Toyota 3/4 Ton with Big Block V-8
16791112
  • twowheelertwowheeler Member Posts: 89
    pick the Kia, since cars are only for transportation! It's late, and I gotta sleep. Goodnight.
  • hillhoundhillhound Member Posts: 537
    I copied this from another truck forum and I think it kind of sums things up in an unbiased sort of way:
    From a topic on comparing the Tundra with the Big3 half-tons........
    "They shouldn't be compared in the first place.
    Tundra was created to give an alternative to anyone, that dosen't use the truck so much for work, but rather for commuting to work.
    Pickup trucks are getting more fashionable than ever before, and Tundra is targeting the customers, whom are looking for something that has the handling of a passanger car, but could be also used like truck for ocasional trips to Home Depot.
    A typical Tundra owner couldn't care less, if his truck couldn't haul a heavy load from a construction site, because that isn't the purpose he got it for.
    A "big three" owner on the other hand would argue that truck is meant for work,and couldn't care less for Tundra's refined smoothness and handling capabilities."
    True words, in my opinion.
  • bamatundrabamatundra Member Posts: 1,583
    "I'm confused. This particular topic is about towing at 10,000' levels in the mountains. "
    Roger that one! LMFAO!
  • ndahi12ndahi12 Member Posts: 235
    on the Turd 5.4 vs. the tundra
    ------Turd 150-----Tundra
    0-60-----9.1---------8.0
    0-60
    w/1k lb--10.7--------8.27
    1/4------16.8--------16.2
    1/4
    w/1k lb--17.7--------16.7
    60-0-----140---------125
    60-0
    load-----140---------139
    Slalom---54.8 mph----56.8 mph
    Towing---7000 lbs----7100 lbs
    Tundra wins in every obejctive compsrison over the Turd 150 5.4 :-P
    I'm re-opening the topics that were shut down this morning and I'm going through them to remove any traces of the personal back and forth that's been going on.
    This discussion is about the Toyota 3/4 with Big Block V8, let's stick to that. Posts that are off-topic or violate the member agreement will be taken down.
    Back to the trucks!
    PF Flyer
  • fischdafischda Member Posts: 272
    I agree with catam - the Toy 4.7 should be compared with the Ford 5.4 and Chev 5.3, and here are two more reasons why:
    1) If I gave 3 truck buyers $30K and each chose different trucks, which engines would they get for the money? That's right - the 4.7, 5.4 and 5.3L. For the same price range you get more displacement w/Ford and GM
    2) Toyota knew what they were competing against with their 4.7L - right again, the 5.4 and 5.3, NOT the 4.6 and 4.8.
    So even though displacement differs, they are ALL still apples! That said, how do I rate the engines? Toy, GM and Ford in that order.
    The Toy emgine is fully capable of everything I need it to do (including towing), and it's by far the smoothest and most quiet. The mpg numbers are too close to even argue, although I think Toyota should find a way to get a few more miles from a tank.
    The GM engine is torquey and relatively smooth, not bad. The Ford has enough power and torque, but it absolutely roars, and just doesn't feel nearly as well mated to the drive components as Toyota.
    Now, if Toyota builds a 3/4 ton, I would assume it to be marketed as a work truck. They'd have to come up with a bigger engine (or tweak the 4.7L up to around 275-300 horse/340+ torque at low rpm.
  • lariat1lariat1 Member Posts: 461
    One of the big reasons the Ford, GM, and Dodge numbers lag behind the Tundra as far as performance is the rear end gear ratio. The Tundra (if memory serves me right) uses a 3.92:1 ratio, both Dodge and Ford use a 3.55:1 ration and I am not sure about the GM. I drove both the Ford and the Dodge with the 3.73 and 3.92 rear end respectively and those trucks were very snappy, I am sure they would cut a lot off the 1/4 mile times. Another thing to look at is the tire sizes. All of these things affect the final gear ratio and affect power to the ground.
    if (when) Toyota enters the 3/4 ton market, it will have the proper gearing. The new Lexus 4.7L V8 GX470 SUV, which is to be in showrooms next winter, has a new 5-speed automatic. I'm sure this tranny will spread to other Toyota trucks and SUVs in the not too distant future. Combine that with a proper final drive ratio, and the Toyota 3/4 ton will have great gearing.
