Inconsiderate Drivers (share your stories, etc.)
16364666869478
  • capitanocapitano Member Posts: 509
    Less expensive vehicles are easier to total out than the more expensive ones. That is a factor.
    Your BI and MP rates are based on the likelihood of injury to you in your vehicle. It has no relation to the likelihood of injuries you may cause to others.
    I am also saying that this factor works in my favor!? So I take it you are confirming that my so called "safer" is not really safer? :)
  • andyman73andyman73 Member Posts: 322
    Maybe one of ya'll can answer this for me. Why do some motorists have the need to use their brakes on the slightest of downgrades, or on nearly flat roadways? Usually it's the ones that are hugging the speedlimit, on surface roads, in good conditions. I was following a couple in a Daewoo Lanos, and the driver was braking everynow and then, to stay within 2 miles of the speedlimits. And no, I wasn't tailgating, so that's not the reason.
    That is really a good question. When I see brake lights come on with clear visibility and heads up longer distance looking, I immediately go into heighten alert state. (Perhaps I don't see what the driver in front doing the braking sees) To me, unless you are avoiding a rear ender because you misjudged your following distance, debris in the road, imminent collision or really warning those behind of a dangerous condition, etc, my short answer is: STAY OFF THE BRAKES!!
    When I see them braking in earnest, it's one thing, but just braking slightly, that's different. It's almost as if they realize, OMG, I'm going 5 over, better brake back on down. Not even thinking for a moment that, the same can be achieved by taking their foot off the gas.
  • grbeckgrbeck Member Posts: 2,358
    kdshapiro: "Only if you believe you know better than the traffic engineers and the government that provided the funding. You begin to see it's a circular argument."
    You might try to provide an example that rebuts mine. It will be more effective to your arguments.
    kdshapiro: "So do we in NJ because speeders are an easy pick. Much easier for example than jaywalkers."
    Which futher proves my original point that traffic fines are designed more to raise revenue than improve traffic safety. Governments generally choose the path of least resistance when raising revenue.
    kdshapiro: "Actually NJ studied this and found that fatalities did not decrease with increased speed. Sort of goes contrary to a now 15+ year old study that probably now holds no water."
    And the New Jersey study is more accurate than a federal study conducted across the nation in exactly what way? It also flies in the face of the continual drop in the fatalities per 100 million vehicle miles driven since the repeal of the national speed limit in 1995.
    I'd say the New Jersey study doesn't hold any water. Maybe the study's authors need to check their methodology.
    kdshapiro: "That is due to the fact the people who obeyed the law still obeyed the law, but the rest of the people didn't speed up. In other words, those who were doing 65 before did 70 after. Those who did 55 before now did 65."
    And your proof of this contention is found where? Studies have repeatedly found that changing speed limits on interstate highways has little effect on most drivers' speeds.
    kdshapiro: "Unfortunately fatalities started creeping up again as speeds and reckless drivers now went even faster."
    The fatality rate per 100 million vehicle miles driven - the accurate way to measure highway safety, as it accounts for increases in driving - has continually DECLINED since 1995, and, as of last year, stood at a record low figure. The roads are safer now than ever.
    Any increase in the absolute number of fatalities occurred for two reasons:
    1. As the economy kicked into high gear - which it did after 1995 - people started driving more. A healthy economy encourages more pleasure driving. But, based on fatatilies per 100 million vehicle miles driven, which accounts for the increase in driving, the roads became SAFER.
    2. Motorcycles have become more popular, with a resulting increase in motorcyclist fatalities. There has been a spike in the number of fatalities among motorcyclists over the past 2-3 years. These fatalities are included in the total number of traffic deaths for each year.
    Both of these factors have nothing to do with increased speed limits or people driving faster.
    The absolute number of fatalities has gone up or down by relatively minute amounts since 1995, especially in view of the total numbers (about 40,000 per year).
    kdshapiro: In fact, it's the speeders that cause the issues, not the people going at the speed limit, driving properly.
    I don't see drivers exceeding the speed limit camping in the left lane. Considering that "failure to yield" is regularly cited as one of the top irritants of most drivers, I'd say that drivers exceeding the speed limit are not causing the "issues."
    kdshapiro: "Sure, the Autobahn is exactly like the GSP by Union tolls during rush hour.
    There are plenty of congested stretches on the Autobahn. It skirts major urban areas (those are the stretches with speed limits). This summer I encountered stretches where traffic came to a dead stop due to heavy volume or construction.
    When traveling on the Autobahn for any length of time, you are likely to encounter a variety of traffic conditions, as it crosses both urban areas and the German countryside, and varies in the number of lanes.
    Drivers, however actually slowed down for the speed limit areas, as those speed limits had some relationship to improved safety.
    Which is what I originally contended - people will obey speed limits WHEN THEY HAVE AN ACTUAL RELATIONSHIP TO IMPROVED SAFETY.
    Seems that Germans have figured this out, too.
    kdshapiro: "In Montana where there is no speed limits the cops will nail you, if you go above 75."
    That sentence is not only inaccurate, it doesn't make sense. If there is no speed limit, why would the cops nail you for going above 75 mph?
    When Montana enacted its "reasonable and prudent" law in 1995, cops were on record as saying that anything under 95 mph was fine, depending on road conditions, traffic and the vehicle. At speeds above that, they would scrutinize the situation more closely.
    Since that time, Montana has enacted a 75 mph speed limit after the state's highest court threw out the "reasonable and prudent" standard. A motorist cited for driving too fast for conditions challenged it in court, and the court agreed with his contention that it did not provide adequate guidelines for motorists.
    Interestingly, fatalities INCREASED after Montana enacted the 75 mph speed limit. (And even now the cops have said that they aren't going to cite most people for anything under 85 mph.)
    Which puts another nail into the "speed kills" coffin.
    kdshapiro: "That's slower than most people in NJ drive on the turnpike. Does that make NJ or Montana a safer place to drive?"
    Considering that, based on my experience, you are less likely to encounter a left-lane camper in a rural, western state than New Jersey, I'd say Montana. That, of course, has nothing to do with "speeders."
  • carlisimocarlisimo Member Posts: 1,280
    I was once behind a Taurus whose brake lights were coming on briefly every 4 seconds on a freeway with a healthy flow of 70mph. After a while it started feeling like chinese water-drop torture...
