i still dont have a good solution for the leaking bolt on top. maybe the only thing to try is a very small amount of sealant there--or make a rubber washer??? the mech said he hadnt seen that, and try this maybe.
one question if anyone knows---How do u access the speedo cable to lube it?? my disk manual doesnt address this---anyone know??? i plan on using "kable eaze"....
in other things, anyone gonna respond to my vacuum question?
This is the only vintage MB thread, so I'll gripe about the fintail here. It's been in for some work...so far, one of the spark plug wires I bought was defective, the generator bracket that was supposed to fit the car doesn't fit, and the clatter I've noticed that I thought was from a wheel bearing or misadjusted brake is apparently some kind of driveline bearing, not easy to fix. The fun of old cars. The one week trip to the shop is at 3, and counting.
into 3rd ) for a year. I could live with that. Now I must drive slow for about 4 miles before it will even try to shift. Had filter changed, no help. Would like to check modulator, need help finding it. Thought someone went through this mess and had some tips. THANKS
I just got through changing out my modulator on my 300d, and I can tell you it's kind of a pain in the neck unless you have a lift. Nonetheless, it is located on the driver's side of the transmission and has a vacuum hose running to it. You should test your vacuum system including the modulator before taking it out. Your problem could be a simple vacuum problem or much worse. Use Google, there are lots of internet pages on this topic. If the vacuum test seems daunting you should seek out a good mechanic who is familiar with mercedes to help you.
Aren't most diesel "additives" mostly ethanol/methanol? Adding gasoline might lower the viscosity a bit, but winter diesel here is already formulated for the cold weather.
Cheers.
When I worked in Alaska, the diesel trucks there solved the problem of sub-zero starting. They just never shut the engines off from November through March. They idled all night at the roadhouses.
I did this for a company of military vehicles in Korea when it was -20 without windchill and -40 with the windchill calculated.
Let the glow plugs go about 30-40 seconds past the glow plug light going out and then start. There is a timer in the circuit that turns the plugs off after about 45 seconds after the light goes out. Try it you will hear a click as the relay turns the plugs off.
Best to use an engine/oil heater, MB has one built in and you should try to wire it and test it in the good weather.
As the battery gets cold it is weaker. Use a trickle charger at home and it will help to keep the battery warm. Another item is a battery hot blanket that you can plug in with the engine/oil heater.
NRK
On my VW diesel I used a battery blanket and block heater, most of the time not absolutely necessary, except on the coldest days. Those are the real tests of how good a diesel is. Interesting that MB has a built-in heater! I had never heard of that.
I am looking at a 76 300d , not winter driven, 165k miles, everything working, recent engine/trans service, brakes done, little or no rust. Any estimates on what would be a reasonable price?
cheers.
Obviously I haven't called the shop but what is the fix for this problem?
Many thanks
PS- The last thing I want to hear is that I have a cracked block. According to the dealership, the car has never been winter driven, (I'm in Ontario) and has 113,000miles.
Thanks though for your reply.
I may just use (ugh!!!)a vise grip.
5/8 is the rough equivalent of 17 mm
Thanks again.
There are *different systems* on 80s cars and some are worse than others, but all are pretty lame. Sooner or later, you or any 80s Mercedes owner will have to deal with it. The Mercedes AC sucks altogether, but I did manage to keep my working rather well, although I had to charge it and fix leaks at least once a year to get any kind of efficiency out of it. But I ran AC in the desert for hundreds of miles, no problem---it cost me about $250 a year to keep AC working.
Your results may vary, and I hope so! I personally never had a heater problem per se but the climate control was always lazy and erratic.
Sometimes if you spin the climate control dial and count to 100, it'll work. Be patient, cross your fingers, pray and buy a rabbit's foot.
I've been away from a computer for a few weeks, but thought Id share some results and post another question. Hope you dont mind my encyclopedic rambling....
Ive been on a big road trip with my 82 3ooD. a few weeks ago my speedo hit 200k and 2 miles later started malfunctioning--it began clicking like a metronome. of course i followed some good advice and removed the instrument panel to see what was going on. i was able to use a small square drive to attempt to reverse the speedo where the cable inserts, but found that it would only reverse the trip meter. in desperation to avoid the annoying clicking, i tried to reverse the miles from the front of the odometer by using a tiny screwdriver, which actually worked without breaking anything. i had to start from the right and work my way left thru the tiny gears, but once i tested it, it stopped the click, and joyfully I removed many long miles, and added new life to my engine and tranny!!! just a little bit of magic for anyone plagued by the clicking speedo. Note: I see that this had been done before, as when i registered the car it "had" 195K, but the woman at DMV said it had a reported 196K.
Another note on my valve cover gasket-- I took more good advice from a mechanic and filed down the castings on the V-C where the V-C bolts mount to put pressure on the gasket--about 10 thousandths. i also checked for warpage with a straight-edge. ignoring some advice, i used copper spray adhesive to "glue" or seal the gasket to the V-C, as this didnt leave any gloppy silicone to clog oil ports and nicely kept the gasket in position during installation. Long story short--it worked, no leaks after 500 miles.
Now to my question:
Yesterday my alternator stopped charging. I started up in the morning ok, but after shutting it off and restarting, it cranked at half speed. it started and the next time was even lower. 3rd time wouldnt start. from previous posts i suspected the voltage regulator on the alternator went bad, if not the whole alt. i bought a new VR, but not installed. what baffles me is that today in the 90 degree weather the temp guage for the first time ever went above 60 C (its been off and on 90 for a month). It happened several times while idling in traffic, but if i put it in neutral and revved it up, the temp guage went down. it never went above 80 C and never boiled coolant that i could see. once i started driving, no temp increase. How are these two problems related? I could see that if it was an electric fan, then the low battery/ bad volt. reg would cause a fan malfunction, but its a belt drive clutch fan. Any ideas?? thermostat??
Sorry for the long post, but hope its useful. Thanks again and i still love my car. :shades:
On the same logic I guess French-built indicator signal would be made of one part, out of rolled sheet tin, look ridiculous and sort of -loosely- work, when it didn't fall off, but be unfixable when broken. I'm thinking of the gear shift on a 2CV, for example. Well I hope my MB will have strong heat, and weak a/c is OK! Thanks again.
The AC is, well---it is what it is and ain't what it ain't. The Germans just couldn't design efficient AC for the longest time. Between their temperate climate and the large glass areas of their cars and some of their whacky engineering solutions, the poor AC just lagged far behind American units.
-Ryan
I hope you made sure the water pump isn't leaking from the shaft seal, and just running off the bottom of the pump, causing you to think just the pump gasket is leaking.
I usually take the radiator out for access. It's a good time to have the radiator cleaned (rodded out) and checked also.
It's not anything to do with German engineering. That engineering is not to make it easier to service and repair, but to make it run and operate smoothly.
-Ryan
Anybody run into this problem? Is it OK/ safe/ helpful to spray WD40 in the ignition?- Thanks-
Use graphite lock lubricant please.
What form does it come in? Powder/ paste? And how do I apply it and where can I get it from? Autozone/ Murray kinda places?
WD-40, or any lube for that matter, isn't good for locks. It's an oil-base and it gets old and gums everything up. You'll may get results but then later on bad results. Graphite just stays the same regardless of how long it sits in there.
... until someone gives it a squirt of WD-40 and turns the graphite powder into graphite paste.
james
