The wagon is rated at 42/50 mpg and the sedan is rated 42/49.
Real world reports also have the owners of wagons acieving higer mpg than sedans. This is according to owners who own or previously owned sedans and now have wagons.
The heavier, higer cd wagon has better mpg than lighter sedan. Hmmm.
Theory is nice in the lab but on the street it does not always work.
1. smaller minority group than the 6% of TDI owners
2. tend not to be more conservative in driving?
There are always exceptions to the rule, but it is typically American, in fact human nature to make the exception the rule!?
Pretty soon you will be telling me an automatic can consistently achieve better mpg than the stick? General information, Jetta Wagon are 42/50, 34/45 EPA. Gee according to you I wonder why the Jetta Wagon auto gets 34/45?
(2) I also heard thta there will be a 100hp version
(3) What is the real interval for oil change and timing belts?
(4) How is the reliaiblity?
(5) any change back to free schduled maintenance? or continue with the current 4yr 50K miles?
(6) Pricing ? Fincancing?
For example. Diesel was $1.37 yesterday and if I use the 45 mpg rating the fuel cost is $.03 per mile and if I use the 49 mpg rating the fuel cost is $.028 per mile. $.002 per mile is no big deal to me. Is it to anyone? That is $200 over 100,000 miles using the above numbers. WooHoo, I'm willing to pay the $200.
What is expected is-
1. 5 speed tiptronic or 5 speed manual.
2. 100 hp PD engine
3. Oil change and timing belt interval, warranty, pricing, are unknown or unconfirmed at this time.
Expect reliability scores to continue to be below average. Pricing will likely be higher. Warranty will likely remain the same as the 2003 models.
34/45 mpg is what VW states. My explanation is the automatic is less efficient than manual. What is yours?
Anecdotal evidence is just that, anecdotal. Not reliable. I've never seen a failure to timing belt on an auto TDI and three on manual transmission TDI. Means very little to someone who has a failure.
The intelligent way to proceed is to check the timing belt when required, change it if it requires, and never exceed the recommended manufacturer intervals.
No 2x4's or saddles involved.
"Correcting misleading information and presenting a different viewpoint or opinion on TDI is my only intent. Having owned both manual transmission TDI and auto, Jetta and Golf, wagon and hatch, I have some experience to relate."
So I guess even you discount your own information and experiences!!??
You dont need anyone else for the 2x4 action.
The information posted is correct. I do discount "as in make allowance for" my experiences and those of others. If I have a lemon VW it does not make all VW's lemons. Your posts somewhat indicate you have a prejudice against automatic transmissions. Is this true?
When you say prejudice what does that mean?
Best of luck in YOUR new Toyota Prius. I have been buying Toyota's for a while,and while I was recently at the dealer for a smog check on a Toyota Landcruiser, I had a chance to check out a Prius. True the gas mileage is GREAT 45/52 mpg, I was not impressed at all.
While the Zero-60 benchmark has been around for a long long time, it almost is just another among many of factors. The TDI has a Zero to 60 of (I am guessing) 10-12 seconds? Edmunds lists the Prius as 12.8. One of my TDI Jetta's stable mates is a 4 second zero to 60 Z06 and I got to tell you I have no problem merging into ANY kind of traffic with either. As a matter of fact I don't even KNOW the zero to 60 for the Toyota Landcruisers!!?? So in fact I can add that I have no problem in merging into traffic with ANY of them. If the Prius meets YOUR needs in comparison to the TDI models by all means: GO FOR IT. Again according to Edmunds.com, this is a $20k car. I got my TDI for way under that.
Since unscheduled maintenance was a concern for me in the VW JETTA I got into one of many VW anonymous groups. They have been very helpful in dealing with my addiction
All of us TDI'ers bemoan the lack of GOOD diesel mechanics. So would you say there are more or LESS hybrid mechanics?
My take on my mileage is currently we get between 45-50. Part of the reason is that this car seems love being run! XXX digit highway cruising is second nature and in fact the car was designed with the autobahn in mind. (.205 injectors, AW AW AW)
Under REAL driving conditions, the TDI has plenty of torque to accellerate to pass beyond that of any same-displacement gasoline engine. (40-60 time)
What about quality interier design, fit -n- finish, handling, braking, ride quality, interiour noise levels, seating position...etc (I could go on for awhile)
Did you know that many automobile manufactures PURPOSLY tewak the engine-tranny to look good on paper? (ie ... 0-60 times) This has little bearing on REAL driving conditions. There was an interesting 'study' about this.
