Honda Odyssey: Problems & Solutions:(1995-2004 Models)
12357126
  • alexmishalexmish Member Posts: 47
    The way I see it, the decision should be simple. If you are dissatisfied with tyres' performance and know that something else is behaving better, then go for it. Each driver has its own driving habits, therefore there is no "silver bullet" solution.
    I have 01 EX with Michellin tyres - snow and ice performance, together with TCS, is excellent. Even without the TCS, I can not complain. But then, I am a careful driver and take it very easy on snow, always try to anticipate changing road and traffic conditions.
  • bjbergbjberg Member Posts: 2
    I have an '01 Odd with 4400 miles on it. Was driving home on Christmas Eve when the check engine' light came on. The manual states that it could be caused by the gas cap not being tight enough which, if it is the case, the light should turn off after three trip's'. I've had the van out for three trips and the light is still on. Can't figure out why this is on. Will schedule apt. with dealer but wanted to find out if anyone else had this same experience
    As alexmish said - if you are not comfortable driving with the all seasons, get other tires.
    We put snow tires on our Odyssey without even trying the Michelins in snow. Since my wife is the primary driver and this is the go everywhere on weekends vehicle, we felt it was worth the $ to get them. First time we have used snows since 1984. Although the weather here in MA hasn't been too bad (only 4" thus far), I felt the snows combined with the TCS makes it a very surefooted vehicle. Will find out more on Saturday as the forecast for MA is for somewhere between a dusting and 24".
    Will advise perfomance later and good luck with your decision.
  • piglet1piglet1 Member Posts: 4
    My Honda service cannot figure out why my traction control light and check engine light will not go off. I just brought it home after they kept it overnight and now it won't idle and unexpectantly accelerates on its own. They told me to go out to the garage and disconnect the battery cable to reset the computer.
    Oh - They said be careful driving, it could be dangerous to drive. My wife has a relatively trouble-free Chevy with 75K miles. I am 6K miles away from warranty expiring - what can I expect then? I beginning to think Honda quality is mostly MYTH not reality.
  • auburn63auburn63 Member Posts: 1,162
    I would think that it is the shift interlock solenoid engaging.Try leaving the key on car/van in park then press and release the brake and see if you hear the same noise.
  • jlanzajlanza Member Posts: 3
    I have pumped 20.7 in my 00EX. Manual says 20gal cap. Dealership says extra was in the filler tube. I must have been running on fumes. 10k so far and no robs, except paint is peeling on door handle. Wonder if rings on my wife's hand is causing the rob. Anyone else expert this ?
    Also get 25mph hwy 18city
    Makes you wonder, doesn't it? I put 20.3 in my Quest a year ago at a Drifters Phillips 66 in Carlsbad NM, when 18.9 is the most its ever held otherwise in a "20" gallon tank.
    Overfilling newer cars with OBDII can mess up the emissions sensors and set off the CEL, btw.
    Steve_
    Vans and Aftermarket & Accessories Message Boards
  • minimanminiman Member Posts: 85
    Sorry to hear of your pain. I recommend hitting the Better Business Bureau. Look in the back of your Owner Manual for the address and get a letter of complaint with documentation off ASAP. I would not rest until this is resolved, especially if your warranty is on the fritz. Remember, a squeaky wheel gets oiled, so squeak! Write down everything said and by whom (esp the comment that driving it could be dangerous). At a minimum, they should extend your warranty.
  • rcsantosrcsantos Member Posts: 2
    I am new to the Odyssey owner club and to Edmunds town hall. Purchased an LX in August. Happy so far. I am experiencing the vibration problem that has been written about. I have spent quite some time now trying to glean the nuggets from the threads on this problem but don't feel I have it quite yet. A neighbor told me about a wheel problem but I haven't seen any references to a wheel problem. Any old timers in this message board that knows of this problem?
    Thanks for your time and help
  • gyegye Member Posts: 31
    Had a EX for a month now. Always get a sore left arm by driving it for long time. Initially suspect of awkward driving position, late on found out it is vehicle's pull to the right at any speed that requires left arm constantly pull the steering wheel to the left, which builds up the strain on the arm especially on long distance driving.
