One point that needs to be made perhaps is that not everyone has the same idea of what is the "best" car. I like my SRX although it is a bit on the thirsty side.
Nah, I actually went to test drive the 335i twice after it came out, I guess my expectation was too high so I didn't end up impressed. The acceleration felt about the same as my IS350 in sports mode and although the handling is definitely better (with sports package that is) but that's an easy fix with the Eibach springs (just got them installed last month).
I guess the most important issue for me is that I still can't get pass 3er's interior...
I am really liking the 135i though, too bad that it doesn't come with 2 extra doors.
Different strokes for different folks. I have always like BMW interiors. :surprise
Then just be glad you don't have a 6000 SUX. :shades:
Best Regards,
Shipo
I agree with fedlawman...let's give GM about 5 years to adapt to good cars again. The we can compare and decide if OK to consider them again.
OW
OX
Or a Canyonero. :P
What made you have the Eibach Springs installed? Are you happy with their performance over the stock setup? How much did you lower the car?
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
I've lowered the front by 1" and rear by 0.8". It's a mild drop.
Here are some pictures with the Eibach springs:
Suspension modifications are such a great way to improve your car's performance. I had front & rear SUSPENSION TECHNIQUES sway bars installed in my Prelude a few years ago. For a little over $500, they make such a difference.
Last time I checked, now I am at at little over 27k miles. You are right about the suspension modifications and I think my next task will be adding strut and sway bars to the car.
335d = 30 MPG 36,000 miles @ $4.19/gal = 1,200 gallons = $5,885
335i = 23 MPG 36,000 mile @ 3.19/gal. = 1,565 gallons = $4,993
These prices were tonights prices for diesel at an Exxon station vs. premium at an independent in Central NJ.
Assuming there is a premium price 335d vs. 335i, the diesel is a mute point!
Correct me if I am wrong. Bottom line, the d uses less fuel but the i is cheaper to keep 'er!
OW
Though, I don't know if diesel will get lower than regular unleaded. It probably will at some point. Maybe as more people get diesel vehicles. :confuse:
-Brian
23 MPG 36,000 miles @$3.69/gal = 1565 gallons = $5775.
Of course, I'm not sure why, but I only average about 19 MPG with my little 4-banger...
Besides which, I neither need nor want a 335d. I'd buy a 2.0 or 2.5 tomorrow if they were available over here, and my experiences in the UK and Europe is that I'll get closer to 40 mpg than 30 with either of those engines. Now, if we were to re-run the calculation with a $0.50 delta between the two fuels and 33% less consumption for the diesel, I think that will be a more useful number, at least to me.
However, to support your point a bit, diesel has nowhere near the demand flexibility that gasoline has. The trucks, locomotives, heating plants and other users of diesel and similar fuels (jet A for one) will keep right on consuming pretty much regardless of price, while passing the added expense along in the form of higher prices for whatever goods are being transported. As we've already seen over the past few weeks, when gasoline prices go up significantly, people use less -- it's discretionary to a much larger extent.
Should be interesting to see this play out.
OW
335d has a combined rating of 42.2 MPG (imperial)
335i is 31
thus one computes 853 gallons of diesel vs 1161 gas (premuim I suppose) for 36,000 miles
from the AAA price for NJ I get $3.393 for premium and $4.038 for diesel. ( not imperial gallons though)
adjusting for the size of the gallon (div by 0.8) premuim is $4924 and diesel is $4306
There are a number of diesel engines that are smaller and use less fuel.
Best Regards,
Shipo
I guess there's enough in Boston for most of New England...
Oh, well, guess well have to wait for the Hydrogen 3er.
OW
1) Gasoline: 51%
2) Fuel Oil (home heating oil and diesel): 15%
3) Jet fuel (kerosene): 12%
4) Still Gas (unrefined natural gas?): 5%
A couple of points:
- As I understand it, the above percentages cannot be varied by much.
- As the demand for petroleum based diesel fuel rises, there will be a commensurate rise in the production of gasoline.
- I've "heard" that one of the reasons (beyond taxes) that allows gasoline to be so inexpensive here in the States is because Europe consumes so much diesel.
- As the demand for diesel fuel rises (as a percentage of fuel required for passenger cars) it stands to reason that the price of gasoline might actually drop.
Please understand that I am no expert in this area and I'm just throwing the above factoids out there to generate some discussion.
Best Regards,
Shipo
At that sort of delta diesel is an easy choice and helps explain why we Europeans are in love with diesels. On the other hand, the Dutch research might be valid and we're all mad !
Best Regards,
Shipo
The point is that a barrel of crude oil can be refined into almost any combination of useful products. In the winter more fuel oil (like diesel) is made. In the summer more gasoline is made. If the entire barrel were made into one product, it would be mostly synthetic (that is manufactured) rather than natural. Breaking down the heavier molecules into lighter ones is not too expensive but takes some energy.
