Dodge Ram Owners
You can also check out www.stephenames.com/new99.html
But what you want is a Crutchfield catalog. They have excellent prices on everything audio for your vehicle. Their home prices are not that good, but their auto prices are great. Free installation instructions and free phone help. FANTASTIC! They have more CD players than you can shake a stick at and you are more than likely to find something you'll love. Of course you'll also find something that's just out of your price range - which can really be a bummer!
Cheers and good luck,
Ryan
Should I get the short or long bed? Which V8 or is the V10 the way to go. Will be used as primary vehicle. Family of four (2 adults, 1 infant, 1 toddler) Don't need it for work but we do some camping, fishing, bicycling, hunting and other outdoor and marine activities. What is the biggest size boat a 4x4 V8 can pull? I am thinking of a 21ft center console.
But based on that limited amount of information, and without a money amount you plan to spend, I would *suggest* that a 1500 Quad Cab 4x4 SLT 5.9L will do you and your family good (if you stick with Dodge).
If money isn't a huge issue, then definitely get a 2500 v10 Quad 4x4. The extra power and capacity will be there when you need it. The extra fuel bill will be a little larger.
I myself am torn between a 2500 v10 and an F-250 v10... decisions decisions...
Ryan
The old rule of thumb definitely applies to you. Check out the truck that will meet your needs as you see them, then go one size bigger. Once you have the truck, you will find more things to use it for, so the stronger one will stand up better.
Unless you plan on hauling long things often, the shortbed will proibably be ok. My 3500 Club 4x4 is 2 years old, and is currently worth 2/3 of its original selling price. Not bad with almost 36,000 miles on it, either.
Reddfin
Ron Slakie
Springfield, VA
Ron Slakie
Springfield, VA
I ordered the short bed. I am 6'3" and have just enough room and still have a very good turning radius. For most of the hauling I would do, the short bed will work fine, with the tail gate down the bed length is over 8'.
By the way, where you live and do your boating might also be a concern. We live in Colorado and it always seems we need to tow over the Rockies to get where we are going.
Good Luck,
DKG
Alex
Elena
HTH,
Ryan
Towed my 5th wheel a short distance (less than 10 miles) this past weekend for the first time. The front of the camper sits higher but presented no problem with clearance. Only back road travel, but pulled great. Anxious to pull it on a major highway to see how it compares to the '90. I had a little more suspension bounce than the '90, I think it was from the tires in that I didn't have them inflated for the load. Since they replaced my fuel tank last week I'll have to start my fuel milage calculations over. Still have the melting mud flap problem with no solutions from the dealer. Checked the oil level last week thinking I'd probably have burned some because of break-in.
Still reading at the full mark, and remarkably clean. How's yours running?
Ron
Thats realy weird about the mud flap...Mine makes a noise that sounds like air escaping form the engine(valve)sometimes when I shut the engine off. Does yous ever do that?
I have over 9000 mi. on mine and it hasn't used a drop of oil yet. So far I love it...Mike
Any one have any comments about it?
I pull a boat which weighs abour 1500 lbs. I have a 92 Chevy 1/2 ton with 350 and auto, and it pulls fine.
Any one have any suggestions about a comparison betwee the two? as far as power and fuel efficiency are concerned?
It has been to 3 different dealers that say they can not find a cause in the computer. Last dealer even suggested that it was due to the radio wires being to close to the ABS sensor????
No idea what to do. I really like the truck otherwise. Any body out there that can help or sugggest an action for me to solve this.
1999 Quad Cab 4x4 Diesel 5 spd. 3.54 gears, SLT Laramie, 4-wheel anti locks, sure grip axle, tow pkg. HD transfer case, Aux rear susp. White w/mist grey int.
Thanks to all you "motor heads" in here, I feel, with your help, I made the right decision on the truck.
The dealer said the usual,"12-14 weeks", but Iam not counting on that. We shall see.
