Mercedes 300D Suggestions
14142434446
  • benzsilverbenzsilver Member Posts: 21
    Mine was a 1975. I do not specifically recall the number type. It was definitely a fixerupper,but after having it painted, new mb-tex seat covers , and new michelin radials, along with a muffler, the wife of one of my business partners said it was as nice and rode as comfotably as a friend's Rolls Royce. At that, I knew I would always own a Mercedes Benz. :shades:
    Until the Germans got ahold of them, it wasn't hard to be more reliable than a Rolls Royce.
    Probably they wouldn't have been so complimentary had you fixed up a 300D, since they are quire comfortable but rather noisy and slow. A UPS truck comes to mind rather than a Rolls. But even the old diesels have that "rock steady" feel on the road that we've come to appreciate in a Benz and, once squared away or restored, a very credible level of reliability.
  • fintailfintail Member Posts: 58,245
    You've got a W114 then, also called a "squareline" or a "strich acht". What color is it?
    I have to believe there was some kind of strategy back in the day to make the cars age well, so even used cars would lure people into the brand.
    the color is ,I call it butterscotch, about the color of those Weler hard candies that you cannot stop eating with only one piece. My mechanic shop owner had a '72 4 dr also. He tried to bargain for the european headlight assemblies. no, no, no I said, those headlightss are a part of the package and the add to the appeal and character of the Benz. :shades:
    Those lights are pretty rare...you are wise to keep them. On those cars, it makes them look better...only on W111/108 cars do the US spec lights look decent.
    edited August 2010
    Driving north out of Yakima Sunday morning just after crossing the Harold Redmond bridge I noticed a car about 100 yards behind me appear to EXPLODE, big cloud of white smoke, steam(??). Driver seemed to take no notice as the car continued to follow us for miles, 70 MPH, trailing a cloud of smoke/steam all the way.
    I first suspected it to be oil or steam but with it seemingly driving well I decided it could not be and therefore must be a "blown" diesel engine. As we started down the final cut, incline into Ellensburg, the smoke/steam stopped and the car accelerated downhill and passed us.
    I was then able to ID it as a fairly new Mercedes-Benz Turbo-Diesel 4 door sedan..
    Once it passed us our car windshield got quickly coated with a fine mist of.....smelled like kerosense....??
    The last we saw the car she took the turn to eastbound I90.
    Wonder how far she got...?
    Was it badged "turbo diesel"? IIRC that badge hasn't existed since the W210 300D of 1998-99.
    Maybe some of greasel or other homebrew diesel conversion gone wrong? Or maybe some kind of head gasket failure.
    Yes, top passenger side of the trunk lid was labelled "turbodiesel"
    Those here at the office are guessing "holed" piston.
    Could be it. Big clouds of anything usually mean some kind of catastrophe.
  • dotishdotish Member Posts: 20
    I've got a problem with something running and draining my battery while my ignition switch is off. It was a complete mystery until last weekend when I opened the hood and heard a rapid ticking sound that emanates from what appears to be the vacuum distributor, since it has a load of vacuum tubes running to or from it. I've got a manual, but can't seem to find out what the thing is, let alone why it's running.
    My tendency is to jump to conclusions and it's cost me in uneccesary parts, so I'm looking for advice before buying an ignition switch. Thanks in advance.
    Okay, I'm back. I'm now wondering if the starter lockout/backup light switch might be defective since I've been told that my backup lights don't work in addition to the car not starting in Park. Is this switch activated by something internal in the transmission or by something external in the linkage?