    Took it back to the dealer, problem was confirmed by tech. Fixes including rotate the front tires, align the 4 wheels(all out of spec.), and pull the subframe. Still pull to the right after the repair.
    What bother me the most is the pull of the subframe. In Honda TSB for the fix of the drift, it states that 10 bolts need to be loosened to free the subframe completely before the adjustment can be made. As I was watching the repair took place, the tech only loosen 3-4 bolts and then start to apply large force on the left side of subframe and tighten the bolts when force was applied.
    My question is will this cause permanent deformation and damage on the subframe and suspension parts?
    Our family bought 3 Hondas in the last 4 years, '97 and '00 Accords, and '01 Odyssey, we are more and more disturbed by all the quality problems show up in our cars(Transmission leaking on '00 Accord V-6, only partial fix).
    My wife and I talked about not buying Honda again in the future, but we are also afraid to get into something worse. Right now we are just very very disapointed with Honda.
    Where do people get access to Honda's TSB (technical service bulletins)? I can't find them on the web at alldata.com where most other manufacture's are available.
  • johnnyrfjohnnyrf Member Posts: 65
    Just got the opportunity to drive our Odyssey with stock Firestone tires in the Northeast storm. Unfortunately, I got to drive in 6" of snow plus on the highway. The tires were unimpressive, however the traction control system got me up an unplowed long steep hill on the back roads with no problem.
    Didn't think the Ody would handle it, but the TCS performed excellent and made up for the lousy Firestones.
  • mfridaymfriday Member Posts: 4
    When I test drove a new, 2001 Odyssey DX today, the transmission appeared to slip when I acellerated going uphill over a freeway overpass. Has anyone else experienced problems similar to this? Or any transmission problems?
    I did not purchase this particular van, and it sold within hours after my test drive! Before I make a purchase I plan to test drive on hilly terrain!
  • larcklarck Member Posts: 22
    I understand that there is a recall for a multiplex unit (some kind of light controller thing) on quite a few 1999 through 2000 Ody's. Mine is a 2000 LX delivered in December 99. I have not received a recall notice from Honda. Is this just limited to EX models? If any of you would like to share info on this, I would appreciate it.
  • ryr10ryr10 Member Posts: 2
    Have had my car for 2 months.
    Cloth seat creates static build up and we get an 'electric shock' every time we touch the door upon getting out of the car. Is there a fix??
    Is there anything that can be done to change the color of the rear turn lights from Red to Amber or yellow? The red light I'm sure is cheap (single plastic moulding) but we hate it!
    Would love to hear a fix for these...
  • ggermainggermain Member Posts: 1
    I am a new Odd EX 2001 owner, and did not see this problem elsewhere in the posting. This afternoon, while sitting in my van, the horn suddenly began keeping, and all the lights began flashing. At first, I thought I had accidentally hit the "panic" button on my key less entry, but quickly came to the sad conclusion that this was not it at all. This was in the middle of a packed parking lot, and was very embarrassing!! I ended up having to drive home like this. After about a minute, everything went back to normal. However, each time I would unlock the door, the same thing started happening again. This happened 3 times before it stopped. It stopped only after I got home and used the OTHER key less entry set of keys. I read in the manual about this happening if you have the 2 key sets in close proximity, or possibly in contact with metal. At the time, I had the engine off, and the keys were in my pocket with 2 bank cards and a cell phone. Was there some kind of harmonic convergence with these items together that caused this problem. I REALLY, REALLY would rather not have this happen again, especially while driving. Any similar problems?
    Transmission slipping - possible explanation is the hill-holder feature of the transmission (I forget Honda's technical name) but this feature works nicely - on an uphill it holds a lower gear to give you the power to accelerate, and on a downhill it downshifts when it detects you wanting to slow down (on a downhill, sometimes you feel an light shift after applying brakes; that is transmission downshifting to provide additional braking). I assume there is no tranny prob in the van you tested, but if there was it is now someone else's problem!
