Visitor Agreement.
This technican guy is smart: he taped the possible spot from one to another, until he found the right spot. It turned out it is from the front windshield. After he resealed the front windshield, the problem is fixed. The right technican can make huge difference.
Last conversation two days ago with the service advisor and the technician was that the technician couldn't really figure things out. He thinks that battery is bad - it's not. He's going to replace the ABS/TCS control unit at $700 and then the PCM at $1000, if the control unit doesn't fix it. Sounds like he may just be fishing in the dark, although the advisor claims that he is a Master Technician.
Your comment about the ground could be important. In getting this car ready to sell, I removed the lighting harness for the 100 watt headlight bulbs, and that ground point is one that was loosened to remove the harness. Btw, there's also another ground point which I loosed inthe process - over on the left side just in front of the battery and above the left headlight. Gotta go over there today and see what's going on.
Another thing that was done just prior to the problem appearing was that I hosed off the battery connections to wash away some terminal corrosion.; and water went all over everything in the engine compartment in the process of hosing.
Btw, the code resets immediately when cleared, so something is amiss.
Bottom line was a $12.00 part and 3.5 hrs labor. The service writer said they had a lot more time in it than that, but felt they could only justify that much. Total was about $260.
Thanks again, for your good input!
There's an old adage when it comes to trouble shooting problems: "If you're walking around a ranch in Texas and you hear the sound of hoofbeats, look for horses - not zebras."
It's a sad commentary that so many of today's car repair techs are no longer mechanics; and are only able to fix a problem if their computer tells them exactly what and where to do it.
Does any one know what is the procedure for resetting the computer controlling the door operations? Any other advice?
BTW I removed the fuses from primary secondary and indoor fuse boxes.
All the fuses were o.k.
When I turn the ignition off and remove the key the radio stays on and slowly fades to off.
I showed this to the service tech, he said, "Wow, never seen that before".
After spending the day looking at this and my sliding door problems, they had no resolution to either problem.
Suggested that I turn off the radio everytime.
Also said that if they were going to spend more time they would have to charge me because they would have to take the dash apart.
For my sticking doors, they gave me a can of silicon spray and told me that the doors are a known problem that they can't fix.
I feel there is a serious safety issue regarding the doors. Does this sound like a legal issue?
Any feedback is greatly appreciated.
Thx a lot.
This happens at 40 kmh and at 100 kmh ( 25 and 60 mph) At 40 kmh the steering wheel is vibrating with about a 1/4 inch wobble.
I have had tires rebalanced, alignments done etc.
No resolution and my tires are wearing out prematurely.
imhip2 had similar problems, any resolution??
I am also having problems with my doors. I have a 99 Odyssey LX. Almost from day 1 the doors have been hard to open at times.
They know about the issues and have given me silicon spray to spray on the rubber seals. - Big deal!
The tech at the R Hill dealership says you have to lift slightly on the handle when you are opening it.I told him not everyone has the strength or leverage to do this. He just shrugged and said "Oh well"
There was also a recall regarding the doors in 2000 I believe. I'll have to check my records.
I also broke the left passanger handle and the dealership in Richmond Hill fixed it for free.
My doors continue to stick and are almost impossible to open at times, especially after long periods of driving.
I believe that there is a serious saftey hazard here.
For example
What if you had to get the kids out quickly because of say a fire or an accident.
I think there is a design flaw. They use the same handle for the rear and front. If you look at the Caravans, their passanger handles "break" to the front rather than to the back like the Honda.
I appologise to all if this is alittle long winded.
Can anyone else shed some light?
Have you had any luck?
I will persue the same in Canada.
As for the lifting by the handle trick..I dont recomend that as the handle can break. A better thing to try for those that can is to pull on the handle as you mormally would and then reach up to the top of the door and pull out to unstick the seal at the top sub seal. Good luck
The Honda manual recommends to push gas petal halfway then start the van.
This seems to work but has anyone had any similar problems?
How cold? No problems for us - low 40s. SoCal.
Auburn, have there been any TSB's on this?
I can't/won't comment on the Chevy as I'm not a big GM fan from past vehicle experiences.
My next question is about extended warranty since the manufacturer's warranty will expire at 36000 miles. Is it worth spending $1200 to get a 7 year/100000 extended warranty? I thought Honda makes great cars and vans. If the probability of occurrence of major repairs is close to zero I don't know if I should spend that much money on a warranty. I know this is very subjective but am still looking for some advice.
Has anyone got close to 100000 miles on their Odyssey? Any major problems?
steve_ Oct 29, 2002 4:00pm
(There's another one about two posts after my message).
Since the last couple of days, she has been complaining about a loud whistling or howling noise when driving on the highway. At first I thought it happened because it was a windy day, but it seems like the noise is more consistent.
It is quite loud and I don't remember such a noise before this.
We have checked that all doors, windows or vents are shut tight.
I do plan to take it to the dealership tommorow but I wanted to be better prepared.
We have had a lot of snow here and I am wondering if there is some snow/ice stuck in some weird place on the van.
Allthough the noise does seem to be be from the front windshield. I am wondering if it could be a badly sealed windshield.
Has anyone experienced this problem?
PS: Earlier posts in this discussion group will tell you the names of Honda dealers who will sell the warranty (7/100) for under $900.
rockycow
Look at the weather strip acround your windshield. If it is even creased out, it will make that howl.
My minivan never did that again after my dealership fixed it for me - they said it happens a bit when you take your car in for a car wash.
Well here's even BETTER news. They have now reimbursed me for all related misc trans. expenses that I had incurred (flush and labor for solenoid change) earlier. This amounted to almost $300. I cashed the check yesterday.
The also sent me a letter extending my warranty to 7years/100K miles.
This is the same policy they have on the '00-'01.
Will I buy another Honda? ABSOLUTELY!
My advice - Push Honda for everything. When they call you after the repair, tell them how happy you are that they replaced the transmission BUT....
I never had to get angry or upset, just persistant!
