Honda Odyssey: Problems & Solutions:(1995-2004 Models)
                    Here's the new place to continue seeking Town Hall
members' advice/support for Honda Odyssey
problems. For links to past discussions, please
see Honda Odyssey Links.
KarenS
Vans host
KarenS
Vans host
I had lost one of my remote keyless entry for my
EX. Do anybody know how much is the replacement
cost? Do I had to bring my van and the other remote entry to the Honda dealer so they can reprogram the new remote keyless entry? Thanks.
[and others with similar problems]:
Do You have a LX or an EX?
You probably know what you meant to say, but did not say so. There is no 'defroster' for the front windshield. There is only a "defogger". Defroster is at the back only (cross wires on glass).
LX - you have to control the heat level and fan speed manually. EX - (if you have it) you probably have already set a comfortable heat level, and based on the temperature within the vehicle (as reported to PCM via temperature sensor on steering column) fan will, on full automatic, revolve correspondingly. To override, you must use the fan speed dial, to your preference.
Everyone knows that fogging is caused by moisture breathed out by people entering the vehicle on a cold day, and/or atmospheric moisture entering vehicle when doors are opened. Made worse by us trying to heat up the vehicle faster by pressing 'recir' button (which is not incorrect, though). Defogger essentially routes in air, heated, via the heater core. Enough heat evaporates the moisture/fog within the vehicle.
The trick to quick defogging is using the a/c, since the a/c works as a de-humidifier as well. On EX, pressing the defogger button does three things automatically. Air is directed fully towards the windshield plus the front door panel vents to clear the side glasses, a/c will come on automatically and last, fresh air is drawn into the vehicle (recir light will go off, if it was on). If you have a crowd of excitable party kids in the vehicle pouring out lots of moisture, you can (initially) leave the rest of the system on automatic, but manually override the fan speed to a more slower and silent level.
If you have LX and your fan speed does not increase with each increment of the switch upto max speed, then your fan speed switch has failed. If your defog button does not direct 95% air to the windshield, then your vent control module has failied. These items will have to be replaced by dealer.
If you have LX and defog button and heat level are set, to aid defogging, press a/c switch to on till everything clears. Once the vehicle is warmed up and you use other switches (front vents or feet) to re-route warmed air, cycling the a/c once in a while will remove any built up moisture. Remeber that in any air vent position, some air is always directed towards the front windscreen.
If yours is EX and, in full auto, if the fan does not increase in speed as you dial in temperature, then your fan speed potentiometer has failed. This needs to be changed. Note that fan speed is tied into temperature control. If you constantly keep the temperature control on high, you are going to have high fan speed unless you override it manually. (Same thing in hot weather with a/c. The colder you want the vehicle, the higher the fan will run. Dial in temp closer to ambient and the fan speed slows down).
Check everything out. If you need more diagnostics, post your findings. Thank God your dealer did not design this vehicle; you might have to drive looking out of your side windows.
Good luck and careful driving.
and others with this problem:
I have not tested the '01 but found out something strange with the '99.
ALWAYS leave the cabin lights control switch (full on/door-open on/full off) in the same position when opening and closing your sliding doors. WHY??
Once, with the switch off, I opened the right slider. I then put the switch into door-open position. When I closed the slider, it would try to close, beep, retract half inch, stop beeping and not close fully. You can see the gap front and back of door. Thought I had another problem on my hands. Actually left door that way to attend to some urgent work. On returning sat and re-though my actions when closing the door. Suddenly struck me that I changed the switch position. I opened the door. Put switch back to 'off' and walla, the door just slid into place like nothing had happened.
Your problem Reposer, in my opinion, needs to go back to the dealer. But before that; how many times does this happen, what frequency, intermittent or continuously for a period of time? Next, just make sure no grime is preventing the control cylinders from moving freely. These are on the inside of the door and make contact on the frame.
Note that these are contact switches. By looking at the 'knock' point on receiving edges you or the dealer should be able to verify if they are in alignment.
I am of the opinion that your contact assembly is not properly aligned. Cannot imagine it being identical on both sides, but your post does not mention if the exact same thing happens with both doors at the same time. Or, if it is with both the doors or just one door.