    On amber turn signals - I noticed that the turning lights have the more trendy clear lens appearance than the upper portion of the tail lamp assembly which has the older fuzzy red. I have been wondering if you can place an amber bulb behind the clear lens and get the orange turn light effect w/o replacing plastic lens covers. If anyone tries this, please report back.
  • spangler1spangler1 Member Posts: 9
    I have had a problem with my '00 Odyssey right sliding door opening mysteriously and unexplained on a number of occasions. I took delivery of the vehicle in March and to date I have at least 12 documented occurrences. I keep the remote controls on a table when not in use. Some of the door openings occurred at night. The problem has occurred in three states and one occurred while the vehicle was in motion. The door openings have been full as well as partial (several inches). The vehicle in motion incident was only a few inches. My dealer says he has only one other case with the same problem. He said he changed the remote controls and that seemed to cure the problem in the other vehicle. He also said that he has heard that there appears to be a bad batch of remote controls which are super sensitive to vibration, temperature, movement or some other stimulus that cause this problem. He replace my remote controls about 2 weeks ago. The Honda area representative told him to order new remote controls and not to use the ones he had in stock. So far I have not had a reoccurrance of the problem.
    I had intended to put the remote controls on a vibration table and do a three axis vibration test but the new controls came in before I got a chance to perform the test.
  • ruggbruggb Member Posts: 5
    Mine does to. RIGHT side. Notice that the right side button is bigger than the left side.
    I decided it is the brand of jeans I wear. ;>)
    Solve the problem by not carrying the FOB in your pocket or
    LOCK the doors. Then it requires an unlock first.
    I did this once but lost the recipe.
    I thought it was by removing fuse 13 for 10 seconds, but that didn't work.
    Anyone know??
    Not carrying the FOB in my pocket does not solve the problem. It has opened at night with the FOBS on a table. Keeping door locked at all times probably would solve the problem. But, that door ain't suppose to open unless someone actually depresses the button. The dealer has indicated that a bad lot of remote control devices have been shipped with some vans. Replacing the FOBS have in one case seemed to solve the problem. The jury is still out in my case.
    I still don't understand how an intermittent FOB problem could cause the door to open while the vehicle is in motion. Do you have an explamination for that?
    I am just guessing at this point. I can't prove to myself that the button got pressed in my pocket. Since it is the right door all the time and the right door button is bigger I drew this conclusion.
    It could also have something to do with the fact that it looks like an Ody dealership here.
    Got two across the street, one next door and one on the back street. Maybe someone elses FOB like I opened my neighbors garage door with my opener.
    I'll have to experiment more.
    Thanks for the quick response to my question about the transmission! Next time I road test I'm bringing someone with me who knows enough to tell if this was a problem - or just the "hill holder" feature! I like the Odyssey better than anything else I have tested, so I'm hoping it won't be toooo long before another becomes available!
  • mschafermschafer Member Posts: 317
    Press the odometer reset button. Then, start the car and continue to hold the button in until the light stops flashing. It's reset, and this procedure is outlined in the owner's manual too.
  • zaxcdzaxcd Member Posts: 1
    Bought a LX last week and while driving the car back home, both the Check engine and the TSC light popped up(remain on until the key is turned off).Pressing Traction control button does not have any effect on the light.
    The next time when we start, only the Check engine light pops back up. Took the van back to dealer next day and was the problem was fixed ( some code problem). The very next day the same lights popped up again.
    Has anybody faced this problem?
  • cbendercbender Member Posts: 1
    My LX had the sticking door problems that others here have discussed and most recently, the door latch for the right (passenger) slider busted. My wife was opening the door and didn't realize it was locked and some internal mechanism broke such that the door cannot be opened from the outside. When I took it to the dealer, they informed me that there is now a service bulletin on the sliding door gaskets and they would replace both side gaskets and the right side latch. I was a bit upset with them since the van had been there just two weeks prior for a scheduled maint and no mention of the bulletin. Anyway, I tried to convince the service manager to replace the left latch as well since they claimed that the reason for the right one breaking was the excessive pulling stress from when the door was sticking. I told him that the left door had stuck as well and so that should be replaced, but then he gives me this story about how only the right side latch has this problem. This sounds utterly ridiculous to me. Any advice? I'd love to hear from someone who has had the problem on the left so I can use this as ammo. I really don't want to bring the van back when that latch breaks.