    dotish.... this problem is one I am not familiar with, however, if I were faced with the situation I would make sure the key was not in the ignition when you open the hood as , as you said the battery goes dead and that ticking could represent the battery's last gasp so to speak because of the key alarm, open door alarm or open trunk alarm( buzzers and lights). With that cleared uo, next perhaps the radio is not operated by the key, and again the battery's last gasp. Third, if you boost the car to start it, when you turn it off, be sure it is either dark outside or park the car in the garage, turn motor off, close garage door, turn off garage lights and see if there is any light inside or outside of the car, that would represent a closed circuit to some light source that should be open as the ignition switch is off, doors and trunk closed, and light switch off. Check your cigarette lighters and ash tray lights, glove box lights, switches for rear window defroster, emergency brake light, vanity mirror lights, seat warmer light. Make sure top of battery is clean and no corrison at terminals. Also, the disk brake sensing light may be defective or loose and draining the system. Let me know if this helps and happy hunting. benzsilver :shades:
    That "vacuum distributor" sounds like the servo valve to me, which is part of the climate control. It's also is electrical, so it could be the problem...............
    Does it have a large block of vacuum lines, electrical connectors, and coolant hoses going into the bottom? If so, it's the servo valve.
    The way I have always trouble-shot electrical drain issues is to disconnect the battery and put an ohm meter across the battery cables. Disconnect any lights, etc that could be activated (such as an underhood light) and then see what the resistance is across the cables. It should be very high. If not, then start disconnecting circuits by removing fuses until you find one that causes a big change. That will at least point you in the right direction. Some fuses are in line and may be more difficult to find. A good wiring diagram helps immensely.
    Thanks for your reply. Yes, it's definitely the servo valve and it's definitely what's ticking when the battery is connected and nothing's turned on, including the ignition. If all that the servo does is related to climate control, I'll just disconnect it, since nothing except the defroster works anyway and I'm not going to need that any time soon in Texas.
    Thanks for the battery drain troubleshooting tips.
  • manifesterosmanifesteros Member Posts: 1
    my 84 turbo deisel benz runs fine but wont go forward or backwards-It is an automatic.what could be the problem.It stopped moving after i shifted it in reverse after going forward without completely stopping
  • 1984300d1984300d Member Posts: 1
    Any thoughts on how best to find a potential new owner (preferably in Bethesda, MD) of a classic '84 300D in need of some fix-ups?
    Craigslist is really the best venue for this type of car. You want dreamers---big dreamers.
    edited January 2011
    '84 cdt won't stop running when key is turned off! Help
    edited January 2011
    It sounds like you have a defective vacuum shut-off valve for the fuel. This is located at the left rear of your engine (driver's side is left).
    REPAIR INSTRUCTIONS
    Mr Shiftright: Thank you for your response. While checking the location of the shut-off valve, I have discovered a black vacuum line that goes thru the fire wall along with two yellow lines a green line, two gold blue strippped lines and another line. The goldblue stripped lines are connected to the ignition switch, the yellow lines go tward the defroster ducts, the green toward the a/c system and the other line somewhere else. these are all connected to something; however the black line is not connected to anything under the dash inside the car. the other end is connected to the y- connector that connects to the big line that goes to the booster and the business that sits on top of the rocker arm cover. I have looked for vacuun diagrams, however, none that I have seen so far illustrate the line that I am seeking a connection point. My vehicle is a "84 300 CDT. I have removed the lower dash panel and instrument cluster to be able to see the area better. I would appreciate your help and info regarding this quest. benzsilver and thank you again :cry:
    I don't have such a diagram either. Best thing I always suggest with loose vacuum lines is to extend them as far as they will reach in a 360 circle until it meets up with a connector that it can reach.
  • stop_motionstop_motion Member Posts: 1
    Glad to see Mercedes-Benz recognizing the work of Mercedes Motoring out of Los Angeles. They do some incredible work. I've followed them for years and their restorations only get better. Check out this short documentary on http://mercedes-benz.tv/
    Too bad the people making the video were more interested in their cameras and the music than in actual content. :mad:
  • mickeypatinmickeypatin Member Posts: 3
    Hi Everyone,
    I'm thinking of selling my 81 - 300D non turbo sedan with automatic trans. I do not want to mis represent the car so would you please comment on my following statement about the transmission.
    Bought it in Houston 4.5 years ago and have been using it down here in Cuernavaca, Mexico ever since and it stills runs great at 220,051 miles, which I believe to be accurate.
