Honda Odyssey: Problems & Solutions:(1995-2004 Models)
Happy driving
You may want to check out the Tires, tires, tires discussion topic in the Aftermarket & Accessories message board.
Drew
If there's a TSB to fix the problem, and it centers around the PCV valve and routing, I doubt if the octane has anything to do with it.
IMHO if you use less than 35 psi in your tires -(cold) you are reducing the capacity of the tires to safely perform at the Ody's maximum gross weight. I ran 42lbs on a 2000 miles trip from Denver to Phoenix and back and got the best mileage ever. 27.9 at 75 to 80 indicated. I know wind has a lot to do with mileage but I got 27.9 coming and going (two people bags for a weeks stay and a set of clubs and a case of maui splash!
rockycow
Question for Ody owners - is the AC up to the task of keeping the van chilly in the summer months? I have a '93 Civic Si and don't even bother to use the dealer-installed AC because it's so weak. I imagine the Ody has factory-installed AC so it's a little hardier. Please let me know how your Ody's have been treating you, both up front and in the rear of the van.
I also posted this query on the "Honda Odyssey" board. Sorry to annoy some by double-dipping, but my "refundable" deposit is going to be collected soon, so all info helps. Thanks.
Jim
One tip to speed up cooling it down after you've been parked for a while. Open the rear vent windows for a few minutes, and the cool air will move through the vehicle quicker. (I know there's a rear vent at the bottom of the rear side panel, but it doesn't pass enough gas to cool it as quickly as opening the rear vent windows.)
Drew: I never said the label on the car was frivolous, but I suspect that the car manufacturer wants the car to seem to ride smoother so understates the recommended tire pressure by a few pounds, since I have noticed this on virtually every car (mostly Hondas) that I have owned over the past 20 years or so.
Since I seldom replace the original tires with the same brand, once they have worn down, I am not sure that label applies to any replacement brand tires.
I have had no problem with my tires. As I said,
I have had only 3 sets of tires on an 83 Honda with 180,000+ miles, so I am not going to change
my pattern of 34-35 psi. Incidentally I have never had any problem with abnormal tire wear from over-inflation or under-inflation. Other
autos (depends on weight and size) I have averaged between 30,000 and 45,000 miles per set of tires.
But they are the one who state the recommended pressure in the first place, LOL. So if they understate something, wouldn't that be the recommended pressure instead? The tire manufacturers only specify the maximum cold tire pressure that you should inflate the tire to, but rarely do they specify pressures for specific vehicles as the same tire may be used on different makes/models. As I mentioned, the vehicle manufacturer works with the tire manufacturer when developing the vehicle, so all of this is taken into account. Generally though, most manufacturers seem to try to find a balance between ride quality, performance, fuel economy, and tire wear.
Good luck!
Drew
I did that shortly after getting our Odyssey. I too thought it was funny the stations had changed by their self. On reading the manual I found that if you push the Asel button again it reverts back to your programed stations.
I think it is a common problem for the techs to push against the sliding doors just below the window during repairs and cause these dents. I noticed another new EX at my work parking lot with palm dents as well. I talked to the owner and sure enough her driver side slider had stopped latching and had just been repaired. She had not noticed the dents, until I pointed them out.
Dave
That sounds like something you should take to the dealer. The thud or thunk happens after the car has been moved and when you're changing gears. There shouldn't be a thunk on start-up (at least mine doesn't do that - 2500 miles EX GG).
Druce
Have a nice day!
Greg
I don't understand why Honda can't find a fix. The problem now exists over 3 model years...what's it going to take? I'm going to unload this van before the warranty runs out.. I don't see how irreversible damage can't be occurring with every mile.
We've gotten very little help from our dealership over this matter.
Thanks for listening
Also what is the best stratagy for driving in a hilly/mountain roads? should I reigiously downshift on the slopes (less than 5-10% grade)? I am looking forward to driving my 00LX from Carolinas to Yellowstone.
Ody's Grade Logic will automatically downshift on downslopes when the brakes are applied in order to enable the engine to help with the braking.
I thought Grade Logic was a good idea, but so far I've been dissatisfied with its decisions in the mountains, and have selected gears myself, whether going up or down. The only time Grade Logic has downshifted for me has been unexpectedly in town, usually when traveling downhill and slowing for a turning or lane changing driver... only want to scrub off a few mph and abruptly I'm in second gear... it isn't really annoying, but given the choice, I'd disable the Grade Logic.
Also, in my experience, the low fuel light will come on within 5 hrs. on cruise control. ;-)
On a related topic, I averaged 23.7 MPG during the return trip (after the odometer had passed 1000 miles), going 70-80 MPH on the Interstate most of the time. I think this is pretty good for a fresh engine. I expect it will get a little better for the next long trip in July.