    Bob
  • losangelesemtlosangelesemt Member Posts: 279
    I see your point about why the 4.7/5.3/5.4 engines are compared to each other as it currently stands. In regards to these statements :
    " 1) If I gave 3 truck buyers $30K and each chose different trucks, which engines would they get for the money? That's right - the 4.7, 5.4 and 5.3L. For the same price range you get more displacement w/Ford and GM
    2) Toyota knew what they were competing against with their 4.7L - right again, the 5.4 and 5.3, NOT the 4.6 and 4.8. "
    First off I agree that anyone looking for a truck from different manufacturers, would want to see their top of line models within reason. Yet I'm not here to dispute that. Is it Tundra's fault that Chev and Ford didn't put as much effort into the 4.6/4.8s ??? Very true that they geared the 4.7 with the 5.3/5.4 in sight, since 4.7 would be top of line.
    I'm talking about comparing the ENGINES not the options, top of line status, etc etc. If you came in here and said the Tundra 6.0 beat the pants off GMs 5.3 and Fords 5.4 I'd have the same argument, regardless of where each truck fell in the grand scheme of marketing (bottom/top of line)
    It's probably not fair to compare the 4.7 Tundra's options or other items that are geared for top of line, to the 4.6/4.8. Obviously because the 4.6/4.8 aren't top of line and aren't equipped to match a top of line Tundra or any other top of line for that matter. The engines however are chunks of metal, they have a specific displacement and design. Their performance has little if nothing to do with options, pricing, or anything else that would be affected by model status (top/bottom of line). An engine should be able to be compared to a similar engine period.
    I'm talking about looking at these engines as if I was a engineer/technician in a shop, for purpose of engine performance statistics. Not as if I was a buyer looking at which offers best options and so on for the money, because then you're right you can't compare the 4.6,4.8, with the 4.7 . Thats the difference.
    I actually tend to agree with that article. No way Toyota intended to blow the doors off the Big3 1/2 tons in toughness with introduction of the Tundra. Whether or not the statistics show otherwise, who knows. I did see a Tundra commercial the other day though which was set in a construction sight, eluding to fact that truck is tough and can be used as such. Yet not many guys, especially domestic owners, will not consider the Tundra a grunt, and I think thats pretty fair. It's a good truck for what it was designed to do. Pulling a 10,000lb. load at high elevation is NOT what the Tundra is for.
    In the latest truck trend i was reading someone wrote in asking what vehicle the new catepillar diesels will be going into. Truck trend stated possibly the tundra HD (hmmm name stealing?) or the new nissan trucks that are coming out
    Any truth to this "rumor"
  • saddaddysaddaddy Member Posts: 566
    Would be the most awesome thing I can think of. Now, I have never really defended the tundra with you guys or anything. But I can think of no better combination. My fingers will be crossed until I hear some more news. WOW! I even have a caterpillar tag on the front of my taco.
  • xyz71xyz71 Member Posts: 179
    What a waste of time. The 4.7 Toy - should it be matched against the GM (5.3L / 4.8) or Ford (5.4 / 4.6).
    It depends on what you want the truck to do.
    If your main concern is Max towing or performance compare the largest engine offered. DUH
    If you care more about MPG look at the most efficient engine offered. DUH
    The idea that just because Toyota only offeres a 4.7 we must compare the smaller GM and Ford V8 is totally wrong. Since when do companies play fair. The idea is to beat the competition. DUH
    If a company can offer a 10L engine that gets 25 MPG and is rated at 450HP and 400 Foot pounds would we say - gee the competition only has a 5L engine that gets 15 MPG 200 HP its not fair to compare the two. Only the weak are afraid to go up against the best the competition has to offer..
    Id say a cat engine would be nice
    I have a few pairs of catepillar shoes/boots and they are built like tanks.
    If the tables were turned and Toyota was using a half liter + bigger motor in comparison to Ford/GM , the Chev/Ford boys would be crying foul.
    "The idea that just because Toyota only offeres a 4.7 we must compare the smaller GM and Ford V8 is totally wrong. Since when do companies play fair. The idea is to beat the competition. DUH "
    That's the silliest thing I've heard all week. If a company has to cheat to win, then why would I want anything from them. Of course the object is to beat the competition, but thats what engineers, design, testing are for DUH. If a company isn't competent enough to win that battle in the production/manufacturing process, I suppose tilting the comparisons is all thats left.