    But I'm guilty of the opposite sometimes. I should tap the brakes to let people behind me know I'm going to start braking soon, or stop relying on engine braking quite so much.
    On downgrades, I understand. Especially on automatics. They never seem to slow down when you take your foot off the gas.
  • avs007avs007 Member Posts: 100
    I believe driver's side airbags were required in 1994 along with passenger passive restraint. Passenger side airbags I believe were required in 1997.
    GM was actually the first to offer airbags. Back in 1973.
    As for a reason to be on the cell phone while driving... I have a good one... One time I had to drive to Seattle/Redmond for a meeting with Microsoft. During the drive, I also had to be in a conference call, as I was a required attendee. I can't pull over for the conf call, because it's 2 hours long, and I'd miss my meeting in Redmond. It wouldn't have helped to drive the night earlier, because I had meetings down here I also needed to attend. I also had a late night conference call with some people overseas, that was 3 hours long, so even if I did drive the earlier, I'd still be on the phone.
    Not everyone that is on the phone while driving is distracted. Some people yes, but not all. I disagree with a previous poster who said that silence is not tolerable on a phone conversation. I never talk on the phone, just for the purpose of talking. There are plenty of times, when I stop paying attention to the phone conversation, if I'm concentrating on something like changing lanes in tight traffic or something. I personally fail to see the difference betweeen a phone converation and a conversation with a passenger.
    You'd be surprised how many types of "other" distractions I see everyday on my drive to work. I even see people singing/clapping along with the radio, with no hands on the wheel...
  • alfoxalfox Member Posts: 708
    I believe that these are a specie of driver I call the two-footed white-knucklers. They drive with one foot on the accelerator and the other on the brake, and maintain speed by modulating one against the other. My conclusions about the two-footed white-knucklers are:
    - I don't want to be behind them because asside from the annoyance their brakle lights are useless to me as a warning signal, and their turn signals become nearly ambiguous with all the flashing lights on the back of their car. Plus, I do not trust their reactions to an emergency situation. I wonder how many of the unintended acceleration accidents were two-footed drivers;
    - I don't want to be near them because they are so hung-up on maintaining speed and distance that they are not focused far enough ahead to identify danger in advance. They are dangerous;
    - I would never want to buy one of their cars used - can you imagine what the transmissions and brakes must look like? Also, considering that most of the fuel we waste driving goes into braking, imagine what their fuel economy must be.
    I stay clear of them. Who teaches these people to drive two-footed anyway?
    If you are truly not distracted by a phone conversation as you say, then I believe you are one among thousands and thousands who react otherwise. However, I suspect that the driver is one of the worst judges of his/her own driving or distraction.
    That said, I might do one of the (annoying) 2-hour conference calls in the car, on a headset as well, since they are generally all listening, and my attention is usually not too focused on these things even when in my office.
    If any real attention is required, or interaction is required on my part I would stop. But this sounds like a self-imposed problem. No reasonable employer would seriously require you to drive and attend a conference call at the same time. If my employer put me in that position, and would not yield on either the requirement to drive at that time, or on participation in the call, I would consider calling their bluff.
  • kdshapirokdshapiro Member Posts: 5,751
    "You might try to provide an example that rebuts mine. It will be more effective to your arguments."
    There is no rebuttal to the fallacy that speed limits are only there to enrich government coffers and not for public safety.
    "Which futher proves my original point that traffic fines are designed more to raise revenue than improve traffic safety. Governments generally choose the path of least resistance when raising revenue."
    No it just says there are far more speeds and far few jaywalkers.
    "And the New Jersey study is more accurate than a federal study conducted across the nation in exactly what way? It also flies in the face of the continual drop in the fatalities per 100 million vehicle miles driven since the repeal of the national speed limit in 1995."
    What makes the federal govt study accurate? Do the drop in fatalities have anything to do with better driver education, more police enforcement, better cars and maybe less to do with the increase in speed limits.
    "I'd say the New Jersey study doesn't hold any water. Maybe the study's authors need to check their methodology."
    I'd say the NJ study is probably more accurate than the federal study.
    "And your proof of this contention is found where? Studies have repeatedly found that changing speed limits on interstate highways has little effect on most drivers' speeds."
    And your proof that I'm incorrect?
    "The fatality rate per 100 million vehicle miles driven - the accurate way to measure highway safety, as it accounts for increases in driving - has continually DECLINED since 1995, and, as of last year, stood at a record low figure. The roads are safer now than ever."
    See comment above.
    "Both of these factors have nothing to do with increased speed limits or people driving faster."
    People can drive safe fast, but it is not always safe on every road to go faster than posted limits.
    "I don't see drivers exceeding the speed limit camping in the left lane. Considering that "failure to yield" is regularly cited as one of the top irritants of most drivers, I'd say that drivers exceeding the speed limit are not causing the "issues.""
    Correct but speeders will usually combine speeding and reckless driving, cause there is that need to speed.
    "kdshapiro: "Sure, the Autobahn is exactly like the GSP by Union tolls during rush hour.
    There are plenty of congested stretches on the Autobahn. It skirts major urban areas (those are the stretches with speed limits). This summer I encountered stretches where traffic came to a dead stop due to heavy volume or construction."
    Most of the autobahn does have speed restrictions? do people obey them?
    "Which is what I originally contended - people will obey speed limits WHEN THEY HAVE AN ACTUAL RELATIONSHIP TO IMPROVED SAFETY."
    The problem is that it is you are making the call, sort of like going to the doctor having a heart attack and telling the doctor what treatment you want.
    "That sentence is not only inaccurate, it doesn't make sense. If there is no speed limit, why would the cops nail you for going above 75 mph?"
    Don't make me post a link. Do a search on the internet.
    "When Montana enacted its "reasonable and prudent" law in 1995, cops were on record as saying that anything under 95 mph was fine, depending on road conditions, traffic and the vehicle. At speeds above that, they would scrutinize the situation more closely."
    Not true anymore
    Anyway this has been fun, if you pass me on the GSP, I'll probably see you in front of a trooper. Have fun speeding.