    Also, anyone experiencing problems with the slider appearing to be ajar such that the interior lights and the dash indicator go on? Seems to happen only occasionally, and usually if I break hard or go over a bump. I have no idea if the door is really ajar or if it's just the sensor. Still does it even after the dealer "fixes" it.
    Btw, is there any way to search for keywords inside one of these discussions? It's a real pain to page through hundreds of postings.
    Earlier in this very topic someone posted on a similar problem in an older van. Look earlier in this Problems VII topic and you will find it.
    Read up on your local lemon laws and get the van back again and again until you force them to give you a new one because looks like they cannot solve the problem. Indeed a headache, but press Honda on this one. If your dealership cannot help, then write to Honda regional office, then to BBB. Directions/addresses in the back of the Owner Manual.
    It is a total disgrace that any manufacturer will release vans with some of the problems we read about here. Toyota and the American brands are not exempt. They seem to feel that once you buy the vehicle, screw you. I think the multi-billion $$ companies can stand behind their products a little better, but unfortunately, why should they? If you or I choose not to buy another Honda, then there are 3 to 6 months' worth of other in line right behind us.
    I own a '00 EX and have been disappointed at Honda's less than stellar record thus far. Unfortunately, Honda's competitors offer little better.
    Glad to have helped.
    I now favor the LX model. I have an EX; really wanted the TCS and was ambivalent about the power doors but in '00 TCS was only avail on the EX. Steering wheel stereo controls and auto-off headlamps are cool, but not essential. Now that LX has TCS, bag the power sliders, they are more trouble than they are worth. I think GM invented the power sliders (figures), but Honda has not helped them evolve much. My sister's '99 Winstar also has power sliding door problems. I think they are inevitable; add 'power sliding door malfunctions that the dealer cannot fix no matter how much time you waste going back again and again...' to the list of taxes and death.
    My 99 EX with 75k miles on it just started this recently. I have not brought it in to the dealer yet, so I don't have a solution either. Even though it's the TCS light that's coming on with the CEL, the service manual indicates that this can be a whole lot more than just the traction control and/or antilock brake systems.
    FWIW, it sounds like your dealer just reset the PCM without any real fix being applied. I do this myself by pulling the correct fuse, and the van will then run for anywhere from minutes to days before the lights pop on again.
    Keep us posted on developments and solutions. I'll do the same.
    Just a thought about door suddenly openning. I don't think it has anything to do with the FOB. Remember, if you push a door button on the FOB while the doors are locked, they should not open. So it is always you must first unlock the doors (press the unlock button TWICE) and then open the door. It is just too many thing to happen "accidentally" in the right order with correct timing (doors self lock if you did not open them after 30 sec after unlocking).
  • jjohn2jjohn2 Member Posts: 2
    I have a 2001 EX that we only drove for 1 week before it was towed away. They have had it at the dealer for 40 days and it is still not fixed. The main computer has been replaced twice, also the main wire harness has been replaced. we have formally asked Honda to replace it, but no reply yet...
  • rattles33rattles33 Member Posts: 18
    I've got a 99 lx, for the most part we like the van- good value even at msrp. I have noticed some irritating items since the bad weather hit the midwest.
    1. Hard to keep the windsheild fog free, have to have the air on alot.
    2. wipers are appalling, especially the pass. side. Only 8,000 miles and they perform like 50,000.
    3. No traction control offering on the lx is a bummer. would of liked to have had that option sans power doors of ex. Still does ok in snow, but could be better if I'd get rid of those firestones.
    I heard from Honda today. they have taken the stance that if I want the van replaced that I will have to go to arbitration or lemon law... has anyone else had this experience.
