Honda Odyssey: Problems & Solutions:(1995-2004 Models)
I am new to this forum and have a problem with my Honda Odyssey 2003 model. Since today I am having problem of shifting gear to REVERSE or DRIVE. After few attempts then I could able to swift the gear. Before I take it to the repair, wants to know what could be causing this problem.
Thanks for your reply.
I will follow your exact steps to see if I can replicate them on my '04 EX.
Maca
Just a wild guess.
Realistically, you should get 28mpg if you drive constantly at 55mph on the highway with no sudden acceleration and no high speed driving. These EPA(of 28mpg) ratings are ideal lab conditions ratings that are not daily driving conditions we experience; but can be used for relative comparo purposes between vehicles. Getting 19mpg for city and highway driving(that I believe you meant) and speeds much over 55mph for a 4500lb vehicle is not unreasonable.
There are so many variables involved. Your city and highway driving conditions would be different from other drivers. We all have to live with the physics of the situation.
But one must recognize that lab conditions are not road conditions where there is more road and wind resistance and even load.
If you really want 28mpg, I suggest that you do not drive above 55mph in the highway. If you can by miracle keep your speeds at 55mph forever, exceeding 28mpg should be easy.
But is driving that way realistic and logical?
NO - Not for lead feet like mine. I like to enjoy the energetic and spirited performance of my vehicles like in my Ody.
Have you tried to manually set the climate control to blow all its air to your feet? It has been very cold here a couple of times and I have never been cold in my Odyssey. I keep the climate control at 72 and it can get down right warm!
To my understanding, the "transmission issues" pertained to the previous generation Odyssey (pre 2004 models). Not the current generation (2005+ models). My car is almost at 17K miles - pretty hard-driven but well taken care-of miles - and is as close to perfect as I could wish for, other than the minor niggling issues mentioned.
Took delivery of '06 Ody EX last night. On the road and in many online pictures, seems every other Ody has its "Odyssey" badge on the right side of the rear hatch. Mine is on the left, and the dealer name badge is on the right. Just wondering if anyone else has come across this one.
I doubt the dealer moved the "Odyssey" badge over and put theirs on the other side. It most likely came from the factory that way and they took the open side for their name.
While the perfectionist in me is a little aggravated, it may be one small way to tell mine apart from the others in parking lots.
Anyone else with a badge on the left side????
Given that the alignment is now fine and that all the suspension components are also fine, I believe a new set of rims and identical 4 tires would be the cure.
"To my understanding, the "transmission issues" pertained to the previous generation Odyssey (pre 2004 models). Not the current generation"
Those are very serious transmission issues. Consumer Reports online edition rates Odyssey transmissions the worst possible reliability rating on their chart from about 1999 to 2002. It's a solid round black dot on the Consumer's chart. Worse than Dodge, Ford, Chevy and others. Can't be sure about the newer ones. Maybe they just take a few years to break down. Can't trust what a dealer may say about transmissions of the newer models either. New ones are too new to know what will happen in a few years. And when I looked at a used older model, the salesman claimed there were no transmission problems in Odysseys! Incredible.
1 New tranny, and I'm good to go. Most of the cost was picked up by Honda...
Now I'm just wondering if I wanted my $600 back, how would I go about filing the paperwork to get a check in my hands?
Mike
Fortunately it hasn't happened to me- yet.
Perhaps if you aren't upside down on it you can go and trade it on a Sienna or other minivan.
The previous generation Odyssey definitely had transmission issues. There is absolutely no indication or data to suggest that the current generation has the same. Also, the company is Honda - not Ford/Chevy. They certainly did a thorough engineering analysis on the issue and designed the new transmission in a way that eliminates the possibility of it ever happening again. There was probably a weak link in the old transmission design, which caused it to fail under certain circumstances....I am not too convinced about the fixes they have in place to take care of the old problem, without doing a complete re-design.
Knowing Honda and their enormous engineering strengths, I sincerly doubt they would allow such a faux pas to slip by, the second time around, when they had multiple years to study the problem and make internal design changes. For the record, I don't need a salesman's glib talk to convince me of anything !
During the first year of ownership, I went 4 to 5 times to the dealer for this problem, with no good results. I even broke the drivers side door handle. To prevent the handle from breaking, I have to open the front door and grab the sliding door frame to yank it open.
It sucks to have a new vehicle requiring a major repair, but manufacturing defects occur no matter who. It even happens to Lexus, gasp!
Wow look another post from a person who never owned a honda before and which helps nobody!! Oh at least it adds to the number of posts!! Oh this one is adding to it too, and it helps noone!! It dosen't matter LOL!! Count it up DCX boys I still am happy to be driving a Odyssey!!
They "support" new of everything else. I have a question;
How is it that I can go to a Honda dealer and buy a "certified" used Honda which carries with it a 100,000 mile warranty through Honda Care (which costs the dealer an inspection and about $350) but the NEW Honda only has a 3/36K mile warranty! IF they are so good...why not give them a 100K Warranty to begin with?!
New Odys come with 5yr/60k miles powertrain warranties. Pretty much as good as it gets these days without going to a luxury brand. Honestly, if an engine/tranny doesn't self-destruct within the first few miles, it'll go 60k miles with abuse and lack of service so it's really a marketing ploy IMHO. I'm sure Honda only came around because Toyota has offered this for many years. It never effected my decision to buy a Toyota, I also never used the warranty. The only powertrain warranty I've used in such low miles were the u-joints on my 1-ton Dodge and it pulls 15,000# 30k miles a year so it was nice to have that coverage. Of course DC doesn't offer the 7/70 anymore.
I'm not saying Honda couldn't supply their dealer chain with brand-new transmissions. However, it would be silly because for every bad transmission, there is typically a good case that can be reused. Every manufacturer does this with transmissions, except some of the luxury brand simply because there is not enough demand/failures to warrant rebuild facilities. A transmission is a very complex machine and has a higher failure rate compared to other vehicle parts. It's really one of the last vehicle parts that I would consider problematic and that goes for all brands/manufacturers. Even poorly designed engines can go 200k miles these days. The average life of an automatic transmission is in the 130k mile range.
Where does this information come from? What evidence, OF ANY SORT, do you have that Honda is scavaging flood damaged Odysseys for the transmission cases? Or are you just making this up because it sounds good and you want Honda to give you a brand new transmission case?
A transmission CASE does not wear out. No mechanic looking under a hood would be able to tell it had been replaced anyway and this certainly wouldn't devalue a car.
Isn't the tranny case made from the same RUSTPROOF material as the engine block (aluminum)?
Just faulting the math! Glad you are Happy with your Odssey.
So which is it? Are you getting a rebuilt or a remanufactured? A remanufactured is essentially a new transmission. A rebuilt is a different story. A salvage transmission is also completely different and I'd never believe Honda was using Salvage transmissions for warranty replacements. Regardless of where the case came from, no mechanic will have any clue the transmission has been replaced without checking some sort of records. And a factory remanufactured transmission installed by a Honda dealer will not devalue the vehicle one bit. You're having emotional issues with this machine.
And how would the transmission case from a flooded vehicle look any different than one drug around under a vehicle through rain/snow/ice/mud for xx,xxx miles??
Probably but I'm sure there's something that can Rust, and once it does, it's the end of a good vehicle
