Entry Level Luxury Performance Sedans
1211212214216217435
  • bastukbastuk Member Posts: 3
    I posted a similar post in the Luxury Performance forum but this is probably more fitting. And it's related to the recent posts by "dash5" on entry level luxury cars.
    I've been driving a '01 Accord EX-V6 for the past 8 years - it's been a great car - the only things I have done are the std maintenance items - brakes, tires, etc. I am starting to shop for "newer" used car with less miles as I have 151K miles on it. I am looking at moving up into a more luxury class - looking at Audi A4/A6, BMW 3 or 5 class or Acura TL. Today, I had a chance to drive all of these and in addition a MB. The dealer had a 04 Mercedes E320 and it was awesome to drive and seemed priced ok ($17K).
    As I have been doing research I continue to find the biggest complaints against the German cars being reliability and the high cost of repairs. Honestly, after reading the articles and reviews, I am reconsidering "moving up" and thinking about buying a newer Accord or just moving into the Acura class.
    A couple of questions -
    + Are the repair costs significantly higher with a German car vs Japanese? I have no baseline on my Accord since I have not had to do any repairs.
    + Is the reliability that much worse for the German cars than an Acura/Honda?
  • carnaughtcarnaught Member Posts: 3,610
    Yes, yes.
    I would not own a used German-made car without an extended warranty.
  • roadburnerroadburner Member Posts: 18,677
    Over the past 27 years I have owned nine BMWs. In my experience a 3 Series won't be all that expensive to run, assuming that you have a good dealer or independent BMW tech to rely on. Here are the current running costs on my four cars that are used on a regular basis:
    2007 Mazdaspeed 3- 4.4 cents per mile over 52,000 miles
    2004 BMW X3 2.5- 2.8 cents per mile over 86,000 miles
    1999 Jeep Wrangler TJ- 5.2 cents per mile over 58800 miles
    1995 BMW 318ti- 5.4 cents per mile over 120,000 miles
    In 86,000 miles the X3 has needed one warranty repair- a passenger SRS sensor. Aside from that it has needed one set of brakes at 60,000 miles and tires at 46,000. The Inspection II(major) service and a brake fluid flush at 65,000 miles cost less than $370.
    The 318ti is my part-time track rat(note that its running costs include four sets of track rubber). In the 15 years I've owned it it's needed two sets of front pads and one set of rear pads along with four rotors. I've also replaced the drive belts and idler pulleys, the brake light switch, battery and the thermostat, all of which costs less than $550. My last Inspection II cost $495, and that number included a coolant flush and a four wheel alignment.
    In contrast, my Mazda has needed major mechanical and suspension repairs- it will soon be replaced with either an M3 or M5.
  • plektoplekto Member Posts: 3,738
    The problem stems from the suppliers for electronics in Europe that German companies use. With their insane taxes, they are pretty much forced to use Bosch and a few other makers for their switches and electrical components in the vehicle to keep costs down(Porsche doesn't but they also charge the difference and then some).
    Conversely, most of the better stuff in the world comes from Korea and Japan, so the components that cause the repairs don't fall fail half as often. The trick, of course, is to get a Japanese or Korean made vehicle that isn't full of Chinese and Malaysian and wherever else labor is cheap electrical and mechanical parts.
    How do the normal maintenance costs stack up for German Cars (oil changes, tires, etc)? I know BMW requires synthetic oil changes - not sure if Audi or M-B does either.
    Much, much higher as they tend to use European filters and so on that aren't usually interchangeable for the first few years until the equivalent replacements start to come out.
    Then there's idiocy like the new Mercedes that doesn't even have a dipstick. Better hope the computers catch that leak before it goes bad.... :sick:
    And the shame about it is that while the cars are horrendously pricey to fix and maintain, and the electronics and accessories are crap, the engine and drivetrain in them are some of the best examples of engineering on the planet.
    For instance, the Mercedes engines are fantastic. But the rest of the car isn't put together any better than a Chevrolet(and for 2-3x the price, it had better be a LOT better in those areas) Don't even get me started on the pleather/MB Tex nonsense... Even Ford has better "leather" seats than that stuff.
