on the net was saying change at 500 miles to get out metal
particles. The '02 did not come with standard magnetic drain
plug, you had to add as aftermarket. The wife's '04 did
have the magnetic drain plug and it did have shavings at the
first change, not much since but with her's I did the first
change at about 3k miles. I still have the extra mag drain
plug I bought to install in that car.
With my car, since it does track duty I change at 3k miles
or after 3 track days, which ever is first. Actually the OLM
doesn't come down that fast even with moderate track duty.
I get the engine oil temps up into 270's about 3 to 5 times
a day at the track while on a road trip it never sees over
about low 200's.
I'm betting that with standard use anything under 15k miles
is probably still overkill but what the heck on a 50k car!
Randy
1. 2002 air filter cover (much greater openings cost $45.)
2. drilling holes in the stock 2001 air filter cover (to make much greater openings; cost ZERO)
3. removing the air filter cover all together and plastic tie the stock oem filter in place (cost ZERO).
You can do a search on the Z06 site. It is also complete with dyno tests!
The key point here is Corvette specifies their off the shelf vehicle with an unseen test passage of snow prophylactics. In the worse case, the car after being confronted with a 3 foot wall of snow will prevent possible hydro lock of the engine by advertent or inadvertent ingestion of snow. Bottom line is that is the real majority reason for the constriction. So if one does not need, want, or is willing to self insure, just the air filter cover removal is good enough for more freer breathing.
I would not use a oil media filter for it increases the likelihood of the intake portion being coated with mineral oil, as it simultaneously allows more silicon (grit) into the intake system than a stock oem filter. This of course adds to wear.
With 60-70,000 miles I have actually used a soapy water white cloth to clean the insides of the intake (clean side) and the white cloth showed literally no dirt. There was no oily residue, but predictably that was due to NOT using mineral oiled media. Also if you use oil media products, use increases the chances of coating the very expensive intake sensors, which increases the chances of failure due to corrosion of those sensitive sensors.
Far less important (on the consumer side, but probably the real core reason on the vendor side) is how much you pay for "mineral oil". 1 gal retail is app $21. How much does one pay relatively when one buys the 8 oz bottle or spray? (per gallon?)
The $750 option gets you the transparent top IN PLACE OF the painted. The $1,400 gets you both tops.
For $750 you get the transparent top IN PLACE OF the painted top.
$1,400 gets you BOTH tops.
Mine came with painted only, which is what I wanted...like the look of painted only. There have been some complaints of excess heat with the transparent top, obviously from areas of the country that can get pretty "toasty" although you can purchase an interior cover (after market) to cut down on this. I sure didn't want both tops....just something else to store in the garage.
I wouldn't mind the "view" with a transparent top but I just much prefer the solid color look rather than the 2-tone look of the transparent one.
It's a matter of personal taste.
I have a 2002 triple black convertible C5. I've owned it since new and it has 25k miles on it. I've had very few problems with the most expensive on being about $600 to fix a headlight that wouldn't go down. After calling corporate and telling them the car just went off warranty last week, they helped me out a lot. Now, just one month after paying the car off, the dealer tells me I have a electric brake control and brake pressure modulation valve that needs to be replaced. Cost: $4000. I literally thought he was joking when he called me. After five minutes of laughter I finally realized he was serious. He said "hey, you got a vette" as if I should have expected this. BS! Last I looked GM/Chevy may not have been at the top of JD Powers or Consumer Reports, but I'll be damned if they were at the bottom.
Is anyone familiar with this problem and its resolution, options, alternatives, etc.. Oh, I find this out a week after I listed the car for sell. Fixed or not, I will NEVER buy another vette and would advise anyone that does to lease it and send it back b/f the warranty expires. Oh, and find a more sympathetic dealer/service department. I've called corporate again, but haven't heard back as of yet.
experiences that will make you swear off a few more makes
and models but fact is, today things are expensive. I have
a 2002 with almost 70k miles at 6 years old. I got the ABS
system replaced around 4.5 years and close to 50k+ miles. At
that time they said the unit was $2,700 + labor. It was
covered under the 6/60 warranty I had from when new. Also
watch out for the rear brake light module, that was also
replaced. Fact is you either pay for new and depreciate or
you pay to repair and only you can tell which is less painful.
