Visitor Agreement.
On the lights, I bought my 2000 Venture used, and had to read an owners manual to find out how to get the interior lights to work. Seems that you have to "program" the lights, so see your owners manual. There is also a switch on the overhead console that can control the interior lights, at least there is on my Bugs Bunny edition.
Thanks for any help.
The only fix is to replace the pump and guage as a whole unit. I just did mine about a month ago. Expect around $450+ .
Please read this below and if you know the answer please repond.
check for corrosion on the pins where a cable is plugged in that goes to the guage readings on the dash. after they cleaned the pins I didnt have any more problems. I learned the hard way because that sensing unit they put in the gas tank cost me about $400 Dollars and I dont think that I needed it.
Starchy
Since i purchased the van i have been concerned with noise from fuel pump but was told by my mechanic that it was normal. I did not have any signs of pump going out during this entire time thats why i am really frustrated that i cannot start the engine especially when i use it for work. Been really happy with the van up until now because i was not prepared nor have the funds to cover such an expensive repair.
I did get the area manager to pay for half of the head gasket problem when my van had 84 000 km. Funny that the dealership didn't mention this "goodwill warrantee" when I paid the bill . . . I had to write to the company to get this after reading about it in Lemon Aid.
I am planning to take GM to small claims court for the transmission since they refused to help with any expenses. I just need to get some testimonials from transmission repair people who can attest to the fact that the Venture/Montana transmissions have had problems. What do you think the odds are of winning?
The gauge does not register...or at least move up at all.
The coolant levels are good as well.
Any suggestions?
come to find out when we bought the van, we were told we had 3 yrs warranty on it, come to find out we were lied to (by a salary employee), we were told why buy the extended now since you have 3 yrs to think about it..
we have since moved to texas from VA..we were told by the Va dealership if we bring it back up there, they will do a goodwill but down here they wont and they knew we were military and moving when we bought it...ugh!
I read a bunch of other messages here about similar problems, but none seem to address mine directly.
Any suggestions? I can't even see any way to get into the mechanism from the inside - there doesn't appear to be any way to get the inside panels off while the door is closed. Is a dealer shop going to be able to help me without damaging something? I've got a bunch of stuff that I really need to get out!
Thanks for any info - John
John
Remove EGR check for carbon build up.
Anyway, I did not have any break lights and still do not. I replced the switch this evening and nothing. The bulbs are fine and everything. Is there a fuse somewhere I am missing?? I am going crazy here, lol. :confuse: Help needed <-------
P.S. we have taken the van into the chevy dealer and they are confused and can not find the problem
Warning light comes on but then temp drops. Seems intermittent problem so I thought it was the thermostat. Do you know how to locate it? I'm no mechanic but I can't even find it! Also, is this the problem or is it something else, like a water pump leak?