    Although revenue may be perpetuating the status quo, that's not where they came from. I believe they were set in early years based on no statistics at all (since there were essentially none) to try to match the capabilities of the average driver with the2-lane roads, most of which were empty most of the time. The standard speed limit numbers (35, 45. 55. 65) sort of evolved. Most rural 2-lane highways had 65 mph speed limits. With the exception of a few well known speed traps, enforcement was more or less for the purpose of traffic safety, and speeders were very much the exception.
    As the number of cars increased the carnage also increased, and speed limits were lowered. With the advent of the Interstate system, the limits could be raised again. What numbers did they choose? The traditional ones - 65 mph. Not for any statistical reason, and not as part of some conspiracy to raise revenues, just based on the traditional speed limits everybody was familiar with and the cars were built for.
    Fast forward 40 years: Traffic has exploded, highway deaths went up to numbers higher than all of the deaths in the entire Viet Nam war - annualy! Public pressure brought on congressional pressure, and the speed-kills thing evolved. Enforcement and lowered speed limits are all they knew to throw at the problem. Still, nobody was thinking about safety, in terms of the ability of the roads and the drivers to handle speed. No, they lowered limits, resulting in more bunched-up traffic, and more accidents. So, more enforcement: a typical governmental stupidity cycle.
    But in the process of throwing more enforcement and lower speed limits at the problem, police departments learned that there was a lot of money in this, money that could pay for more enforcement technology, more cruisers and (oh yeah) more overtime. What's not to love?
    To this day nobody is really looking in-depth at what changes would enhance traffic safety. Too much money involved now....
    show me a cop, ambulance driver, firefighter, politician, or anybody else who can easily get a ticket "fixed", who religiously follows the speed limit while not in emergency situations. Then I'll firmly believe that speed limits are there for our own good, and not as a money making scheme.
    Currently, about the only time a cop gets ticketed is if he happens to be speeding out of his jurisidiction, and that other jurisdiction has it in for him! Or, years ago, when Marion Barry was mayor of DC, his limo was speeding through a town in Maryland and he got pulled over. First thing he did was spout off about being the Mayor of DC. First thing the cop did was remind him he was in Maryland!
    and I agree that revenues tend to perpetuate speed limit enforcement. But you can't really say that speed limits are there only to produce revenues. I agree that they function best for that purpose, lol, but there is a huge albeit misguided belief on the part of the general public that "speed kills", that having been drilled into our collective heads for decades.
    Just imagine what would happen if any public official seriously attempted to eliminate limits or advocated increasing them to realistic levels. The speed counterpart to MADD would get AAA and the insurance lobby to fight it tooth and nail, and the official would go down. Nobody is going to touch this issue, just like they don't touch the foolish excesses of DUI enforcement. With the brainwashing done to the motoring public, those dogs just won't hunt!
  • gambit293gambit293 Member Posts: 406
    Funny that Andyman should bring this up. Just this morning I also got stuck behind one of those brake-every-3-seconds-for-no-apparent-reason cars. It was a middle-aged woman in a Lincoln.
    Like everyone else, my response is get around and away from this car asap.
  • ANT14ANT14 Member Posts: 2,687
    I have a friend (he's young, 29) that drives "boat style", as people here in Miami call it. He presses the accelerator, let's go, presses it, let's go... it's constant... He is NOT able to keep it at one specific point. I've tried to teach him to play with the tachometer, and see if he can keep "the cute little line" on one number, but nothing.
    And he does the same brake pedal issue... He just taps it, instead of letting go of the gas to slow down. And this is constant. We have yelled at him, cursed, made fun of him because he drives like an old lady, but nothing...He continues...
    It's now getting to the point we won't even get in his car because it's nauseating. And what's worse, ON a Camry... it's bad enough how that thing floats and wallows all over the road, with his imput, it doesn't help things any. AHHHHH
    I'll do that sometimes with my '79 New Yorker when taking off sometimes. Part of the reason though is that the sound it makes is actually somewhat addictive. My exhaust came completely loose from behind the catalytic convertor, so it makes a nice, deep rumble when you step on it. Also makes kind of a cool noise when you're accelerating, and then take your foot totally off the gas pedal, almost sounds like a big rig as it's slowing down.
    My '67 Catalina's kinda fun to do that with too, because it'll throw you back in your seat. It also has a nice rumble to it that often sets off the alarms of parked cars in lots and parking garages.
    I don't do it on a regular basis, though!
    Ha ha Gambit293, gotcha!!! Aren't those folks so annoying!?!
    Here's another one. This evening on the way in to work, I was behind a mid 90s Maxima. The guy driving was driving at a decent speed, and not bothering the brake pedal. But, when he braked for curves and such, he was crossing the yellow line after slowing down. I see this all the time, usually it's "Soccor Mommies" in minivans and suvs. They brake to or below the limit, and then either cut the inside on a left turn or curve, or go wide to the right. I cringe and fear the worst, when they do this on blind corners or curves. And I hang way back. Back to the guy in the Maxima. He got a little adrenaline rush. At one point, at an intersection, I was turning right, and he decided to do same, about 10 feet past the turn poin. I had to jab the brakes to avoid him, and he had to swerve to avoid the left turners in the lane waiting. Here's were the adrenaline comes in. Sitting across the intersection, heading the way we were turning, were two local "fuzz" units. 3 seconds later lights and sirens come on and they come a running. Flew by me, as I knew they would, and slowed down at him. Luckily for him, they both turned down a side street right in front of where he pulled over. I bet his wife gave him a little for that boneheaded manuver at the intersection. I smirked and said to myself, next time be a considerate driver. This concludes my novella.
  • derekgdwderekgdw Member Posts: 51
    I had one guy tapping his brakes to make them light up once every 10-20 seconds on the road once years ago, ahead of me, no passing zone and no traffic.
    I was pretty far back (3 or more seconds following distance at the time so I certainly wasn't tailing him) and he was doing 65 in a 55 as well.
    Finally after a few minutes of this I started flashing my brights each time he tapped his brakes. (You flash me I flash you) I don't think he got my message as he kept on doing it at the same intervals. Oh well.
    Hmmmm, maybe he was signaling aliens, and was waiting for them to come and take him to the mothership?