    The OEM oil filter for a 2010 Accord V6 costs $7.00
    The OEM oil filter for a 2010 328i costs $10.00
    The OEM air filter element for a 2010 Accord V6 costs $26.13
    The OEM air filter element for a 2010 328i costs $22.95
    I didn't mention Toyota because the truth is that while nobody was noticing, they've raised their prices to higher than almost all of the rest for parts. The cars don't break as often, but I can guarantee that anything OEM from Toyota costs twice as much as most of the other makes - and in many cases, more than Mercedes or BMW.
    Brakes and struts and other "consumables" are also high for Toyota as well.
    Note - the cheapest cars to maintain and fix parts-wise tend to be Nissan/Infiniti and certain GM models(mostly their heavy duty trucks and Isuzu models).
    note - real shame Isuzu doesn't make passenger cars any more.
    http://www.isuzu.co.jp/world/product/dmax/index.html
    You'll note, though, that most of the SUVs and trucks are re-badged and sold in the U.S. under the Chevrolet badge. (the one above is called the Chevrolet Colorado in the U.S, of course)
  • billyperks2billyperks2 Member Posts: 378
    "Note - the cheapest cars to maintain and fix parts-wise tend to be Nissan/Infiniti and certain GM models(mostly their heavy duty trucks and Isuzu models)."
    This is not true, Nissan/Infiniti is the most expensive to repair out of the Asian brands.Toyota is the cheapest, my mechanic speacializes in Japanese cars and he tells me this all the time.He even shows me the invoices for the parts he orders and warns me never to go with Infiniti/Nissan.
    http://www.intellichoice.com/top10/Top_List/year/2009/list/Lowest%20Repair%20Cos- - ts/category/Luxury%20Car
    I'll believe these guys. The last time I had to get part for my 4Runner, the Toyota dealer was an absolute ripoff. Now, true, there were cheap aftermarket parts to be had, but I can guarantee that since we're talking luxury and sport sedans and the like here, Lexus isn't going to be "cheap" to fix.
    If you look at the lists from 2008, it shows Isuzu(Chevrolet trucks), Infiniti, Mitsubishi, and Hyundai as taking most of the entire list. Toyota isn't there and neither are any of the European brands.(or Cadillac)
    edit:
    If you go back to 2006, Toyota is on the list. But since then, they are suddenly a lot less reliable and a lot more expensive to fix. Something has gone wrong with Toyota in the last 3-4 years and I'd no longer recommend anything they make other than their trucks/SUVs.
  • kdshapirokdshapiro Member Posts: 5,751
    I don't. I've owned Toyotas and they have been dirt cheap to operate. You my friend are being ripped off.
    As far as reliability I don't know anyone complaining about the lack thereof, except here.
    Me I put a 1000 miles on a rented Camry SE recently and I loved it. I'm thinking of buying one. If there is one company that will make good on issues, it's Toyota, the other is Honda.
  • bob550kbob550k Member Posts: 148
    My mistake for dropping in here, the thread is "Entry Level Luxury Performance Sedans". Reads more like "my econobox is cheaper to operate than your econobox".
    True. And of the cars that fit the thread's description, Infiniti is currently the least expensive to maintain. It'd have added Lexus as nearly tied as well, but their recent problems and solutions are less than inspiring. And that's not counting the recent Toyota/'Lexus transmission issues. There's a reason they dropped down the list in the last couple of years.
    You must be talking a different Infiniti and a different Lexus company. Lexus are comparable in price to BMWs, while Infinitis are no better. At least BMWs cost $0 for the first four years. All you have to do is look through car threads to see that these upscale brands, including Acura charge an arm and leg.
    I owned a Lexus for a brief while, $275 for an oil change...I think not. My Infiniti owning friends go to Jiffy Lube. If you mean the cars are cheaper if you take them to Jiffy Lube, I can buy into that, else it's a load of bunk.
  • gooddeal2gooddeal2 Member Posts: 750
    1. I bet Lexus uses the synthetic oil for that $275. So, you only need to go there once a year instead of 3-4 times a year.
    2. The Infiniti dealers in Philly only charge ~$40 for an oil change w/ hand wash. However, they usually have the oil change coupons for about $25-30.
  • qbrozenqbrozen Member Posts: 33,860
    I don't buy that for a second. No way was it just "an oil change."
    I stand corrected, oil change and a lube, check the fluids, tires, battery, etc.
    Nobody is talking about the price of an oil change and ongoing recommended maintenance. To me $40 is still expensive, my oil changes are $17 on my other cars. One can bring their cars to a third party mechanic for major work.
