Corvettes and all things about them
13334353638
  • cruisinloucruisinlou Member Posts: 27
    Since we are talking about the new Camaro VS the new Mustang, I feel that the Camaro is a better car because it does share the engines of the Corvette and other mechanical parts and also gives you a back seat.
    Oh did you mean Cadillac XLR? I don't consider that a sports car myself.
    The Viper, definitely, and a brute, too.
    Really, if we are talking about a refined, comfortable and yet true and serious sports car that you can track, Corvette is the only American one we have.
  • starrow68starrow68 Member Posts: 1,142
    edited March 2010
    " ... serious sports car that you can track, Corvette is the only American one we have. "
    Ah, don't tell that to the Viper folks that spend time on track, very fast but tough
    to drive. The benefit of the C5 coupe is that while having adequate HP it is fairly
    easy to drive on track. Even at places like Sears Point (Infineon) that are much
    more of a challenge technically and closed in with more concrete than most road courses.
    Even the C5 Z and C6 coupe are pretty tame with their extra HP. I don't even want
    to discuss the C6Z which can get out of shape very easily, did just enough right
    seat time to want to stay away from those who are new to the track. But at about
    3400+lbs with driver, all of them are hard pressed to stay with a full race prep Miata
    on race tires on a tight track. Somebody once praised lightness, spending time
    in anything over about 2000lbs and you begin to define sports cars as those that
    get close to that figure. The recent gen's of Corvette are lots of fun and great
    touring cars. Too bad the more recent American offerings didn't show more
    performance.
    Randy
    edited March 2010
    True enough....and I did warn the Viper owners by using the words "refined" and "comfortable", which not even the most diehard Viper owner would pin to their cars.
    Sears is a very technical track indeed. I still like Laguna, even after they changed it. I got pretty good (for me, I mean) on the corkscrew, in an open wheel car. With a Corvette, I dunno, I wouldn't be so frisky on that part of the track.
    Actually in the C5 the corkscrew is a hoot! Get the entry (blind) right and pick up
    the visual cue at the bottom, one of the Oaks, and you can dump it over under
    some throttle and power out carrying much more speed than T9 will allow. If you
    look at a data system log you can see that it is much straighter than you might
    even consider from late apex on the left berm to having your right side come down
    just over on the right berm and you start to turn right after car gets on full pavement
    again. It took several years to get it right, but it is almost as much fun as the
    carousel at Sears Point.
    Turns out that at LS turn 4 seems to be the nemesis for Vettes, another one
    bought the inside wall there last week and I know of several others who have
    left an impact on both the inside and outside wall. Late apex solves that but
    some get wound up in the moment and lifting at any point is not advised.
    Randy
    Yep, lifting on a car like that is usually a very bad idea.
    edited March 2010
    During the 1990s, I got to drive the track for half a day in a formula-ford limited to 75 mph. I would enter the corkscrew at maybe 15 mph and would still be terrified every time at that speed.
    Also on many weekends I attended races at Laguna Seca and liked to watch cars exiting the corkscrew and into the next turn where there were many small bumps.
    One thing that impressed me was how much more composed the BMW 5-series cars were on that part of the track, compared to all the Corvettes. The Corvettes skipped and skittered all over that section of track, losing traction, losing speed. The BMW M5s displayed none of that behavior - total composure - totally stuck to the road - blatantly faster than the vettes through that section of track on every lap.
  • higgy62higgy62 Member Posts: 5
    Could there be such a thing that I had the vehicle running when I filled it with fuel? (I know your not supposed to do that). If it ran it's test with it being fueled then there would be no pressure on the system. Just "what if ing".
  • Yes, I understand that refueling with the engine running could cause a gas-cap "evap leak" code.
    You posted the same problem in two different topic areas.
    And, yes, if you fuel while running it definitely will set the check engine light.
    The 'run its test' is when Onstar contacts the car and uploads certain info from the 'computer'. It does this one time a month. If you do not have Onstar active it will not do this upload. Having the cap off will not set a code during the upload (unless the engine is running), it only uploads codes previously set.
  • ernied2ernied2 Member Posts: 1
    I have a 1967 Corvette Coupe that the tank sticker identifies as coming from dealer number 715. Does anyone have any idea how to find out where that dealership is?
    You'd have to know the ZONE as well. There would be more than one dealer # 715 around the country.
