Chevy Vans: Problems & Solutions
Motor oil--3100 5w30
3800 10w30
Trans dexron III or dexron IIE
Coolant50/50 mixture water and ethylene glycol antifreeze
Any more questions just ask. Also-about the first problem---if you've fixed those things already you might look at the ignition switch (the electrical not the cylinder). It is sometimes the problem.
There is a class action suit out there on the Dex Cool product. Be advised. Dex Cool allegedly eats through gaskets. In my case, it was the intake where the cam shaft is housed. Cold air on a hot camshaft. Result, camshaft metal integrity compromised, shaft broke and ........ had to replace the engine.
You got off easy. My Intake gasket went and result was broken cam shaft due to cold air passing on the hot metal ... shaft broke ........ $2.5k engine job. I understand that Dex Cool is the culprit. There is a class action lawsuit out on this product.
The sound is similar to a tire rubbing in the wheelwell but it sounds more like it originates from the center of the rear where the differential would be on a conventional (non-AWD) vehicle. I checked underneath and there are no indications of rubbing anywhere, and the undercarriage is quite clean and not corroded.
No idiot lights are on. The brakes and rotors, as well as tires, have been replaced in the midst of this with no effect on the noise. Wheels appear solid...no 'real' loose bearings that I can tell as a layman.
Is there special AWD fluid I should check (no signs of leakage - all is crisp and clean) ...or maybe something electrical that may not be controlling the rear AWD module correctly?
Other ideas?
Tom
There is a RECALL on Venture minivans for POWER STEERING axles that grind when you turn - the axles could crack and break. Take to dealership and tell them you noticed on consumer reports that the van was on safety recall for the power steering and sliding doors and need them checked and/or replaced. There is a recall for Venture vans also for the sliding doors. Evidentally even with the lock engaged the doors can open going down the road.
leah
Thank You
BillB
Good Luck.
Bob
Bob
NOTE: ACCORDING TO CAR FACTS IT IS NOT A LEMON.
Anyone else have this problem. It has 71,000 miles on it.
Thank you, GOP4LIFE
My friend recently recieved the computer control for the gear-shifts (Part No. 16197427). And we rigged it into his Chevy Van '95 model. But then that's where the van decided to turn against us. :mad:
At 1st gear it's incerredibly tired (A mule can beat it at take off!) but at 2nd and 3rd gear it's moving along nicely...that is until you get to the 4th gear. That's when the van REALLY starts to choke, you can literally feel it giving up. The part is genuine and brand new but we don't know where we went wrong, we checked the prints in the manual and double checked the wiring and all but nothing seems to be out of place. :confuse:
As I said before, I'm no mechanic and just to inform you that the part that before the new one (the computer control that was SUPPOSE to be in there actually got stolen, don't ask me. My friend still has nightmares about that :surprise: ). So where did we go wrong? The part by the way is correct and proper for the van, a helping hand would be greatly appreciated! :sick:
-- In-take Gasket - $791
-- Water Pump - $258
-- Front Pads - $195 (W/O Rotors - may have to Resurface rotors)
-- Filters (Air etc.and inside the car) - $140
My other cars not Chevy's never need In-Take Gasket and pump never before 100,000 miles. Is there a way to check if it truly needs a gasket. What is reasonable charge for replacing gaskets? Any suggestions would be greatly appreciated.
Td
Did you ever find out the problem?
It has not cranked 4 times in the last 3 weeks. Eventually, when you come back to the van (usually within a few minutes to an hour) it will crank like nothing is wrong. My mechanic said it would be a waste of my money and his time to try and pin-point the problem. Have you figured out what the problem was with your van? Would love to know!