    Andyman 73 - Well then I did my good dead for the day by helping him be more easy to find wasn't I? :-)
    Ha ha ha ha ha...that was great!!! I lived in the High Desert area around Barstow, Ca, many years ago. Saw many interesting things in the skys, at night and in the day. I bet "they" really appreciated your help! LOL!!! :)
    I had some friends who used to live out there. I visited them a few times. Kind of a cool place to visit. It's neat seeing a mostly self-contained city of about 30,000 or so people out in the middle of the desert, with literally nothing stretching for 30 miles or more in every direction! Dunno if I'd want to live out there, though!
    I had a '91 Civic rental car on that trip. Discovered that, given enough of a downhill grade, it would hit 115 mph. And STILL get blown off by people in their Benzes doing 140!
    kdshapiro: "There is no rebuttal to the fallacy that speed limits are only there to enrich government coffers and not for public safety."
    Working in state government, I can assure you that speed limits are not always set to the recommendation of traffic safety engineers. The pressure is to lower speed limits, both for bogus "safety" reasons, and from the insurance companies and local governments, who are enriched by fines and surcharges from speeding tickets.
    And, as I've shown with Pennsylvania's recent addition of surcharges to traffic tickets to close a budget deficit, state governments benefit from too-low speed limits, too.
    kdshapiro: "What makes the federal govt study accurate? Do the drop in fatalities have anything to do with better driver education, more police enforcement, better cars and maybe less to do with the increase in speed limits."
    Considering that many school districts have reduced or phased out driver education programs under budgetary pressure, I doubt that better driver education is the explanation.
    Vehicles have been getting safer since the 1967 model year, when the first passenger safety standards where implemented as per the federal government's direction. The drop in the fatality rate during the 1990s can't be explained largely by safer vehicles, as cars and trucks have been getting better for decades. Plus, the vehicular fleet is not completely turned over in one or even two years. It's not as though everyone is suddenly driving vehicles with the latest safety equipment.
    kdshapiro: "And your proof that I'm incorrect?"
    According to a seven-year study conducted by the National Highway Traffic Safety Administration (NHTSA), in which speed limits were varied at 100 locations nationwide and the traffic flow studied, "raising posted speed limits by as much as 15 mph had little effect on motorists's speeds."
    Going further, the report states that, "contrary to public perception...the data actually indicates that accident rates were REDUCED (emphasis added) at sites where speed limits were raised."
    So, yes, you are incorrect.
    kdshapiro: "See comment above."
    The fatatility rates per 100 million vehicle miles driven is tabulated annually by NHTSA. The results for the previous year are widely reported in the summer (usually July).
    Check out these numbers - which are the accepted, most accurate way to measure road safety - and you will discover that your original contention is, indeed, incorrect.
    kdshapiro: "People can drive safe fast, but it is not always safe on every road to go faster than posted limits."
    And no is saying that it is. We are saying that exceeding the speed limit ON CERTAIN ROADS isn't the crime against humanity that the "speed kills" acolytes make it out to be.
    kdshapiro: "Correct but speeders will usually combine speeding and reckless driving, cause there is that need to speed."
    And your proof of this is found where? Considering that people who exceed the speed limit on interstate highways have fewer accidents than other drivers, that is an incorrect assumption, based solely on your opinion.
    kdshapiro: "Most of the autobahn does have speed restrictions? do people obey them?"
    I don't know the percentage of the Autobahn that has posted speed limits. Considering that I observed traffic continually slowing down in speed restricted areas, I'd say that people do obey them.
    kdshapiro: "Don't make me post a link. Do a search on the internet."
    Considering that you originally said that Montana still has no speed limit, I'd say your link is not accurate. It may be time for a new source of information.
    kdshapiro: "Not true anymore."
    I never said it was still true, in the wake of Montana's enactment of a 75 mph speed limit.
    kdshapiro: "Anyway this has been fun, if you pass me on the GSP, I'll probably see you in front of a trooper. Have fun speeding.
    Highly doubtful.
    Given recent events in the state, I'd say New Jerssy residents would do well to spend less time worrying about people exceeding the speed limit and focus on other, more important matters. Such as corruption in government, and whether the governor's boyfriends are really qualified for the positions he appoints them to.
    Friday's Wall Street Journal had an article on cellphone use in cars. I think the gist of the article was that there was no evidence that hands-free cellphones were safer than manual phones for drivers.
    What I thought was interesting was that they noted that car use of cellphones accounts for 40% of all cellphone use!
    That same issue also had an article about Oprah's car giveaway and the impending tax disaster.
    "Working in state government, I can assure you that speed limits are not always set to the recommendation of traffic safety engineers. The pressure is to lower speed limits, both for bogus "safety" reasons, and from the insurance companies and local governments, who are enriched by fines and surcharges from speeding tickets."
    As long as my property taxes are lower because speeders are getting surcharged, I am a happy camper. To lower my property taxes I would even vote for a proposition for more enforcement on the road. Thank you for pointing that out.
    "Considering that many school districts have reduced or phased out driver education programs under budgetary pressure, I doubt that better driver education is the explanation."
    Maybe in Pa. but in NJ drivers ed is alive. And still gets you discounts on insurance and is necessary to get a drivers license.
    "Vehicles have been getting safer since the 1967 model year, when the first passenger safety standards where implemented as per the federal government's direction. The drop in the fatality rate during the 1990s can't be explained largely by safer vehicles, as cars and trucks have been getting better for decades. Plus, the vehicular fleet is not completely turned over in one or even two years. It's not as though everyone is suddenly driving vehicles with the latest safety equipment."
    Actually the 90s saw the standardization of some small but significant auto improvements that contributed to better passenger safety, thus reducing fatalities.
    "According to a seven-year study conducted by the National Highway Traffic Safety Administration (NHTSA), in which speed limits were varied at 100 locations nationwide and the traffic flow studied, "raising posted speed limits by as much as 15 mph had little effect on motorists's speeds. Going further, the report states that, "contrary to public perception...the data actually indicates that accident rates were REDUCED (emphasis added) at sites where speed limits were raised."
    The problem is I've seen other studies to the contrary. There is an old saying, lies, damn lies and statistics. This is one of a number of studies with inconclusive evidence. So I believe I am as incorrect as you.
    "And no is saying that it is. We are saying that exceeding the speed limit ON CERTAIN ROADS isn't the crime against humanity that the "speed kills" acolytes make it out to be."
