Honda Odyssey: Problems & Solutions:(1995-2004 Models)
You're right about not seeing many/any boxes on Ody's. There is so much room in the van that it will be rare to need the extra space - just when we go camping with the kids and with the bikes and all of the associated gear.
the sound you hear, if once when first taking off is most likely the Anti-Lock Brake System (ABS) performing a self-test and is quite normal. there is even a procedure I believe for your dealer to exercise the ABS self-test in your presence to help you correlate the sound you hear with the function.
if however you hear and feel this grinding multiple times when comming to a stop and proceeding...this would be indicative of a problem.
How about posting your purchase information over on the Honday Ody Prices Paid and Dealer experience board.
Well, the glovebox issue is hardly anything to
And the noise you were speaking of is just the van doing an antilock brake check.
See...problem solved.
I guess I can over look the glove box problem since it's only a cosmetic issue, but I hope I don't have a problem of getting very low gas mileage as some of the other owners are. I would be disappointed if I were to get it in mid teens.
I wish more owners would post about their mileage. I'm wondering if only hand full of owners are experiencing the low mileage or most owners are getting close to EPA estimates. I only have 100 miles on my Ody, so after several fill ups I'll post my numbers up at the other forum.
insist that the service writer get one of the senior techs to ride with you so they hear the same thing you do.
sounds like it might be a stuck / lazy caliper disengaging - but whatever - relatively straight-forward to diagnose.
best of luck.
Anyone have experienced this problem ? Would appreciate any feedback or recommended solution to this problem.
I don't see how; Honda of America specifically prohibits importing "grey market" vehicles form Canada. I think the dealership would be responsible.
If it occurs the first time, and the first time only, after you start the car and then accelerate, it is likely to be the ABS self-test.
If it occurs at OTHER times (or everytime you accelerate from 0 past 10-12mph), then it sounds like a problem which the service department needs to address.
I am also interested to hear from jprantl, who wanted to ride the neighbor's van to see if the sound is there or not.
OWNER OF '05 ODYSSEY.
A quick search would have revealed this is just on paper. Same motor, same everything.
What changed between the '05 models and the '06 models was the SAE (Society of Automotive Engineers) testing procedure. The engines are EXACTLY the same.
BTW - the '05 models were rated at 255hp, not 265.
Try to tune it to 77.9 or 77.3.
See if it works. I had it in my 2004 Ody and it worked.
Rgds
RCS
By 4pm on Friday I got a call stating that the vibration was gone. I picked it up on Saturday morning, and YIPEE it drives like a Honda again - no shaking steering column, no vibration in the pedals...smooth!
The culprit was the rear engine mount - the stabilizer was not engaging at all anymore.
This has been my only problem so far, and I'm at 13k+ miles.
A couple of points:
First, turn off the CAPS LOCK. "Shouting" is really unnecessary.
Second, no, Honda didn't overstate the horsepower. The engines made 255hp under the old standards. Would you say that all the manufacturer's were 'cheating' up until the early 70's when the SAE changed the standards from the old 'gross hp' ratings to the 'net hp' ratings?
An analogy:
Two students take the same class taught by different teachers: Both students get 100% of their homework correct, both students score a 90 on their midterm and both students score an 80 on their final.
Yet one teacher decides that the homework should score 0% of their grade with the mid-term and final weighted equally at 50% apiece. The student in that class has a final score of 85. The other teacher weights the homework, mid-term, and final exactly the same, each at 1/3. The student in that class has a final score of 90. Two different results, yet EACH student scored exactly the same on the individual components.
Has the student with the 90 "overstated" their grade? No, different methodology was used to determine the final grade.
Are you aware that there are at least a dozen ways for an individual running a dyno to generate hp numbers? Some methods yield higher numbers, some methods yield lower numbers. So long as the method used to generate the numbers is a standardized method, there is no 'cheating' or 'overstated' numbers. I've heard of unscrupulous speed shops who sell performance parts and offer dyno services who will do dyno runs, before and after the sale and installation of speed parts, who will tweak the dyno to 'prove' the parts sold actually added hp.
Do you have any evidence that, under last years SAE testing methodology, Honda inflated the horsepower ratings?
http://www.detnews.com/2005/autosinsider/0508/17/A01-283759.htm
You might see my point of view.
What the SAE did with their revised methodology was to try to eliminate some subjective rules which could be interpreted in various ways. I should point out that whereas Honda and Toyota have revised their hp ratings for virtually ALL vehicles in their lineup (new and carryover), this was voluntary on their part since the SAE only required NEW vehicles or vehicles with revised/new engines to use the new SAE standards.
Note that the domestics did NOT re-test all their engines under the new SAE standards, instead selectively re-testing.
Can you point to ANYTHING which states that Honda, or any other manufacturer, violated the old rules for hp ratings?
If you weren't happy with the performance, you shouldn't have bought the car.
Lived here for 10 years now, and would NEVER consider the Detroit News a mouthpiece by ANY definition!!!! Look at the Minivan write up a few months ago I posted, showing the Oddy the winner, or some of the reviews i.e...He says, She says etc........
They just called me and said that they tested it and it was a knock sensor and something about connector wiring might need to be replaced. and that it was not
EGR. They saw some rodent droppings and thought they may have chewed the wires??
I did not okay the work yet. Should I call him back and tell him that my mechanic checked for knock sensor and that that was not it?? Does it make sense what he said about rodents chewing the wires??
I am so frustrated because I drove a Dodge Caravan for over 10 years with absolutely no problems. We buy an Odyssey and already we are having problems? Thank for your help.
Few FYI's......
I'm a big Honda fan....this is my 3rd Honda('05 EXL RES/NAV). '99 accord, 02 oddy. I and the Mrs. been very happy with the '02. '05 is far better in many way vs. '02. '05 performance is big improvement over '02.
http://www.alldata.com/tsb/Honda/1121842800000_1123225200000_05-026/601.html
i think the MIL (malfunction indicator lamp) is synonymous with the CEL (check engine light). the maintenance reminder lamp is different.
there's nothing in this document about the TCS (traction control system) lamp.
jcchevy
In my earlier 00 TL, when put into the sportshift mode, it would display the gear that you are in. The Odyssey does not seem to have that display and merely has "D", 2 and 1 and also an "Overdrive" off/on button
Something tells me this will continue to get brought up for months to come!
I saw some posts on transmission problems , but did any one experience any humming noise , should I take to the dealership ?
Buy the way I really low Honda's they run great.