    I noticed when I bought it that it ran up higher rpm's before shifting than I was accustomed to. A non related mechanic of vintage Mercedes' told me it was designed that way to keep the small diesel at high rpm's when climbing hills or steep mountains.
    I thought it made sense and I went back and bought it. But I did think it strange, and still do, that it would not shift earlier without a load on it.
    My 79 300 SL turbo., which i believe had a little more powerful 5- cyl. engine always shifted like the many american gas cars I've owned over a lifetime.
    The little 5 banger has faithfully climbed Mexico's highest mountains and has made countless trips between South Mexico and Texas and Louisiana. The trans. shifts the same today as when I bought it. A different Vintage MBZ mechanic in Dallas told me the same thing plus gave me a tip to release the excelerater momentarily when I wanted it to shift earlier and that has worked fine over these 4.5 years.
    Can any of you pros. out there tell me the correct story of this particular automatic tranny?
    Mickey
    PS: I'm fairly certain the Trans. is operated by vacuum from a vacuum pump attached to the engine.
    Sounds pretty normal to me. You might check the vacuum lines that go to the vacuum modulator---or check the vacuum lines in general. If you have any kind of vacuum leak, this will affect how the transmission shifts.
    One tip off of a large vacuum leak would be that you can shut the engine off with the key sometimes.
    Thanks for your opinion Mr. Shiftright.
    Mickey Patin
    By all means check the small vacuum lines and junction blocks that sit near the top/back of the engine on the driver's side.
    Hi, I've just purchased a 1985 300D turbo that runs well, but shifts with a jolt into 2nd gear. Can anyone suggest what the problem might be? Vacuum leak?
    Sounds just like a 300D to me! :P If it was a vacuum leak, it probably wouldn't shift at all.
    They shift hard as a rule. Of course, we can't tell what you mean by "hard"---compared to modern transmissions or compared to other 300Ds?
    These are wonderful cars, but cars have come a long way since 1985, and now transmissions are electronically controlled to the max.
    1)Is the jolt produced by the rear end or the transmission? 2) a vacuum leak is highly suspect, however another avenue or two may be a) low trans fluid level; b) poor adjustment of the shift linkage; 3) possibly the adjustment on top of the rocker arm cover that controls the trans could be out of adjustment. This line is easy to adjust. Just pop it off , make sure the ball tht i ataches to is at its stop, then if needed , simply turn the adjusting screw ( it is white in color, probably made of nylon) turn it 1/2 turn clockwise, start car and drive it ablock or so; if there is an improvement in the shifting, leave it alone( make sure you drive fast enough to go thru all the forward gears before reaching your decision that is is now ok.. If no improvement, repeat process with another 1/2 turn clockwise. if no improvement, turn white knob back or counter clockwise to is original position or 1 full turn counterclockwise; thee repeat process by turning 1/2 turn counterclockwise, test drive again and see if there is improvement. Believe me it basically is a trial and error process, but with patience and perserverance you possible will be rewarded with success in this process. Have fun! :shades:
  • coach17coach17 Member Posts: 10
    edited December 2011
    I have a 1981 300d with 200,000 miles. The heat works fine at times. However,if I turn it off, then turn it back on a little later, it blows cold air. I have found that if I stop and turn car off then re-start it, the air will be hot again. (the heat seems to only work on high. And only comes out of defroster and upper vents, nothing out of the lower foot vents) My commute is about an hour. If I keep the heat on the whole way (glad it has a sun roof!!), the air will turn cool after about 45-50 minutes. Any suggestions???
    yeah, that sounds like the typical Benz problems with the climate control unit. There were two systems, the earlier one being the most notorious.
    Not sure which system you have, since your year is on the 'cusp', and also Mercedes at that time were often registered as 1980s when they were actually 79s, and as 81s when they were actually 80s (long story).
    Anyway, WATCH THIS VIDEO
    It tells you which control unit you have at about 1:30 on the video. If you DO have the earlier control unit, you'd best watch the whole video. If you don't, then come back and we'll take it from there.