    If you're gonna ramble off options and pricing and all the gimmick stuff then I agree, top of lines should fare against top of lines. Even still, you cant expect bigger things from a smaller product, no matter what it is. This isn't so hard of a concept here though. You take Toys 4.7, GMs 4.8 and Fords 4.6 and run some numbers from them. That means on a similar rear end, trans., etc. etc. . Will this ever get done if it hasn't, probably not.
    The point being that the word "compare" usually refers to similar items. So to all the geniuses here, what's similar about a 4.7L motor and 2 other that are at LEAST a half liter larger DUH ??? Does anyone realistically expect the smaller motor to out tow/haul the others, regardless of who has what motor ???
    The Tundra is NOT a grunt for huge loads. It wasn't designed to be. So to add insult to injury, theres a few knuckleheads who think its even fairer to compare unsimilar engines/stats. If the other 2 engines in question performed similarly to Toys. 4.7, it wouldn't be such a big deal would it. This isn't to say Toy would or wouldn't have the numbers advantage for eng. performance. Mod threw out a few figures, but I don't have any other numbers and thorough tests have probably never been done.
    Why it's important ... well it reallty isn't until you get someone in here who wants to point out that the 4.7 lost in such and such categories to the 5.3/5.4 .
    "GMs 4.6 and Fords 4.8"
    I think you have em backwards
    Sure enough thanks Ryan, or Babs as others say.
    Why?? Because even though the Toyota 4.7 outaccelerates the GM 4.8 the fact remains that a GM1500 with that "weak" 4.8 can still be factory equipped to have a tow rating of as much as 8300lbs (2001 GM Towing guide). That beats the Tundra's 4.7 rating by 1000lbs.
    So by playing fair and doing a comparison with the smaller GM V8 versus the largest offered Toy V8, the GM1500 still whups the Tundra in work performance. We don't even need to start talking again about how bad GM's larger V8 outclasses the iforce v8.
    So the Tundra with a 4.7 beats the Silverado 4.8 in a drag race. Big deal. If that's all that's important for you in a truck then the Tundra is a perfect choice. Just make sure you don't unknowingly drag race a 5.3L!! LOL!
    BTW-My personal preferences are that I don't race other vehicles or buy a truck based on it's speed. If you like your truck fast more power to you. No offense, but I just don't understand why since if speed is so important you can buy a nice fuel-efficient $20,000 mid range sports car that will blow the doors off of every every stock pickup save dedicated "fast" pickups like the lightning.
  • jaijayjaijay Member Posts: 162
    This discussion so far has been very entertaining and it appears that the belly-aching is all about vehicle options and engine sizes. If I head out to the edmunds site I can spec out the typical bare bones Silverado with a 4.8L engine.
    However if I do the same for the Toyota Tundra, and order a bare bones truck I get the 3.4 6 cylinder engine.
    Perhaps if the discussion is going to measure trucks on their base models, the comparison should be on the GM 4.8, Ford 4.6 and the Toyota 3.4 base engines.
    Yes, all this engine business IS BS. Like I said, it only matters to the individual who knows what he wants his truck to do. I give kudoz to Ford and GM for bigger engines that perform well in terms of power, torque and gas milage. Really, the most popular engines in the three trucks are prety damn close anyways. My choice then was based on which one felt the best and hooked up with the road the best.
    As for grunt work, if I needed to pick up a ton of landscaping rocks, I would choose Ford, because it's got the payload to do it. I'd have to take two trips in the Tundra. Actually, that's a trick question - I don't think 2,000 lbs. of rock will all fit in any of the pickup beds!!
    As for towing, how often to you people in this forum tow 7 or 8,000 lbs.? Come on now, a horse trailer, boat, camper, etc. only nets out to 3-5,000 lbs. maybe. Anybody really using a Tundra/F-150/1500 for a third wheel or cattle trailer?
    As for the CAT diesel in a Yota - tell me more about CAT, cause I thought they only made plants for loaders, shovels and earth movers.
    Your "cheat to win" remark is classic. Please explain how GM and Ford are cheating by offering a better choice of engines? With more HP and the same or better MPG? Like I said - only the weak are afraid to go up against the best.
