Visitor Agreement.
van to shut down. Under the van three wires where dis-connected. I plugged them in. The car started up. But I have three messages that wont go away. They are ...service engine soon, Trac system off,and abs off. Is there a way to re-set the system? I think that is what the problem is. Any suggestions would be appreciated.
Gord
leaking manifold
leaking master brake cylinder
leaking brake line
radio speakers
fuel pump (thats 500 bucks or something for the part!)
wiper motor
HVAC controls (resistor or something gone)
at least it hasn't been as bad as our 00 Windstar- new tranny (actually they tried to replace the tranny and found the new one didn't fit! then found they needed a new torque convertor too!)
I am very grateful to GM for not having 8 seats in the Venture replacement, now I can get a Sieena or even the 05 Ody which will come with 8seats!
Thank you sooooooooooo much!
7,380 miles: Belt squeal, serpentine belt replaced.
12,130 Miles: Pass. Rear door motor assembly replaced, door opens while driving (recall), Driver side rear door latch replaced, Serpentine belt and tensioner replaced (belt squeal), Rear brakes replaced, Rough idle, can’t duplicate. Front suspension bushing replaced(noise) alignment checked.
14,473 miles, Serpentine belt replaced(squeal,chirping).
14,990 miles, Water leaking at rear hatch, Rear intake leaking oil( oil pan bolts, oil filter, drain plug tightened) Questioned fix and was told that’s how they fix Honda’s., Front alignment( Paid by me)
17,578 miles, Serpentine belt squealing and chirping( belt replaced) Water in LR taillight(replaced)
19,696 miles, AC pressure valve blew out.(replaced) AC air is warm and spitting water out vents. This is Aug. 2003
19,826 miles, Told AC is working Fine, use recirculate to cool Vehicle. Water coming out of vents normal. Was told no problem with serpentine belt, tensioners, pulleys etc. Belt squealing and chirping normal. Some belts do this(This is 4th belt since new) At this time I made the mistake to contact GM Customer Service, then the BBB. Both said they would help me neither did. All I have ever got is to be told to take it in for repairs. Dah! That’s what I have been doing.
20,752 miles, AC recharged, Vents stopped spitting water, Air cool at times but not close to what it was, mostly warm and humid. Belt squeal was used on belt many times and did not fix. Belt noise to be fixed for last time Per area Service Manager. Dealer saturated the belt with belt lube, then told me they could not duplicate problem. Belt still squealing and chirping. E-brake not holding, brakes not stopping van. Rear brake parts fell apart.
21,380 miles, Belt problem addressed again, pulleys not lined up properly, seems to fix. AC still not working right, told cannot fix unless hot outside. Begged them to fix so I could travel to Arizona and Florida, they refused. Pleaded with them to compare to other like vans( I did) they refused. 60 degrees outside, drive all day long will AC full blast and not be cold.
Arbitration Hearing, IMPARTIAL Tech. Determines AC is working properly( 35 Degrees outside) Failed to mention noise in vent for which there is a TSB on. Offered extended warranty, Told GM I couldn’t get it fixed with the one I had.
23,296 miles, Loss of power, bad gas mileage, Oil leak, anti-freeze in oil, rough Idle( intake gasket replaced) engine oil overfilled 3/4 Qt. AC checked(warm outside) No Problem found. Although dealer claims they did not work on AC, works a little better.
24,000 miles to current 25,600 miles, Oil leak continues, Oil dripping from engine since May 2003. Engine stumbles or bucking while driving, Transmission slams into gear and slips. Driver window slow or almost stops midway. AC Blows warm humid air with moldy smell. Before AC was repaired you could have made ice-cream and van smelled new. I had to turn rear unit off cause kids were too cold. Dealers have never driven Van more than 2-3 miles. Vehicle never wrecked or abused and serviced above normal.
25,848 miles, Engine problem caused by spark plug wires not attached properly when intake was done. Bracket not connected and wires shorted out on egr tube. Had AC checked by a private tech. To confirm AC was not working properly. Then had GM dealer check again. Both agreed it was not right and has low charge. After 3 last chance to repair and 5 attempts to get fixed in almost a year I had an attorney file for repurchase under lemon law. GM refused my claim on that primary concerns have been fixed and AC problem cannot be duplicated. GM has flat out refused to fix the AC and properly diagnose problem since Aug. 03. At times AC vents look like a steam iron and now Recirculate/outside air switch will not work. I have gone to different dealers. Yes this is a true story, I wish it wasn’t.