    Mr. Shiftright...I watched the video. I do not have that climate control system. My buttons run horizontal. Any suggestions?
    Well then you're in luck..you only have the* second* worst climate control :P I think you should investigate these people --
    http://mercedessource.com/techhelp
    I suspect that your problem is in these controls somewhere.
    Does anyone have the schematic for the vacuum lines on a 1981 300d transmission. I am told this is a California car and the # on tranny is 722.118.
    I have a 1981 300d with 200,000 miles. It seems to slip or flare from 2nd>3rd, and 3>4. 2nd>3rd seems a little worse. Also, it shifts into third at around 25MPH (which is very close to the 2nd>3rd shift around 20-23MPH). I can start out in "S" and then shift into "D" at 30 mph and it doesn't seem to slip.
    The tranny looks like it may have been taken out and possibly had work done. I'm hoping it is just a vacuum issue.
    Any suggestions???
    Quite honestly, if you're new to this car you may be experiencing the typical behavior of the 300D tranny, especially if you're trying to accelerate quickly.
    When I first got my 1980 300D I was alarmed thinking that I had a problem. After reading some posts here and talking to a few other owners in person, I realized that I was trying to push the car too hard and that I was going to have to relax and settle for slow acceleration since pushing it harder didn't speed things up, it just caused the weird shifting you're having. I don't think you have a problem.
    I'd see what others have to say, but this is my experience.
  • onewheelsonewheels Member Posts: 1
    My blower motor would no longer turn by hand once removed, I also discovered that replacements are no longer made, and if you actually find one it's at least $168 online but NAPA did not have it in stock anymore.
    My successful $53 solution:
    Use a blower motor from a newer Chrysler and 'make it fit'. I went to an O'Reilly Auto store in Kansas City and Tom the Eagle Scout helped me out. The motor that Tom found is the VDO PM3324 for $53. The motor diameter of the body and the shaft are an exact match. Electrically it works perfectly at all speeds from ultra low to high, and this solution does not require any modifications to your original Mercedes wiring. However the new motor is constructed a little different and some creative engineering is required to get the fit just right.
    Photobucket
    Before you start
    Use a voltage meter to verify the blower motor electrical plug has 12 volts when you turn the ignition key on. A no fan issue could be a resistor or fuse problem.
    Tools required:
    Bench grinder, basic metric socket set, screw drivers, crimping tool, 3m black vinyl tape, 3m double sided foam tape, hammer, drill with 15/64th bit or so, one male one female red spade connectors to crimp to the motor wiring, semi rusty vice grips optional.
    First remove the old motor under the passenger dash, so remove the panel first. The electrical connection easily pulls straight down. If you remove the 4 machine screws from rear to front, it will fall right into your hand, if like my 15 year old son you remove screws front to rear it will fall right onto your head. I love teaching my children the finer points of working on cars :shades:
    Remove the single bolt in the middle that holds the motor in place. The motor can now be wrestled out. Note the 4 vertical ridges in the Mercedes plastic that holds the motor.
    The new motor bottom needs 4 notches:
    The VDO motor has an ridge in it's bottom cap construction, I used my bench grinding
    wheel to notch this cap flush with the body in 4 90 degree cuts to fit the plastic ridges, 2 of them at the 2 attachment bolts on bottom, the other 2 90 degrees from these bolts. I recommend making them a little wider than required for an easier fit, a tight tolerance won't help you here.
    The new motor needs it's bottom cap circumference reduced:
    The bottom cap has a outside ridge, carefully rotate the motor against your bench grinder to reduce, but not remove, the outer lip. Once it fits into the top of the Mercedes plastic base this task is complete.
    Protect your wiring!
    The black and blue wires come from the top of the motor. Cut the foam tape, stick the wires below this so they are flush with the side of the motor. Wrap with 4 or so times with a good 3m black electrical tape. I highly recommend you avoid the cheap stuff here!