    I never said that, but the fallacy of studies that roads are safer when the speed limit is raised. Where there is a speed differential due to speeders the road is inherently unsafe. Raising the speed limit, does not automatically reduce the fatalities.
    "And your proof of this is found where? Considering that people who exceed the speed limit on interstate highways have fewer accidents than other drivers, that is an incorrect assumption, based solely on your opinion."
    The proof is studies that show speeds with the speed differential responsible for car crashes due to negligent driving. Again, post a link to a study that shows me to be incorrect in my observations.
    "Considering that you originally said that Montana still has no speed limit, I'd say your link is not accurate. It may be time for a new source of information."
    That is true, and cops will ticket you going above 75.
    "Given recent events in the state, I'd say New Jerssy residents would do well to spend less time worrying about people exceeding the speed limit and focus on other, more important matters. Such as corruption in government, and whether the governor's boyfriends are really qualified for the positions he appoints them to."
    The problem is corruption won't end my life. But a speeder can, especially if driving recklessly, tailgating, cutting people off, etc. The governers sex life has nothing to do with inconsiderate driving, and frankly if he can make the road safer I don't care who he brings aboard.
    collected at the county level, and not the state level? And trust me, just because the speeders are getting tickets, your property taxes are NOT going down. Instead, they're just going to find ways to spend that money on bogus new programs, skim some off the top, then find ways to make the budget bleed red so that they still have to jack your taxes AND keep harrassing people with speed traps.
    As for the government and cars, 1967 was the first year that they required collapsible steering columns, and even before that the gov't was starting to have some influence in automobile safety and emissions. The government had their fingers in the auto industry's pie long before the 1990's!
  • gee35coupegee35coupe Member Posts: 3,387
    Can end not only your life, but the lives of others. When the curruption cause health and social services to suffer, it's detrimental in many ways. But then the rest of that post didn't really say much other than nuh uuh anyway.
    I lived out there from 89-92, finishing up High school in 92. My father was stationed at Fort Irwin, north on Barstow rd. That's also where I learned to drive. I-15 was always fun to drive on, more so than 40. BTW mom's 89 Shadow would peg at 125 or so, had 2.5l 4pot, w/5M.
    Would go to Victorville just to go anywhere decent. Barstow does have the largest Mickey Ds in the U.S. Gotta count for something. And Henry Fonda went there in movie "Grapes of Wrath," should be worth a few points. Plus tons of off road racing in the area. And just about equal distance, give or take, to L.A. and Vegas.
    One of my old school chums still lives there. She's a teacher in the SV school district in Yermo, just over the hill from Barstow.
  • gregoryc1gregoryc1 Member Posts: 764
    In New Jersey we have a type of driver that will "tailgate" another driver at any speed in any lane. EXAMPLE: A driver could be driving at the speed limit, (65), in the right hand lane of the New Jersey Turnpike, the middle and left hand lanes could be clear, but the person behind the driver in the right hand lane will choose to tailgate the other vehicle, rather than pass the vehicle. In addition, the driver that is "tailgating" gets mad at the other driver for doing the speed limit in the right hand lane! ----------Why?----- The cause of the problem must be in the water!
    so evidently the other states must be tapped into NJ's water supply!
    kdshapiro: "As long as my property taxes are lower because speeders are getting surcharged, I am a happy camper. To lower my property taxes I would even vote for a proposition for more enforcement on the road. Thank you for pointing that out."
    Considering that I never linked a reduction in property taxes to increased revenue from traffic tickets, that certainly came from out of left field.
    Property taxes, in Pennsylvania at least, are collected at the local level and are used to fund education. Property tax revenues are not added to the general fund at any level of government - state or local. Nor are revenues from traffic tickets used to reduce property taxes.
    Of course, if revenues from traffic tickets in New Jersey are being used to reduce property taxes, that only strengthens the arguments of myself and many other posters that speed limits are set as much to raise revenue as anything else.
    You can't have it both ways - scoffing at the idea that speed limits are set to raise revenue, and then gloating about it when the revenue from traffic tickets is used to lower your non-traffic related expenses.
    kdshapiro: "Actually the 90s saw the standardization of some small but significant auto improvements that contributed to better passenger safety, thus reducing fatalities."
    As Andre1969 noted, the same thing happened to vehicles during the 1960s and 1970s (safety glass, collapsible steering columns, door side beams, etc.), thus negating your point.
    kdshapiro: "The problem is I've seen other studies to the contrary. There is an old saying, lies, damn lies and statistics. This is one of a number of studies with inconclusive evidence. So I believe I am as incorrect as you."
    First you demanded that I provide a study to back up my statement, all the while claiming that your "studies" proved otherwise. Now, when proof is provided, all studies suddenly have "inconclusive evidence." (Your rhetorical dancing around the gist of the argument would put the late Gregory Hines and Gene Kelly to shame.) The study certainly sounded "conclusive" to me.
    You asked for proof, and you got it - and from NHTSA, no less.
    kdshapiro: "I never said that, but the fallacy of studies that roads are safer when the speed limit is raised. Where there is a speed differential due to speeders the road is inherently unsafe. Raising the speed limit, does not automatically reduce the fatalities."
    The speed differential causes the road to be "inherently unsafe"? Someone forgot to tell the Germans on the Autobahn. The speed differential between the fastest and slowest cars can be as much as 50 mph. But the roads are safe.
    The key is lane discipline, as shown by Montana's experience when there was a RISE in fatalities with the imposition of a speed limit.
    kdshapiro: "The proof is studies that show speeds with the speed differential responsible for car crashes due to negligent driving. Again, post a link to a study that shows me to be incorrect in my observations."
    First you say that "the proof is studies that show speeds with the speed differential responsible for car crashes due to negligent driving" (which is a little hard to follow).
    Then you finish off demanding a link to a study that "shows me to be incorrect in my observations."
    So which are you going by - these mysterious studies, or your observations?
    kdshapiro: "That is true, and cops will ticket you going above 75."
    As I said before, considering the inaccuracy of the information you provided regarding Montana's speed limit laws, anything from that post will be taken with a rock-size grain of salt until proven otherwise.
    kdshapiro: "The problem is corruption won't end my life. But a speeder can, especially if driving recklessly, tailgating, cutting people off, etc. The governers sex life has nothing to do with inconsiderate driving, and frankly if he can make the road safer I don't care who he brings aboard."
