Warped brake Rotors
I used to own a '91 Taurus SHO. Among the many maintainence issues affecting that car was a repeated ocurrance of brake rotors warping. I was told by a dealer principal with whom I was friendly that this was caused by over tightening wheel nuts when mounting tires.
I didn't believe it because I'd never had the problem recur so frequently with any other car. Most cars I've owned never had the problem but a buddy has had it w. 2 different Tauri.
Oddly it's never occurred on my other Ford product ('86 Mustang 5.0L).
Was he making excuses for Ford or just passing on an old wive's tale, or is there something to it???
Lug nut torque should always be checked a couple hundred miles after tire changes--or whenever you let anyone work on your vehicle ;-)
Some other more common ones are using 2 feet to drive, the left one usually ends up resting on the brake pedal causing them to drag. Another one is bad caliper hardware or a stuck caliper overheating the rotor causing it to warp.
One other common misconception I have discovered is that if you turn a warped rotor to make it square again it only warps again because you have removed more material from one part than the others causing a thinner spot, and that spot is more likely to overheat than the thicker spot, once again warping the rotor. In general if I have a warped rotor I replace it and go over every part of the brake system to make sure it's fixed right. After that all that's left is over torquing.
I am a GM fan through and through, I have seen this happen on GM cars too, the Cavalier/Sunfire come to mind right away. Watch those tire guys, make sure they use torque sticks and a click wrench to tighten your rims.
ther ya go!
see y'all
Rando
The only cure is to replace the front rotors with Taurus Police rotors from Bendix or another good brake component company, or if you don't mind shelling the dollars, contact Baer Racing - they make a 4-wheel replacement kit with bigger, more gnarly rotors that will lower your braking distances considerably.
Jim
those brakes are converting, in the case of my exploder, 3200 pounds * 40 mph of energy into waste heat in several hundred feet at every stop light. that's a lot of calories. the rotor or drum is the only place to sink that heat away. plenty enough heat to warp a big chunk of solid metal, which is why rotors are made like the Fan Impellers From Hell, and why there are big holes in wheels.
tire monkeys with air wrenches are public enemy number 1... it's much better if they start on "first click" and star-pattern across the bolts several times to get things tensioned right. that also minimizes the chances of "cocking" the wheel at the edge of the threading on one bolt because the opposite bolt(s) were taken tight right away... that makes the wheel a lever that with the heat is sure to warp a rotor in a relatively short distance.
and once warped, you are never going to get that rotor straight again.
And the calipers slide on these pens. With no lube the calipers, with the pads, will drag and cause more heat in the rotor, causing warping.
In general, I think the rotors in the last few years are being made cheep (low quality steel or thin rotor) because you are hearing a lot about warped rotors on all kinds of cars.
Not long ago I drove a 1998 Caddy Seville with only 4,000 miles just coming off a 3 year lease (yes, you read this right, just a little more than a 1,000 miles a year driven!) and it had badly warped rotors. Sevilles are known for this problem. But in 4,000 miles?????? It did come from Michigan, I wonder if the combination of salt and very low usage caused the calipers to freeze up and cause warping even faster.
I also drove a 97 Seville at about 27,000 off a 3 year lease and it also had warped rotors.
Like I said, it's rather common now on a lot of cars. And this is something you never heard of happening until 60,000 or more miles 15 years or more ago
you have a point on the thread lugs being used dry and dirty, that's another reason why 5-minute-Fred scares me at tire places. the flip side is that I have seen recommendations that the wheel lugs NEVER be lubricated, because excess grease will supposedly also cushion the nut on the lug, and it will shake loose.
hanging calipers will also definitely beat the rotors up, but there should be some sense of the car "pulling" or extra noise most of the time. I had one hang, barely, on the right front recently, and a car wash and the old self-adjusting drum trick of backing up at about 10-15 mph and doing a firm stop got whatever was sticking on the pin free.
If they did it's a built in design flaw that any rookie engineer or amateur mechanic could tell you was WRONG.
Also older Honda disk replacement is a bear because they are pressed into the front wheel bearing assembly. Supposedly 98 and up rotors are much easier to replace.
So watch out when anyone changes tires on your vehicle. You could get bent rotors out of the deal.
Just a thought
at that time i was taking automotive classes. my prof said the rotors looked too thin. i got new ones @ $18 each. (Midas is SUCH A RIPOFF. they charged me $50 per rotor to machine them while on the car!)
10k miles later (my class has ended), the noise has returned. is it the rotors?! how can i tell if it's warped? (my prof didnt say anything about the old ones being warped.)
slowly spin the rotor around. on any rotor, there is bound to be some minor movement of the dial pointer... but it should be under a specified range for the vehicle. for sniffs and grins, let's say .005 maximum runout is the spec on your car. if the needle is swinging from .017 to .002 you are finding a warp out of spec.
the tool is probably in the $100 range give or take, but any serious mechanic who does brakes will be equipped, because that's how you qualify a warped rotor (needing to make a payment does NOT constitute a test for valid anything.) so any mechanic who works brakes should be able to do this for maybe 30 minutes worth of labor charges and a couple bucks worth of the usual shop rags fee.
When I have tires replaced now-I take my own over priced torque wrench and watch the tech use it to tighten the lug nuts.
I have had a major vibration from my front
brakes.I have had my rotors cut (3) times.
Has there been any bulletins about this
problem and/or solutions?
Accelerate to a good highway cruising speed - say 60-65 mph - brake hard to a complete standstill and hold your foot on the brake pedal for a minute.
The hard stop puts a huge amount of heat into the rotor (that's what it is there for), but holding your foot on the pedal keeps the hot brake pads in contact with the rotor, preventing that part of the rotor from cooling down as fast as the rest, which is exposed to the air. The temperature differential across the rotor then causes warping.
Most rotors are quite thin these days, for cost and weight/CAFE reasons, so they can't resist warping like the older thicker ones.
Warping is felt as a pulsation through the pedal when braking. In severe cases the whole front end may shake, which can be felt through the steering wheel.
Best way to try and avoid it is to brake hard only when really necessary, and to release the brakes as soon as possible after a stop.
Dust and dirt will generally cause scoring of the rotor rather than warping.
Your brake shop can do a simple run-out measurement on your rotors to tell if they are causing the vibration. If they don't do the run out test they are just guessing and so are you.
The probe is placed aganist the milled face of the rotor, the area where the pads push to impart braking action.
The meter is zeroed. The rotor is slowly turned by hand while watching the micrometer dial. The amount of change registered on the dial as the rotor turns is the 'run out'. This should be done for several radius of the rotor and inside and outside surface.
I don't know what amount of runout is allowed while still being within specifications. The brake people should know. The runout is measured in thousands of an inch.
Basically, if there is much 'runout', the variance can be felt in the steering wheel while braking. It usually will not be felt though the brake pedal.
Just a suggestion in case you haven't considered it.
Alcan, after an intense research in the internet, I have decided to go with Raybestos SuperStop pads and new rotors since Motorcraft is asking $130 per piece for rotors (I did not even asked them the pad's price).
My 2000 Taurus has ABS. Any precaution I should take for ABS system or this is pretty much the same process.
Thanks everyone for their inputs.
One question..I have noticed with this and other cars, that when the car is cold, and I start driving and stop at a red light..if I lift my foot a little off of the break it makes this really loud noise...but if I drive for a while and do the same thing, it doesn't make that noise any more. Anybody know what causes that? I noticed it in other cars, too.
Factory discs in front
Drums in back
Engine = 289 4 bbl 225hp Challenger V8
Transmission = C4 automatic
