Visitor Agreement.
Some vehicles have firm suspensions, regardless of whether they're brand new of a few years old. However, check the cold tire pressure of all four tires after your vehicle has been sitting overnight. If the pressure is higher than what is indicated in the owner's manual (under the normal load, cold tire pressure section), this could explain why the ride is firmer or busier than expected. The factory usually overinflates the tires so as to prevent flatspots while the vehicle is being transported. Dealers usually forget to deflate the tires to proper specs while delivering the vehicle to the customer.
Good luck!
Drew
Vans and Aftermarket & Accessories message boards
Mine have been done three times already in less than 31,000 miles!
According to the results of Consumer Reports' customer surveys, brakes are one of the Odyssey's two biggest problem areas. The other is "hardware".
The dealer fixed it the second try by re-aligning it. They mentioned that all Odyssey's will drift to the right because the right side of the engine mount is heavier.
True? False?
After the re-alingment, it was the same as Phil47's.
Anyway, my problem now is the passenger side sliding door (manual, since it's an LX). The door can't be opened from the outside. Since I knew the dealer wouldn't fix it for free, I actually pulled the inside door panel off to see what the problem was, and there is a white plastic part with a lever arm that trips a linkage to the door latch when the outside handle is pulled. The lever arm has broken completely off. Is this a problem anyone else has had? The plastic part looked pretty wimpy for having to do a job thousands of times during its life.
I'm scared to death thinking what the dealer will want to charge to fix this, but I don't see any other options. Thoughts, anyone?
>allowed to start.
Don't think so....
We _also_ had the exact same thing happen....dead-dead...no turn, no warning lights. Tried the other keys. Tried jumping the batt from my truck. When the dealer's wrecker came, the guy tried jump w/ his portable charger...and it worked!~ Dealer said they thought it might have been a "intermittent" bad cell in the battery, though it load tested normal...yeah, right.
3 is a trend...
Also, I haven't looked closely yet, but my crossbars also make a lot of noise - any trick to taking them off (only need them for ski trips)? The dealer put them on and it looks like a gorilla w/ a screwdriver did it based on the marks all over the side bars.
Since the tank is supposed to have a 20-gallon capacity, I divided 211 (the miles I drove) by 20, to get 10.55 miles per gallon. That's a heluva lot lower than the advertised 18 city/20 highway.
I wonder how much gas is supposed to be left in the tank when the gas indicator comes on? Maybe if I let it run dry, I would have got better results?
Our low fuel light comes on with 6-7 gallons left in the tank. The guage reads "E" with 4-5 gallons left.
By rule of thumb... lock the pump nozzle and fill until it shuts off, record the mileage. Using as much gas as possible and at next fill (using the same pumping technique), note the fill volume. Then, divide the number of miles driven by the gas volume you just pumped in.
Does the pump fill the tank accurately to 20 gals? Not necessarily, your error margin is where the pump shuts off by backpressure - but still within 1 gal. Other variables - use the VERY SAME pump and use the first notch to lock the nozzle, and you may not normally get a proper mpg reading during break-in.
Good luck and let us know.
My 2001 EX is now getting around 13.7 L/100 KM (17 MPG) around town. Considering it's winter and it's really stop and go driving (and I only have 2500 miles on the van), I'm very happy with the mileage.
Sorry, I could not resist.
Second, I'm a little confused about how and when TCS (traction control system) works. I know you can depress the button the dashboard to enable it, but it seems that every time I get a wheel spinning on snow or ice, the TCS light on dashboard comes on, whether or not the button is depressed. Does the TCS enable itself automatically when it senses wheel spin?
Now I wonder what really is the status of the brakes. I do some stop and go driving commuting. I can't imagine brakes wearing out at 30K miles much less 15K miles.
I am waiting to hear brake noise. I always resist "problems" found during planned maintenance.
<<Does the TCS enable itself automatically when it senses wheel spin?>> YES, but only when the system is on. This is explained fairly well in the manual. It is a little counter intuitive so you have to read it a few times. Bottom line: Leave the button alone and TCS IS available.
It's been awhile since I've cruised the Town Hall section of Edmunds and it's good to see that the problems that people have had have pretty much remained the same. Nothing new and earth shattering.
I'm coming up on 1 year ownership of my '00 MB EX and still happy that I bought it. No problems with it at all.
It says that Alldata is negotiating with Honda to publish the data.
http://forums.legend.org/Forum1/HTML/000640.html
When I take my foot off the brake the noise goes away. It usually doesn't come back. Seems to happen when I first start the van and drive a few minutes, then it goes away.
Does that sound familiar to anyone?
I believe the fix was a weight or a little more slack in the cable...
Can I invoke lemon law to get a replacement?
Second, unless there is some operational problem with your vehicle (the misinforming gas gauge is not one) I would imagine that it would not be worth attempting, irrespective of your prospect for success.
My '01 EX does the same, but seems to be learning - the gauge is somewhat more accurate (and the 'low fuel' indicator as well) at 6000 miles than it was in it's first several tanks. Once you have a general knowledge of your vehicle's gas mileage, knowing when to fill up is pretty simple. You can always fill up when it tells you to, or you can wait a bit if you're comfortable with that.
Dave Kelsen.
50 mph (fluttering noise) has been reported here numerous times. I've looked
thou most all messages
but fail to see any reports of Honda's fix for this problem. Has anyone had a
tray replacement as a satisfactory fix for this. I keep getting " they're working
on it" kind of response. Have had 2000 Odyssey for better than a year. If anyone
has had problem fixed ple3ase post message
Mike
advise..coolscene@yahoo.com
I would like some commentary on problems with the EX power doors. Thanks.
I don't think there's a definitive answer as to which is safer. Either way, it really needs to be impressed on the children to stay clear of any sliding door.
I'm not sure how good it would be for the power mechanism to close the power doors manually on a regular basis.
I have a 2000 Ody LX, manufactured in August 2000. While the car is at complete stop, there is a clunking noise when gear is shifted from D4 into R. All other gear positions are noiseless and no clunking noise while moving in reverse. Is this noise normal? what cause it?
Thanks for any info!
No, I have not seen any of them. I was wondering if any of the ones doing it had alarms or if they had left the overheads on in the back. I will try and remember to ask tech line the next time I am on the phone with them.
odyfan
Although it is always tough to diag noises on the net, there are some engagement noises that sound like you described and they are normal.I would think that what you are hearing is normal but if you are not for sure take it in to the dealer for a check.The cause of the normal noise is in the design of the trans. Most of the time the noise will be at it's worst when there is a load on the trans, like when on a hill and need to shift.
Thanks for your response.
Do you know anyone specifically who has solved problem with trany replacement
The word "apparently" in your respoce will not fly with my Honda dealer. Do you by any chance
have a message number to support your claim. Ultimately I need to connect with somone
who has solved this problem with Honda. Thanks for responding
Does anyone notice a really loud noise when driving over snowy/slushy roads?
My problem is major. I have a '00 X. I parked on a driveway, left the car running, in park with the emergency break engaged. I got out of the car and was walking up to the house when I turned to look at the van, it was rolling down the driveway. (We live in a very flat area) I managed to catch the car and hopped in to stop it. When I took off the emergency break and put the car in drive, the car acted as if it was in neutral. I had to put the car into park again to engage it. Honda could not find the problem. I did write a letter to them and am happy to say they responded in less than a week. My car is going back in this week. I witnessed my neighbors' '00 EX roll down her driveway a few months earlier. Her car was in park, engine turned off and keys in her hand. As in my case Honda could not find the problem. Told her to use her emergency brake. Didn't work for me.