    ABOUT ZONES AND DEALER CODES
  • ggreen3ggreen3 Member Posts: 2
    I have a 1989 corvette that has a removable top. It appears to be made of some type of acrylic material with a metal frame. My problem is that the acrylic is coming loose from the frame... What type of adhesive can I use to stick it back together?? Any help would be appreciated!!
    ggreen3
  • iaff2879iaff2879 Member Posts: 1
    My wife just got a 75 Stingray from her father. He bought if from the original owner and has had it garage kept for quite some time. I'm looking to get a no bs appraisal on the car to properly insure it. We live in the panhandle of Florida and need to know the best way to go about this.
    The vehicle has all original components, to include the engine, which was rebuilt with all original components still on it, and transmission. Definitely needs some more TLC to get it back to show condition, but we're working on it.
    So any help would be greatly appreciated.
    edited May 2010
    You might cruise the "Services Offered" section of Hemmings Motor News (www.hemmings.com). Be sure to check the appraiser's credentials and be sure he is an independent appraiser and not a dealer. Insurance companies don't like dealers doing appraisals, because they tend in inflate values.
    Also, keep in mind that any legit appraisal is based on what the car is at the time of the appraisal. You can't put future plans into the car's value. So you may want to hold off until you get the car to some decent point, or, you might do an initial appraisal for a lower value and then revise the appraisal (a simple update) later on.
    If the car is currently a bit shabby, it's not going to have a lot of value, so if you have it appraised while it still has lots of needs, don't be disappointed at the low numbers that come up. Once you spiff the car up, it'll look better on paper. The 75s are not the hottest Corvette in terms of collectibility but these can be nice drivers once you get them squared away.
    In general I agree with Mr Shiftright. (Almost always always agree with his views.)
    But I will be somewhat more 'pointed/direct'.
    Just go to your insurance agent and have this car insured. If it's a 75 in need of some 'TLC', I personally would not seek out 'speciality' insurance. Maybe after a total rebuild, probably including new interior and paint, would increase the value to where it might need more coverage than your regular insurance would cover.
    A 75 isn't terribly collectable. They were low powered, smogged down autos. I've owned a 72 and and 81. By 81 they were still slow (85mph speedometer), but a very well handling car - it had larger tires and sit closer to the road than the 70's.
    I am of the opinion to 'keep it stock'. You might consider this when applying the TLC. Keep the colors stock. Buy parts from Corvette catalogue people that furnish reproduction parts that would be close to original. I think this makes the car worth more than if you re-painted it your 'favorite color' and had the local auto upholstery shop put new seat covers and carpet in it. Use repro covers and carpets that are exact to what the original ones were.
    Otherwise, if the car runs well and seem reliable, just drive it and enjoy it in the meantime, as you correct the needed items.
  • jkmz06jkmz06 Member Posts: 2
    I bought a new Victory Red 09Z06 a year ago and use it as a daily driver. It is garaged at home at at work. The right rear fender was damaged last week with a 1/2" hole and 12" tear right above the wheel well. I plan to keep the car as a classic but don't know which type of repair is the best for the value of the car as a collector. Should I have the panel repaired or should I have it replaced?
    Here again, don't worry about things like this. Just get the car fixed as professionally as possible. If the job is done right, there will be no decrease in value. As for collectibility, your car is far too new for that and it will behave, price-wise, as an ordinary used car for at least the next 15 years--that is, the older it is, the less it will be worth. This is how Z06s have been in the marketplace. They are not appreciating in value. At best, they depreciate less than base Vettes. Even ZR1s behave this way.
    True "collector" cars generally become *more* valuable as they age.
    So really you are thinking about things that might not even concern you in 15+ years. You have a swell car, so drive it and enjoy it.
    Thanks for your insight.
    Also, the fenders on current Corvettes basically 'screw off'. You said rear fender, right? Open the hatch and look at the screws around the edge - these, with some other screws and fasteners will remove the fender.
    I would have a complete new fender put on. Getting a color match would then be your big problem. They might want to 'fade in' the door, etc to make a match. I don't know about wanting this. I would request they paint and if needed, repaint, the complete fender until they get a match for the rest of the car.
  • bust_itbust_it Member Posts: 26
    Can someone please re-post the settings for long distance driving ! Factory settings are too aggressive and wear the inside edges of the front tires ! PLEASE !
    I presume you are talking about front camber settings. While I have a C5 and not
    a C6 I can't see that will make much difference. The factory setting for the C5 is
    up to -.70, negative camber will wear the inside of the tire. That said, I run -.90 and
    don't have any issues with excess inside wear and the car handles much better
    going around turns with that setting. Backing off to -.4 or -.5 will help you some
    but going to zero will cause outside wear, I would think. I never bothered to look
    at the other end of the range.
    Randy
    Can you put the same tires on a c6 thats on a 07 zo6 ?
    edited November 2010
    Not sure but I think it is like the C5, the Z06 wheels are wider than the stock ones.