    This quote constitutes "Exhibit A" as to why state government in New Jersey is so corrupt and incompetent. Considering that the good governor tried to have his...special friend...appointed to a position dealing with homeland security, I'd say that the corruption in this particular case COULD end your life.
    "You can't have it both ways - scoffing at the idea that speed limits are set to raise revenue, and then gloating about it when the revenue from traffic tickets is used to lower your non-traffic related expenses."
    I actually don't have any control over the way it is. But the idea that speeders can reduce my property taxes sure makes me smile. :)
    "As Andre1969 noted, the same thing happened to vehicles during the 1960s and 1970s (safety glass, collapsible steering columns, door side beams, etc.), thus negating your point."
    But you are specifically citing studies that shown an increase in speed reduced the fatalities.
    My guess is these studies do not take into account the safety improvements.
    "First you demanded that I provide a study to back up my statement, all the while claiming that your "studies" proved otherwise. Now, when proof is provided, all studies suddenly have "inconclusive evidence." (Your rhetorical dancing around the gist of the argument would put the late Gregory Hines and Gene Kelly to shame.) The study certainly sounded "conclusive" to me. " You asked for proof, and you got it - and from NHTSA, no less.
    The NJ study contradicts that study.
    "The speed differential causes the road to be "inherently unsafe"? Someone forgot to tell the Germans on the Autobahn. The speed differential between the fastest and slowest cars can be as much as 50 mph. But the roads are safe."
    Since when is the Autobahn comparable to the GSP during rush hour.
    "First you say that "the proof is studies that show speeds with the speed differential responsible for car crashes due to negligent driving" (which is a little hard to follow). Then you finish off demanding a link to a study that "shows me to be incorrect in my observations."
    I'm still waiting.
    "As I said before, considering the inaccuracy of the information you provided regarding Montana's speed limit laws, anything from that post will be taken with a rock-size grain of salt until proven otherwise."
    I'm waiting for some concrete information to show the contrary.
    "This quote constitutes "Exhibit A" as to why state government in New Jersey is so corrupt and incompetent. Considering that the good governor tried to have his...special friend...appointed to a position dealing with homeland security, I'd say that the corruption in this particular case COULD end your life."
    The corruption didn't end my life, and being in Pa I'd be worried about the potential fallout. However, to get back on topic reckless drivers who speed, tailgate and cut people off can. Especially if these drivers are driving large trucks. It's nice to try a loose cause and effect with NJ corruption and the end of life as we know it.
  • scotianscotian Member Posts: 1,064
    Those who defend their habit of left lane camping cause much discussion in newspapers as well as here:
    http://www.twincities.com/mld/pioneerpress/news/editorial/letters- - - - - - - - /9753132.htm
    http://www.twincities.com/mld/pioneerpress/news/editorial/letters- /9753855.htm
    http://www.twincities.com/mld/pioneerpress/news/opinion/9783094.h- - - - - - tm
    http://www.twincities.com/mld/pioneerpress/news/opinion/9792847.h- - - - - - tm
    I like this line:
    "Left-lane bandits are criminals who cause road-rage fatalities."
    Sorry, I can't seem to find the letter that started this.
  • imidazol97imidazol97 Member Posts: 27,745
    Can't read the first link without registering.
    Why not copy the relevant porttions and post them here.
    Since that's not another discussion group site, I believe that
    fits the rules for copying here -- with notation of source.
    I think registering is free. Also, pasting all the text might run afoul of the rules here. I could do that, and see what happens...
    If this gets removed, fine, just don't send me an email telling me I violated the rules.
    These are all letters published in the Saint Paul Pioneer Press:
    http://www.twincities.com/mld/pioneerpress/news/editorial/letters- - - - - - - - - - /9753132.htm
    http://www.twincities.com/mld/pioneerpress/news/opinion/9783094.h- - - - - - - tm
    http://www.twincities.com/mld/pioneerpress/news/opinion/9792847.h- - - - - - - tm
    Response to left-lane mentality
    About the lady who said, "I'll drive in the left lane at the posted speed limit if I want to because it's the law," well, I hope Miss Right will be happy when her holier-than-thou attitude causes a traffic accident by people trying to get around her, possibly hurting or killing an innocent adult or child in the process.
    The issue is not speeding but what action you take to provide safety for all. Driving the speed limit just because it is the law does not guarantee it is 100 percent right. Speed limits are suggested speeds in optimum driving conditions only. Common sense and judgment are also important factors.
    GARY J. RHEAUME
    Little Canada
    In response to Jennifer Anderson's statement that she is within her rights to drive in the left lane when she is going the speed limit: First of all, it isn't your job to enforce the speed limit.
    Move over. If people want to take a chance and speed, or to use the left lane to pass someone going just under the speed limit, the left lane should be open to them. In the metro, where most freeways are three lanes, speed-limit followers should be in the middle lane, not the right lane.
    The right lane is used for exiting and entering the freeway, so stay out of it. No wonder it's so difficult to merge onto the freeway, even when I adjust my speed and plan ahead for what that right lane is doing — people are camped out in it, merrily going 55, giving others more to work around.
    Just coast along in the middle lane, where the minimum de facto speed is usually 60 anyway, and leave the left lane to speeders/passers, and the right lane to mergers/exiters.
    ANGELA NIMS
    St. Paul
    I have a couple for Jennifer Anderson. First, it states in the Minnesota Drivers manual that the left lane if for passing only. I have seen State Patrol officers interviewed on television regarding this subject stating they do not encourage people to constantly drive in the left lane.
    If someone wants to speed, that's their business; it's not your job to enforce speed limits. You could be obstructing someone trying to get somewhere in an emergency.
    Secondly, if you sit there in the left lane and intentionally block someone who obviously wants to get by you, just think about how upset they are probably getting. Then think about all the nuts you hear about in the news every day and the things they do when they get upset. Think about what could possibly happen if you so enrage someone that they decide to do something to let you know just how they feel. . Then ask yourself if it would be worth it.
