Visitor Agreement.
Many thanks
Best Regards
Edgar
When your overhead lights are on before you start the van, i would think they'd temporarily dim, or go completely off when trying to start the car. See, the starter pulls a LOT of current when engaging the engine to get it to turn over.
Van sitting on warm days causing a problem with the doors? Never heard of it, but I believe the "window regulators" (motors that move the windows up/down) have temperature protection such that if they meet too much resistance doing their thing and begin to over-heat, they shutdown for a while. Like a window regulator, perhaps a door getting direct sun warms the door motor too much such that it shuts down almost immediately. If that is the case, i'm not sure how you'd replicate it for the technicians. The next time this happens, see if the other door also has a problem. Maybe you have a marginal motor that needs replacing. Perhaps getting them to note it on your records prior to warranty period being up will help you after the warranty period.
I know that the aligment was correct and I do not drive hard or take corners fast. The Symmetry is the worst wearing tire that I have ever had and give Michelin a bad name. My mother in-law has a pair of them on a Toyota Camry and are not wearing well at all.
I now have a 99 Odyssey with a set of Michelin Hydroedge and at 38,XXX miles are wearing so well that they still look like new. These tires give a stiff ride with not so good traction in snow but give outstanding performance in the rain.
I don't mean to discourage you, just sharing my personal experience.
I just replaced my temperature control light. I know someone that took it to the dealer and was charged $100 for this.
To remove that part of the dashboard, you need to move the shift lever to the 1st gear position. Then, you can just pull the dashboard off.
Disconnect the wires to the interior lights and the temperature controls.
When you turn it over, you'll see 6 round holes in the back. These are for the 3 large and 3 small lights (one of the small lights is labelled 'black')
To remove a light, just use a flathead screwdriver and turn the base of the light counter-clockwise. Try and grasp the light and remove it.
Insert the new bulb, and lock it in place with the flathead screwdriver.
Re-connect the wires, and press the dashboard back into place.
1. Remove the Center Panel (has temperature control)
- see above instructions.
2. Remove the Driver's Switch Panel (has cruise and TCS control)
- gently pull on the right side (by the steering column)
- then pull on the left side
- disconnect the wires
3. Remove the instrument panel
- remove 8 screws holding the instrument panel
- gently pull the instrument panel off
4. Replace the light bulb
- turn the instrument panel over
- you should see a round hole that contains the light bulb
It may seem light a lot instructions, but if I can do it, anyone can. Check out what the dealer will charge you for doing it, and you may find it worth your while.
If so, you are transferring oils to the bulb. The high head of a halogen bulb will cause it to basically cook itself with those oils.
Just a word to the wise. That prior owner installed a trailer hitch. When we looked at the van the first question I asked was what he was towing and if he installed a transmission cooler. He reported the hitch was only used to mount a bike rack so no cooler was needed - and we have never used it for towing. The dealer told me Honda voids the extended warranty IF you have a hitch installed (used or not) - but he was willing to fight for us to get warrenty coverage. Not sure if that was smoke - but I understand the logic if you use your van for towing without the cooler. If you are going in for a suspected transmission issue and have a hitch you can remove - it appears that might be a good idea.
Only other items I have fixed were rear shocks - which were leaking and riding lower than they should (very noticable once the new shocks were installed).
Jim
Turns out there was a problem in the passenger sliding door wiring harness. When the temoperature heated up, metal structural pieces near the harness would expand just enough to pinch the wiring harness and short it out. Honda "re-routed" the wiring harness away from those metal pieces and we have been trouble-free now for over 4 years. Hope this helps.
I am getting ready to walk in your shoes, how did it turn out or has it? Patrick Martin
Assuming it is rubber adhesion to metal, you need to start out with a thorough cleaning of both the rubber, and the metal surfaces they contact. When everything is clean, go over the metal parts with some car wax, and the rubber with Shin-Etsu grease (Honda parts counter). I have also used Meguires spray rubber & seals treatment, and it works quite well but not for as long.
Now granted, I have an '02 motorized EX, but my doors are smooth, quiet, and squeak/wind noise free when I do this. They get nasty pretty quickly when I neglect them.
Steve
Rick
http://world.honda.com/news/2002/4020920.html
Good luck
I had a sound like that about 4 years ago - step on brakes and hear "squeal, squeal, squeal, grind, groan".
Have them checked out.