29,000 miles After AC not right for over a year, 3 Last chance for repair notices, BBB hearing, and lemon law Attorney saying I had a weak case to do anything I put my tail between my legs and took Van in to be fixed again. The Van was there for 3 weeks. Driver window regulator replaced after a year of refusal. Oil leaking for over a year: Rear engine main oil seal replaced. Interior panel clips replaced. Since wires were replaced mpg on highway has dropped by 5 mpg, no problems found. Dealer claims AC had low charge and leak. Could not find leak and charged system and claims it is working fine. As soon as I got Van back I noticed AC is almost as bad as it was before just a little colder at times. I drove 30 miles from the dealer to my house with AC on full and was not cold. When I got home rear air was 75- 80 degrees, front was 50-55 degrees. Gm has spent more money on repair attempts and fighting to prove there is nothing wrong with AC than it would cost to replaced the whole system. It has not worked properly since Aug. 03. Last response from GM is there is no issue with AC problem. This is short version of my ownership of this Van.
Sounds to me that the neutral safety switch on the gear shifter is bad. Had a ford truck that the only way I could start it was bang the steering column and shifter till I was able to get it replaced.
Used to have that problem a lot. In fact, I replaced three window motors because of it. When I mentioned it to a master mechanic whom lives across the street to me I found that the fix was really easy. The felt strips that the window runs up and down in needed lubrication. I bought a can of silicon lubricant, sprayed the groove between the strips, and the windows flew up and down. I have not had a problem since.
PLEASE HELP!!!!
This car is a nightmare. If you have one-- trade it!! I am trading mine and will NEVER buy another GM car.
JunkVenture!
I own a chevy van G20 1989 with a problem[8D]
When the motor is running and a turn on the lights or use the horn or use the back airco the engine stops running.
The only thing i hear is a lot off noise from this thing(foto)
Anyone knows what is is and what it does??
http://community.webshots.com/photo/232189798/299636363Jikifz
when i turn the wheel of my van i get this loud noise when i start my van and it my brakes i get a loud noise i just had the abs fixed on my van not to long ago
thought it was power steering but that is not it
it is a whin noise even when you are driving it down the road please help me to find out this problem it is whinning just like the power steering but power steering fluid is up to snuff
so i don't know what it could be the belt is fine
Cruise control will disengage on long hills.
random stall of engine.
How long has your shocks lasted? The rear is now taking two or three up down bounds to settle after a dip in the road.
To bad GM vans are junk. We can haul eight people in the flex seating in this van.
Cheers
Bernard
Does ANYONE ELSE have this problem?
up. I have tried both the driver and passenger controls and I ge the same behaviour.
I went to the dealer and they said it may be the switch or the motor. The motor doesn't
make sense as it goes down very well. It worked once and I was able to get it back up.
Where is the switch located? Can I change the switch myself?
Any help is highly appreciated.
RajMan
Jody
It appears to address your issue.
This is an informational post.
I have a 2000 Astro van with 48800 miles on it. I would not have expected to have a transmission problem at this year and mileage.
Last week I had a “check engine light’ activate. The computer was scanned for codes and it showed P1870. This code indicates the transmission is slipping. After researching the code and problem I found that this is a common code for General Motors 4L60E transmissions. This transmission is used in most if not all Astros and Safari vans. It is also used in many of GMs pickup trucks. I found that most, if not all of the 4L60E transmissions have a problem with a spring-loaded valve located in the valve body, which is inside the transmission housing. This is most likely a defect in the transmission, but GM will not admit it because of an expensive recall that GM would have to pay for.
The spring-loaded valve in the valve body wears in its round hole causing it to stick and causes the transmission to slip and the P1870 code to appear in a computer scan. The valve can be replaced by reaming out the hole and placing a superior after market valve and spring in the new hole. This generally corrects the problem. The cost for this valve replacement is about $400.00. If you take the vehicle to GM they will replace the entire valve body, which contains the same old valve and spring. The cost for this is about $800.00 and you can look forward to the P1870 code in the future.
Well, my transmission was destroyed by this slippage. The transmission shop pulled the pan and the oil was like molasses. It needs a bunch more than a new valve. At this time my van is still in the shop. They will need to pull the entire transmission and rebuild, or possibly replace it. The cost for this can be about $2000.00. Fortunately I purchased an extended warrantee when I purchased the van. Hopefully, all I will need to pay is the $200.00 deductible.
The spring-loaded valve only activates at speeds above 45-50 MPH. If you are climbing a hill above this speed and the valve fails to function, a check engine light is likely.
I hope this will alert others to the problem.
The other thing is that the engine oil level light is on after I start the on. After 2 minutes, it is off. The low coolant light is not on.
Who can tell me the problems.
Thank you very much.