Personally, I spend much more time DRIVING my vehicles than I do with FULL-THROTTLE BURSTS from 0-60MPH. I look for a comftable,quiet ride that gets good MPG during NORMAL driving conditions. (I average about 52MPG)
Besides... those HYBRID vehicles are hard on the envrionment. The battery-packs are HAZZARDUS WASTE and very expensive to replace every few years.
AS FOR TURBO-LAG... Why do you suggest that VW has "trouble" with it. This is not "trouble" by any stretch of the imagination. It is just the nature of a turbocharger... PERIOD. (Just like lightbulbs make HEAT, lawnmowers make NOISE and it hurts when you hit your thumb with a hammer... it is the nature of the beast)
There are allready several TDI/electric vehicles available.... just not in NorthAmerica.
I too have a Chevy 4x4 and I completely disagree. The truck amazes me, even pulling 5000 lbs. Throttle response is beyond there. Now I test drive a TDI, hit the gas...nothing happens....when the car is finally pulling...it is time to shift! VW states 0-60 in 12.5 sec with manual, 14.9 sec with auto (yikes). The 2004 Prius is 10 sec flat with auto. That’s a big difference while getting better mpg. I want good acceleration while getting good mpg and a fun to drive car. I think the 2005 Golf with TDI/manual will be just that.
Now imagine the TDI having the 295 ft/lbs of torque the Prius has. I think that would overcome the turbo lag and make on heck of a fun to drive car and get even better mpg.
For the record, I have been driving my friends Audi A4 1.8T with automatic Quattro. I also HATE that car. You can floor the car at a light and let up on the gas and no one in the car would even know you stepped on the gas. Try that in a Chevy.
So, I think what you are trying to say is the VW feels quicker. There can be many reasons for that from the VW being lower to the ground, engine noise, vibration, and the feeling from the hill being pulled without downshifting. But, if you take your stopwatch with you I think you will be surprised.
For one thing I don't like the looks of the Prius. I can appreciate great engineering when I see it and Toyota has done it again. They are light-years ahead of most other car manufactures. I still say that TDI/electric would be a great combination.
I also did not say the Tahoe was slower 0-60, I agreed that it was faster. In many other circumstances though, it is not. I do have about 25% more power than a stock TDI. I've never actually measured the 0-60, partly because it's not a standard that tells me much. I've driven many cars that have low 0-60's that don't feel all that fast in day to day driving. I don't call constant red-lining the engine day-to-day driving. I'll give you another example. My daughter has an '02 Celica GTS (borderline lemon at this point, but that's another story). That car CAN get to 60mph somewhat quickly, but good lord do you have to work for that power. Driving around on typical country roads is a chore and six speeds is hardly enough. Around town, don't even think about dropping below 3 grand or you'll be behind the pack. I just don't personally like driving like that. And talk about a lame duck on the hills, turn the A/C on and it feels like any cheap economy car. Requires premium fuel and very lucky if you get 30mpg on the highway. She's been driving my TDI on all the trips to the dealership to try and fix her car and she's determined to weasel it off of me. I'll probably trade her car in on a Passat TDI when/if they make it here.
I've got a Cummins Ram we use exculsively for towing. I've driven it some empty and it doesn't feel fast to me, even with the HO six-speed and 305hp. I've seen them do 13's at the track though so I'm sure there's potential. As long as it pulls our 16,000# trailer down the highway at 70mph, I'm happy.
HOWEVER: Since you have such specific 'needs', you will most likely find there are very few to choose from. Heck... many folks have to 'order' somthing like that up to several months BEFORE THE PRODUCTION RUN STARTS.
It goes without saying that the less 'picky' one is, the wider the selection will be.
Right now gas is too inexpensive and there is not enough demand for diesel versions of most vehicles.
I could load my snowmobile by just lifting the skiis up to the tailgate. (Tailgate height was about knee-high)
In addition to my snowmobile, I hauled gravel, picnic tables, helped friends move and generally worked that thing pretty hard. At 120K miles, it was still running strong when I traded it. (Too bad it was rusting badly)
Since the plant where these were built in the USA (Latrobe PA) is now a SONY factory... the rabbit-pickup is no longer available in NorthAmerica.
http://www.upsolute.com/
Very simple answer: its a better car!