TO ALL, Thanks again
and he wants to get new rims on the truck,but I just wanted to get bigger tires on it, because I think that the factory rims are fine. Does anybody have any suggestions? Also, anybody know any good places to get a dual exhaust done?
Sean, LEVITTOWN,PA
owner's regarding Manual and Automatic trans,.
Plan to order a New One but am having trouble
deciding on Transmission. Would appreciate
some input. Am thinking abouit exhaust brake also. Pull a 30-ft 5th wheel. Do they work good with Automatic Thanks Harlan
Dodge. Has anyone had problems or can you help me decide. I have been leaning toward Ford--I know dirty word but I paid a lot of money for the truck and want to have one that will continue to run and I acan feel safe in.
Did I mention that 6 days from the show room floor it spun a rod and threw a bearing and we had to "FIGHT" with "Crysler" (my new spelling) to get a crate motor instead of a rebuilt motor. Did I mention the fact that we have owned the vehicle less than 90 days it has been towed twice and in the shop for 30 days of that? All but 5 of the days were consecutive.
I will still say that is the most "prettiest" truck, ~grin~ even when getting towed. The performance has been a constant bother and harder to care and maintain than a new born infant. The "Crysler" customer care one.... is so useless !!!!
I want another but am so afraid because the story from sweet pea3 is like being there all over again, I have fought with the dealership and crysler for so long, I just hope that Feb gets here quick. But I am going to look at the Fords before winter.
I did drive the 5 speed Dakota and had a hard time with the ratio kept missing third, gears very tight. But it was only a six and I had a hard time getting use to not having the power after driving a eight cyl.
Good luck to all , I will keep checking and let you know what happens.
club cab shortbox 4x4 two years ago.We have had much the same experience. It's powered by a 360
V-8. The engine is terribly underpowered for its size. Gas mileage is acceptable though. We get about 17.5 miles to the imperial gallon. We live up here in Canada where the weather can get really nasty and another problem we have encountered is that at temperatures colder than -22 degrees C. the overdrive is locked out. If you have no overdrive you can imagine how fast the fuel guage drops!!! The dealership where we bought the truck told us to cover up the front end which we did. Still no overdrive. ITS ALMOST AS IF DODGE NEVER TEST DROVE THESE TRUCKS IN COLD WEATHER!! But you know what? I'd buy another one in a minute. This is the prettiest truck in the history of the automobile. Actually we just ordered a 1999 Ram 2500 Qaud cab shortbox 4x4 with the Cummins deisel. Deep Amethyst pearl coat. Can't wait to start dolling her up. This one will be a masterpeice when I'm done with it. I know what you're thinkin. WHAT AN IDIOT!!!!!! and the sad fact of the matter is that you're absolutely right, but I got the Dodge disease and am powerless to stop myself and specalk don't buy a Ford please. they are the UGLYEST (SP) TRUCKS THAT I HAVE EVER LAID EYES ON!!
Supercel34 that is one of the nicest features about these Ram club cabs/quad cabs is the interior room. They advertise it as the most interior room of any pickup truck in the world and they aren't lyin!!! Our club cab while having incredible amounts of room is not the greatest to get in and out of in the back but I'm sure that the Quad cab will solve that problem completely
As for roominess, I believe the Superduty cab is the largest in it's class.
I'm assuming that you are figuring you got a lemon tranny since you've decided to buy another Dodge. Certainly you wouldn't buy another truck if you knew that you would still not be able to use overdrive in cold weather. Although I've heard of numerous Dodge tranny problems, the cold weather one is new. Hopefully, it was a fluke. Dodge quality is improving every year.