Randy
BTW, the brake system is what makes the 4 wheel ABS capable
of the small interventions that make Stability Control
possible. It helps if it works right.
wife has one and it is used mostly in the winter, hence not
much heat issues and at night for driving on trips when
having the Moon up is really great. It can be fun if you
learn to live with it at the times it adds some value, not
what they charge but some.
Randy
I had an after market exhaust on my '03 Z06 which barked pretty good but at crusiing speed there was a "drone" which was a bit annoying.
The stock exhaust on the coupes was just OK...too mild for me but an after market cat back exhaust is about $1,500+ and you may again end up with the "drone" at cruising so the $1,200 cost for the dual mode made it a no brainer for me. Certainly not worth the $$$ for only 6 horses but I wanted it for a more aggressive sound. The drawback here is that the valves open at about 3,500 rpm and unless you are tracking the car, one would not get to hear the open valve sound very often.
Now, all one has to do to keep the valves open at all times is to pull the fuse for the dual mode (it's a stand alone fuse). Sweet music but the dreaded drone at cruising could wear on you.
SOLUTION--and this is awesome. There is a vendor who sells a "MILD TO WILD" unit which is ultra slick. $100 gets you the unit. It plugs into the dual mode fuse (a 2 minute install) and comes with a FOB so with a push of a button you can either leave them in the stock position or open the valves at anytime. It's a small FOB so I did the velcro bit and put it right next to the start button so I can open/close the valves at any time. The best of both worlds to me.
Here's the deal...If you put the gear selector in "D", it shifts just like a regualar auto does...i.e., starts in 1st gear, up thru 6th.
Put the selector in "S" WITHOUT TOUCHING THE PADDLES and it operates like the regular auto with firmer shifts.
Activate the paddles and it will start out in 2nd but a flip of the paddles and you can put it in 1st.
More confusing than it needs to be but it becomes second nature after you have driven it a bit. A peek at the HUD shows what gear you are in. Easy to get used to.
I'm old, fat, blind, but still have my hair.
My wife and I have both been lately stopped for 7 or 8 over the limit, both were warned only, so we're not going to be pushing it much in the future.
On one of our local speed "traps" they have taken to using 5/6 patrol cars. One car is the lead radar "gunner". If you happen to see him and slow down (pretty hard and DUMB not to), one tends to speed up down the road- some distance later: which would be a mistake, as down the road the other patrol cars sit...waiting to either stop the car/s the lead gunner radio's or gun you separately as you... speed up.
One of those officers was either bored or had a hunch, (being in a "Corvette") came out of a dusty hiding spot and got behind as I was going 60 mph in a 65 mph zone. He almost rear ended me as he caught sight of some soccer mom in a Honda (or something) whizzing by. (presumably WAY over the speed limit) He popped on the lights and almost caused a further accident down the road, pulling this Honda over in a major transition turn off exit!! :confuse:
The mufflers are in the back but it's still pretty loud in the car but you are driving a Corvette, enjoy the growl!
It's the kids driving wrecklessly who don't deserve to drive faster cars.
I'll get off my soapbox now.
That being said, I do drive in the fast lane sometimes.
tom
Seems we can put a web site here but if this post gets removed, private me at gbjerke@aol.com
The Mild2Wild I have can be seen/purchased at www.nakidparts.com
Awesome service also. I was leaving for a golf trip up north on a Friday and it was now Wednesday. I wanted overnight delivery but there was no provision on the on line order form so emailed them. Within minutes, the response was they would do the overnight. Sure enough, Thursday a.m. came the Fed Ex truck. 2 minutes later it was installed.