    So on a C5 that is 8.5" front and 9.5" back on the stock model and 9.5" front and
    10.5" back on the Z06. According to Tire Rack, 245/285 on the base C6 Vette and
    275/325 on the Z06, same size wheel diameter so like the C5, the Z06 wheels
    and tires are likely to fit the coupe or vert but the Z06 tires are not likely to fit the
    base model wheels.
  • porchrdporchrd Member Posts: 1
    I am now 69 years young and have always loved and driven high performance or modified them to be that way vehicles. I have previously owned 7 CORVETTES 19651/2 thru 1990 and now that I have gotten my 1st C-5 2004 Z-06 I can honestly tell all of you vette owners it is BY FAR the best vette ever that I have ever owned. It is probably 98.9 % faster than all of todays vehicle. You can say that I am bragging well you are right for I have been there and done that and more than once too!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    My car will run 11's all day long
    0-60 under 4secs
    Top Speed you will want to change your underwear
    Best body style ever period. Why on earth did G.M. stop making this coupe with a real trunk lid???? I will never know. I hope in the near future to install a complete ZR-1 drive train
    in my car unless G.M. brings the coupe body back.
    My millenium yellow vette really stands out from all of them, even from the new Z-O6's I know that I have driven over a million miles in WRAP YOUR [non-permissible content removed] WITH FIBERGLASS ha ha ha
    Question to you guys and gals:
    1. Is there a Z-O6 Vette yearly gathering??? and if so when & where???
    2. When & where is the NCCC meet this year???
    3. Is CORVETTE QUARTERLY history or will it go into print again???
    Hope to hear from any and all of you wether your feedback be positive or negative.
    Thiis is what I love about being an american and living in the USA we have FREEDOM OF SPEECH & PRESS
    Glad you like the new Vette, they are amazing. Just a suggestion, instead
    of spending a bunch on more power, like you said, you have plenty now,
    try going to a few driving events at your nearest road course. I spent years
    on Sears Point (Infineon) and Laguna Seca, in addition to a few others, it
    made a great difference in my enjoyment of a performance car. As most
    see it, it's the most fun you can have. At Sears, doing over 100mph, four
    times each lap and getting the most out of your ride is work and tons of fun.
    After several years I got to be an insturctor and even got some lap time for
    free. Check it out. Search on Corvette Forum and I'm betting you will find
    a couple places with more info.
  • One thing about Corvettes some people are interested in is how much better they are than Camaros. (or are not!)
    So for example, please advise a hypothetical person cross-shopping a 2012 Camaro ZL1 and Base corvette - the prices are apparently within $2k.
    I understand 2012 Camaro ZL1 will include magna-ride & HUD, two great options that hypothetical person might consider.
  • sportscarfan1sportscarfan1 Member Posts: 7
    This is a little off topic, but is anyone else totally hyped to see the Corvette Racing C6 ZR1s at Le Mans this weekend? I've been following these guys in the American Le Mans Series, they're just the sexiest cars on the planet. :)
  • fedlawmanfedlawman Member Posts: 3,118
    "One thing about Corvettes some people are interested in is how much better they are than Camaros. (or are not!)
    So for example, please advise a hypothetical person cross-shopping a 2012 Camaro ZL1 and Base corvette - the prices are apparently within $2k."
    Yes, but what about all-wheel-drive, 22" wheels, rear-seat DVD, and a two-speed transfer case with neutral position for dinghy towing?
    The Avalanche is the vehicle to be cross-shopping!
    edited June 2011
    If you want a Pony car, drive a Camaro, if you want performance get the Vette.
    The Vette is so much lighter it just is a better package altogether.
    As for LeMans, fantastic result, really had me worried at 7 hrs to go!
    Totally. I don't have a Vette myself but I'd love to get one at first chance. Brilliant cars.
    I loved Le Mans! So close, tough break for the Corvette that crashed out. Now I'm hoping these guys can get back on top of the ALMS points at Lime Rock early July....
    Article: http://www.americanlemans.com/primary1.php?cat=news|15850
    Talk about ugly result at LR, getting collected in somebody else's incident is
    never nice. Maybe Mosport will go better.
  • c2c35c2c35 Member Posts: 37
    My car is Black on black it came w/the 40Th anniversary logo on the seats the vette symbols doesn't have the Mobil 1 tag it has the bowling green tag inside the hood, LT 1 tag on the rear rite bumper, even inside i have the spec plate on the cup holder cover and the space between the seats came w/ the anniversary logo. do i have the bragging rights for the anniversary edition? I haven't seen any others w/the options i have. just kinda interested that's all. I know it came from the factory like that but, i wish i had the original sticker to see what option package she is.
