A/C reduces humidity in the summer as well, maximizing the feeling of cool.
Just surprised that it seems to stay on A/C basically all of the time.
No WONDER the compressors seem to fail down here a lot.
I guess I need to go on a longer drive in cold weather to see if/when the A/C switches off.
AFAIK, if you burned the CD using Windows Media (WMA), it should play like a "regular" CD. I don't think the issue really involves mp3 since WMA isn't a compressed format. There are other compressed formats that provide superior sound to mp3 that probably are not compatible, however.
Yeah, mine does that too. Weird, isn't it? And sometimes the fan speed indicator stays on, sometimes not.
A word of caution--my Freestyle already has to have body work done. You know how when you open the door (usually on the passenger side) and it scrapes on a high curb? Well, my daughter did that to mine and the bottom panel partially popped off. It's just clipped on there. It was such a slight bump that I didn't even hear it. My daughter told me about it because she knew the car was new. Well, it looked bad with that piece of plastic popped partially off, so I took it into the dealer and asked them about it. I thought I would just be able to have one of the guys pop it back in with a special tool or something. Nope. Whole panel has to be replaced, painted, etc. Going to take about 6 days. That is something that has happened to all of our cars, I'm sure, but The Freestyle doesn't handle that kind of mishap very well, I'm afraid. I also had a rattle that sounded like it was coming from inside the driver side door. Well, the rocker panel isn't fitted right so they have to order a whole new one of those, too. Sigh. So I'm driving a rental Explorer. Geez. Other than that, it did great on my trip to L.A.--fun to drive, got about 25.5 MPG out on Interstate 5. Got stuck at the top of the Grapevine in a 2.5 hour traffic jam. I had to keep it running the whole time because we were crawling just fast enough that I couldn't shut it down and start it up. The temp gauge never budged, the car handled it amazingly well. Still got a very fussy 6-CD changer, but not enough to take in to be fixed. Still lovin' my Freebie.
MP3 (MPEG-1, audio level 3), MPEG-2/AAC (Apple), WMA (Windows), Atrac3 [sounds like 8-track] (Sony) are compressed music formats. In general, ~ 1MB/minute of stereo sound.
A car's CD/MP3 player would need to have decoders for WMA and AAC digital music in the electronics. There is some hope - the iTunes music library on my computer lets me burn an "MP3 CD", though AAC is the default compression for iTunes.
AIFF (Apple) and WAV (Windows) are uncompressed and when burned to CD, play like a regular CD. ~ 10 MB per minute of stereo sound.
Any chance you could change your name to avoid confusion?
strengths--AWD is fabulous--dealt with subzero slippery Minnesota weather and roads much better than my previous Jeep
Fit and finish and interior comfort very superior
knock on wood absoulutely no problems
quirks--climate control is industrial strength and very efficient even for Minnesota--on Auto need to go down to 68 degrees after engine warmed up otherwise you roast
otherwise hard to complain about anything
One the design changes that were made to overcome that lack of efficiency was to close all of the pre-conditioned cabin air's escape routes.
The idea being that once you cool the passenger cabin to the desired level the less of that air that escapes the less "make-up" fresh incoming (HOT??!!) air must be cooled.
So, you drive up to the pass to pick your three teenagers, wet and sweaty after a day of snowboarding.
Soon the passenger cabin is heavy with moisture.
The windshield starts to fog over.
Lower the rear windows slightly, turn up the temperature setpoint, with the blower on high, to just below your personal discomfort level, and put the system in defrost/defog/demist.
Unplug the connection to the A/C clutch.
And right there another truck, with Saturn minivans (Relay).
Also, I washed my car for the first time and I think that is the best way to find out how the car is built. I love the car and I realize that if every car was hand built and everything fit perfectly, I think you might have to pay a bit more (like a Rolls Royce maybe?). But, I found a third piece of loose, ill-fitting trim that needs to be replaced. The dealer has been great about fixing these cosmetic things and giving me free rental cars. I get the feeling that modern assembly line cars are like Lego block cars: snapped together and it usually is right, but there is just a certain number of things that get by quality control. As long as it's only silly stuff like that, I'm cool. All the guts under the hood are more my concern and I think I lucked out there! (Knocking on wood. Hard.)
I have found my digital air gauge to be most accurate, round dial analog gauge pretty good, Black and Decker Airstation to read about 1.5 pounds low, and an analog stick gauge to be low by about 3 pounds. When I add air with the Airstation, I just add the 1.5 pound fudge factor.
"Give an engineer a meter (gauge) and you have an expert; give two engineers meters and you have confusion..."
Regarding your Freebie's tendency to the right, I tried your light-grip-on-acceleration approach, but got no real tug wither way. Maybe yours was meant for doing crop circles. If the dealer does realign things, a check of the tie rod ends and steering rack may be useful.
Mine still scheduled for 24th....feet have been getting a little cold so I drove by the dealer today to visit another one.
My past several vehicles have been nightmares so I'm just a bit nervous, not to mention incredibly impatient.
About those crop circles... not much of that around here! Well, we did have a sighting of one, but some kids finally admitted doing it. I just love California...
And Btw thanks for all your input.
However I have a question about the power plugs. On every previous vehicle I have owned, the power to the "cigarette" jacks turned off with the car. However on my Freestyle they appear to be always on.
Is there any way to change this behaviour?
If not - does anyone have experience with allowing cell phones/ipods to charge with the car off? Does it drain the battery too much?
xnappo
You can't easily change whether a "power point" (cigarette lighter) is switched or not. Have you checked all three of them to see if they are all unswitched?
xnappo
Even if not for power concerns, I wouldn't want to have all that equipment sitting in the vehicle routinely to finish charging for an extended period of time.
I prefer the non-switched powerpoints myself. I can always disconnect the power from the device if I decide that I don't want it to charge.
I seem to remember the saleman saying yes but all the materials say no - so I'm confused.
In "single play" mode, whatever source you've dialed in on the radio is pumped to all of the speakers (depending on how you've set the left/right and front/rear, of course).
In "dual play" mode, the rear speakers are disabled, and whatever you select on the radio is only pumped to the front speakers.
Those in the rear then need to listen on the wireless headphones. I believe that each set of wireless headphones has its own volume control.
Our Disco has rear audio w/out a DVD -
I highly doubt there's rear audio controls in the non-DVD version. Why would there be?
At any rate, I don't know where they'd even put them.
I can't imagine different sources coming out of the various speakers.
Only with headphones for the rear would this make sense, IMO. And the only way you get those is with the DVD.
Are there other cars where the back seats can be listening to the radio (out of the rear speakers) where the front seats can be listening to a CD (out of the front speakers)?
I've never heard of this, and it just sounds . . bizarre! It'd probably drive me insane. LOL
Sorry if I am redundant, but over 2000 msgs. was a lot to go through.
The DVD model comes with two sets of wireless headphones, but I think they only receive what's coming from the DVD player.
Maybe you should get one with the DVD player after all!
But I believe that the ground clearance on the AWD version is about 1" higher than the FWD version.
I want to say maybe 5" on the FWD and 6" on the AWD?
A couple of nights ago we have almost 20 inches of snow. The freestyle plowed through it no problem. I have put four snow tires on it.