It comes with 2 FOBs. One of my FOBs worked, but the other didn't. Another email and again, with 15 minutes I had a response. Likely a weak battery and he asked I check the brightness of the red light on the "bad" FOB. Did so and it was weak so just picked up another battery---problem solved. They even advised that they would send me another battery. Not necessary I told them but it gives you a hint af their service.
I did the velcro bit on the one FOB and stuck it right next to the start button. Never thought I'd ever need/want a second FOB but they come in handy when someone wants to hear the difference. Car sits idling and while back there a push of the button opens or closes the baffles. COOL!
As I probably mentioned earlier, the stock exhaust is pretty tame soundwise so a unit like this is perfect. Library quiet when you want and a great BARK when you feel like it.
Not getting caught?! PRICELESS!
Front or mid engine?
Vette : front engine, and refine, refine, refine.
New upscale exotic: Mid engine at a slightly higher price point - say $10-15k. A Ferrari kicker. Use as many Vette componments as possible. Needs a new name. Maybe share the name with a super sport sedan, see below. Something exotic, like Zastra.
Then move the Cadillac to this platform with a similar hike in price and go luxury sport. Now, you have a range of models.
Could even do a super sport sedan off of it. Same components. I like that thought. Isn't Porsche doing it? Emulate the very best in the world. M5 maybe? AMG?
Dunno, I don't have that problem. How did you happen to think of it? Seriously, it just popped into my mind as I was typing and I couldn't think of anything better. Suggestions?
Why not just call it "Corvette?"
What parts could they carry over from the Corvette to build this new exotic? Maybe the lug nuts...
You would probably surprised what could be used. Brakes, engine, radio instruments and much much more. That just scratches the surface.
Engine? Let's see - Ferrari 112hp/liter; Porsche 133hp/liter. Corvette 72hp/liter. :sick:
Didn't catch the word 'could', I take it. They 'could' make it anything they wanted to, including the engine with twin turbos. Are we in a pissing contest here?
I've been intrigued by the Corvette for a long time and I very much like the C6. I think it is the first true American alternative to some of the best sports cars in the world, and I'm looking forward to watching it "grow up" as the C7 and beyond come along. But the Corvette is a uniquely American sports car - possessing a driveline and suspension that, while terrific for what it is (the archetypical American sports car), is a relatively crude sledge hammer by European standards.
I just think GM is a "bang-for-the-buck" company with little financial (and management) leeway to build a car without compromise - which is what would be needed in order to play with Ferrari or Porsche on a level playing field. To build a true exotic, GM would have to start with a completely clean slate - a daunting and expensive proposition that would be a huge financial gamble that I don't believe GM management and stockholders would tolerate.
You know, there are many, many stories where the underdog had the fever and dedication to defy the odds and win. The old American spirit we seem to have lost. Drag racers like Sox and Martin. They showed the factory that they could win and got factory support and sponsorship. Then there was a guy named Carol Shelby with the Cobra and Mustangs. Ford supported him. The cars are now classics. And it seems that there was a group within Ford that came up with a lowly GT40, and probably on a budget too. Didn't they go to Europe and beat Ferrari? Maybe I'm not too out of line mentioning that name. Then there was a guy named Duntov that worked wonders with the Vette. Surely you have heard of him.
What I'm saying is that it can be done. Someone needs to have the dream and the passion - and support. Surely GM has the technology. The expertise is out there with guys like Shelby. Hell, hire Schumacher to evaluate the machine. He surely knows what a Ferrari is. The American automotive industry needs a shot in the arm and it will take something special to allow them to hold their head high again. I would like to see them go for it. Using components in production cars would ease the financial pain. Really, how much more does it cost to manufacture parts that are properly designed? With todays technology, machining and manufacturing to tight tolerances should be a snap. Out with the old and in with the new. And that goes for people too. If you can't adapt to today's world, hit the road.