  • lumanskilumanski Member Posts: 39
    jjohn: I'd like to know which problems you had with your Odyssey. I am considering getting one but I know there have been some major problems reported (hence, this discussion site). You can email me at darin.luman@brannforbes.com
  • sfg2sfg2 Member Posts: 1
    I recently traveled during the holidays and had an incident with the gas pedal being frozen so that I could not accelerate. This seems to be a serious safety problem. Anyone experienced a similar problem?
  • msibillemsibille Member Posts: 275
    I don't have much info to base this on, as I haven't heard the whole story, but my question would be whether you got the response from your dealer, or from American Honda?
    I had my first Ody replaced and in very short order (expected a fight, but didn't get one) after I met w/ the Svc Director and gave him copies of my documentation of the problems, including the number of attempts at repair and the results of same. My guess is that if the vehicle is truly a lemon, the dealer would want to handle it quickly and quietly - and so would Honda. If, however, the dealer svc dept is chronically incompetent, they may be downplaying the vehicle problem and describing you as unreasonable. After all, Amer. Honda will only replace so many vehicles as lemons at a given dealership before they figure out that these guys are incompetent.
    In any case, gather your documentation as though you are going to have to go thru the process of invoking the lemon law. Bring copies of same to a meeting w/ the highest level of management in the dealership that you can get to and explain that you want to be reasonable, but that this has gone beyond your patience as well as the requirements of law in your state. NOW -- all this assumes that you did in fact give them a reasonable opportunity to fix the problem. Such a reasonable opportunity is generally defined by the lemon law as to how many attempts and/or calendar time that has transpired where the dealership was unable or unwilling to repair the vehicle. Further, you should apply your own sensibility as to what you would expect the customer to endure if you were in business and selling the vehicle. My thought is that whichever of the above is the most tolerant, that's the one that would rule.
  • patupatu Member Posts: 4
    Thanks to 2k1odyssey for the suggestion.
    It seems that recycling the doors several times has reset the synchronization of the doors. I have not had the problems for two weeks now. We shall see if this is the fix for the long haul.
    Note to POSTS #86 and # 187: Try reading post #164 for a suggestion regarding the doors. Mine seems to be cured for now. It also appears the dealers have no clue how to resolve the issues.
    My suggestion is that it is something electrical or software related. The dealer claims that he fine tuned the adjustments???? Pretty poor design if a two ton vehicle has to be fine tuned to make it work porperly. Also, if it was a mechanical design problem, it would be showing up much more on this site.
    Thanks again.
  • timothyadavistimothyadavis Member Posts: 322
    It may be hard to avoid using them as reference, but realize that the post numbers on this new software are dynamic. If an early post is deleted, then all the subsequent posts drop back one number. So, try not to use the numbers alone, if at all possible. And, if you are looking up a referenced post number and it doesn't seem to be the right one, try reading a few post prior to that one....
  • drew_drew_ Member Posts: 3,382
    Yes, the message numbers are dynamic. This solves the problem of people asking, "Hey, where did post # xx go?".
    Drew
    Host of Vans and Aftermarket & Accessories message boards
  • 2k1odyssey2k1odyssey Member Posts: 68
    To Alexmish – Post #180
    Hi Alex. Glad to know that you had a safe trip. Don’t have NAV in Canada but have used the one in the Acura – really neat stuff.
    Did you have a problem with the rear washer itself (fluid spray) or the wiper? I am trying to clarify if it is the same product but understand Canadian models come with a heavy-duty wiper for frost and snow. Your dealer could possibly carry a heavy-duty rubber strip, if not the whole unit.
    Sorry about the less than impressive gas mileage. Factors such as load, terrain and cross-winds do effect consumption when travelling, compared to ‘ideal conditions’ numbers provided by the manufacturer.
    Did you inform your dealer about the sticking brake switch? If going to him is not too much of a bother, request him to spray the plunger shaft with electric lubricant. It could be spray or grease and will benefit the switch if moisture has already gone in once with possible corrosion of metal contact points.