    We are talking what happens after warranty when the tranny fails, water pump fails, alternator fails, o2 sensor fails, fuel pump fails, engine blows up. How much does an Infiniti alternator cost, vs a BMW, vs a Lexus?
    The first three years, 4 for BMW, are covered by B2B you can take the car to the dealer for warranty work and Jiffy Lube for oil changes. You can spend as much, or as little as you want on service. There are people who are DYI and people who bring it to the dealer.
    It's when the warranty expires what are the price of the parts and labor, and to even the playing field I'd suggest using dealer rates, not third party mechanics.
  • jimbresjimbres Member Posts: 2,025
    Well, no. The cost of the "free" maintenance is baked into the purchase price of the car. You pay for it up front.
    Why would you go to the dealer for routine service? My wife has been driving Lexuses since the late 90s & is on her 2nd car. Our excellent independent mechanic, who takes care of all non-warranty work on our cars (we also have a BMW), charges $25 for an oil change.
    Again, why would anyone go to a new car dealer for a plain vanilla oil change?
    Well yes, I bought a car, paid a price and now I pay $0 for the next four years.
    That is exactly *part* of the point. The rest of the point is how expensive are these vehicles when the warranty expires. There are those who believe Infinitis are cheap to own. I assert all of the vehicles are cheap to own for the first three years. But to calculate the costs, one has to assume, either all third party maintenance or all dealer maintenance...except for BMWs.
    My assertion is after the B2B an Infiniti water pump costs as much to install as a Lexus water pump as a BMW water pump...or at least close enough for government work.
    Agreed. This has been my experience with my BMW, which has been out of warranty since the middle of 2005. Here again, our independent mechanic provides the labor, & his rates are obviously the same whether he's working on the BMW or the Lexus.
    I think that people who say that Japanese luxury cars are cheaper to maintain than their German counterparts have something else in mind -- namely, that the German car is likely to require expensive repairs sooner (earlier in the car's life) & possibly more often than the Japanese car. So while it may be true that the cost of replacing part X is pretty much the same for a BMW as it is for an Infiniti, this part typically lasts for 125K miles on the Infiniti but usually fails at the 90K mark on BMWs.
    True. And the electronics are more pricey on the BMW, Audi, and Mercedes as well, which are usually what goes bad first. For some reason, the German electronics firms just make second-rate junk, but they don't change to more reliable Asian suppliers. Actually I suspect the real reason is politics and taxes.
    I do know that when I owned a Mercedes a few years ago(and a couple of Volvos back before Ford ruined them), they cost significantly more for the parts and often there was no aftermarket replacement for switches, accessories, and computer modules. I think what finally did it for me was when it cost me nearly $30 for a factory shift knob replacement for my Volvo. (don't get me started on stuff like keys)
    The raw data suggests the following arrangement::
    1:Infiniti
    2:Lexus(Toyota is now almost as expensive for parts as Volvo, unfortunately. Their transmissions are a known hugely expensive problem as well)
    3:
    4:Cadillac/Acura (they tend to switch back and forth - Acura breaks less often, Cadillac costs less to fix - nearly a tie as a result)
    5:
    6:
    7:
    8:(all the rest start here)
    There's a tiny gap between Lexus and Infiniti, then a small one to Cadillac(major improvement in the last decade) and Acura, and then a large drop down to the rest. I think what does it is that it's really Nissan, Toyota, and Honda versus the rest. In Japan, there is only one product line - and the premium models are just that - the upper end models of the normal line.
    Man, I'm getting confused. The same exact discussion on 2 boards right now. Here and the Luxo Performance board.
    Can you back up your "raw" data other than the website you mentioned. The internet is great, anyone can say anything and have it be a fact. I certainly, and this is me, would not get an Infiniti thinking it would be cheap to own after the warranty expires. But neither a Lexus or BMW either. How about true cost to own on Edmunds, what do they say? Frankly I'm not looking it up, because your assertions don't pass the wet finger in the air test.
    edit: I checked TCO. Try it..it contradicts your assertions and is line with some common sense. BMW 328X, Lexus 350, G37X are all within a few bucks of one another. BMW 335iX is $10 grand more...of course the 335 leaves the others in the dust in both performance and TCO. Camry 4c more than $20 grand less.
  • I assert all of the vehicles are cheap to own for the first three years.
    Actually, no. The depreciation costs in the first 3 years dwarf the maintenance costs in the out years. You just don't see those costs until you sell.