    Picture this - Man goes into a Ford or Chevy dealer and says. I just got done testing a Tundra - performance is important to me, but gee it would not be fair to test a bigger V8. Do you have any trucks with small engines in them?
    I have not looked up the exact $$ - but I would bet the additional cost to upgrade engines from V6 to a V8 (5.3 Chevy, 5.4 Ford, 4.7 Toy) are all within a few hundred $.
    I hope the news about the Toyota 5.4L is true - lets keep raising the bar - it makes all trucks better. The Sequoia I test drove last year was a dog it needs a larger engine.
    is on its way. Then and only then will I take any 1/2 ton comparisons to heart. The 4.7 is great, but anyone who expects it to beat the larger 5.3/5.4s isn't being realistic.
  • kg11kg11 Member Posts: 530
    Is why a lot of us did'nt buy Tundras.Thers nothing wrong with the truck,it just dont offer what some ofg us want.If yopu're comparing truck to truck instead of comparable engines,it IS fair to compare 5.3/5.4/4/7
    kip
    Ya I agree whole heartedly. As a consumer, you're gonna want to see top of line in the class from every manufacturer. Its not GM/Ford/Dodge's fault that the Tundra is a smaller truck. It still should be compared as a 1/2 ton since thats what it's marketed as. Me personally though, when it comes to the numbers which are affected by having a smaller 4.7 engine, I take them with a grain of salt. Knowing that if a 5.4 was in same truck, the numbers may be significantly different.
  • plutoniousplutonious Member Posts: 799
    you all realize if and when Toyota offers a 5.4, it will outperform the Chevy 5.3 and Ford 5.4. Then, the Chevy/Ford boys will compare it to something bigger to make themselves feel good.
  • catamcatam Member Posts: 331
    You want to compare just engines, right.
    You stated, "I'm talking about looking at these engines as if I was a engineer/technician in a shop, for purpose of engine performance statistics. Not as if I was a buyer looking at which offers best options and so on for the money, because then you're right you can't compare the 4.6,4.8, with the 4.7 . Thats the difference."
    Well if I was an engineer, the first thing I would notice about the hypothetical engine comparo would be that you want to compare a 32 valve OHC engine to a 16 valve pushrod engine and a 16v ohc engine all of essentially the same displacement. My first thought would be, well duh of course the 32 valve engine is going to absolutely kill the 16v motors. Imagine my suprise when I found out the lowest tech pushrod v8 came through with the most HP 275 to 245. I would have retest figuring I did something wrong. Alas, in the end, I would have to shake my head and say for all the technology and money poured into that 4.7L it sure just doesn't deliver what it should. And worse yet, it sucks up more gas.
    In the end your hypothetical engine comparo is pointless and stupid. Nobody buys just the engine, they buy the whole truck, and compare the whole truck to other whole trucks. When people do that they buy the biggest and most powerful engine available in overwhelming numbers.
    Lets compare those apples.
    Man you must have a crystal ball or something being able to tell us about the performance figures of a truck that doesn't exist.
    Can you tell me what stocks to buy too, cause you must be the richest man in the world being able to predict the future and all.
    When Toy introduces the 5.4 ,it'll be as big as any 1/2 ton engine.GM and ford don't have a bigger engine in thier 1/2 tons.That should capture more market share but they still need more brakes,suspension and cab space.Then I guess it'll be "the big 4"
    kip
    The only thing pointless, is pointing out how a half liter + larger engine is able to tow/haul larger loads. I've stated once and will again to make this clear. The Tundra should be compared to all the other 1/2 tons when it comes to purchasing. If Toyota is going to market it as a 1/2 ton then it shall live with the others.
    Lets try this again, ME PERSONALLY, I will take the certain comparison results which may be affected by having a smaller 4.7 engine with a grain of salt. I worked in an engine shop and when we tested engines, we used different engine makes of similar displacement, and ran them through a standard/universal drivetrain mock-up. This was done to establish ratings for the engine with no variables in the further drivetrain. Of course the different engine designs played a role in ultimate HP/torque, but certainly not as biased as running a 4cyl. vs a V8.