    MARK A GLEASON
    Lindstrom
    The left lane of any divided highway is a passing lane. The speed you are going does not matter what lane you drive. If we would all just use the passing lane for what it was intended for, there may be fewer accidents. So for all of you who ride the left lane, you should pass the vehicle you are trying to get around and get back into the right lane. As far as people driving fast in the left lane, you have no idea what their circumstances are. Maybe they are on their way to the hospital to have a baby or are trying to get medical attention for a bee sting.
    Let the State Patrol control people who drive fast in the left lane. Don't try to control people's speed by driving the speed limit in the left lane.
    Maybe people who like to ride the left lane should move to a different country where they always drive on the left.
    D. J. MILLER
    New Richmond Wis.
    Left-lane mentality response
    In response to Jennifer Anderson's "Left-lane mentality," I would like to share what my driving instructor told me behind the wheel four years ago. I had merged for the first time onto the interstate and was doing no more than the minimum. He told me it was imperative to accelerate and keep up with traffic, that that was more important than going the speed limit.
    You are only an obstacle in the left lane when you go the speed limit and that is dangerous.
    M.E. MOSNER
    White Bear Lake
    Passing in left lane
    In response to Jennifer Anderson's Sept. 23 letter concerning driving in the left lane:
    It is your right to drive in the left lane at the posted speed limit. There is no law to prevent that type of driving. However, common sense, common courtesy and a desire to be as safe as possible would dictate that you drive in the right lane unless you are passing.
    GREG MAJORS
    East Bethel
    No permission to speed
    I am a driver who will not move out of the left lane for someone who is attempting to make me drive faster than I am, which is usually faster than the posted limit right along with the rest of traffic. Should you want to move any faster, go around.
    Speed limits are posted for a reason, not decoration. The Minnesota Drivers Manual states under the section "Freeway Speed and Lane Use" that you are to "Maintain the same approximate speed as surrounding vehicles, when possible, but never exceed the posted speed limits. If you are driving at a slower speed than other traffic, stay in the lane nearest to the right side of the road. Otherwise, choose the lane of traffic moving at the speed you prefer and stay in it."
    This does not give permission to speed, nor ownership of the left lane to those who really want to speed. Going the speed limit would not be dangerous, as implied by some, if all drivers obeyed the rules. Those who tailgate and push others to drive too fast are the true hazards on the road.
    ANNE TUCCITTO
    St. Paul
    Driving statute says move right
    Left-lane bandit Jennifer Anderson (Sept. 23) mistakenly indicated that she has a "right" to act as a vigilante and block traffic in the left lane as long as she is driving the speed limit. There is no law that authorizes her to block the left lane even if she is driving the speed limit. However, there are numerous laws that make it a crime to block the left lane, even if you are driving the speed limit.
    For example, Minnesota statute 169.18 says: "Upon all roadways of sufficient width a vehicle shall be driven upon the right half of the roadway, except … when overtaking and passing another vehicle." The law also says: "Official signs may be erected directing slow-moving traffic to use a designated lane or allocating specified lanes to traffic moving in the same direction, and drivers of vehicles shall obey the directions of every such sign." The law also says: "Upon all roadways any vehicle proceeding at less than the normal speed of traffic at the time and place and under the conditions then existing shall be driven in the right-hand lane."
    DON DAME
    Woodbury
    That is why I will continue to pass on "the other left" ! :)
    I've been talking to a friend of mine who's just starting to drive regularly. She's still a bit intimidated by the freeway, and told me that she prefers staying in the left lane because she only has to worry about watching one lane next to her instead of two. She's right that the right lane has the most activity, and trucks, and I'm having a hard time convincing her that the second-to-leftmost lane is a better idea than the left...
    and "left lane for passing only" was something that they did NOT teach us in Driver's Ed. I didn't learn it until I was 17. That spring break, I went on a trip with my grandparents down to see my Dad, who was living in Florida at the time. At that time, I really didn't have much experience with highway driving, because mainly I just drove from home to school, and then to work, and then back home. Or goofing around with my friends, which really didn't take me out on the highways much.
    So the interstate was a relatively new experience for me, and I didn't know the first thing about passing lane etiquette. My goal on the highway was to stay out of the right-most lane as much as possible. So I wasn't going into the passing lane automatically on highways with 3 or 4 lanes in each direction, but once we got out of the DC area, and I-95 went down to 2 lanes in each direction, I stayed left. I figured I was doing everybody a favor, by making it easier for merging traffic to get on at the interchanges. It didn't take long for Granddad to explain it to me, though!
    One of my buddies, the one who used to have a '95 Grand Marquis, and now has an '04 Crown Vic (yet he's only like 32) has a habit of left-lane camping. Makes me nervous as hell whenever I'm riding with him, because he starts talking, singing with the radio, etc, and just loses track of his speed, often to the point that he's dropping down below the flow of traffic. When I say something to him, at least he does move over.
    kdshapiro: "I actually don't have any control over the way it is. But the idea that speeders can reduce my property taxes sure makes me smile. :)
    You don't have any control over the way traffic laws are written and how revenues from traffic fines are used? New Jersey doesn't have representative government?
    Now one could argue that New Jersey has uninformed, apathetic residents, especially when it comes to understanding the relationship between speed and safety.
    Incidentally, since the main purpose of traffic fines in New Jersey appears to be subsidizing the property taxes of residents, now I really don't feel the least bit guilty about exceeding the speed limit on the Garden State Parkway.
    kdshapiro: "But you are specifically citing studies that shown an increase in speed reduced the fatalities.
    "My guess is these studies do not take into account the safety improvements."
    Wrong, because the NHTSA figures from 1995 and 1996 show a noticeable drop in the death rate per 100 million vehicle miles travelled when the nationwide 65 mph speed limit was abolished in late 1995. This decline occurred within a one-year period. The turnover of the vehicle fleet within that one-year period was not enough to influence the results. The entire vehicle fleet is not replaced within a year.
    When Montana instituted a 75 mph speed limit, it experienced a rise in fatalities, as compared to when there was no numerical speed limit. Again, this occurred in a relatively short amount of time.
    Safety features have been phased into the vehicle fleet over a period of 30+ years. The turnover of the vehicle fleet is fairly constant.
    If anything, new vehicles last LONGER than before, thanks to improved rust-proofing and more durable drivetrains. The average age of all vehicles on American roads was increasing through the mid-1990s. (The recent spate of post-9/11 incentives, which has made new vehicles more affordable, may have driven the average vehicle age back down.)