Again, be patient and persistent. Dealer services are scared to go near anything electronic. They try brushing it off. They will stall you, waiting for the regional tech to make his monthly visit. Your situation also tells me a trouble code could be set, so have the dealer extract it (if that one or others exist in the PCM). The doors fully closing is good. Beep going off and not coming on again when switch turned on means the PCM could/is emulating 'fail safe mode'. Chances are the door is not likely to open by itself and anyway, it is deactivated when the vehicle is taken out of Park. If you are concerned with driving the vehicle till you see the dealer, a second safeguard is to lock all doors when driving. That prevents the unlatch mechanism from cycling.
Get it seen to and fixed as soon as you can. Post your results. Till then, safe driving.
I seem to remember that a while back, someone proposed changing the wiring for the doors to permit them to open while the vehicle was in gear but not in motion. Also seem to remember much debate as to whether that modification was wise.
Did i understand correctly that you traded 99 for an 01?
Interestingly, I once asked the manager of the Toyota engine factory in KY how he would break in an engine, and he said "I just drive 'em without worrying about it". Not the answer I was expecting.
Also, somewhere I heard that Mercedes-Benz does, or used to maybe, tell owners to change the AT fluid after the first 1,000 miles. The break in period supposedly puts a lot of fine metal particles in the fluid and should be removed. Important? Who knows. I do it to be on the safe side. To get most of it out, I drain it, fill it, drive it, three times. When I saw what was on the magnetic drain plug--basically a lot of fine metal--sort of a mud, I felt like it was a good thing to get that out of the transmission.
I also put the Honda trans cooler on my van. It's not really a difficult job, although a little scarey taking the bumper cover off. I think the dealers only charge about an hour labor to do the job. The transmission gets so hot under normal use, I'm guessing that going over mountains, and/or driving a heavily loaded vehicle makes it even hotter. These vans are heavy to begin with, so I want that transmission to stay in normal temp range. Toyota puts a trans cooler on virtually all their Sienna LEs, so once again I took their approach.
Even the oil change interval in MBz vehicles from MY1998 onwards is extended from a minimum of 10K miles to a maximum of 20K miles; there is a computer monitoring a variety of parameters (engine load, driving style, temperature, oil qualtiy/viscosity etc.) and will adjust the flexible service system counter as needed.
Drew/aling
Townhall Community Leader/Vans Conference
Look like it's time to go after those EX wheels next.......I'm spending more time driving rentals than I am driving my van....... ;-(
The problems that I have don't occur always, but occur frequently enough. If I drive the van for 30 minutes, I can pretty much guranteed that the problem will occur.
I think that my van is having a problem with the transmission. However, when I took it to a Honda dealer for service, they told me that they didn't find any problem with my van. They also told me that I am the first person ever to report any problem with the transmission, or like as I discribed.
I am taking it to a Honda service again next week.
Does anyone have a similar experience? And, how serious is my problem? I am bit concerned because my wife drives the van with two kids who are only 3 and 1 year old.
That's okay. I know it is difficult to tell rpm from the tachometer.
Not only for transmission break-in, but for everything else, do, do work each and every gadget and if it pertains to drivetrain, at different speeds. Don't stop using cruise-control. In fact, use it as often as you can, and if the intercity roads have moving but slow traffic, use it there also but carefully. This will break in the cruise modulator. Try holidng cruise from its lowest speed setting (30mph) up to your normal highway speeds. Only thing, don't keep it extended for >20 miles at one setting.
Your accelerating rpms are just fine. 70mph max for a little time longer will help both engine and transmission. On your upcoming trip, on a mountain road, maintain a constant speed and unless you come across a really slow vehicle, resist the urge to floor the gas and overtake at high speed.
Yes, transmissions take the worst beating. Read posts of just about any manufacturer, including the costliest vehicles, and the crowning problems are transmissions.
Glad to be of help. I will assist any way I can, other than having my own repair shop.
Keep my notes when checking your wheels. At the outset I don't want the dealer to make things worse. Front wheel alignment is as tough as it can get.
Safe Driving.
and others
Just forgot something.
I have practiced this for 25 years and it has appreciably helped to extend transmission life.
I have substantiated this with my transmission mechanics, but a dealership service or general garage may not be able/willing to do so.