    Drill the New mounting Holes:
    Getting the new motor into the old Mercedes plastic requires a firm tapping, not hammering. Place on motor on your work surface, with shaft just off to the side and tap the plastic on the motor. When the bottom two mounting bolts hit bottom the will leave your drill location marks. Wrestle the motor out and use a 15/64 drill bit to make 2 new holes. Hint: remove the extra two nuts at this time. Re-tap the plastic onto the motor making sure the bolts come through the holes, attach with the washers and nuts that come with the motor.
    Cut no wires, Make the Electrical Connection:
    The fan requires a CCW rotation when looking down at the top of the shaft. Terminate the black wire with a red(22-18 gauge) male spade to fit into the Mercedes side female connecter, which is the + voltage side. Terminate motor's blue wire with a red female spade connecter for ground. The motor wires were a very tight fit into the red connectors and crimped down just fine. I did not cut any wires, and was able to nicely tuck them both down into the plastic base when done.
    Photobucket
    The smart choice, a new squirrel cage:
    The shaft is a little longer, this was not the problem as there is room above. The original motor top is tapered, and the original fan support is curved to match. The new motor has a right angle top, not tapered which means the original squirrel cage fan cannot be tapped down as low on the new motor. Though this is not what I did I think it's likely the better choice.
    Plan B, What I did:
    Tap the old fan onto the shaft, when it reaches flush, use a deep socket to tap it further down about 1/4 inch, until the motor top is just barely not touching fan. I actually had the slightest of fan to motor rubs, as I assumed it rubbed itself out during the first 20 minutes of operation.
    The new system will be about 5mm to tall and the an will rub on the top side. I used a blue foam 10mm thick and 4 screws that were a little longer that the original and it works great. Photobucket Photobucket
    The foam I cut into a circle around the bottom of the fan, and use a marker to trace and cut the external plastic shape. A couple small pieces of 3m double sided foam tape and
  • watexwatex Member Posts: 3
    I recently purchased an 84 300d with 49k miles. It had been living in a dry climate (LA) and stored for several years. The car runs great and performed perfectly during the journey from LA to Seattle.
    The paint (gold) is showing evidence of wear (small scratches) on the sides of the body. Roof, hood and trunk are okay. I would like to have the car repainted. I took it to a paint shop recommended by my local MB dealer here in Seattle. They told me the clear coat was cracking and could not be repaired. They recommended a repaint. The prices quotes were incredible ($7k if I keep the same color and $12k for changing the color).
    I have several questions:
    1. What is a good price for a repaint job (using MB colors)?
    2. Should I keep the same color (I do have a preference for another MB color that was available that year)?
    3. Is replacing the seals (around the doors and trunk lid) a big ($$$) expense and is it something that I could do (not being a weekend mechanic yet).
    Just getting started with this car. It is the first classic car I have purchased. I actually owned a similar car new (back in 84) so am reliving my past!
    Any guidance and recommendations would be helpful.
    Well I think it would be a good idea to drive this car for a while before investing in paintwork, just to make sure all the usual 300d bugs are out of it.
    The door seals are a good idea and no problem except that you have to be very neat about the application of the glue--so if you aren't somewhat fastidious, and have good glue solvents on hand, you might farm this out. But it's hardly rocket science.
    Good paintwork is very expensive because it is a) intensely labor dependent work and b) if you don't use the best paint materials, the job won't last.
    To give you an idea of the range of quality, I have spend more on the PAINT and MATERIALS for a paint job, without even opening the cans up, then what Miracle Auto Body charges to paint an entire car.
    That's a lot of money to invest in an old 300d and you'll never see it returned on resale, so unless it looks really awful you might think about living with it, at least for a while until you see how the car works out.
    Pay particular attention to the heater/AC system controls, to the rear hydraulic compensator, the front coil springs (they sag). Invest in good brakes and tires, and perhaps a water trap for your fuel system. Get used to using additives for the fuel (biocides, cetane enhancers, injector cleaners), and change the oil frequently. Flush out the coolant, too if the old stuff is still in there.