Same reason a Passat is a better car than my NB TDI.
The Jetta wagons are built in Germany.
Drive 1/2 hour on the freeway and any VW will smoke you on 0-60. The hybrid relies on regenerative braking to top-up the batteries to help get going again.
On I-5 my TDI is in the fast lane at 85+ MPH, and I've never seen a Prius that isn't in the slow lane trying to keep up to the speed limit.
The Prius is Toyota's attempt at environmental brownie points to make up for the 8 or so models of SUVs they sell (5 Toyota SUVs, 3 Lexus SUVs if you count RX300 & RX330 as one model)! That's why they sell them at a loss.
But its the worst environmental disaster of them all. If anyone looked into how much energy is consumed, and pollution is generated, to create the exotic metals in the high-density magnet/motor asemblies (plus the batteries) these vehicles would be banned! But it's OK ... its only killing people in Asia, Russia, etc. We here in North America aren't directly affected. (out of site ....)
And I'd be surprised if there aren't ones out there already. Any links to "driving turbo-charged cars for dummies" ???
An almost show-room stock GOLF TDI won the SCCA Rally championship racing against SUBARUs and Toyota Celicas. The performance of the high-torque diesel engine combined with higher reliability enabled it to overtake all gas-powered competitors.
Here's one site with a nice synopsis:
http://www.motorsportvortex.com/features/rallyvw/rallyvw.html
(Try winning that championship in a Prius!
Building a rally car from scratch in such a short amount of time is quite an accomplishment, made even more impressive when you realize that it was done completely out of Jon’s own pocket... "
I am not sure you are reading the same article that you posted that I read! If so, the term "...almost showroom stock..." could apply to a NASCAR Chevy!!!!???
A 90-HP TDI beating 4-WD Suburus and well-financed Toyota cars with double the HP rating (& less weight) is a true testament to the performance of the VW diesels.
Imagine how fast the new A8 is with a 4-litre diesel rated at 3-times the power of the SCCA winning Golf's engine!
So when the author sez "...building a rally car from scratch..." that truly does NOT connote to me "show room" stock.
Again, to really state the obvious, if it WAS showroom stock, why didnt he say THAT!!?? Reason? Ethos! Common man (target audience) can, off the showroom floor keeping the stock engine, and modify a TDI body for the rigors of rally racing.
I believe Audi still offers this.
VW probably dropped it to make price comparisons against Japanese cars closer, as the maintenance was built into the purchase price. Even so, their warantee is better than Toyota's, the cars have many more safety features standard, and they handle much better over bad roads than anything from Asia. (Most European cars handle bad roads nicely).
On the flip side, you do have to do the maintenance on a European car. If you wait till something breaks (like lots of folks do with Japanese cars) then you'll be in big trouble.
But if you maintain any German car, they last a LONG time ... and VWs also have higher resale values than Japanese cars.
NOTE: Only the Jetta wagon is built in Germany. The sedans are not quite as good. The heavier wagons even get better mileage.
Within 6 months you'll be able to get a German built Passat TDI with 134 HP. And it has the 5-speed Tiptronic, which you can't get in a Jetta.
You might consider waiting for that one!
Jetta Wagon built in Germany is no better than Jetta Sedan built in Mexico. No one has been able to point out any factual differences in quality. A major amount of the components such as TDI engine are made in Europe no matter if the car is assembled in Mexico or Germany.
I'm not sure what would cause this, tighter gaps in the doors?! Gee, I think I'd lend the slight difference to possible aerodynamic or variance in the testing conditions. I've not seen any proof that german built Golfs get better mpg than NA built ones. Seems like the same typical problems apply to those cars as well regardless of where they were built.
Tiptronic® is a special kind of transmission. It combines the convenience and refinement of the automatic transmission with the driving pleasure and dynamics of a manual transmission. The driver can switch from automatic to manual mode at any time while driving. In both modes, gear shifts take place with no power interruption.
To see a picture of it. Looky here -- where I found the above info.
http://www.audiusa.com/lexicon/0,3864,categoryId-5_glossaryId-159- _,00.html#159