    Speeds over the “ideal” 93kmph (60mph) also contribute to poor mileage, and with 87 octane I would say that 22mpg may not be too bad. Regular 87 octane is fine. I used it on my ’99 for inter-city driving and put in 91 octane just for the needed oomph on hilly highway driving. My 2001 has only tasted 91 octane but don’t know what was filled first time from the dealership.
    Take care and happy driving.
    To Delfb – Post #183
    No, there should be no clicking when turning the steering either way. There is a condition applicable to such a noise and it has to do with your vehicle’s rack-and-pinion setup. I am advised that your dealer should do a complete check of the system including the power steering pump and fluid pressure. Breakdown of power steering fluid (which ‘technically’ is a special Honda product) has been attributed to this noise as well. Please take the matter seriously and work with your dealership service department. Steering clicking in certain models of GM vehicles has led to ceasing of the rack and loss of steering control.
    Take care and drive carefully.
    To Miniman – Post #187
    You need to work with your dealership service department. ‘Operating within designed specifications’ means doors working perfectly, no questions. But you have problems with your doors.
    Please read a previous posting of mine (probably in the previous discussion number), and print and take it to your dealer if needed. I have comments regarding use of cabin master switch with doors open, as well. Your doors are completely out of synchronization. I don’t mean to rap all dealerships, but I have noticed that quite a few in the US don’t seem to care for their customers.
    Let me tell you right off that your repair is very time consuming and the manual procedure will have to be followed in sequence. Motor running with door partly closed means the revolution counter is out of sync. You could have a problem with the latch mechanism (a recall) where too much grease interfered with the latching process leaving the door technically unlatched, meaning the latch hook curved in before contacting the striker plate. Use of the master switch to stop a sequence and moving doors without switch in off, further aggravates the problem.
    Working with your dealership is the only solution. If you have a good personal mechanic, a complete shop manual and a free weekend, you could probably do it yourself.
    The genesis of the problem is electrical technology not normally reserved for the every day use automotive industry. A number of conditions, including atmospheric, can generate a malfunction. The solution is available – in your hands or in the hands of your dealership.
    Good luck to a complete repair and possibly please post the results. Thank you.
    To Rlam1 – Post #189
    I was not trying to be smart or anything. Please don’t ask me how, but a few postings entered on that day all came up with unknown letters and numbers between my words. I was told that it was a problem with the new system. If you want a repost of that information, drop me a note and I will do so again.
    Per your service advisor, 18 out of 20 gallons only usable is incorrect. So long as the pump sucks up fuel, you can use it to the last drop. The exact moment (in terms of volume) when the lamp should come on is nearly impossible to replicate in regular driving conditions. It is based on the float switch.
    Replacing your fuel sending unit may not solve the problem. Sending unit problems are more attuned to improper high or low level dial gauge readings and not when the lamp could come on. However, you can go ahead and have it replaced.
    Also note that this ‘lamp’ problem exists with every horizontal fuel tank. It does not do so in vertical fuel tanks. Over the years horizontal fuel tanks came into existence since the vertical ones reduced either the cabin or trunk space and front wheel drive-trains allowed more space for a horizontal tank under the vehicle. Most manufacturers of vehicles with horizontal tanks did away with the lamp indicator as it was more bothersome than useful and only left the level gauge indicator. This problem is more pronounced in very wide and low height tanks, which is what the Odys have.
    Yes, fuel volume is related to temperature, because it is a volatile liquid. However, fuel volume to temperature is adjusted (and corrected) at the pumps and the liquid volume you put into your vehicle is what you pay for. (Will you be willing to pay for 10 gallons if only 9.5 gets into your tank? The volume/temperature correction factor should also be stamped on the pump indicating at what temperature the correction factor is applied.) Your service advisor has picked up different pieces of information, but is not providing them in the proper context.
    Please post your findings after the sending unit is replaced and you have a chance to check this situation again.
    To Mike734 – Post #190
    To All posts interested in this topic
    In my opinion, I don’t believe any Ody owner is really interested in knowing the dry-run volume of the fuel tank, other than it is volumetrically a 20-gallon tank. I don’t believe anyone also waits to run the tank dry before filling up.