Odyssey being a lemon. I have a 2000 EX and have
had trouble with the passenger sliding door since
the beginning. I have had it repaired seven times
(it's in the shop again today) and even the dealer
advised me to contact American Honda and declare it a lemon. It's always the same problem - the alarm sounds but there's no light showing the door is open. Also the door doesn't always close correctly and pulling the handle doesn't open the door. This last time the door wouldn't lock with the rest of the doors. I took it in to be repaired and they cleaned the contacts and told me it was better - it wasn't. The door got stuck open and my husband got so frustrated he pulled the door too hard and snapped one of the cables. They have previously replaced the handle and the control panel and it keeps coming back. Anyone else had problems this bad with their EX? I did contact American Honda by phone today and they were extremely nasty. I guess I'm in for a long fight. I just want my car fixed!
Sorry I didn't get back sooner. Had my 00 LX back to the dealer on May 2 (this is a second dealership not connected to the one that gave me all the grief). Met with the service manager and Field Engineer. Went for a ride, the service manager drove and we agreed we felt the vibration. Back at the shop I took a rental and went off to work eagerly awaiting word on what they would find.
At 4PM my phone rang, it was the service manager saying " I think we got it, come on down and lets go for a ride".
So I hurry back, all three of us get in the van and I head off down I-10. As I start to get it up to speed I did notice a difference. It wasn't vibrating nearly as bad as it was previously. But it wasn't compleatly gone either.
Explanation, Radial Force Variation. (Radial Runout) The Field Engineer was very technical with his explanation, but I managed to cut through the technical jargon and get some useful information.
The right rear wheel is the most sensitive position on the van. My tires and wheels measured as follows, LF-5, RF-5, LR-6, RR-15 RFV. The lower the number the better the RFV. 15 RFV is the maximum allowable limit for any wheel and tire.
So the next step was to index the tire to the wheel. Apparently when Michillen X One's are new they have a dot that is to be indexed to the valve stem on the wheel. If this isn't done it causes a higher RFV. It took them six tries but they got that tire and wheel down to a 7. As I said this made it better, but didn't cure it.
Of course this was all done on a Hunter GSP9700. Without that machine they'd still be telling me there's nothing wrong with my van. My question to the engineer was "do they index the tires to the wheels at the factory?", he said "yes". I then asked "then why did I have the same problem with the Firestone Affinity's?" Of course he couldn't say without examining the original tires.
So my feeling after nine months of having my chain pulled, Honda owes me at the very least a set of wheels, a new set of tires and an upgraded warranty to 5/50. I told that to Customer Service in Torrence this morning and am still waiting for a call back.
Will keep you posted.
My readings were LR 11, LF 18, RF 12, and RR 20. The RR was the bad tire and out 32 but they managed to bring it down to 20. They told me that 11 was a very good reading. I'm still not convinced this is the cure but it sure helps. Need to see how the tires wear and if it comes back (I'm sure it will)
Like you I think there is still something wrong with this van. In my opinion it is with the front suspension. I think we have the exact same problem. We have the same problems with Honda too. I am going to write the Executive VP of Honda Canada Inc. He is the guy in charge of sales, marketing, parts, service, and dealer development. I figure they owe me as well.
E-mail me at Th@zeifman.ca if you want and lets see what our vans have in common. IE build dates etc.
I just got my Ody, in the way back from pick up. I noticed that my Ody has a relatively loud wind noise (55mph) from the top of the car. I guess it may because of the cross bar of the roof rack? Anyone had such experience?
HT
Noise seemed to be coming from the drivers side and the bump could be felt under the drivers foot.
Took it in to the dealership and they said they tighned a few things and the problem is now fixed.
In any event, if that's the noise, the weld did not have to be redone. It had too much build-up which was contacting another component, and they just had to grind it down some.
FWIW, I've had the van for a year+, have 15,000 miles, and that's the only problem I've had. Been very happy so far.
The dealer says it is a mystery as to why this happened. States the clearance between the hardware on the inside and the sheet metal is very narrow. He could not tell me what what going to be done to prevent this from happening in the future.
I also mentioned to the dealer for the 3rd time I heard a clunk in reverse. The 1st 2 times he could not duplicate the sound. This time he says "Oh ya - there is a bulletin out - you need a new transmission.
Has anyone else had these the protrusions on their doors? Will the car ever be the same after the new tranny?
I did not buy the extended warranty because I was buying a Honda. Shame on me!!
Dave
2001 Mesa Beige, 3900 miles
I vaguely remember reading that in these boards before.
Try turning your CC completely off including the rear, wait a couple of hours and then start the van. If the noise is gone, perhaps you have found the culprit.