    My point all along is you cant expect a 4.7 to be put in the very same Ford 5.4/GM 5.3 trucks and get the same test results. If it comes close then great, but it can't be expected. Regardless of whether or not anyone agrees with this, it is still my opinion, and makes mechanical sense.
    Very true that in addition to different engine displacements, the valvetrain designs and so on will affect performance. Nobody told GM/Ford that they couldn't use DOHC or 4 valve technology. If everyone used the same setup, then a 5L GM engine would be almost exact same as Ford, Dodge, Toyota, and so on. The design of the engine is what sets different engines apart. However, there is no question that a 2L 4 cyl. is not going to overpower a 6L V8. Maybe you think otherwise, but to me its a matter of physics.
    It's not all that hard of an idea here. Should the 5.4 hit ground soon, we will compare the 1/2 tons. Since you guys are all so confident with the 5.3/5.4s, they should blow the doors right off Toys. future 5.4L. No reason for Toy to even show up really, it will always be inferior to the domestics in toughness wont it ???
    You can be sure that GM will offer their 6.0L in the comparable truck.
    Then we can have this same arguement all over again. You can whine because it is not "fair", and Chevy can smile because it offers better performance and gas mileage.
    Looking for an opinion from Toyota OWNERS here since the domestics have already shared their thoughts. Any of you guys feel its reasonable to expect the lighter weight, lower powered 4.7 Tundra to match up number wise with Fords 5.4/GMs 5.3 ??? Looking for a neutral honest answer here.
    But you guys are saying the 1/2 ton Tundra really isn't a 1/2 ton. So maybe then the proposed 5.4 would fit the bill as a 1/2 ton right ??? So then why would it have to be compared to a larger 6L Chevy or so, when the 5.3 would be perfect for it. Even if the truck does come out as a 3/4 ton, I doubt many of guys in here would consider it one and I can't say I disagree. It's been said many times before, just because they claim its a 1/2 ton 3/4 ton, might not always be the case to some peoples definition of 1/2, 3/4 ton etc.
    to match numbers with the big 3.They built a dependable ,comfortable vehicle to meet most peoples light truck needs.When Toyota enters the full size workhorse market,and they are clearly headed in that direction,there's no reason to think it won't be as good as the rest of thier product line.
    kip
    I think the Tundra is a 1/2 ton truck.
    It is just that its workload capacities are more limited than anything from the big three.
    The point I have been trying to make in a roundabout way is that some people posting here keep trying to profess that the will outtow, out haul, outwork, etc. anything from the big three. It is simply not true.
    I think the Tundra is a great truck, and it would actually work very well for me as I don't need a lot of working capacity. However, the things that keep me from owning one are, 1) back seat is too small for my 3 kids (same problem with the Ford, unless I looked at the supercrew), 2) No manual tranny available with a V8, Chevy offered a manual with the 4.8L in 99.
    Toyota does make a good truck, so do GM and Ford. I just get tired of hearing that the Tundra can do everything a truck can do better than everyone else. It can't, it does some things better, and some worse. In the end personal needs should decide.
  • quadrunner500quadrunner500 Member Posts: 2,721
    I know you must think domestic guys like me would change our minds, IF ONLY we would just try one. (For my part, I've driven several). And that we would instantly recognize the 32 valve OHC benefit. (I do).
    But the 32 valve OHC (along with drum brakes) is exactly one of the reasons I DON'T want a Tundra. I'm intimately aware of the benefits from years of riding (and wrenching) on Japanese multi cylinder crotch rockets.
    To set the valve lash on Tundra, you don't have threaded adjusters, but shims under buckets that have to be changed out. Doing so requires camshaft removal. Put another way...99% of owners will put off or omit doing this hassle. It's going to have an adverse affect on longevity of the top end, and result in well stocked grave yards of Tundra parts in a few years.
    Toyota doesn't do this to make a better truck engine. Truck owners want simple reliability, not unnecessary complexity that has no long term benefit. We all know that 4 valves per cylinder breaths better at all rpms. Ford has been making 32 valve OHC V8 engines, but isn't putting them in trucks. Why? Toyota does because that's their small engine know-how. They don't build them any other way. But it's not the best for a truck, when it's simpler and more reliable to get the same result with a few more cubic inches, and a few less valves, hydraulic lifters and no maintenance.