    Owning a car for 3 years and then selling it, might as well lease. One has to assume if looking at these costs one drives the cars until the wheels fall off or at least 5 years.
  • But still, depreciation is the biggest cost, dwarfing any maintenance costs. In fact, pretty much if you can afford to have a newer ELLPS you shouldn't be worrying about maintenance costs at all, as your big hit is acquiring the vehicle in the first place. The only difference is that the cost is either all up front, or fixed monthly-- whereas maintenance is sporadic and could be large.
    One only worries about depreciation if one is going to sell almost immediately. It is not a financially good decision to buy a car with selling it in three years in the back of your mind. If you are going to do that leasing is available.
    It's no secret I love BMWs, but if I get the car I love, it's nice to have $0 maintenance for four years. In today's economy even the super-rich worry about their dollars.
    I love BMWs too - I own one - but I don't think that BMW's "Ultimate Service" (their name) program will influence my decision when the time comes to replace my car (probably next year).
    It might be a tie-breaker for me if I had to choose between a BMW 335i & a comparably priced car from Audi or Mercedes. But I don't particularly like Mercedes & having owned one Audi, which was nothing short of horrific, I'll probably never buy another.
    It's much more likely that the final decision will come down to a BMW 335i versus an Infiniti G. And the price gap between the 2 cars is so great that the amount of money that "Ultimate Service" would save me - $649.40 over 4 years according to BMW's web site - is just laughably trivial.
    That doesn't mean that I might not buy another BMW, but it does mean that "Ultimate Service" won't be a factor in my thinking.
  • One only worries about depreciation if one is going to sell almost immediately. It is not a financially good decision to buy a car with selling it in three years in the back of your mind. If you are going to do that leasing is available.
    This is a silly argument we are having. Even if you drive a car for 10 years, if it cost $45K new and $5k in 10 years = $40K = $4k/year in depreciation.
    If you buy a new Camry for $30K and it costs $3K in 10 years = $27K = $2.7K/year.
    So the ELLPS is $1.3K/year more expensive due to depreciation. Which is why I'm saying that maintenance should not be a big factor. You would have to average $1300/year MORE in maintenance costs on the Camry PER YEAR to equal the much larger cost of the ELLPS purchase. So the ELLPS is a lot more expensive to own. And that is why even a grand or two every few years in maintenance costs is not that big. It has nothing to do with how long you keep the vehicle. Maintenance is not a large part of the ownership costs. And I haven't even brought up the costs for insurance, etc.
    So if you like an ELLPS and you can afford it, buy or lease it and don't worry about the maintenance costs, or perhaps you can't afford the vehicle in the first place. If you want a real worry, then the relative risk of breaking down or of time in the shop is probably more important, since that is a convenience issue rather than a cost issue.
    TCO has a huge problem with it.
    1: Depreciation isn't a factor in comparing cost to fix/repair/upkeep a vehicle. Also, neither is stuff like insurance. Yes, it matters, but not to compare which vehicles are the least expensive to keep running(you really only lose money when you sell the car, if you ever do - or to be more accurate, you only GET BACK the difference in depreciation when/if you sell it)
    2: The first years where the factory warranty is in place artificially skew the results. BMW comes out well by this measure because it does cost you nothing to keep the car running, or nearly so. But try that with a 5 year old BMW...
    TCO is pretty worthless, really.
    Just looking at the data I posted - if you go back to 2005, you'll see Lexus is taking about half of the spots. Infiniti and Cadillac vastly improved their quality since then and Lexus slipped a bit down to where Honda/Acura is.(still very good, especially if you get a car with manual)
    link title
    The problem is that costs to fix things is skyrocketing. A replacement transmission in a Camry, for instance, runs over $3500 now. That's just silly. Bumpers and other components that get scuffed or cracked are hideously expensive. Want to replace a Toyota or BMW or well, almost ANY car's headlight assembly?
    So if one company can come in with less frequency and/or less cost per part than the competition, it wins. Mercedes, Audi, and BMW flat-out fail here. Volvo is also notoriously pricey to fix. Acura and Infiniti are a bit better, as is Cadillac(they take grief about not using the best newest tech, but then again, that's less stuff to break as well) Toyota just has problems recently and I'd not recommend anything with an automatic or ETC(electronic throttle control) on it from them.(that's 80%+ of their line currently.