It's on another Edmunds Forum : "Diesels In The News". The actual post number is 5167.
Hopefully my comment will make more sense once you've read that post.
What about the reverse? I know that gasoline for instance is a light distillate that is extracted from crude oil by simply heating said oil up to ~150 C. Once the gasoline is distilled out, half of every barrel is already gone. The heat is then increased to about ~200 C and kerosene is distilled out; increase the heat again to ~300 C and you get diesel oil, and yet again to ~370 C and you get home heating oil. Increase the heat beyond the ~400 C mark, you're extracting lubricants, paraffin and asphalt.
So, are you suggesting that if the chemistry set is fancy enough, diesel can be made out of gasoline?
Best Regards,
Shipo
Best Regards,
Shipo
I think another factor is the efficiency and demand of the truck diesels which are a large percentage of the US domestic commerce. If public transport demands more diesel, the price will rise. Simple.
I know the economy is there in Europe but it remains to be seen how the US model for diesel plays out. Interesting to say the least.
OW
As I understand it though, the European market (a market that uses similar amounts of diesel and gasoline) needs the American market to continue consuming gasoline so that their diesel prices stay relatively stable. If it is in fact true that more than three gallons of gasoline are produced for every gallon of diesel, then if the world suddenly switched to diesel cars, there'd instantly be a HUGE glut of gasoline on the world markets. Yes, no? :confuse:
FWIW, I've long been a strong advocate of diesel engined cars, however, if it does turn out to be true that the percentages of what comes out of a barrel of crude are relatively fixed, I may be driving a gasoline engined car for quite some time (at least until methodologies are put in place for the production of mass quantities of bio-diesel).
Best Regards,
Shipo
If gasoline is the volatile byproduct of making the kerosine (Jet A) & diesel (heating oil) for which there are few substitutes. . .
Maybe I'll be keeping my new gas motor longer than I thought, not that that's a bad thing.
I still maintain that U.S. consumption of diesel fuel for cars isn't likely to drive price trends anytime soon, but that it certainly appears to be at the mercy of the rest of the world and the other fuel oil consumers in North America.
Not really. Some of that goes on, but not a lot. This is the root of a major problem, the increasing heavy oil fraction of today's production. We don't have an oil shortage, actually, we have a hydrogen shortage, for cracking the heavier oil fractions. And no, refineries are fine tuned to their input crudes, and can vary the mix very slightly once built. Can you build a refinery with significant flexibility? Yes, but that does little for the large number of existing set of refineries.
We have a shortage of the most abundant element in the universe??? :surprise: :surprise:
However, I will agree that the refinery is tuned to output a certain mix of products based on the crude oil that is available. This tuning is adjusted from winter to summer to increase gasoline or heating oil (basically diesel).
"The current U.S. refining industry has only limited capability to generate more diesel versus gasoline in the short term.
In fact, I personally believe the diesel market in the U.S. will not take off like it did in Europe for two reasons:
1) Europe's rapid dieselization was heavily subsidized by preferential tax policies vs. gasoline. This type of aggressive social engineering is not as likely to occur in the U.S.
2) Europe's dieselization was essentially "costless" in terms of refining capital expenditures, as European refiners simply cranked up their excess refining capacity to make more diesel and gasoline, selling the excess gasoline to the U.S.
In fact, the U.S. imports roughly 1 Million Barrels of gasoline and gasoline components from Europe every day.
In other words, Europe's dieselization was done on the back of the U.S.'s continued consumption of (relatively cheap) gasoline.
If the U.S. were to "dieselize" in any significant manner, it would require 10's of Billions of Dollars in refining capital expenditures for process units such as Hydrocrackers to shift the product mix from 2/3 gasoline ~ 1/3 diesel to half & half gasoline and diesel."
All of this relates to your statement "The point is that a barrel of crude oil can be refined into almost any combination of useful products." Can the mix be modified? Yes. Is it easily varied to create "almost any combination of useful products"? I don't think so.
The problem today, as reported on the Nightly Business Report, is that refineries are running at an abysmal 82% of capacity. I would hope that the reason for this is not to boost prices, but to switch over to making more summer fuels.
.................but not very well.
Apologies, couldn't resist.
A little taken aback in trying to consider either of those as "Entry Level" or "Luxury" in the case of the M3. However, they both tick the "Performance" box rather well.
One of the main reasons I purchased the truck was for my hobby of fishing ect...beach access and towing a small boat. With the new job and little one I dont have time for that anymore.
With that being said I've been in love with the 3rd gen Acura TL's.
My wife and I own three cars...98 VW beetle and 96 Vette. The VW was paid off years ago and she owes about the same as what I owe on the truck. The VW is her daily driver and the Vette just doesnt get used like it once was.
One option I was considering was trading in my truck.
I'm just looking for some advice on what, if anything I should do here.
A certified 2 year old MB C320 CDI would be nice...