    There's never been any difficulty in achieving high horsepower from simple pushrod designs. Combining high hp and small displacement is another matter. The fact that so many high performance engines use 4 valves per cylinder and OHCs in racing is because of size, packaging, aerodynamic, rules-making concerns. Top fuelers don't need them. Neither do Nascar stock cars and trucks, which probably account for more miles of engine longevity than most other forms of motor sports.
    For me...I just don't want to adjust any more valves than I already do now, whether be motorcycles, ATVs or generators. I'm just trying to keep everything running, not make a career in small engine repair. It's one thing to have a bike put up on a stand for the winter, awaiting parts, putting in pistons, stroker kits etc, and to adjust the valves when putting short lived motors back together. I don't want the same thing for my truck, which I may need for picking up those very parts.
    I would guess Toyota would put this new engine in the Landcruiser and LX 470 (make that LX 540!) before it will make it to the Tundra. By then Dodge will have the 5.7 Hemi and I am sure Ford and GM will do their best to keep up (ahead of) each other. Lets all hope that 350 HP / 350 foot pounds with 18-20 MPG are the norm in 2004. I will be shopping for a new truck in 2005 and look forward to test driving each truck.
    I hope that EPA (or whoever) doesn't get in the act and we all end up with 150 HP 6 bangers in our HD trucks!
    Boy I couldn't agree with you guys anymore. Many of my thoughts exactly. Cat, the lack of rear room along with questionable workload capacities are definitely big reasons why I don't recommend this truck to guys who need a serious work truck or for hauling the family around in COMFORTABLY.
    Quad, I think you share a similar feeling that I do here. It's fun to work on engines,bikes, etc. as long as they're secondary projects !!! I personally don't enjoy performing engine/drivetrain overhauls on the truck that I need on a daily basis. The whole hobby of working on cars suddenly finds a way NOT to be fun at that point lol.
    Also, no way would I want to try to persuade a domestic owner to go foreign or even vice versa. It's been said in here many times ... certain trucks work better for certain people. I personally believe the current Tundra to be a good truck for people who 1) don't have to haul family around, 2) need a light work truck / Home Depot etc., 3) for those of us that wouldn't be hauling a 10,000 lb. trailer or carrying 40 bags of concrete.
    In Toyota over the years, I've come accustomed to smoothness, reliability, and a overall good quality. Many others share this experience. I'm hoping they can incorporate these things into a true work truck one day and bring their best game to the table.
    I also have a hard time believing that the Tundra out hauls/tows the other 1/2 tons. Reason being that first off the Tundra still isn't viewed as a grunt by many. More so though, the trucks it's compared to are significantly larger to start with, so Tundra is already at a struggle to even MATCH the figures of the Big3. The suspension/brakes etc. are still questionable to some. I believe a possible 5.4 will be more on the level of true 1/2 tons. The current 4.7 is a fine motor I'm sure and I leave comments up to those who own.
    I happen to like Chev/Ford trucks as well. Not a big Dodge fan but never have been. To the guys that are happy with their GMs/F-series, more power to them. I don't think they quite yet boast as much reliability as the imports, but certainly highly regarded as Americans' choice for work trucks.
    I suggest you read the service manual for your I-force V8.Quad accurately described the process.
    kip
  • urkillingmeurkillingme Member Posts: 22
    needs shims to adjust the valves in addition to periodic timing belt replacement. Both expensive dealer procedures.
    In this day of modern, low maintenance engines the Tundra is much more expensive to maintain during its first 100,000 miles.
    Interesting that if a particular motor is quicker, it's bad because the powerband is too high(chevy) but when the motor that makes the most torque at the lowest RPM (Ford) is not as quick as the Tundra, that's also bad.
    I sure hope that EMT is more representative of the Toyota owners here than the other fellow that doesn't know his Toyota motor requires valve adjustments.
    Interesting points about HP/torque at RPMs. Just to set record straight, I dont own a Tundra yet. Actually was on way down to sign the paper work, and got a call from the ambulance company I worked at telling me that I didn't have a job anymore. I refused to go along with their crooked operation, as I was used to a very professional para-military setting after 8 years with the fire dept.. At any rate, I believe the company viewed me as a threat, and now the matter is in the hands of the good ole Teamsters.