    There were MORE older vehicles in road through the mid-1990s, without the latest safety equipment, but the fatality rate per 100 million vehicle miles driven still declined.
    kdshapiro: "The NJ study contradicts that study."
    I guess studies are now valid again? Before they were made up of "lies, damn lies, and statistics." President Bush and Senator Kerry aren't the only ones flip-flopping in this fall season!
    Considering that the NHTSA study, along with virtually every other piece of research conducted on the subject contradicts the New Jersey study, I'd say it's worthless.
    kdshapiro: "Since when is the Autobahn comparable to the GSP during rush hour."
    You raised this point in a previous post, when you wrote, ""Sure, the Autobahn is exactly like the GSP by Union tolls during rush hour." This argument has already been refuted.
    For everyone's convenience, I'll copy my rebuttal from post #3396:
    Just to be sure I'm clear - the Autobahn, in certain areas, has a rush hour, too.
    kdshapiro: "I'm still waiting.
    Funny, so am I.
    kdshapiro: "I'm waiting for some concrete information to show the contrary."
    As I've shown, you were incorrect in stating that Montana has no speed limit; therefore, everything from that site is suspect until proven otherwise. As of yet, no other proof to back up your original contention has been provided.
    Now, I did visit the official homepage of Montana state government. Is the site you were referring to? Here is what it said:
    "As you drive Montana's roads, the Department of Justice reminds you to always wear your seatbelt, observe posted speed limit signs and never drive under the influence."
    Of course a state government will tell drivers to obey posted the speed limit, which in Montana is 75 mph on interstate highways. Pennsylvania tells drivers the same thing about its 65 mph speed limit. Depending on the traffic conditions and weather, however, the Pennsylvania State Police will not pull you over for anything up to 75 mph, even though the posted speed limit on interstates is 65 mph. I've spoken to state troopers about this, and experienced it firsthand.
    Even though the posted speed limit in Montana is 75 mph, that doesn't mean drivers can't exceed it up to a certain point, as was mentioned in an Autoweek article a few years ago.
    kdshapiro: "The corruption didn't end my life...It's nice to try a loose cause and effect with NJ corruption and the end of life as we know it."
    Because this one was nipped in the bud.
    Incidentally, I find it amusing that you get worked up about people exceeding the speed limit on the Garden State Parkway, because it constitutes "breaking the law."
    Meanwhile, corruption in state government - which, the last time I checked, is illegal - illicits nothing more than a yawn.
  • Kirstie_HKirstie_H Administrator Posts: 11,247
    What would be even more convenient for everybody would be if you two would stop bickering. You're also way off topic.
    kirstie_h
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    supposedly at the beginning of the year, the state of Illinois made it illegal to drive in the left lane of an interestate for more than 1/2 mile. I found it here: http://www.cnn.com/2003/LAW/12/31/new.laws.ap/ 5 paragraphs from the bottom.
    Interesting idea, if it's true. However, I wonder how they'd enforce it during rush hour! And on an interstate with only two lanes each way, it's going to make the right lane awfully crowded.
    And now this press release words it a bit differently... http://www.isp.state.il.us/media/pressdetails.cfm?ID=161
    "While traveling on an interstate highway, a vehicle may not be driven in the left lane, except when overtaking and passing another vehicle. This prohibition does not apply to authorized emergency vehicles while engaged in official duties."
    This has been "the LAW", my understanding and or practice in the 38 or so years that I have been driving. The problem has always been enforcement. If you ask most folks, they "know" about it. The problem is there is a fair to large % of folks who do no practice it. For years, it has been understood that passing on the right was not a good practice; all the way to verboten. I was in fact taught it was really against the law. But the practical answer and practice is (for CA anyway) is it is legal to pass on the right.
    http://www.twincities.com/mld/pioneerpress/news/opinion/9802828.h- tm
    Slow drivers are hazard
    The writer of the Sept. 29 letter, "No permission to speed" states that she "will not move out of the left lane for someone who is attempting to make me drive faster than I am."
    Hey, lady, are you trying to boil our blood more than a traffic jam does? I doubt that anyone is trying to make you drive faster.
    Making faster cars pull around your slower vehicle causes even more safety hazards. The left lane bane of commuters are drivers like you who ignore the common-sense principle of "Slower traffic keep right." Imposing your speed on others is the problem. Ask any traffic official … you'll find that slower drivers are the hazard, especially in the left lane. Obviously, life in the fast lane is not for you, so try public transportation.
    JOSEPH COLLINS
    St. Paul
    Nice and safe driving
    Driving in the left lane just because you think you're driving at the posted limit (the speedometer on most cars shows less than your real speed) and blocking traffic is not safe.
    Slowing down to look for pedestrians in the crosswalk is safe.
    I was recently annoyed by cars practically stopping when taking a right on green in Los Angeles, until I realized they were slowing to look for pedestrians. Funny how a common practice there is uncommon here.
    Come on, let's not let those L.A. liberals out-nice us!
    MARTIN BURKEL
    Minneapolis
    Speeding is breaking the law
    If I am driving the speed limit in the left lane, I am not obligated to move over for Don Dame or anyone else who is breaking the law by tailgating me and speeding ("Driving statute says move right," Sept. 30). Webster's dictionary defines the word "limit" as "the greatest number or amount allowed." I am only obligated to move over if I am driving below the posted speed limit.
    I will not break the law because of your selfish road-bully attitude.
    BRIAN ERICKSON
    North St. Paul
    Great reason to pass on the "other left".
    but one of my friends, who is from Detroit, and has a dual US/Canadian citizenship and has spent alot of time in Canada, says that left lane camping is a ticketable offense there, to the tune of $200. Anybody know if that's true or not?
    Yes it is both a ticketable offense in CN and the USA. I suspect in both places it is seldom enforced. So for example the normal highway speed limit is 65 mph. You can actually go 45 mph in the left lane and still be "legal"
    If the limit is 65 and I'm in the middle lane and encounter a slow driver...move to pass in the left lane, someone is doing 80 in the left lane... they will have to slow down and I will move over right. People who hog the left lane not going at the rate of traffice are rude and inconsiderate, they are not the police. Let the police deal with the speeders*.
    grbeck - Maybe the fines can be put toward my property taxes.