I have a 2002 Odysse and recently I had a similar noise problem with my brake. After driving for awhile with many stops, the brake would produce a rubbing/??? noise when I brake to a stop. The noise is difficult to describe. It was not metal grinding noise. Anyway, my mechanic told me that it is normal with the OEM part. The material builds up heat faster that produce the sound. An alternative is to replace it with a semi-metallic pad. Semi-metallic pad would wear out the rotor faster and may produce squeaking sounds when braking. I decided to use it, after 50 miles with the new Bendix semi metallic pad, so far no problem. I hope this would solve my problem and may be it will help yours too. Good luck.
Regarding this "grinding" noise, I just purchased a 2006 Odyssey and less than 100 miles I've noticed this "grinding" noise too. I term it as a "mechanical engagement or release" with feedback felt thru the accelerator pedal. I just took the car to a local Honda dealer and reproduced the sound for them. The service manager then drove the van and reproduced the same noise. Before driving in the van, the service manager advised me that Honda Odyssey ABS calpers, etc are making noises wherein owners are caught off-guard by this. However, after driving my EX model, he stated it was a noise he NEVER heard before. I think it is quite ODD that the "feedback" would be felt thru the accelerator pedal. For me, this "issue" always occurs after I start the engine, and when the speed reaches 11 mph. Thereafter, having come to a stop light or sign, and reaching 11 mph and up, there is no indication or "issues" of any sort whatsoever. My gut instinct tells me that it is something engaging and then releasing as a routine operation, but it is odd that it occurs only on some vans. I think all vans do this, just that the "feedback" is more apparent on some and not others.
Another "noise" issue I've detected is a "low-popping" noise when creeping thru a parking lot or street. From my experience, it is due to the struts. Either the struts themselves, the mounting, or bearings.
The dealer is going to look into the two issues. I will let you all know what they say.
By the way, I live in SoCal, and the EX model was purchased for $24K, thus $26,200 out the door.
Best of luck to you all!
77porsche
Also went over the rubber seals with silicone grease.
i think you can search this forum for messages related to EGR.
look at message 5912; even if your VIN doesn't fall into the range, seems like it may apply.
Check me out!
http://www.carspace.com/master1
My question is . . . . Does anyone know if the '03 version has been better than prior years with respect to engine/transmission reliability? Does anyone know if my transmission were to go out on me if Honda is pretty much picking up the bill on transmission failures prior to 100,000 miles?
Any info or personal experiences out there would be greatly appreciated. I am trying to decide if I should buy an extended engine warranty or just roll the dice for 3-4 more years. Thanks!
Hello I just wanted to tell everyone that HONDA really backs up their product.
I just had the trans replaced a power door-lock (slider driver) and replaced the ignition interlock on a van that is OVER 7 years old and has almost 80,000 miles on the odo. No hassle, no BS just yes sir we will repair this under Honda's warranty service. I never bought an extended warranty either. I will drive nothing but Hondas from now on and I will most likely buy them at Norm Reeves in Cerritos SoCal!!!!
Sidenote, - I had a lincoln continental, blew the trans at 72K, the motor at 75K and the suspension at 80Kmls. Ford told me to go fly a kite every time! Guess what? -- I dissuaded at least three peoples from buying a ford product, but have swayed at least six peoples to buy Hondas. I have three Hondas: a '91 Accord, a '99 Odyssey, and an '05 CR-V...
And I really want to add an Element to the list... :-)
:confuse: ">
In 3 weeks our 1996 Ody with 150K will be towing (for the first time) a small tent trailer. Due to my mechanics opinion and the fact that I just mailed off our last car payment, am I tempting fate?
Symptoms:
- Start vehicle (no buzz)
- Run vehicle for about 5 to 10 minutes and buzz gradually starts up in radio without headphone use and in wireless headphones and becomes constant
- Buzz is so loud in headphones you can't hear anything but the buzz
- Turn radio off, buzz stops in headphones and radio without headphone use
- Turn vehicle off, but leave radio on, buzz slowly disappears in radio and headphones almost as if something in the engine is winding down that causes the buzz to go away.
- Turn vehicle on within about 5 minutes of turning it off and buzz immediately starts.
- Again noise is just enough to be annoying through the radio (without headphones), but it renders the wireless headphones useless once it starts (that is all you can hear in them)
Any thoughts on this one? :confuse:
i'm thinking a radiator fan motor problem. does the sound go away slowly as the radiator fan stops running, perhaps after the engine is shut off?
then when the fan starts up again after the engine is warmed up, does the noise return?
get out of the car when it's idling and see if the sound is there and coordinated with the fan running.