That reminds of a bumper sticker that became very popular in Alaska. Each March, they have an 1,100 mile sled dog race from Anchorage to Nome called the Iditarod. In the 1980s, a lady named Susan Butcher started dominating the race. Prior to her, almost all of the races had been won by male mushers. With four victories under her belt, she was on her way to a record fifth win. At that time, she was tied with musher Rick Swenson, who also had four wins. With only a 100 or so miles to go, she clearly had the fastest team. However, a big storm blew in and she decided to wait it out. After several hours, other mushers started showing up at the checkpoint she had been resting at, waiting out the storm. The other mushers also decided to wait out the storm, that is, all the mushers but Rick Swenson and one other guy. They took off into the whiteout conditions, where they might lose the trail, end up having to make camp somewhere in the storm, and finish well behind the mushers waiting out the storm. As luck (and years of experience racing the Iditarod) would have it, they didn't get lost, and Rick Swenson won the race. The bumper sticker that appeared after that race said, "Alaska: Where men are men and women win the Iditarod when the weather is good." If that cold weather Dodge tranny story turns out not to be a fluke, it might not be too long until you see Ford trucks with similar bumper stickers, maybe along the lines of: "Alaska: where Fords are real trucks and Dodges run when the weather is good."
I say this all in good humor. The Dodges are good trucks. Their recurring tranny problems are puzzling though.
A. the fact that the Deisel probably runs quite a bit hotter that the gas V-8 may help. and
B. It may be a totally different transmission and cooler design
If we had not ordered the Deisel package we would not be selling the Dodge pickup we currently have, tranny problems and all. NUTS EH?? I guess beauty is in the eye of the beholder and Dodge has got me right where it wants me I'm afraid to say. You sound like you own a Ford F-150 Brutus. If you and all the Chevy guys wanted to argue about the virtues of your respective gas engine power trains I'm afraid I'd have to sit here and take it because you'd all be absolutely right. I've never driven a Ford but have driven the Chev 350's all my life and they in my opinion are fantastic. BBBBBUUUUTTTTT
if this Cummins drive train is as good as everybody's been saying then I think I'll HAVE IT ALL.
THE TRACTOR
I don't own a F-150. A few weeks ago I sold my truck. It was a 1992 F-250 5.8L 4x4 Lariat regular cab that I bought new in Alaska. It had 86,000 miles on it and I had no complaints. I have a new truck on order. It's a 99 F-350 Superduty Supercab 4x4 Lariat V-10 dually with all the bells and whistles. I put a downpayment on a big truck camper, which is why I needed the duallys. I'd exceed the GVWR with a single rear wheel truck with the camper on. I'm headed back to Anchorage early next year. What part of Canada do you live in?
Congrats on ordering the new Ford! I'm sure you'll be delighted with it. What size is the Ford V-10??
Are you headed back to Alaska permanently?
The town I call home is Brooks, Alberta. Population about 10,000. Mostly oil and gas, meat packing and agriculture around here.
I will be moving back to Anchorage permanently. I've spent about 18 years up there total. My job transferred me out of Anchorage in March of 1993. I recently turned down a career job with my company in North Dakota. I also told them that I would not extend my contract for another full year. My contract is up at the end of the year. I told them I would consider a 3-6 month extension, but I suspect it will be a full year or none at all. Chances are that I will be headed back in January.
In addition to the brakes, and a half dozen recalls, this Ram has had two fuel pumps, under warranty, put in under 30K. There was a bad valve which let gas go back into the tank, which caused hard starting. The mechanic told me that Dodge knew about the problem when they pulled the tank to fix it the first time, but "that was the only part available to put in" They later changed manufacturers and the thing has held, so far. But with this kind of quality control on the surface, how much is lurking beneath, waiting for warranties to expire?
I wonder if Ford trucks are this bad, too? Time to check out their forum. But Toyota is looking awfully good, right now.
Johnboy.
Infact when I reached "CRYsler corp. on the phone the nice man asked to speak to my husband. As far as I can see our dodge is BEAUTIFUL, on the tow truck, on the roll back and in the garage.
If in fact this is unusual with this truck I would except better service, and at this point a replacement vehicle !!! The almost 4,000 miles have been NOTHING BUT A HASSLE !!!!!
If anyone who reads this has any ideas for the "NICE MAN" at "CRYsler", or whom I should speak with.. I am all ears.