When stopped at an intersection or in long standing lines of rush-hour traffic, expecially at night with lights on and/or (at any time) with a/c on, for >15 seconds, put the vehicle in Neutral (and keep your foot on the brake) [Anticipate traffic movement]. This will help the engine to rev under no load, keeping its cool and conserving fuel. The transmission clutches will also be disengaged and the torque converter will idle giving the fluid a chance to cool. You will get longer life from the guts of your transmission.
Factory dynamometer tests are done under 'no-load' conditions. It is a free-standing run with no vehicle weight to pull. Break-in is therefore necessary, and if possible, with no extra weight, like when travelling.
At every fuel stop lock the gas cap and let it click five or more times. '01 models have a vapour recovery system that should eliminate having to click the lock three times (but I am waiting for more information on this fix).
Take care.
Drew/aling
Just hope that those of you who has this problem does get it resolved.
Just took my 01 EX to service guys and they found higher-than-normal and different tire pressure on all 4 wheels (stupid me for not checking it myself). They said that the pressure was as high as 50 psi on one of the wheels. After equalizing the pressure on all wheels to 32psi, the car handles perfectly and there is no more pull, as well as steering wheel looks straight. Also, the pulling to the right when accelerating has also dimished greatly and is insignificant at this point - they said it is normal since axles have different lenght on each side of the van. The ride became much softer and quieter. I think that 32psi is a bit below mfr suggested 35psi, so I will increase it to 33-34psi.
As to squeaking driver's side inside door handle - they removed the door cover and lubricated "rod to latch clip". The squeaking is gone.
Now I am very happy with the van and, barring future issues, my faith in Honda cars has been restored. Happy driving everyone.
Still, since this would concern upcoming Odyssey models, a new topic would be appropriate.
KarenS
Vans host
So, is it 35psi when a tire is "cold" and the outside temperature is 70F or outside temperature 25F ???
Does anyone have chart(s) of tire pressures vs. outside temperature vs cold/hot tire ?
never shows completely full, even when I top it off, the reading is about 1/8 tank down. BUT sometimes it does go to the top of the gauge. It's almost like the float was sticking in the tank, but not always! Also re: the spedo accuracy, at 60 to 70 mph its exactly 4-5 mph less. I've used a GPS and this is about the norm all the way to 85 (so you're really doing 79-80).
When I went to service my O1 EX last Friday and mentioned the fuel tank issue (can not fit more than 14 gals when empty light comes on), the service manager said that his computer indicates tank capacity at 17 gals, wondering whether the manual is incorrect or he is just trying to ignore the issue.
My 3 other friends who also own Ody indicated the same issue with their cars.
Maybe the car really has 17-gal fuel tank. Then, a 3 gal reserve is a norm. Does 2k1odyssey has exact dimensions of the fuel tank - we all can do the math, right ?
That's how my gauge problem was handled and it has been working Ok for the last 5000mi. Good luck.
i tried to read the recent postings, but didn't
find an answer. i plan to buy a '01 EX, but
want to know if the transmission problem has
been fixed by now. i remember reading a few
months back that there was a problem w/ "knocking" sound coming off the transmission
axle. Did Honda fixed this problem?
in your opinion, is Odyssey a mechanically
reiliable vehicle?
lexor
I have the same problem with my ex 99. I went out and bought new one and it fell off again some days later. I dont know what to do now. Should I bring it to dealer and complaint to them? How to fix this problem? Any suggestion would be appriciated.
Is yours a '99/'00 EX? Yes, in cold weather the slider panels begin to make funny noises; like something is loose. This is due to the press-in tabs used extensively.
If you have a good dealer service, request them to remove the panel/s (right and left) and put in new tabs. Do this when cold as the new tabs will seat in better. Interior of the panel may also need some insulation on door frame contact surfaces. Alternatively, have them change the panels to (original) '01 panels. I understand that they were strengthened/modified for 2001.
Please post your results.
I don't know what US dealers charge for a keyless fob. You do not need to go to your dealer if you are able to get this elsewhere. I think the owners manual describes how to programme/reprogramme a remote. However, if you are buying one from your dealer, take your van and the second remote to them and have them do a full job. Though this is not a warranty job, I am sure they will do it goodwill (free) for you if you have good relations with them.
Happy driving.
I have yet to put in 1000kms on the '01 Ody. You might have read my last postings re why I changed over to a '01. Knock on wood, till now no funny sounds or rattles and the vehicle drives well. I have not tried any driving tricks with it yet since it is not fully broken in.