    Thanks c2c35
    Probably not. All Vettes with *leather* seats had the 40th anniversary logo.
  • ChasboyChasboy Member Posts: 186
    Hi, I'm new to this forum and am not yet a Corvette owner. I've wanted a sports car since I started driving almost 50 years ago. I've seen a lot of vehicles over this time, and even tho' a split window is one of my favorites, it's cost is way to high for me. I was wondering if there were any years/models to avoid, engines to be wary of, as well as years that might be a good buy. I'm not particular, my basic desires are a coupe(I have concern about T-tops), manual tranny and I MUST have a/c. Don't want a project, but a nice driver...and wouldn't mind an 'upper' level engine instead of base.
    Thank you all!
    ChasG
    edited July 2011
    Okay, I'll give you my two cents, and I'm sure others will have interesting opinions about this!
    Well the later C3s which were crippled by emissions controls and low HP are good buys, like from 1975--1980 or so. I'd stay away from any Vette with the "cross-fire" injection (I think that's '82 & 84--from the last C3 to the first C4). I'd plan on modifying those mid 70s C3s though, because they are kinda doggy in stock form.
    Many folks don't like the looks of the C3s also.
    A mid-80s C4 is a helluva good buy, and if you can stand the hard ride, a lot of bang for the buck indeed. I'd stay away from that 4-3 transmission they made, though.
    90s Vettes are good buys but interior build quality isn't the best and they made so many of them, that there is virtually no investment potential for a C5 or C6 unless you pick out some very rare models.
  • bhill2bhill2 Member Posts: 2,649
    You didn't mention what your budget was or whether you were buying it as a driver or as an investment. Therefore, I will provide input based on my personal experience with a 2003 (C5) manual. It looks like I am approximately your age, no more than 5 years or so younger. These C5s look to be selling in the low to mid 20s for a car with average mileage.
    I have enjoyed this car immensely. I have had no engine or transmission problems, but that is just one data point. The reliability of these cars has not been a strong point, but I believe that is mostly due to more minor problems. The car is very powerful (of course this is subjective), and I seldom to never need to actually spur it hard. I do anyway on occasion, but don't need to. The engine is a torque monster, so under most circumstances downshifting is optional and you use the transmission to choose your final drive ratio. It is worth noting that in high (6th) gear the engine is turning about 1300 RPM at freeway speed and the car is returning at or close to 30 MPG. The transmission itself takes firm inputs, but the gates are definite and easy to find. As far as the AC goes, it is standard, and it only takes a few minutes for it to qualify the car as a small refrigerated truck. I literally think that they used the same AC unit that they put in the Tahoe.
    One final thing to keep in mind with any Corvette is that it is very low. I am blessed with good joints and balance, and I need them.
    Good luck in finding your perfect ride. I love mine.
    Thanks so far! I'm thinking, from what I've seen online, I would like my budget to top out at 15k. I'm looking for a driver, not an investment.
    I've always wanted a muscle car, and once had a 69 Malibu, but I don't want any type of sedan. I have always wanted the sound of a muscular American V-8. I'm also looking at other sports cars. I want to get as much bang for my buck, and I don't want to spend every waking hour fixing(as opposed to tinkering/modifying).
    My favorite all time car is an XKE, having driven one in college (in 1967 or so). I always wanted a 911, and have yet to drive one, but even used, they seem to be pricey, especially for what you get. I have found that the 928, another favorite, seems to be a good buy for the buck, tho' I worry about the complexity and cost of parts. I guess I just want something out of the mainstream, and almost any true sports car is. I've also looked at some 'special interest' cars like the MGBGT, Healey 3000 and Triumph GT6. I don't like convertibles, and all I've ever heard about T-Tops is that they leak and squeak, 2 no-no's for any car I have ever owned.
    Oh, and I'm pretty limber :P
    Oh, no, you don't want a Porsche 928. Don't go there, no matter HOW cheap.
    An MGB-GT would be a nice choice---simple to fix, fun to drive, comfy inside and the aftermarket parts network is extensive---also well under $15K, by a long shot, and the best of the Brits, IMO.
    911s are good cars but in your price range you'll be limited to somewhat older ones---from the 80s--
    In terms of bang for the buck, you still can't beat a Vette, and $15K can buy you a lot of pretty decent C4s and C5s.
    Thanks Mr.Shiftright. Can you tell me more about the 928? Don't go crazy, because I think my trepidation leads me to $$$$$$$ repairs/maintenance right from the gitgo.