    Good sturdy old car, though!
    Thanks for the input. I think you are right. The finish looks okay from about five feet away. I may try some elbow grease and buff as much as I can.
    I noticed that the trim (aluminum?) is dull (faded) and not shiny. Can I buff the trim (e.g. around the windows) so that they return to their original shiny state? Is there a product that brings the condition back?
    yes you can buff it out--but be gentle. Start off with that very fine bronze wool that they use to buff out the fittings on sailboats and powerboats. AND BE SURE to stay away from the paint---mask the paint off if you are going to use bronze or very fine steel wool.
    On restoration work on very expensive cars, they often remove the old trim, and carefully tap out the dents with a tiny hammer (you have to really know what you're doing in this case) and then buff the trim on a wheel, using a very fine jeweler's rouge. But that's probably too extreme for your situation.
    Thanks so much for the guidance. I guess I have my winter projects lined up!
    Just remember that ALL polishes are *abrasive*, no matter what the claims...so gentle, gentle, is the word on an old car's chrome and paint.
  • lydia2lydia2 Member Posts: 18
    Read the info online here. I have not had anything done like Steveo did. I do not drive this Collector too much. I noticed that the gas guage is fluttering. You speak about grounding a possible problem; so how do I investigate this? However, as the battery has run down a few times, it has had a charger on it to bring it back. The battery has been checked, is holding its charge and I try to drive it to keep it that way now.
    Do not want this problem or anymore like it; please suggest my solutions.
    Lydia
    Guess I conveniently forgot that my odometer has not worked for last ten years or so and that the tac comes on periodically for a duration of 5-10 minutes occasionally. I did a few $$trips to the mechanic who wanted to look for something electrical. Too expensive and no results, so I have lived with those malfunctions. Mr. Shiftright solved my turning signal problem, much thanx!
    Any chances of help with this business?
  • reugenioreugenio Member Posts: 2
    The door latch does not latch completely into the door striker. One mechanic looked at it and recommended changing the door striker but problem not solved. Another mechanic(Mercedes Benz) inspected it and said the problem was the latch itself,but the part is very hard to find.Also suggested to look up auto salvage parts.Also suggested to look for a right front passenger side latch.disassemble it..maybe the problem on the left side is only a spring inside? What would be the best way to resolve this and make the door work right..to latch correctedly? Where do you find this latch?
    I bet you could actually order that latch from Mercedes...it's worth a shot...you'd be amazed at the number of old parts you can still order from them.
    Barring that you can try here:
    http://www.a-r-a.org/AF_memberdirectory.asp
    Also, breezing through the "Mercedes parts" section of Hemmings Motor News (www.hemmings.com)
    these door panels come off pretty easily, so if you're handy I agree with your mechanic--take the lock out and see if its just a busted spring.
  • wagonlustwagonlust Member Posts: 2
    I've been looking at old mb's and thinking about taking the plunge, but now I've found one that's really in the deep end. It's an 83 300 turbo diesel, but it hasn't been driven for over 10 years. I'm told the filters have been changed, and it runs, but not much more info, other than 'everything works'. Mileage is said to be under 120k. I'm virtually blinded by the red flags waving around but can't help wondering if it could be returned to driving condition, and at what cost? Exposure has done a number on the paint but there's apparently no rust - dry climate here, so this could be true, maybe. I'm not too worried about cosmetics as much as viability. Turn and run, or proceed with caution?
    Depends on the price of course, and on what works and what doesn't. Some red flags would be a) hard to start----diesels should start right up without cranking very much; b) inoperative heater/AC controls. That can get pricey; c) lots of black smoke that does not dissipate after the engine warms up d) excessive turbo whine (like a police siren).
    These are very good cars but the mythology surrounding them has to be taken with a dose of realism.
    Not running for 10 years is not a good sign--the tires will be no good, and one wonders about the condition of the fuel tank.
    Best thing i could say is don't buy it unless you can drive it around and give it a good test; otherwise, if you have to buy it "as is", buy it as a parts car.