    It is neither given in your owner’s manual nor in the workshop manual but your fuel level lamp light is designed with a special mechanical intention. Due to terrain or any other condition like a weighted down trailer hitch, if the suction mechanism sees less than 75% if its volume of fuel, it will signal the PCM to put the lamp ‘on’. A warning to fill up above the level, but not necessarily a full tank. On a low bed tank, so as not to suck up churned debris within the tank (collected over time), the lowest portion of the suction mechanism sits approximately half-an-inch from the bottom of the tank at a higher position than the tanks deepest portion , where debris is allowed to settle and collect. There is no adjustment; by design it will sit at the right height when installed in the tank.
    By design, you can never “run-dry” a fuel tank. There will always be one location where the float does not reach and which holds some fuel along with debris suspended in it. However, from the moment the sending unit (that is why it is now called a sending unit and not the more commonly used ‘fuel pump’) sees less than 75% suction, it is in the process of destroying itself. Letting the unit draw percentages of fuel up to 0% will kill it in a matter of time. At the outset it will begin to malfunction. Additionally, damage has been known to be caused to the fuel pressure regulator and fuel injectors.
    Under warranty, a dealer service department will change your sending unit if it ‘malfunctions’ in a purely electrical manner, meaning, lamp coming on too early or dial gauge not reading properly. A mechanical sending unit failure (ceased pump) is very, very obvious and evident and can be checked very easily by the dealer. In all likelihood he will not replace it for you under warranty.
    This is my caution to you. I have seen it happen, I have heard the words exchanged and in the end the customer paid for the unit.
    Drew:
    I don't get what is happening. What are all these signs and digits appearing in my messages. It is confusing.
    Note that I am not typing directly into this area. I am putting the information into a MS Word file and then cutting and pasting sections. Could your experts there tell you if you wordprocessing package is utilizing the right links?
    I need help with this ... or posting becomes tiresome to read.
    Thanks Drew
  • rlam1rlam1 Member Posts: 6
    Thanks for your response 2K1Odyssey. The sending unit has been replace. Waiting for the gas light to come on again. Will let you know what happens. But from what you were describing, it wouldn't fix this problem. I guess this is something we have to live with. My brother-in-law has a 00-ODY and they are experiencing the same thing.
  • ktongktong Member Posts: 6
    Fuel gas light: I have owned '87 Prelude, '91 Accord, '00 TL, '98 Odyssey. They all have 17 gallon tanks, the fuel gas light starts coming on when there is 4-5 gallons of fuel left. This
    is normal.
    Fuel gauge: My '98 Odyssey had the problem that some of you described, the needle does not indicate FULL when it is filled. It ended up at around 7/8 mark.
    The dealer changed the fuel sending unit (the one at the tank). That didn't solve it. So I kept complaining. What finally fixed it was that the technician said that a wire was not grounded properly (which was at the sending unit area). I watched him tighten and jiggle the wire.
    That fixed the problem.
    Transmission: My '98 Odyssey (the small made in Japan one) check engine light came on the first day I got my car. The computer indicated something wrong with transmission, even though I couldn't feel anything different while driving. Dealer cleaned some sensor and changed transmission fluid. Light came on again a day later. Dealer changed PGM (I think its some
    sort of computer). Light came on again a day later. Finally, Honda told the dealer to replace
    the transmission (this at 3000 miles as Honda wanted to examine the transmission). That fixed it. No light has come on since and I have 50,000 miles on the car.
    You guys are describing the same fuel guage & transmission problems as I had
    on the pre-1999 Odyssey (the one with the 4 swing out doors). It's deja vu!
    The list of my Honda's with least amount of defect/problems listed first
    1. '87 Prelude (least repair, the best car I've ever owned)
    2. '00 TL (minor fit/finish stuff)
    3. '91 Accord (had brake problems)
    4. '98 Odyssey (see above)
    There seems to be a pattern, the newer Hondas seems to have more problems than
    the earlier ones, which Honda built their reputation on.