    I certainly like the truck and for me not having a family or hauling huge things it will work just fine. I might just have to wait until the 2003s come out, we'll see. I'm a truck lover of all types. Roomate has a 96 Rado out front and I think the truck looks sharp, very capable of performing work. It's important to keep an open mind about all trucks ya know. Each offers something unique.
    Hey to Toyota's credit, I think the 4.7 hangs in there. I don't have all the 1/2 ton figures on hand, but from what I remember, the Tundra stays within shouting distance of the others. The other 1/2 tons are a bit larger in many ways, so it only makes sense to me that the Tundra might not be as capable in certain aspects (loads/hauling, torque/HP).
    I haven't been able to tear a 4.7 apart yet but I like the design for most part. Over the years I've always been impressed with the interior of Toy engines. Very clean looking after high mileage, parts usually quite smooth which is a good reason why the engines are quiet and smooth running. I'm not expecting the 4.7 to out-perform the other 1/2 tons, but given its good design I feel it's certainly possible.
    "In this day of modern, low maintenance engines the Tundra is much more expensive to maintain during its first 100,000 miles."
    Even Edmunds said the Sierra was the most problematic long-term vehicle they ever tested and predicted the owner would be "taken to the cleaners" once the warranty ran out. Predicted long-term reliability and related ownership cost is most definitely in the Toyota's favor.
    The 99 silvderado that I owned was in for warranty repair only once in the 28,000 miles I owned it. That was to replace the right rear window that was misaligned and allowing road noise in.
    Hardly a maintenance headache.
    BTW, no engine knock either.
    Perhaps, Edmunds had one of the few lemons, not necessarily a typical example. It was only one vehicle out of several hundred thousand. Kind of hard to make a sweeping generalization based on that.
    "Interesting that if a particular motor is quicker, it's bad because the powerband is too high(chevy) but when the motor that makes the most torque at the lowest RPM (Ford) is not as quick as the Tundra, that's also bad. "
    Well, no. The best combination is a truck that does well in the quarter mile and also has good low-end torque. The Furd is underpowered. The Chev is peaky. The Tundra is the best compromise.
    "I sure hope that EMT is more representative of the Toyota owners here than the other fellow that doesn't know his Toyota motor requires valve adjustments"
    When did I (or anyone) say this? Hallucinating again?
    While I know that it is possible to get a good Chev, it appears that it is not the norm. I'm glad that you got a "good one", but what about the poor saps like Quad and ObywannaTundra who didn't luck out? Can they trade their lemons in on a Tundra without taking it in the shorts?
    While the tested GM may have had problems that are the exception not the norm(please do not try to say that all GM trucks exhibit the same problems)These "problems" are covered under warranty which may be extended for up to 100,000 miles.
    On the other hand, Toyota REQUIRES expensive, major service during 100,000 miles. The shimmed valve adjustment and timing belt should be done by a dealer.
    Toyotas have excellent reputations, and the Tundra seems to uphold this. But, again, in this day of 100,000 mile tune ups and no adjustments, the Tundra is behind.
    why do you STILL insist on calling me a "chevy boy" when you know I've owned 6 toyotas and ONE GM.
    I have nothing against Tundras or Toys in general or I wouldn't have been driving them for 30 years.I come here and post FACTS about your truck that you should want to know ,and you call me a liar and "chevy boy" as if that means I never serviced one of my Toyotas.
    I don't care if YOU drive your truck without the required maintanence ,BUT you need to quit telling other Tundra owners thier truck runs on water and sh*ts gold before some poor sap believes you and ruins a good truck with bad advice.
    kip
    my truck turned 2 yesterday (rolled off the line 4-6-00).
    Its been a wonderful 2 yrs and many more to come :)
    "Well, no. The best combination is a truck that does well in the quarter mile and also has good low-end torque. The Furd is underpowered. The Chev is peaky. The Tundra is the best compromise."
    What's all this about? The Tundra has a lower tow-rating than the GM 5.3L and is out-accelerated by it empty and with a 1000lb load in the bed 0-60 AND 1/4 mile. Ford's 5.4L has been used succesfully in 3/4 and 1 ton pickups for years so don't even go there.
    Perhaps you mistyped and meant to say "The Tundra is the most compromised of the fullsize half-tons"!!!!!