    The only Corvette I ever drove was an 84. I liked it, but I remember it riding hard. Did the C4 improve over time? Is getting a late C4 a good 'goal'? Also, I do like the c5's. What would be a 'better' buy, a low mileage C4 or a higher miles c5(I figure miles would lower the price).
    Is the C3 a 'different animal" than the C4&5?
    Well I'm not a Corvette expert but I have driven the various models. For "bang for the buck" you can't beat a C4 since this would cost you 1/2 of a C5...but the C5 is certainly a more advanced and more competent car and still under your $15K budget. The later C4s didn't ride as hard. I guess it depends on what taste you have in looks and how fast you want to go!
    On the C3s, as time went on they got worse and worse, unlike all the other Corvette generations which got better and better.
    I have no personal experience with the C4s, but I know they were considered pretty good in their time. I did a little research on them and found the following major changes during their years of production:
    1) In 1989 the dreaded 4+3 transmission was replaced with a true 6-speed.
    2) In 1992 the engine was bumped from 245 to 300 hp.
    There were, of course, other changes over the years but those are the ones I would consider deal changers, especially the first one since I have heard nothing good about that 4+3 transmission (which involved having a separate overdrive that operated on gears 2 through 4, usually at the wrong time.)
    The C5 debuted in 1997 and ran with only incremental improvements through 2004, so you may indeed find some good deals there. In any case, good hunting.
    Hope you decide to go with the C5 over the C4, I got my '02 and after trying to
    keep mileage low driving my prior daily driver, I just couldn't face the old car
    any longer. So to keep miles low I got a '95 with very low miles and drove it
    for 10k over the following year, too hard to get in and out of compared to the
    C5, too hard in the ride and it was stock suspension vs. the Z51 performance
    suspension on my C5. Just all around not up to the C5 in any way.
    As for the Vette coupe, it has a removable top, not T tops and I've never had
    any issues on the '02, 118k miles or on my wife's '04, only 40k miles. Hope
    you keep us posted if you find your solution.
    Thank you guys. I have decided to get a C5. I've driven a C6 and a C5 Z06 and I just want to drive a few more so I pick the right one.
  • highenderhighender Member Posts: 1,358
    hello...
    i just got my first corvette last year at age 48....
    love it. Monster car and best value for performance. Mine is a 2004 Z-06, with bored out 7.4 liter engine, new Fast intakes, twin turbos.....
    mild to wild ...wahoo !!!!!!
    :shades:
    Good Luck! I have a deposit on an '02 Z06...box stock. Can't wait to get it. :)
  • copiecopie Member Posts: 1
    mybe u can help me i am looking for a vette 03 to 04 which has the best engines with and auto i am looking at a vette right now and 03 with 90000 miles on it an auto convertible for 17.5 she said i had to get my own car fax and also said it was an one owner pls tell me what u think do not want to spend no more then 22500
    copie, that does not seem like a good deal at all. :mad: I wouldn't buy any car with that kind of miles. Decide what you want, a driver, garage queen or project. 90k spells project to me. :lemon: Have you searched on Ebay, Cars.com, autotrader and http://www.thevettenet.com/listing_by_category.php?category=C5 ?
    Join a local club. I am getting mine from a club member, which allows me to trust what I'm buying. I'm getting a 2002 Z06 six speed with 16k miles for a little more than your budget. It drives better than a brand new one.
    BE VERY CAREFUL. I responded to an ad that (I'm in NJ) that seemed to be in Long Island and it turned out to be in Iowa!!! She wanted me to buy the car unseen and then I could return it if I didn't like it!! Also watch out for Texas Direct Auto.
    USE THE INTERNET! its great for research. From what I have learned, you could get an 03-4 but it will have 50k miles which is reasonable. Go a bit older and you will be right in there. Converts are usually higher priced.
    The most powerful engine is the LS6 in the Z, with 405 hp. That started in 01 or 02.
    too much money. If very clean, it's worth $15,000 tops and miles are troubling. As wonderful cars as they are, Corvettes suffer on resale value once the clock turns 100K and often the interiors do not endure.
    I agree that is too much money.
    For $22,500 you should be able to get into 2005 year, with rather low miles. Maybe even 2006 with higher miles.
    2005's are good cars, they just have a couple 'first year' of a new design problems. The manuals will kill a battery, but there is a re-flash of the computer logic that supposed to fix it. On some motors, I think the early ones, the crank bolt did not hold. I believe this might even be a recall. If you could get to the 2006 year, the automatic is a 6-speed, verse a 4 speed previous. (Nothing really wrong with the A4.) By 2006 the new design problems are fixed.
    Keep saving your money for a while longer, and get to the 2008. There is a jump of 30hp, and changes to the steering 'fell' that is significant.