Now, I have driven Japanese cars and bikes for over 20 years because I couldn't accept the junk being shoved out over here. Patriotism only goes so far. I work hard for my money and I will spend it on the product that is right for ME. When they wouldn't step up to the plate while poo pooing the Japanese, I left. Lately though, I like what I see from GM. A year ago, I took the leap and bought GM stock at $25. My gut told me to do it. Lately, it was around $47. I still can't get myself to buy the product though, but they're bringing me in closer and closer. The new CTS looks like a winner. Now if they could just do something about resale values................
It is far from a 'crude sledge hammer'.
What is the comparison with Ferrari? Or Porsche? This is a $50,000 comparison with what, $90,000 and $135,000?
Why would GM want to inflate their price and cut out probably 40% of their current buyers? Just my wild guess, but if you read on other forums, there are a lot of 'payment' buyers of Corvette. Buyers that would not be able to make the $100,000 plus market of the car you seem to want the Corvette to turn into.
I think GM knows exactly where the market for their car is, and what they need to do to place the car there. And, they have the Z06 for the really go-fast market. Like the base motor, with a top speed of 186mph isn't quite enough?
The current car has much more power than the average buyer needs, and probably can 'handle'. Turn the wheel slightly, jump on the gas, and the car will go sideways before the traction control can kick in. I have driven mine for 11 hours, and I am no longer very young, and I felt better than any other car we have ever owned. While cruising, which the car can do at 100mph+ if you don't value your license, it is very quiet (runflat tires road noise is the main thing you will hear), tracks great, looks stunning. If you open it up, the exhaust howls, all that I would ever want to hear.
The car is what it is. If this isn't what you want, find the car that is. And, probably dig much deeper into your pocket to get it.
I thought I had mentioned that too, but guess not. No, I have not driven the C6, but I understand it was a big leap forward. Bout time. I drove a Boxster, and was very impressed with the refinement and that wonderful mid-engined feel. A friend that owned a 99 Vette suggested that I not buy one because of lack of refinement. That may explain the sledge hammer comment. Comparrison tests I have read came away with the same conclusion. Lots of power no doubt. I hope the C6 minimizes that. The problem is similar to high end audio. Once you get used to the refinement - and it may not be obvious at first, the lack of same just jumps out at you when you go back to something less. Things can be very impressive IF you have not experienced better, generally speaking. It may or may not apply to the C6. I wouldn't know. Too much bulk for me. I do know a Boxster has been on my short list, and while not being a Ford guy, the 05 Mustang is the first of that breed that I could own, based on what I see. But, I have not driven one of them either. That could change my mind.
I have driven the C6, and as I have said before, I think it is a terrific sports car. I just don't think it possesses the chassis or driveline refinement/composure that a Porsche has. I think for starters, the next generation Corvette would benefit from a fully independent suspension and a smaller, more efficient (but just as powerful) V8 with multiple cams and variable valve timing.
The Corvette is what it is - an American icon that is not intended to steal sales away from Porsche or Ferrari. And I think the Corvette is exactly what it should be - don't make it mid-engined, don't build it out of carbon fiber, and don't jack the price up to $90,000+.
No, the original point of my musings was simply to state that I don't believe a smattering Corvette parts could be assembled to create an exotic American sports car that competes head-to-head with the imports.
That's basically what I think.
nothing more than spening more money, in many cases for far
less performance. I see comments about how great the Boxster
is and have read the articles in the mags about how it is
great on track. I then see that they were using an autocross
(slow speed) track. Take it to a road course, 2+
miles with some room to get into triple digit speeds and even
a stock C5 will be passing it with equal driver. After I had
spent about a year on track I've never been passed by a
Boxster, even with R compound tires and after market suspension
set-up. The Cayman is another story, very capable but again,
spend more and you usually get more. The 911 is great if you
can master it but again the base car is sometimes 50% more
than a base Vette, so why compare?