  • ivan_99ivan_99 Member Posts: 1,681
    Gives me a flash back to last year when I wrote off my Q45 (wasn't that bad of an accident). ONE headlight assembly came in over $1200...ouch
    There's that expression again, lies, damn lies and statistics. You get to pick your metric and make your case based on your metric. There is no getting around it, the more expensive the car the more it costs to own.
    For example: In my area a rebuilt G35 tranny is almost $2K, but a rebuilt Camry tranny is $700. Not sure where you get your figures from. A headlight assembly for a G37 is nearly $800. Ouch.
    If you are saying an Infiniti tranny breaks less often than a Camry tranny after the warranty period, you would have to point to some credible source for me to believe it. Not just a CR survey.
    But it still boils down to will *your* car have an issue, and if it does what will it take to repair it. My BMW can be cheaper to own on a parts basis against a used Accord if nothing breaks on it and the Accord is constantly under repair.
    I suppose if the rebuilt Camry transmission is a generation or two old and has no warranty and is out of some shop in the middle of the industrial section of town, you MIGHT find one for $700. But here in Los Angeles, a 4-5 year old Camry automatic is well over $3000 by the time you write the final check. The best I could find locally was $2100 with a warranty, not counting labor, shipping, tax(etc) and a core charge. The CTS transmission was only $1600. Now $500 might not be a huge amount to some people, but that's more than I spent last year on maintainance on my 4x4.
    With that sort of potential repair and the issues that keep coming up(plus the new Prius recall, now!) I can't recommend Toyota other than for their trucks.
    Who buys a new transmission? Almost nobody? It must be a regional thing. The numbers I cited were local. It must be a supply and demand issue in the LA area, which is a very narrow slice of information to make a broad generalization on.
    The other potential reason for the difference is that CTS trannies may be crap, you get what you pay for.
    I have no problems with Toyota, I would buy any of their cars in a heartbeat, recalls or not, doesn't bother me in the least. I really like the Camry SE and am mulling over buying it.
  • 1bythesea1bythesea Member Posts: 52
    "... Toyota just has problems recently and I'd not recommend anything with an automatic or ETC(electronic throttle control) on it from them.(that's 80%+ of their line currently. "
    Couldn't agree more. Throw in transmission hesitation. I had a hesitating 2005 V6 Highlander. You could never pinpoint when it would happen but it did several times a day. I reached the end of my rope when it had a full 2 second hesitation while highway passing. When it kicked in I almost had whiplash the car took off so fast. Very dangerous. It was dumped after 1 year as the TSB didn't work. I was done after 21 years of loyalty and great vehicles. The worst part being Toyota refusing to acknowledge the problem. To my knowledge it still exists. Finally, the Prius brake issue. Toyota has some quality control issues going on right now.
  • smarty666smarty666 Member Posts: 1,503
    I'm confused, why are the words, Toyota, Camry, and Highlander even doing in a el-lux performance sedan forum anyway? the words, luxury and performance don't even belong in the same discussion as Toyota
    You have to read the threads, there was an assertion an Infinity G3x is cheaper to own than a Camry. Of course, based on the metric one choses it could be shown to be cheaper.
    Hope this clarifies your confusion.
    wow, thats a weird question to ask? the tires alone make the G37 more expensive alone!
    I guess the reason they are included is because I see Toyota as "Toyota", since it's just one company in Japan - with 40 or so different vehicles ranging from econoboxes for the poor to luxury cars and even military transport vehicles and commercial equipment. Also, many of the "Lexus" models share DNA and parts with the more common vehicles, which is where the problem is right now. Toyota isn't admitting it, but OF COURSE Lexus models are also going to be affected.
    That said, manual transmission Toyota/Lexus models are fine. They have no computers in the way and are as solid as a tank. The same can be said tor Mercedes as well. *If* you get a C or E class sedan with manual(yes, I know, only automatics normally make it over here in the U.S.), they are extremely reliable cars. Stripped of all of the electronic junk and transmission and throttle and everything else that tries to out-think you, they are perfectly fine vehicles.
    Now, the real question I guess is what out there that is a "luxury car" doesn't have all of that technological garbage applied to it? I'm unfortunately having a hard time getting any names on my list, as least for stuff that I can buy in the U.S.
    I know that the problems with all cars now a days, everything is computerized in the car and the inside and outside of the car is loaded down with cheap plastics for almost everything!