I am a very sedate driver and don't do jack-rabbit starts or hard braking. I anticipate my driving. Both the '99 and '01 operate the same way and I do love the drivetrain. Smooth and responsive.
Yes, I traded in the '99 for a '01 for its added items (like factory installed alarm system) and wanted to get away from the rattles, etc., that were the bane of the first model year vehicle. You read my post/letter to Honda Canada re problem with clutch pressure control solenoids. For now, everything is working well and I am looking forward to many years of driving this van.
Happy driving.
I get the impression that (when sitting down) you put pressure on the backrest without it being properly latched. Did the seatback jerk back one latch stop? If it did, the sudden movement could have released/broken the latch release handle behind the seat. Does the latch work properly after that incident and does it allow the seatback to latch-stop properly?
If you cannot work the latch handle, then something in the assembly is broken and your dealer should be able to fix it under warranty. If everything is working properly, but you still hear something banging and moving around within the seatback, then your dealer will have to take the cushion covers apart and check inside.
Hope you find a quick solution to this noise. Please post your results.
Olman... you might have read my earlier posting re LX wheel shimmy. I am still of the impression that Honda bought some out of parallel/round steel wheels from some manufacturer and is still disposing them off.
It may be time to get the service tech to drive the vehicle and convince him that a set of EX wheels are in order, or a brand new set of steel wheels with a different production batch number than that shown on your present wheels.
Good luck and happy driving.
Your dealer must be out to lunch...or, you are the first person to come to 'him' with the transmission problem. Lucky dealer, he is.
The symptoms you relate are typical of clutch pressure and shift control solenoid failure. There are quite a few and one or more could have failed. Your PCM is now in a state of confusion as some fail-safe emulations could be interfering with normal operation.
Did your dealer service drive the vehicle and did the tech experience the same things you did? If not, he is going to tell you that he did not find any problem with the vehicle.
Did the dealer raise your van on a hoist and carefully check all the underbody drivetrain components? In particular, check both the front brake assemblies. Loose shims could be cause for vibration when braking.
My reading tells me that 'thunk' and grinding noise between 0-30mph is probably being caused by improper clutch pressure & shift control from gear 1 to 3 and lockup. Jerking back and forth when trying to stop indicates that your torque converter lockup (and unlock) control solenoids are "confused". (Not engineering talk really).
You could be looking at one or both of two problems.
First, one or more of your control solenoids is in the process of, or has failed.
Second, the PCM has failed. Meaning, you have a computer problem.
The PCM can be diagnosed by your dealer, once he admits that a problem exists.
Chances are he has very little to no experience with transmission failure. The only way to diagnose transmission failure, if he has already isolated the PCM and found it to be okay, is to hear the sound when it appears, feel what is happening, pull over and listen for unusual sounds in the engine compartment. Failed external solenoids emit a whining sound of varying intensities. Since you may not know where these are located, doing a diagnostic by yourself may not be possible.
Try the dealer again, or find another one. Post your findings and/or if you need further suggestions.
You got me on that one. It did not strike me to check with you if you verified your tire pressure. My tire tech tells me that high inflation could distend tires in an abnormal way. Meaning, up to a certain pressure (about 5psi above tire rating) the tire maintains it rotundity. Beyond that apparently puts pressure on 'pressure-points' on the tire, and it could bulge or distend around any of its surfaces. Your pull to left and right could just have been the emulation of worn/out-of-toe tires in their over-inflated state. Thank God you and the family were safe and nothing untoward happened.
I found 35psi to be hard. I keep my tires at 33psi cold.
As to measuring cold tire pressure, get a good quality pencil type gauge and check the pressure first thing in the morning (inside your garage or outside where you park it - so long as your garage is not the sealed/heated type). I have never placed much trust in checking it after a drive, since many conditions can actually affect the temperature of air within the tire after a drive. Ambient temperature and driving conditions call for how fast or slow a tire cools over a period of time.
Set all four tires to the same pressure. If one drops below the intended pressure I use a bicycle pump to put in a couple of psi more and then deflate it to the right pressure. I check this every two weeks. The 'cold' temperature you set the pressure at is the ambient temperature at the time. If you have very wide temperature fluctuations (20C or more) over a period of time, reset the 'cold' pressure. Don't let anyone at garages, fuel stops and other places check/change your tire pressure. That is not the time to do it.