As for why compare performance on track, when I started going
to track events almost 5 years ago they were not that popular
unless people had a dedicated track car. Yesterday I went to
a track day at Thunderhill Raceway in Nor. Calif. and we had
over 100 Corvettes on track. Amazing! Lots of first timers
but also they filled the advanced and upper intermediate
groups a couple weeks before the event. That worked out as
an indicator of how many owners have taken the time to get
on track with instruction in the past. I've even seen some
all marque events that don't sell out so getting that many
Vettes on track for a day was fun. There is another all
Corvette weekend at Spring Mt. motorsports park in Pahrump, NV
in two weeks. Sponsored by the Corvette Museum.
If all you want is a touring car there are lots of choices,
some are more sporty than others, enjoy what you choose and
I will be having fun driving my C5 to Pahrump and then
having a capable track car as well.
Randy
less performance."
If by "less performance" you mean possessing linear and communicative steering, sublime suspension compliance, and a shifter that snicks into gear like hot butter on teflon, then I guess I agree with you.
less performance."
I fail to see why it has to be either-or. Having worked in design and development, drag raced bikes and cars, and own a 55 Chev with a 425 HP 396, I have seen both. I just don't see why something can't be designed to be refined and perform also. It's just a mindset, and it shouldn't cost much more to do it right in todays world of computer control, precise machining and robots, but the design must be right in the first place. Foreign manufactures seem to have figured it out. Any reason why we shouldn't measure up? I do think we have come a l o n g way though.
If all that refinement means that on the 12 turns at Sears
Point I gain .1 sec per turn for 1.2sec's and loose .5 sec
on each of the three long straights to a stock Vette that
came off the showroom floor in 2001 for $45k, I guess I
agree that the Vette will be leading at the end of the lap.
The wife's 2004, end of the run for the C5 came off at
$39k. That's a good reason to wait for the end of the C6,
IMO. Now what were they getting for the Boxster in 2001?
To those that want a street touring car, ok the Boxster is
probably fun on a canyon road, just like my old MG was fun.
More refined, sure, but never going to do much more. And
considering all the bicycles on canyon roads in CA, I'd be
very careful on that drive. I've done over 100 track days
in the last 4+ years on a stock engine coupe that now has
just over 72k miles and all it gets is oil changes and lots
of tires and new brake pads/fluid. Weight does have a cost.
As for the sophistication of OHC vs. push rods, do I really
care when I put down the right foot? And on road trips,
really going touring, the 24cu ft of storage is truly
amazing.
Randy
Canyon roads or less are where most of us will probably be driving. You seem to assume all of us live in CA. I ride and drive roads like them though, and seldom see a car. Deer - a BIG problem, an Amish buggy once in awhile, a flock of wild turkeys maybe. I'll occasionally run up to 130 with my VTX 1800, but can't get the same sensation with a car, so why bother? Same at the drag strip. A bike is more fun. Twisties? That's another story, but I think a smaller Boxster will give me a sweeter experience. But then, It's my buck, isn't it? I'll buy anything if the price is right. Could even be a Vette. I certainly have nothing against them. Just overkill for what I'll use it for at this point in time. And, I have always felt that if I was brand loyal, no matter what, I was cheating myself of different experiences. When I try new things I learn.
Boxsters start in the lower $40k range. They are NOT equivalent cars. It's apples and oranges. Take your pick, you're paying for it. Yes, they're both sports cars, but that's about it.
Obviously, you enjoy fast laps and gobs of torque - the Corvette is the perfect street/track weapon for you. I happen to enjoy a different kind of car - a lightweight, 4 cylinder that can barely hang with a V6 Honda Accord in a straight line, but on a road course, would give your Corvette fits. It's playful and easy to drive in all conditions, forgiving in nature, super responsive and communicative, and simply a blast to drive.
The point is, both the rapier and the broadsword are very capable and can be a lot of fun. Both have a loyal following and both are worthy competitors. You favor one and I favor the other - and neither of us is right or wrong.
The difference between us is that, while I respect and admire the "broadsword" for what it is and acknowledge it's strengths, you dismiss the rapier as weak, inferior, and overpriced. Why don't you just admit that the two are equal, yet different in their approach? Apples and oranges as '55396' accurately pointed out.
