Honda Odyssey: Problems & Solutions:(1995-2004 Models)
Honda and Toyota dealers are not ranked high in customer service. Their Lexus and Accura divisions on the contrary typically are ranked at the top in this category.
jt
Too bad I can't afford an MDX.
I'm watching both Sienna and Ody problem forums. It seems Ody forums reports much more problems than Seinna, like 10:1. This is for 05 and 06 models only.
I'm planning to buy ody or sienna and monitoring both the forums.
We have brought it to the dealer 3 times so far to have it fixed. First they resealed the windshield trim. Then they replaced the trim. Then they replaced the windshield. Now it howls more than ever. Next appointment is tomorrow. Will report back what they did and if it fixed problem. I know others have had this problem. What did dealer do to fix the problem? Did it take 3 or 4 trips to the dealer to fix it?
jt
No
Is alternator on passenger side of the engine? I suspect it is. Probably alternator gets wet and short things out.
If it happens again, go back to the same puddle and see if you can create it again. If it is safe to stop after this happens, open the hood and see what parts get wet with the splash.
This way you can help dealer to diagnose the problem.
Good luck..
Rick...
The PAX wheels on the Ody Touring will ONLY accept PAX tires due to the design/size of the wheel. At this time, Michelin does NOT offer a snow tire for the PAX wheel. Therefore, one cannot put snow tires on the stock Ody Touring rims.
You might want to contact a vendor selling snow tire/rim packages (tirerack.com) for info about replacement sets. Don't get too hung up on trying to spec a wheel size the same (or close) to the Touring rims; all you need to get would be a tire size with the same approximate outside diameter as the PAX tires (so your speedometer isn't thrown too out of kilter using a different size tire).
Also, you'll need to consider the added expense of fitting your replacement wheels with tire pressure sensors; otherwise your TPMS will be inoperable.
http://www.michelinman.com/assets/pdfs/doc_xice.pdf
Instead, it appears it is built for industry standard rims.
Definitely get a car with stability control. Didn't exist in the 00 Honda, but now I think it should be a top option if you're doing lots of travel on slick, twisty roads.
thanks.
rob
Other posters have indicated that a tap next to the clock on the dash sometimes fixes the illumination problem, but i don't know if this is a permanent fix.
So I sent a pretty nasty evaluation to the dealer. Their new manager left a message requesting I give them a chance to earn back my business. This was around the same time that I noticed transmission problems (55K).
Once again, these boards helped tremdously, because the Honda toll free customer service line told me I was out of warranty, while you people told me that it had been extended to 100K. Since it was a warrany item, back to the dealer I went. Eventually, they decided to replace the transmission. They also gave me a rental for free, which I appreciated, especially since it turned out to be a Silverado. They did end up charging me to replace two broken engine mounts, but I looked it up and they really weren't out of line with their price.
Which finally gets me to my question.
The dealer said that the brakes will need to be changed by the next oil change. This will be the second set I've put on the van so I'm averaging around 27K-29K per set. They said that most people had to change them out every 25K. Does that sound right?
Is there any kind of brake pad that I could buy that could extend that?
What I'm thinking of doing is purchasing the pads online and then taking them to the guy who cleared the AC exhaust blockage. Does anyone else have a better plan?
Thanks in advance.
The guy that unblocked your evaporator drain line...he might have done something as simple as blow compressed air (like from a compressor used to power various shop tools) up the evaporator drain line from below, which would have taken all of about 3 seconds with the vehicle on a lift.
That could have been an easy $100 for him. Personally, I've had it done free of charge for the asking. So, inquire about the cost of the pad change-out.
Here is you all who have experienced problems could help persons like me to avoid these problems, if possible.
Question is.... is it possible to find out any of these problems, e.g. wind noices and others... during test drive(s). How should one test drive and how long to discover these problems before signing on the dotted line. Should you get the vehicle for a day (I'm not sure if the dealer would allow that). And when you get it, what checklist should one go through to ensure everything is working properly.
It is really sad that you're buying a new vehicle because you don't want the unknown problems of the used vehicle.... and new vehicle ends up pain in the :mad:
Thanks vor your help.
thanks.
rob
The clock display on your vehicle is similar to a typical wristwatch LCD display. So at night, it needs some source of back light (either small light bulb or LED) under the display to light it up. I suspect that this back light source is out. Normally, car makers do not have a fuse for every light buld in the vehicle. So a chance for finding such a fuse in your vehicle is next to nil. Sometimes, by luck, some solder joints or electrical connection to this light source may be intermitten. So tapping on the unit may get the lighting back. But if so, it will likely disappear again as soon as your car hits a big bump on the road. The best thing to do is to open this unit and look at the light bulb and possibly replace it. The more expensive option is to buy the whole clock unit.
jt
Don
If this happens you will have to replace the brakes and get new rotors. Also, you do not necessarily have to replace the front and rear brakes at the same time. Often the front brakes wear much faster than the rear and require replacing more often.
a legit concern, or nothing to worry about?
I'm sure there's plenty of dissatisfied Honda owners and there's plenty of satisfied owners too.
Perhaps you just got an unlucky model that was built on Friday afternoon so the workers slacked off. (especially over in QC)
Any ideas on what it might be or is it the same problem that caused the gasoline smell before the check engine light?
The windshield howl is fixed! It seems that when they replaced the windshield, one seal was not installed properly. Once the seals were in place, no more noise!
Side note. Dealer had construction going on for their new showroom. Today I noticed a nail embedded in the sidewall of the rear tire. Went back to dealer. They said they will replace tire for free. No hassle. Great customer service. They also said that if it were a run flat tire on the touring model, it would have cost upwards of $600 because they would have to replace the rim also. Is this true?
I see many people topping off, but I don't because 1) Honda says don't top off and 2) I heard something on CarTalk about not topping off, so I just don't top off to be safe.
I am having the exact same problem. It has happened 2x in the last 3 weeks. I took it to the dealer immediately after this last incident however, just like you they couldn't replicate it-duh! They are no help whatsoever. Please let me know if you find anything out. I am afraid that I will be in an accident before this is solved. My husband just talked to a friend who said it might be a dirty idle adjustment screw that somehow screws up the sensors.
RE: Any ideas on this I have a 2002 Odyssey Ex with 87k miles. In the last two weeks, the van has shut off twice while driving. Lucky, we weren't going very fast (approaching a stop sign, and in residential traffic). The dealer couldn't find anything wrong but as you can imagine this is a very uncomfortable position. Has anyone experienced this?
Your thoughts are appreciated ...
Anthony
If this happened to me on a four year old vehicle I would perform a major tune up. Nothing to lose (relatively) and it may fix the problem. I would replace the spark plugs, air filter, fuel filter, give it a good fuel injector treatment and possibly other things. It could also be related to the condition of the battery and your charging system. Were you running many electrical accessories when it happened? Was it raining, did you drive through standing water.? Another possibility, I have a 1999 Intrepid which has been flawless, but it is six years old. The ignition key is a little bit sloppy. I realized a couple of months ago that after starting the car, when I returned the key to the "on" position, I turned it back just a little too far. The car still ran, but all of the idiot lights came on. Now I am very careful exactly where the key is and I have not had the problem repeated.
Good luck and let us know if you do figure out for sure what caused this problem.
Thank you all
i have an odyssey 2005, and about the same milleage (2100) i am getting the exact same problem.
i was wondering, were they able to find what it is and fix it?
did the problem occured again?
Good luck
rockycow
