailboat, but I wouldn't pierce a hole in one that was mounted thereto.)
After driving in wet, snow and ice, I have come to really appreciate this system. Whether stopping or accelerating, this van is much more drivable and "predictable". I have experimented on numerous occasions by climbing a snow covered hill (or my driveway) with and without TCS. TCS wins hands down every time.
This new software seems to be overly and unnecessarily cumbersome. In order to swap from one forum to another (i.e. Odyssey XXX to Odyssey Problems VII), one must log-out and then re-log-in. Cumbersome. to say the least.
Also, under the old software, it was an automatic log-in, if you allowed cookies. With the new software, it doesn't appear to have an auto log-in when you click to the Forums using a bookmark.
Shortly after the second time that I start the engine after the fill up, *both* the TCS *and* the Check Engine Lights will come on and stay on. If I stop and shut off the engine, the TCS light will be off when I next start the engine; but the check engine light remains on, no matter how long or how far I drive. If I stop the car, shut off the engine and reset the computer by pulling the proper fuse for 10+ seconds, both lights will be off and remain off until the next time that I fill the fuel tank, when the sequence starts again. FWIW, the fuel cap is always closed tight enough to hear it click 6-8 times upon closing. I have not taken it to a dealer with a diagnosis tester (although I might do it to satisfy my curiosity); because, as long as I can reset everything as I am now doing, I really don't care to have a dealer nick me for the reset.
Thoughts, ideas?
As to cheating the system, if there was a real problem, the check engine and or TCS lights would come back on immediately after resetting them. However, my curiosity is up; so the next time it happens, I'll probably take it somewhere with a diagnostic tool.
Has anyone had a moonroof put into the EX and if so, any problems?
Also, what did the dealer charge for the moonroof?
Thanks in advance.
Rick
I think somewhere back the "plain" Odyssey discussion someone had a moon roof installed with great success. You'd have to do a search or post your question in that discussion to see if someone will remember. Or you can try e-mailing timothydavis. He is a long-time member and regular contributor to most Odyssey discussions.
vbeauchamp,
Checked my 2000 EX today -- 20 mpg in a mix of mostly local and some highway driving. You have to have a problem of some kind to get 7-10 mpg -- towing an unseen trailer, parking brake on, all uphill driving in the snow-- just kidding. I'd push your dealer harder!
Terry
thanks,
ryan
Any ideas ? Did anyone seen this before ?
(We'll see if this goes through. I had tried the -- very sucky and non-intuitive spell checker the first time I tried to post here and it didn't post; I just got kicked back to the main topic list. Looks like bugs galore.)
I are a enginer butt I don't kneed spelchek cause I can spel goot! :.)
You may also want to watch these two relatively short video clips on ABS vs. non-ABS, and how to properly use ABS:
Click here for "Stomp, stay, steer"
Click here for the ABS education alliance's video
Hope this helps!
Drew
Edmunds.com Townhall co-host
Vans and Aftermarket & Accessories conferences
The manual states that for normal driving, all that needs to be done beyond oil change is air filter replacement and AC filter replacement.
I called Dublin Honda (Dublin, CA) and Mel Rapton Honda (Sacramento, CA). When I asked what is it they were going to do for 30k service, they gave me a list which included valve adjustment, transmission fluid replacement, coolant flush, brake flush, and distributor cap replacement. By the way, the list of services from both dealers was different. What shall I do? Stick with owner's manual or follow dealer's advice?
Sergey
Here in MA, doing severe service from the manual is the norm and that is what I try to stick by. The dealer many times will come up with their own schedule. I believe Honda knows what is best for your vehicle.
Neil
FYI, ABS on more expensive luxury vehicles can be a lot more refined. For example, Mercedes-Benz's ABS hardly has any brake pedal vibration. The noise is still there, but that's also so you know that you're braking at the limit of adhesion.
Drew
You did not post a reply to #54. Hope you solved your sliding door problems.
Thanks for the response. My wife (and I) will feel better now. It was a concern, considering we are traveling to Chicago for the holidays. I guess it will take some getting used to on our part.
Drew