Also, don't let anyone check your oil level at fuel stops and such places. Oil has not drained back into the pan and, possibly, your vehicle has not been parked on level ground.
Glad to know that the handle creak was fixed.
Take care and Happy driving.
Bschwarz, you say that you have approx 10 gallons left and the "needle" shows 1/4 tank. The lamp does not come on?
If the lamp comes on, then read my previous posting/s. Angular/uneven surfaces could tip the fuel/float right down to signal the computer to energize lamp.
Lamp not coming on but needle lower than normal gives me the impression you could have a malfunctioning fuel sending unit.
Only way to fix it is to inform your dealer right away that you notice this problem, have him register (with date) your call of concern on his computer, and then check this at least twice more, each time recording your findings. You see, a slowly failing sending unit won't replicate the problem right away, say the next tank of fuel, but could go down the tank after that.
If you notice the problem repeated, a new fuel sending unit is in order.
Bluff, you are looking at a similar problem as Bschwarz, but in the other direction. Could indicate a sticky float or failing electronics. Have you shown it to your dealer service? If you have, and he has recorded the incidence more than once, a new sending unit is in order.
Bt the way, don't get bullied into not having it done with excuses that the tank has to be taken down, etc. The Ody has been designed so the fuel sending unit, inspite of being inside and on top of the fuel tank, can be accessed through the floor by removing a flap in the carpeting and lifting a section of the insulation.
Alexmish, this vehicle was designed/built in Canada. All design specifications are metric and the tank was designed in 'litres'. Metric to Imperial gauging is easy enough and all US owners see Imperial markings (miles, gallons, etc.).
If your service manager says his computer reads 17 gallons tank capacity, I won't say he is wrong. Except that his equipment is calibrated in "Imperial Gallons". Double talk here, but don't get confused. In fluid measure there is something known as Metric Measure, Imperial Measure (UK) and Imperial Measure (US).
The Ody is calibrated in US Imperial Measure or US Measure, i.e. US Gallons. 1 US gallon is 3.7854 litres, while 1 Imp. gallon is 4.546 litres. Therefore 75 litres equates to 19.813 US gallons (and not 16.49 Imp. gallons as deemed by the service manager). What we have in the Ody is a 19.813 gallon (say 20 gallon) tank.
Mind you, if it was a 16.49 gallon tank, imagine the fantastic fuel economy we are getting from the engine. (18/26mpg for 16.49 gallons instead of 19.813 gallons of fuel).
Volumetric, from total dry to base of filler neck, the tank takes 74.81 litres. Your "reserve" is typically 3-5 gallons on a very near flat road from the point the lamp comes on. (Cannot remember if the gauge has a coloured mark too). There is no typical switching from regular to reserve tank.
Gas tank cap clicking has to do with pressurised vapour recovery and fuel return pressure. Gauge repeatedly not reading properly warrants a replacement. The shop manual does not relate tank cap closure to sending unit function. They are not connected.
Safe and happy driving to all.
from. The service manager seemed fairly nice
and he claimed that it took about 3-4 hours to
diagnose and identify as problem with the
actuator. Our dealer provided a 'loaner' car
for a day while they was working on it which
was handy..
We will be waiting for the part to get this fixed.
Meanwhile, I would be interested to hear if
others had similar problem.
"Failed external solenoids emit a whining sound of varying intensities."
I have a 2000 LX purchased in Nov.'99. Once in awhile (not very often, and maybe only in colder weather) I hear a very high-pitched (almost only able to be heard by dogs) electrical-whine emanating for amidship. I can hear it from inside the cabin, but it is louder outside. Sounds like its loudest toward the middle of the van or just in front of the rear wheels.
I have none of the tranny problems (drones or clunks) discussed in this forum and no other problems with the van (aside from an occassional rattly noise from a slider). Just this occassional (somewhat rare) whine.
Since I have no problems, I have attributed this whine to a normal operational sound. But when I read your comment, it made me wonder.
Fortunately the solution is simple. Just grab hold of a metal part of the vehicle (the door frame edge will do) before you get out and hold on until your feet touch the ground. Holding the metal will allow the building static electricity to drain back to the vehicle without that sudden and annoying jolt.