  • jtlajtla Member Posts: 388
    As someone pointed out earlier, when discussing maintenance costs, we are not talking about oil change, break pads sort of thing, but repair cost should a car broke down -- and how frequent that happens.
    In my 3 years of ownership of a 2007 328i, I had to take her in 3 times for "unscheduled maintenance". Each and everyone it was due to malfunction of some kind of electronic control unit, and the solution each time was to replace some "module". These are repairs that cannot be performed by mechanics, no matter how good they are, not to mention the expensive "diagnosis equipment" they would have to purchase. Other than these electronic issues, I never had any problem what so ever. However, it is these electronic problems that keep me from owning another German car because they are notorious on electronic components. I do not want to be in a position where I have no choice but to go to the dealer for repair after the warranty expires.
    *You* may see Toyota as Toyota, but there is enough differences between a Lexus vehicle and a Toyota vehicle. That is like saying I see Nissan and Infiniti as one company since the same engine and a lot of DNA is shared between the two companies.
    Your original point, which is a silly statement, is an Infiniti is cheaper to own than a Camry. I guess as silly as it sounds, if you live in LA it's true. In the rest of the world, it's a laughable thought.
    No, I said that an Infiniti is cheaper to maintain than a Lexus according to actual research. And I provided a link for the data as well.
    No you provided one link, which I don't believe. Just because it's on the internet doesn't mean it's true. Or maybe it's true by one measure and false by another. Edmunds TCO tells a completely different story. Additionally I dispute your research for indicated tranny prices as my research indicates the exact opposite.
    Anyone who buys an Infiniti thinking it's the cheapest thing around to maintain is foolish. I could make the statement BMW for the first four years is the cheapest car to maintain in the world and I would be correct and factual. Does it tell the whole story? No.
    Then we should be discussing "repair costs" not "maintenance costs." Maintenance is maintenance, as in the manufacturer's suggested maintenance.
    Not to mention, one person's maintenance is usually not comparable to another's. For instance, I may like to maintain my car by changing the oil every 4k with synthetic, while someone else with the same car may prefer every 7k with off-the-shelf oil.
    You don't find this sort of variance with repair costs (as long as both go to a dealer, that is).
    edited February 2010
    I'd call Intellichoice as reputable a source as Edmunds or any of the other research sites. If you look back 3-4 years, Lexus and Toyota *were* at the top, as you probably would expect. But in the last few years, Toyota has had massive problems with its entire line of vehicles that they've been fairly good at hiding and denying until very recently. It's not surprise that one of the other Japanese makers has managed to move into the #1 position as a result.
    2009
    2006
    http://www.intellichoice.com/top10/Top_List/year/2006/list/Lowest%20Repair%20Cos- ts
    It's been a very hard three years for Toyota.
    I find this discussion about maintenance costs very interesting since I have a Infiniti, Acura, and MB. Its hard for me to add anything really important or helpful to discussion since in the 6 years I have had each car I haven't had anything but normal maintenance stuff done to each vehicle and no other problems as of yet; in regards to normal maintenance the Infiniti has been the most expensive to maintain because the gas mileage is lower than my Acura or MB and plus it has a larger tank than the other two! air and cabin filters were the cheapest in my Acura to replace
    overall, I think my Acura has been the cheapest to maintain but don't get me wrong, both the Infiniti and MB are not that much more expensive and I've been pretty happy at the amount each one has been to maintain!!!
    Pick your metric to prove your point. TCO for a "generic" Infiniti G3X is much more than a "generic" Camry. BTW I call Intellichoice a rag, which is why I do not believe their metrics.
    It's an interesting discussion but what is being discussed has to be clear. As gbrozen stated above maintenance is not repair. You may be of the ilk who likes to change their oil once a month even if you put on 12K miles a year, thus driving maintenance costs up.
    I am talking about repair, which is after the warranty expires. How much does it cost to get brakes replaced, altenator, transmission, water pump, ECU, light assembly, sunroof etc. A Lexus, BMW, Acura, Infiniti, Audi will have a higher repair bill than a Camry and Honda. This assumes you go to the dealer for service.
    As long as nothing goes wrong with the car after the warranty expires, oil changes are cheap. The major services run into some money. A friend paid $275 dollars for his 7500 mile service on his Acura. Sure he could have gone to Jiffy Lube and saved a few bucks, but he wanted the dealer experience.
    A BMW is the cheapest car to maintain because it costs you $0 for four years, but what happens after four years?
